Home » Eclipse Projects » DTP » java.lang.NoClassDefFoundError: org/eclipse/core/internal/runtime/Assert
java.lang.NoClassDefFoundError: org/eclipse/core/internal/runtime/Assert [message #5959] Wed, 21 December 2005 03:40 Go to next message
Originally posted by: christoph.bohl.bit.admin.ch
I try to use the DTP for the first time.
Eclipse: 3.2.0M4, I20051215-1506
EMF: emf-sdo-runtime-2.2.0M3
DTP: dtp-SDK_0.7M2_I121205
When I try to open the view "Data Source Explorer", I get the following
error:
!SESSION 2005-12-21 09:25:45.113
eclipse.buildId=I20051215-1506
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_CH
Framework arguments: -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -data
d:\EclipseWorkspace -showlocation
!ENTRY org.eclipse.ui 4 4 2005-12-21 09:26:21.144
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-12-21 09:26:21.160
!MESSAGE org/eclipse/core/internal/runtime/Assert
!STACK 0
org.eclipse.datatools.connectivity.navigator.dnd2.NavigatorD ragAdapter. <init>(NavigatorDragAdapter.java:45)
org.eclipse.datatools.connectivity.ui.dse.views.DataSourceEx plorerView.initDragAndDrop(DataSourceExplorerView.java:195)
org.eclipse.datatools.connectivity.ui.dse.views.DataSourceEx plorerView.createViewer(DataSourceExplorerView.java:132)
org.eclipse.datatools.connectivity.ui.dse.views.DataSourceEx plorerView.createPartControl(DataSourceExplorerView.java:98)
org.eclipse.datatools.connectivity.ui.dse.views.DataSourceEx plorerView.createPartControl(DataSourceExplorerView.java:73)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:1655)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:944)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:927)
at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.j ava:3263)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3260)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3238)
org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHan dler.java:146)
org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHa ndler.java:102)
org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHand ler.java:70)
at org.eclipse.ui.internal.ShowViewMenu$3.run(ShowViewMenu.java :113)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:492 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:914)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3285)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2905)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Any help is greatly appreciated.
Please reply to the list and myself, as I am not subscribed to the list.
Chris
Re: java.lang.NoClassDefFoundError: org/eclipse/core/internal/runtime/Assert [message #5995 is a reply to message #5959] Wed, 21 December 2005 09:59 Go to previous message
> error:
> d:EclipseWorkspace -showlocation
> snip <
Hi Christoph,
The DSE in the last iteration build and currently in CVS has some problems
running on 3.2M4, and this is one of them. It does, however, run on 3.2M3.
We are working on a solution and hope to have it in our M2 build this
Friday (12/23).
John Graham
Eclipse Data Tools Platform PMC
Staff Software Engineer, Sybase
Re: java.lang.NoClassDefFoundError: org/eclipse/core/internal/runtime/Assert [message #569254 is a reply to message #5959] Wed, 21 December 2005 09:59 Go to previous message
> error:
> snip <
Hi Christoph,
Friday (12/23).
John Graham
Previous Topic:Oracle Driver Template
Next Topic:DTP Milestone 2 (M2) build announcement
Current Time: Sun Jul 27 03:03:50 EDT 2025
Powered by FUDForum. Page generated in 0.04502 seconds
