Home » Language IDEs » AspectJ » Buildconfig package
Buildconfig package [message #67083] |
Thu, 05 October 2006 06:24  |
I am trying to migrate an application from Eclipse 3.0 to 3.2. However I
ran into some problems with AJDT there. The program uses some classes
from the buildconfig package, which was moved into a new plugin as I
found out. However, this plugin was nowhere to be found. Has anyone got
a clue where to find it, or what to use instead of these classes?
Sincerly,
Michael
Re: Buildconfig package [message #67093 is a reply to message #67083] |
Thu, 05 October 2006 07:13   |
Michael,
Yes, a lot changed in the area of build configurations between AJDT 1.2
and AJDT 1.4. There is no longer any buildconfig package or plugin.
Essentially AJDT now uses the JDT build path mechanism to
include/exclude files from the build. There is however still some
support for applying and saving build configurations in .ajproperties
files. This can be found in the org.eclipse.ajdt.ui.buildpath package.
If you still have problems, please explain what the program was using
the old classes to do exactly, and I can then try to suggest a migration
approach.
Matt.
Michael Pisula wrote:
> Hello,
> Sincerly,
> Michael
Re: Buildconfig package [message #67379 is a reply to message #67093] |
Wed, 25 October 2006 09:02   |
Hello again,
I ran into some heavy problems with the migration. I managed to rewrite
the old code to use the package you mentioned instead of the one we used
to use, but the program does not work anymore. What the program does is
to build a project using the ajde build manager, and then to get the
hierarchy and relationship map from the AsmManager.
We used to do it using the ProjectBuildConfigurator to set the desired
build config. Now I set the active build conofig file using the
configurationmanager... well, it works as far as building of the project
is concerned, but the AsmManager does not return anything useful. I
would appreciate any ideas about what could be wrong, as I'm fresh out
of ideas.
Michael
Matt Chapman wrote:
> Michael,
> approach.
> Matt.
>> Hello,
>> I ran into some problems with AJDT there. The program uses some
>> classes from the buildconfig package, which was moved into a new
>> plugin as I found out. However, this plugin was nowhere to be found.
>> Has anyone got a clue where to find it, or what to use instead of
>> these classes?
>> Sincerly,
>> Michael
Re: Buildconfig package [message #67441 is a reply to message #67379] |
Thu, 26 October 2006 07:55   |
Hi Michael,
It's hard to say what might be going wrong without seeing the code. But
I wonder if it might be worth doing some more migration, and switching
to use the higher level classes in org.eclipse.ajdt.core instead. See my
response in the recent "How to retrieve AspectJ model during build in
eclipse?" thread, which shows how to obtain relationship information
from AJDT. Does that look useful?
What does your plug-in need from AJDT? AJDT is now integrated more
closely to the rest of Eclipse, so it's best to work in Eclipse terms.
For example if you want to control which files are built, you would
manipulate the classpath like with a Java project. And to build a
project, you can call project.build() and let Eclipse do the rest.
Matt.
> Hello again,
> of ideas.
> Michael
> Matt Chapman wrote:
>> Michael,
>> 1.2 and AJDT 1.4. There is no longer any buildconfig package or
>> plugin. Essentially AJDT now uses the JDT build path mechanism to
>> migration approach.
>> Regards,
>> Matt.
>>> Hello,
>>> However I ran into some problems with AJDT there. The program uses
>>> some classes from the buildconfig package, which was moved into a new
>>> these classes?
>>> Sincerly,
>>> Michael
Re: Buildconfig package [message #67460 is a reply to message #67441] |
Thu, 26 October 2006 08:17   |
Hi Matt,
My Plug-In builds two versions of a AspectJ program to perform a change
analysis on them. The user can choose which versions he would like to
compare by providing two build configs to the plug-in. Therefore it
would be preferable to stick with the build configurations.
I'm afraid that doing a bigger migration might be problematic, as i have
quite a dense schedule, and the migration itself is not a part of my
task, just something I do to make working easier (and to make sure that
people will actually be able to use the plug-in afterwards, without
having to work with prehistoric eclipse versions ;)).
However, I think I found the reason why I am not getting any results. I
did some debugging and turned the AJDE log on, and found something
interesting.
