Home » Language IDEs » AspectJ » RCP Plugins and AspectJ
RCP Plugins and AspectJ [message #67007] Wed, 13 September 2006 14:50 Go to next message
Originally posted by: canterburry.gmail.com
I am thinking of using Aspectj to weave some into my plugins on an RCP
platform...will this work properly with Eclipse's plugin activation and
plugin dependency approach?
I presume people have tired this. Any negative experiences?
-HC
Re: RCP Plugins and AspectJ [message #67015 is a reply to message #67007] Thu, 14 September 2006 07:07 Go to previous message
I know that it has been done successfully. It's really not much
difference to weaving plugins for use in the Eclipse SDK. When you
convert a plugin project to an AspectJ project it should prompt to add a
plugin dependency on the org.aspectj.runtime plugin. You then need to
make sure this plugin is included when you export the feature/product.
Shout if you hit any problems.
Matt.
> Thanks
> -HC
Re: RCP Plugins and AspectJ [message #594763 is a reply to message #67007] Thu, 14 September 2006 07:07 Go to previous message
Matt.
> Thanks
> -HC
Previous Topic:RCP Plugins and AspectJ
Next Topic:Is it possible to capture a newly initialized object in call pointcut?
Current Time: Thu Jul 17 19:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.05383 seconds
