Home » Language IDEs » AspectJ » advices from aspectPath jars aren't shown in Cross References view
advices from aspectPath jars aren't shown in Cross References view [message #67215] Fri, 06 October 2006 19:36 Go to next message
I am using Spring's aspect library (@Configurable and @Transactional),
which is added it into aspectPath jars to compiler settings. Advices
from that library are woven into the compiled code just fine (I checked
the bytecode). However these advices does not appear in the Cross
References view and there is no markers in AJ editor for advised methods.
regards,
Eugene
PS: I've updated to last AJDT 1.4.1 dev build, and that resolved issue
with aspectjrt.jar, though still would be nice to remove that constraint.
Re: advices from aspectPath jars aren't shown in Cross References view [message #67253 is a reply to message #67215] Mon, 09 October 2006 12:10 Go to previous messageGo to next message
> regards,
> Eugene
Recent dev builds of AJDT 1.4.1 should now show crosscutting
relationships for aspectPath aspects:
http://www.eclipse.org/ajdt/newfeatures/#binaryweaving
Please raise a bug if this new functionality isn't working as described
for you.
--Matt
Re: advices from aspectPath jars aren't shown in Cross References view [message #67263 is a reply to message #67253] Mon, 09 October 2006 14:37 Go to previous message
Does that require these binary advices to be recompiled with special
settings?
See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=160236
regards,
Eugene
>> @Transactional), which is added it into aspectPath jars to compiler
>> settings. Advices from that library are woven into the compiled code
>> just fine (I checked the bytecode). However these advices does not
>> appear in the Cross References view and there is no markers in AJ
>> regards,
>> Eugene
>> issue with aspectjrt.jar, though still would be nice to remove that
>> constraint.
> described for you.
> --Matt
Re: advices from aspectPath jars aren't shown in Cross References view [message #595027 is a reply to message #67215] Mon, 09 October 2006 12:10 Go to previous message
> regards,
> Eugene
for you.
--Matt
Re: advices from aspectPath jars aren't shown in Cross References view [message #595035 is a reply to message #67253] Mon, 09 October 2006 14:37 Go to previous message
settings?
regards,
Eugene
>> regards,
>> Eugene
>> constraint.
> described for you.
> --Matt
Previous Topic:ajdt 1.4 and aspectrt.jar
Next Topic:the shadow for this join point is not exposed in the structure model?!?
Current Time: Sun Jul 13 13:20:39 EDT 2025
Powered by FUDForum. Page generated in 0.09216 seconds
