Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO and generated model Impl
CDO and generated model Impl [message #67271] Mon, 08 January 2007 09:49 Go to next message
Originally posted by: yannick.lizzi.silogic.fr
Hi (again)
I have a question regarding the generated code for CDO model.
The multiple associations (aggregation or not) are generated as follow:
public EList getMyChildren() {
cdoLoad();
if (children == null) (
// init children
return children;
But in case of simple association, the generated code is as follow:
public Children getMyChildren() {
if (children != null && children.isProxy()) {
// resolving proxy
return children;
My question is: why the generated getter does not start with cdoLoad()
in the simple relation case?
This leads to problems (in my code at least): when I load my object
model via some container classes, I call getMyChildren() where I know
there is a children (confirmed also by the database content) and this
result to a null value.
Of course if I invoke cdoLoad() before each call of getMyChildren()
(either in my impl code or in the calling code) it works but I was
thinking of something more automatic if not direcly generated.
Yannick
Re: CDO and generated model Impl [message #67284 is a reply to message #67271] Mon, 08 January 2007 10:50 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Yannick,
I believe that this has been fixed in the context of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162961
The changes are committed to the R0_7_maintenance branch. Unfortunately
I can't publish a new build right now due to an issue with the build system.
If you don't want to checkout from CVS, you can also try to change the
following files to only contain "cdoLoad();"
/org.eclipse.emf.cdo.client/templates/model/Class/getGenFeat ure.pre.insert.javajetinc
/org.eclipse.emf.cdo.client/templates/model/Class/setGenFeat ure.pre.insert.javajetinc
and regenerate your models!
Does this help?
Cheers
/Eike
Yannick Lizzi schrieb:
> Hi (again)
> cdoLoad();
> // init children
> return children;
> // resolving proxy
> return children;
> Yannick
Re: CDO and generated model Impl [message #67313 is a reply to message #67284] Mon, 08 January 2007 11:44 Go to previous message
Hi Eike
OK I was indeed working with the R0_7_maintenance version, but I did not
regenerate the model.
Now I see the cdoLoad() methods everywhere.
Yannick
Eike Stepper a écrit :
> Hi Yannick,
> system.
> Does this help?
> Cheers
> /Eike
>> Hi (again)
>> cdoLoad();
>> // init children
>> return children;
>> // resolving proxy
>> return children;
>> Yannick
Re: CDO and generated model Impl [message #600891 is a reply to message #67271] Mon, 08 January 2007 10:50 Go to previous message
Hi Yannick,
Does this help?
Cheers
/Eike
> Hi (again)
> cdoLoad();
> // init children
> return children;
> // resolving proxy
> return children;
> Yannick
Re: CDO and generated model Impl [message #600919 is a reply to message #67284] Mon, 08 January 2007 11:44 Go to previous message
Hi Eike
Yannick
> Hi Yannick,
> system.
> Does this help?
> Cheers
> /Eike
>> Hi (again)
>> cdoLoad();
>> // init children
>> return children;
>> // resolving proxy
>> return children;
>> Yannick
Previous Topic:Teneo: .ejdo usage in generated editor
Next Topic:CDO and eContainer()
Current Time: Wed Jul 02 07:37:28 EDT 2025
Powered by FUDForum. Page generated in 0.26745 seconds
