CDO and generated model Impl [message #67271] |
Mon, 08 January 2007 09:49  |
Originally posted by: yannick.lizzi.silogic.fr
Hi (again)
I have a question regarding the generated code for CDO model.
The multiple associations (aggregation or not) are generated as follow:
public EList getMyChildren() {
cdoLoad();
if (children == null) (
// init children
return children;
But in case of simple association, the generated code is as follow:
public Children getMyChildren() {
if (children != null && children.isProxy()) {
// resolving proxy
return children;
My question is: why the generated getter does not start with cdoLoad()
in the simple relation case?
This leads to problems (in my code at least): when I load my object
model via some container classes, I call getMyChildren() where I know
there is a children (confirmed also by the database content) and this
result to a null value.
Of course if I invoke cdoLoad() before each call of getMyChildren()
(either in my impl code or in the calling code) it works but I was
thinking of something more automatic if not direcly generated.
Yannick
Re: CDO and generated model Impl [message #67313 is a reply to message #67284] |
Mon, 08 January 2007 11:44  |
Hi Eike
OK I was indeed working with the R0_7_maintenance version, but I did not
regenerate the model.
Now I see the cdoLoad() methods everywhere.
Yannick
Eike Stepper a écrit :
> Hi Yannick,
> I believe that this has been fixed in the context of
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=162961
> The changes are committed to the R0_7_maintenance branch. Unfortunately
> I can't publish a new build right now due to an issue with the build
> system.
> If you don't want to checkout from CVS, you can also try to change the
> following files to only contain "cdoLoad();"
> /org.eclipse.emf.cdo.client/templates/model/Class/getGenFeat ure.pre.insert.javajetinc
> /org.eclipse.emf.cdo.client/templates/model/Class/setGenFeat ure.pre.insert.javajetinc
> and regenerate your models!
> Does this help?
> Cheers
> /Eike
> Yannick Lizzi schrieb:
>> Hi (again)
>> cdoLoad();
>> // init children
>> return children;
>> // resolving proxy
>> return children;
>> Yannick
Re: CDO and generated model Impl [message #600891 is a reply to message #67271] |
Mon, 08 January 2007 10:50  |
Hi Yannick,
I can't publish a new build right now due to an issue with the build system.
Does this help?
Cheers
/Eike
> Hi (again)
> cdoLoad();
> // init children
> return children;
> // resolving proxy
> return children;
> Yannick
Re: CDO and generated model Impl [message #600919 is a reply to message #67284] |
Hi Eike
Yannick
> Hi Yannick,
> system.
> Does this help?
> Cheers
> /Eike
>> Hi (again)
>> cdoLoad();
>> // init children
>> return children;
>> // resolving proxy
>> return children;
>> Yannick
FUDForum. Page generated in 0.17649 seconds