When the program I use to test my plug-in is build by eclipse, the log
reads like this:
"<AJDE> build started:
runtime-workbench-workspace/.metadata/.plugins/org.eclipse.a jdt.core/NullCheck.generated.lst "
However, when my plug-in builds the program, i get the following:
runtime-workbench-workspace/NullCheck/build.ajproperties"
Seems like I'm setting the build config the wrong way...
Would be glad for hints how to get this right, and I'm really grateful
for your help with this :)
Michael
Matt Chapman wrote:
> Hi Michael,
> Matt.
>> Hello again,
>> rewrite the old code to use the package you mentioned instead of the
>> one we used to use, but the program does not work anymore. What the
>> program does is to build a project using the ajde build manager, and
>> then to get the hierarchy and relationship map from the AsmManager.
>> project is concerned, but the AsmManager does not return anything
>> useful. I would appreciate any ideas about what could be wrong, as I'm
>> fresh out of ideas.
>> Regards,
>> Michael
>> Matt Chapman wrote:
>>> Michael,
>>> migration approach.
>>> Regards,
>>> Matt.
>>>> Hello,
>>>> new plugin as I found out. However, this plugin was nowhere to be
>>>> found. Has anyone got a clue where to find it, or what to use
>>>> Sincerly,
>>>> Michael
Re: Buildconfig package [message #67481 is a reply to message #67460] |
Thu, 26 October 2006 08:24  |
I found a solution, somehow writing about what went wrong gave me some
new ideas how to get it right ;) Next time I'll try to get the ideas
before sending the mail ;)
Thank you again for your help,
Michael
> Hi Matt,
> interesting.
> reads like this:
> Michael
> Matt Chapman wrote:
>> Hi Michael,
>> But I wonder if it might be worth doing some more migration, and
>> switching to use the higher level classes in org.eclipse.ajdt.core
>> instead. See my response in the recent "How to retrieve AspectJ model
>> during build in eclipse?" thread, which shows how to obtain
>> relationship information from AJDT. Does that look useful?
>> Regards,
>> Matt.
>>> Hello again,
>>> desired build config. Now I set the active build conofig file using
>>> the configurationmanager... well, it works as far as building of the
>>> I'm fresh out of ideas.
>>> Regards,
>>> Michael
>>> Matt Chapman wrote:
>>>> Michael,
>>>> .ajproperties files. This can be found in the
>>>> using the old classes to do exactly, and I can then try to suggest a
>>>> migration approach.
>>>> Regards,
>>>> Matt.
>>>>> Hello,
>>>>> Sincerly,
>>>>> Michael
Re: Buildconfig package [message #594851 is a reply to message #67083] |
Michael,
approach.
Matt.
> Hello,
> Sincerly,
> Michael
Re: Buildconfig package [message #595126 is a reply to message #67093] |
Hello again,
of ideas.
Michael
Matt Chapman wrote:
> Michael,
> approach.
> Matt.
>> Hello,
>> these classes?
>> Sincerly,
>> Michael
Re: Buildconfig package [message #595150 is a reply to message #67379] |
Hi Michael,
Matt.
> Hello again,
> of ideas.
> Michael
> Matt Chapman wrote:
>> Michael,
>> migration approach.
>> Regards,
>> Matt.
>>> Hello,
>>> these classes?
>>> Sincerly,
>>> Michael
Re: Buildconfig package [message #595160 is a reply to message #67441] |
Hi Matt,
interesting.
reads like this:
Michael
Matt Chapman wrote:
> Hi Michael,
> Matt.
>> Hello again,
>> fresh out of ideas.
>> Regards,
>> Michael
>> Matt Chapman wrote:
>>> Michael,
>>> migration approach.
>>> Regards,
>>> Matt.
>>>> Hello,
>>>> Sincerly,
>>>> Michael
Re: Buildconfig package [message #595165 is a reply to message #67460] |
Michael
> Hi Matt,
> interesting.
> reads like this:
> Michael
> Matt Chapman wrote:
>> Hi Michael,
>> Regards,
>> Matt.
>>> Hello again,
>>> Regards,
>>> Michael
>>> Matt Chapman wrote:
>>>> Michael,
>>>> migration approach.
>>>> Regards,
>>>> Matt.
>>>>> Hello,
>>>>> Sincerly,
>>>>> Michael
Current Time: Fri Jul 18 19:15:02 EDT 2025
Powered by FUDForum. Page generated in 0.04225 seconds
