open several dialog in action problem [message #67065] |
Wed, 19 December 2007 22:43  |
Originally posted by: chenmin827.126.com
Hi everybody,
I've one questions here.
When i open several dialog in action which extends SelectionProviderAction,the Firefox browser often open a dialog says that:
The page at http://127.0.0.1:36293 says:
Multiple browser-instances or browser-tabs per session are not supported.You may click OK fro restarting the session.
and then i need to restart the session.But in fact,i only open one browser-instances and one browser-tabs.can anyone help me?
Thank you & best regards,
cheney
Re: open several dialog in action problem [message #69894 is a reply to message #67073] |
Fri, 11 January 2008 10:51  |
Originally posted by: fappel.innoopract.com
I think this problem is related to bug #208753. Controlling the mechanism we
use to enable the possiblity of single sourcing of RCP and RAP with
reference to blocking dialogs has proved more complex than expected (or
should I say it has proved as complex as expected...). Anyway, since the
mechanism still doesn't work faultless and differs from SWT, we finally came
up with an idea that looks quite promising. We think that we've found a
possibility to implement the Display#readAndDispatch() and Display#sleep()
functionality available in SWT. As the new approach looks less complex and
is a further approximation to SWT I think we could kill two birds with one
stone. We are currently working on this problem and at the end of the next
week we should see, whether the new approach will work better.
Ciao
Frank
"Ben W." <benjamin.wolff@web.de> schrieb im Newsbeitrag
news:c67e01a32229f0238a6e244447ecf8c0$1@www.eclipse.org...
> i'm experiencing the same behaviour. you should take a look into your
> console, there should be a "context has been disposed" exception when the
> session error occurs.
> when i open two dialogs in one method, one after another, this error
> occurs, but the problem is not always... sometimes it works, sometime the
> context disposed error appears.
FUDForum. Page generated in 0.14517 seconds
