Home » Archived » BPMN Modeler » Re: BPMN code generated by Eclipse is strange ...
Re: BPMN code generated by Eclipse is strange ... [message #5971] Fri, 23 January 2009 09:05 Go to next message
<<Forwarding to the BPMN modeler newsgroup>>
Stephane Drapeau
Obeo
Maxime a écrit :
> I drew a BPMN schema with Eclipse and the generated code is really
> complex !
> You can see an example below :
> <bpmn:BpmnDiagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns:bpmn="http://stp.eclipse.org/bpmn"
> xmi:id="_IkqpceISEd24v-Pz8RK2sQ" iD="_IkqpcOISEd24v-Pz8RK2sQ">
> <pools xmi:type="bpmn:Pool" xmi:id="_Ikqpd-ISEd24v-Pz8RK2sQ"
> iD="_IkqpduISEd24v-Pz8RK2sQ" name="Pool">
> <vertices xmi:type="bpmn:Activity" xmi:id="_IkqpeeISEd24v-Pz8RK2sQ"
> iD="_IkqpeOISEd24v-Pz8RK2sQ" outgoingEdges="_o1odIeIXEd2U2cV-da9zcg"
> incomingEdges="_LGAzsefXEd2KnoP9oe57fw" name="Tache 1"
> activityType="Task"/>
> <vertices xmi:type="bpmn:Activity" xmi:id="_lPYvMeIXEd2U2cV-da9zcg"
> iD="_lPYvMOIXEd2U2cV-da9zcg" outgoingEdges="_L-QqUefXEd2KnoP9oe57fw"
> incomingEdges="_o1odIeIXEd2U2cV-da9zcg" name="Tache 2"/>
> <vertices xmi:type="bpmn:Activity" xmi:id="_J21q0efXEd2KnoP9oe57fw"
> iD="_J21q0OfXEd2KnoP9oe57fw" outgoingEdges="_LGAzsefXEd2KnoP9oe57fw"
> activityType="EventStartEmpty"/>
> <vertices xmi:type="bpmn:Activity" xmi:id="_KTM2sefXEd2KnoP9oe57fw"
> iD="_KTM2sOfXEd2KnoP9oe57fw" incomingEdges="_L-QqUefXEd2KnoP9oe57fw"
> activityType="EventEndEmpty"/>
> <sequenceEdges xmi:type="bpmn:SequenceEdge"
> xmi:id="_o1odIeIXEd2U2cV-da9zcg" iD="_o1odIOIXEd2U2cV-da9zcg"
> source="_IkqpeeISEd24v-Pz8RK2sQ" target="_lPYvMeIXEd2U2cV-da9zcg"/>
> xmi:id="_LGAzsefXEd2KnoP9oe57fw" iD="_LGAzsOfXEd2KnoP9oe57fw"
> source="_J21q0efXEd2KnoP9oe57fw" target="_IkqpeeISEd24v-Pz8RK2sQ"/>
> xmi:id="_L-QqUefXEd2KnoP9oe57fw" iD="_L-QqUOfXEd2KnoP9oe57fw"
> source="_lPYvMeIXEd2U2cV-da9zcg" target="_KTM2sefXEd2KnoP9oe57fw"/>
> </pools>
> </bpmn:BpmnDiagram>
> My problem is that I would like to transform a BPMN schema to a BPEL
> code and this BPMN code doesn't match with the BPMN meta-model !
> Do you know how could I do to get a BPMN code like this :
> <BpmnDiagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" >
> <Pool name="Mon Pool">
> <Activity outgoingEdges="task1_to_task2" name="Task1"
> <Activity incomingEdges="task1_to_task2" name="Task2"/>
> <SequenceEdge source="task1" target="task2"/>
> </Pool>
> </BpmnDiagram>
> So without all these namespaces !
> Thank you in advance.
> Maxime
Re: BPMN code generated by Eclipse is strange ... [message #5988 is a reply to message #5971] Fri, 23 January 2009 11:26 Go to previous message
Originally posted by: atoulme.intalio.com
Thanks Stephane for forwarding.
Maxime, the code is not strange. It is necessary to do the mapping with
the bpmn ecore file. We use an id attribute, and XMI brings its own id
on serialization.
You cannot use the name to refer to a task. The XMI id tags are there to
keep the model from breaking.
Antoine
> Stephane Drapeau
> Obeo
>> complex !
>> <?xml version="1.0" encoding="UTF-8"?>
>> </pools>
>> </bpmn:BpmnDiagram>
>> </Pool>
>> </BpmnDiagram>
>> Maxime
Previous Topic:Re: [ATL] Looking for BPMN and BPEL MetaModels
Next Topic:Babel translation
Current Time: Sun Jul 27 12:49:15 EDT 2025
Powered by FUDForum. Page generated in 0.03173 seconds
