Home » Language IDEs » AspectJ » Why do advice-precedence warnings not go away?
Why do advice-precedence warnings not go away? [message #67159] Fri, 06 October 2006 09:39 Go to next message
I have two aspects, both of which declare additional fields one some
types and hence I also advised the toString() method to emit these
additional fields (for easier debugging).
But now I keep getting about a dozen of warning messages like:
"at this shadow method-execution(<class> <class>.<method>(<paramTypes>))
no precedence is specified between advice applying from aspect <aspect1>
and aspect <aspect2> [Xlint:unorderedAdviceAtShadow] <project> line 113
1160141369265 9464183"
even though first to one and then even to BOTH aspects I added:
public aspect <aspectN> {
declared precedence: <aspect1>, <aspect2>;
Why does this not rectify the problem? Why do I still get these
warnings???
Michael
Re: Why do advice-precedence warnings not go away? [message #67178 is a reply to message #67159] Fri, 06 October 2006 12:36 Go to previous message
sounds like an incremental compilation bug. And I thought that xlint
option was off by default, I presume you have turned it on?
Andy.
> Why does this not rectify the problem? Why do I still get these warnings???
> Michael
Re: Why do advice-precedence warnings not go away? [message #594954 is a reply to message #67159] Fri, 06 October 2006 12:36 Go to previous message
Andy.
> Michael
Previous Topic:How I can weave an aspect inside a .jar from eclipse
Next Topic:How I can run a web project with aspectj capabilities
Current Time: Mon Sep 01 02:33:05 EDT 2025
Powered by FUDForum. Page generated in 0.04578 seconds
