Home » Language IDEs » ServerTools (WTP) » indentation in jsp editor
indentation in jsp editor [message #67099] Mon, 24 January 2005 08:12 Go to next message
can anyone tell me how to get indentation activated as part of the
format action in the jsp editor?
everything is lining up at the left margin when i format...
any guidance appreciated, thanks!
Re: indentation in jsp editor [message #67643 is a reply to message #67099] Tue, 25 January 2005 16:13 Go to previous message
Originally posted by: pavery.us.ibm.com
Which sections of your JSP are you referring to as being "lined up at
the left margin"?
The JSP code sections should follow your Java formatting preferences
under: Java > Code Style > Formatter
(if they are written in java).
The HTML sections should follow the formatting preferences under
Web and XML > HTML Files > HTML Source
(if HTML is the content type for your JSP)
Is this not the behavior you're seeing?
-phil
Previous Topic:Questions about Server and Install Server Runtimes...
Next Topic:any progress on the flexible project structure?
Current Time: Thu Jul 17 20:13:17 EDT 2025
Powered by FUDForum. Page generated in 0.06153 seconds
