Home » Newcomers » Newcomers » Eclipse on Linux
Eclipse on Linux [message #67177] Fri, 20 May 2005 15:03 Go to next message
Originally posted by: bleuzetfred.hotmail.com
I really can't start eclipse (3.0.2) on Linux (AMD 64bit).
Does anybody know the command to start it?
I'm sorry for this kind of question but I just read the eclipse FAQ
question "I have downloaded the Eclipse SDK, but it won't start. How do I
start eclipse?". It gives some JRE version advices for several pltforms,
but always come back to "run eclipse.exe" (I know, I was so desperate that
I even tried on Linux :-).
Is eclipse running on any other platform than Windows?
As the FAQ didn't give any answer, I tried to run the startup.jar file
(didn't start because the manifest file doesn't specify the startup
class). So I opened the startup.jar to find the full path to the main
class and ran the command:
java -cp startup.jar org.eclipse.core.launcher.Main
but the java process exists almost immediately. I used the JRE version
1.4.2.
Or is it that instead of downloading a binary version I need to compile it
from source code?
Re: Eclipse on Linux [message #67189 is a reply to message #67177] Fri, 20 May 2005 15:31 Go to previous message
> I start eclipse?". It gives some JRE version advices for several
> pltforms, but always come back to "run eclipse.exe" (I know, I was so
> desperate that I even tried on Linux :-).
> 1.4.2.
> it from source code?
it does run on linux no problem
there is an executable file called, you guessed, eclipse
just type ./eclipse and be done
hth
/adam
Previous Topic:Adding jar target to a plugin project
Next Topic:Eclipse editor complaints
Current Time: Sat Jul 12 20:34:47 EDT 2025
Powered by FUDForum. Page generated in 0.27283 seconds
