SML validation exception [message #5961] |
Tue, 16 January 2007 10:04  |
Originally posted by: elena.tibrea.gmail.com
I tryed to call the validator for this file:
org.eclipse.cosmos.rm.validation.tests\src\test-resources\ru les\Valid.xml
What I get is:
Severity: error Namespace for prefix 'u' has not been declared.
Severity: error java.lang.RuntimeException: Namespace for prefix 'u' has
not been declared.
Severity: error Could not compile stylesheet
ERROR: 'The input document is not a stylesheet (the XSL namespace is not
declared in the root element).'
FATAL ERROR: 'Could not compile stylesheet'
Could you help please?
Elena
Re: SML validation exception [message #7003 is a reply to message #6980] |
Wed, 24 January 2007 10:52  |
You might have an old version of Valid.xml. I had to make the change
I suggested. The schematron should define the namespaces it uses.
On Tue, 23 Jan 2007 22:21:03 +0000 (UTC), elena.tibrea@gmail.com
(elena t) wrote:
>Hi,
>I did nothing to alter the valid.xml file supplied.
>Thanks.
Re: SML validation exception [message #568774 is a reply to message #5961] |
Wed, 17 January 2007 15:51  |
Hi Elena,
I haven't been able to update the validator work on COSMOS CVS (still
waiting for my permission). I will be regularly posting a zip file on
COSMOS wiki page for the community to experiment with. You can access the
latest version from: http://wiki.eclipse.org/images/8/8f/Backup-v2.zip
- Extract the zip file
- Import all projects in Eclipse (using the "Existing Project into
Workspace" option)
- You can either run an instance of an Eclipse Workbench and use the "SML-IF
> Validate" context menu on an SML-IF document OR
run the validator as a standalone Java application using MainValidator <path
of the SML-IF document> (keep in mind that a valid file doesn't produce any
output)
Ali Mehregani
"elena t" <elena.tibrea@gmail.com> wrote in message
news:ff5c4c38b03d32a146cb6ce5bd51ec9d$1@www.eclipse.org...
> What I get is:
> not been declared.
> Thanks
> Elena
Re: SML validation exception [message #568796 is a reply to message #5982] |
Wed, 17 January 2007 17:30  |
Hi Ali,
I'm having the same problems(this time displayed in Problems view)
although I get the 'validation passed' info box (independent of Valid.xml
or InValid.xml)
I'm running Eclipse Version: 3.2.0
Build id: I20060223-16
on jre1.5.0_10
What am I missing:-?
Thanks for replying
Elena
Re: SML validation exception [message #568821 is a reply to message #5998] |
Thu, 18 January 2007 14:07  |
You need to have xalan libraries to be able to run with Sun JRE 1.5.0_10.
Follow the instructions below:
1. Download Xalan from http://xml.apache.org/xalan-j/downloads.html
2. Download an updated copy of the projects from:
3. Import the project downloaded in step 2) in an Eclipse workbench
4. Unzip the xalan zip file downloaded in step 1) to an arbitrary directory
5. Add the following xalan jar files to the "lib" directory of
org.eclipse.cosmos.rm.validation and org.eclipse.cosmos.rm.validation.tests:
serializer.jar
xalan.jar
xml-apis.jar
Although the code compiles with Sun 1.5, it generates the prefix error when
the above Jar files are missing. IBM 1.5 compiles and runs the validator
without the need for the Xalan Jar files above. I'll open a defect to
further investigate this error. In the mean time you can follow the steps
above to make the validator work.
Ali Mehregani
news:9bb0c6d6a9e76027a04c2905a4ad54f0$1@www.eclipse.org...
> Hi Ali,
> or InValid.xml)
> on jre1.5.0_10
> Thanks for replying
> Elena
Re: SML validation exception [message #568954 is a reply to message #6860] |
Mon, 22 January 2007 14:07  |
Hi Elena,
Could you post the Valid.xml you are trying to validate.
I think the schematron rule uses the 'u' prefix and does not define
the namespace. You might need to add the following namespace prefix
in your schematron.
<sch:ns prefix="u" uri="urn:university" />
This is what I mean:
<sch:schema
xmlns:sch="http://purl.oclc.org/dsdl/schematron">
<sch:ns prefix="smlfn"
uri="http://schemas.serviceml.org/sml/function/2006/07"/>
<sch:pattern id="StudentPattern">
<sch:rule
context="smlfn:deref(u:EnrolledStudents/u:EnrolledStudent)" >
<sch:assert test="starts-with(u:ID,'99')">
The specified ID <sch:value-of
select="string(u:ID)"/>
does not begin with 99
</sch:assert>
<sch:assert test="count(u:Courses/u:Course)>0">
The student <sch:value-of
select="string(u:ID)"/> must be enrolled
in at least one course
</sch:assert>
</sch:rule>
</sch:pattern>
</sch:schema>
On Sat, 20 Jan 2007 17:00:23 +0000 (UTC), elena.tibrea@gmail.com
(elena t) wrote:
>I added all the jar files to my projects but it did not work.
>I switched to IBM 1.5, for the moment.
>thanks
Re: SML validation exception [message #569060 is a reply to message #6980] |
(elena t) wrote:
>Hi,
>Thanks.
FUDForum. Page generated in 0.08021 seconds
