Home » Eclipse Projects » Remote Application Platform (RAP) » Text widget on Linux with russian characters
Text widget on Linux with russian characters [message #66982] Wed, 19 December 2007 01:09 Go to next message
Originally posted by: sergeyaldonin.gmail.com
We use RAP (build rap-1.0.1-R-target-3.3-20071207-1851) and we have a
problem.
We use "Text" widget:
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout());
Text text = new Text(composite, SWT.BORDER);
text.addModifyListener(new ModifyListener() {
public void modifyText(ModifyEvent event) {
System.out.println(">>" + ((Text) event.widget).getText());
If RAP client started on Linux (we tried Firefox, Opera browsers) and
input any russian characters into Text widget - listener not notify.
If input english characters - all right.
If client RAP started on Windows and input russian or english characters
- all right.
Help solve this problem, please.
Re: Text widget on Linux with russian characters [message #67004 is a reply to message #66982] Wed, 19 December 2007 02:50 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
hm, sounds like a localization problem. don't know much about linux but is
the language installed and configurated in the browser under linux?
Re: Text widget on Linux with russian characters [message #67194 is a reply to message #66982] Fri, 21 December 2007 06:48 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Sergey,
just a wild guess: do you copy & paste the Russian characters? I am
aware that some people reported that when *pasting* text it may happen
that it is not sent to the server. But we couldn't reproduce the problem
until now.
Can you tell whether a request is sent at all? And if so, what it contains?
Rüdiger
Sergey A. wrote:
> Hello,
> problem.
> - all right.
> Thanks
Re: Text widget on Linux with russian characters [message #67254 is a reply to message #67194] Mon, 24 December 2007 04:25 Go to previous messageGo to next message
Hi Rüdiger,
Thanks for your attention for our problem.
We don't do copy & paste russian characters (but we try copy & paste -
request is not sent to the server).
We just input russian characters to the Text widget.
Well, we inspect requests at the Firebug plugin for Firefox. Request is
If we input string that contains any not russian characters (english
characters, numbers, "space" and other special symbols) - request sent
to the server. And on server then we have full string (with russian and
not russian characters).
Well, we have problem when use russian characters only.
Maybe we have some problems with RAP javascript code? Or some specific
preferences for linux browsers.
Best regards
Rüdiger Herrmann wrote:
> Sergey,
> problem until now.
> contains?
> Cheers,
> Rüdiger
Re: Text widget on Linux with russian characters [message #67264 is a reply to message #67254] Mon, 24 December 2007 05:17 Go to previous messageGo to next message
just to be sure: did you ever tried it on a windows client? Are there
the same problems? Just wondering if it's the RAP js implementation or
maybe really a os-related thing.
Greets
Benny
Sergey A. wrote:
> Hi Rüdiger,
> Best regards
>> Sergey,
>> problem until now.
>> contains?
>> Cheers,
>> Rüdiger
Re: Text widget on Linux with russian characters [message #67274 is a reply to message #67264] Mon, 24 December 2007 08:04 Go to previous messageGo to next message
Yes, we tried it on a windows client. There are no problem.
Best regards
Benjamin Muskalla wrote:
> Greets
> Benny
Re: Text widget on Linux with russian characters [message #68096 is a reply to message #67274] Wed, 02 January 2008 12:54 Go to previous message
--------------070003010901000303000001
Content-Type: text/plain; charset=UTF-8; format=flowed
Sergey,
to me this sounds like a client-side problem. It would help to know
whether the JavaScript keystroke-listener that RAP uses in order to send
the modify-event is ever triggered.
As I neither have a Linux at hand nor a Russian keyboard I attached a
version of TextUtil.js with debug messages. If you replace the original
one (located in the ...rwt plug-in, in js/org/eclipse/swt/TextUtil.js)
with this one, you should see at least see "modifyTextAction" in the
debug window/Firebug console.
Please note that you need to have debug messages enabled by launching
the application with "-Dorg.eclipse.rwt.clientLogLevel=ALL".
Rüdiger
Sergey A. wrote:
> Best regards
>> Greets
>> Benny
Content-Type: application/x-javascript;
name="TextUtil.js"
Content-Disposition: inline;
filename="TextUtil.js"
* Copyright (c) 2007 Innoopract Informationssysteme GmbH.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Innoopract Informationssysteme GmbH - initial API and implementation
qx.Class.define( "org.eclipse.swt.TextUtil", {
statics : {
// TODO [rh] workaround for https://bugs.eclipse.org/bugs/show_bug.cgi?id=201080
// the fix is to exchange the _onblur implementation of qx.ui.forms.Text
// with our own one, that checks parent != null before calling
// setSelectionLength
hijack : function( text ) {
text.removeEventListener( "blur", text._onblur );
text._onblur = function() {
var vValue = this.getComputedValue().toString();
if( this._textOnFocus != vValue ) {
this.setValue( vValue );
if( this.getParent() != null ) {
this.setSelectionLength( 0 );
text.addEventListener( "blur", text._onblur );
// Functions for ModifyEvents and maintenance of the text/value
modifyText : function( evt ) {
var text = evt.getTarget();
if( !org_eclipse_rap_rwt_EventUtil_suspend
&& org.eclipse.swt.TextUtil._isModifyingKey( evt.getKeyIdentifier() ) )
// if not yet done, register an event listener that adds a request param
// with the text widgets' content just before the request is sent
if( !org.eclipse.swt.TextUtil._isModified( text ) ) {
var req = org.eclipse.swt.Request.getInstance();
req.addEventListener( "send", org.eclipse.swt.TextUtil._onSend, text );
org.eclipse.swt.TextUtil._setModified( text, true );
org.eclipse.swt.TextUtil.updateSelection( text, null );
* This function gets assigned to the 'keyup' event of a text widget if
* there was a server-side ModifyListener registered.
modifyTextAction : function( evt ) {
text.debug( "modifyTextAction" );
&& !org.eclipse.swt.TextUtil._isModified( text )
text.debug( "modifyTextAction: first modifying key" );
// Register 'send'-listener that adds a request param with current text
text.debug( "modifyTextAction: register send-listener" );
// add modifyText-event with sender-id to request parameters
var widgetManager = org.eclipse.swt.WidgetManager.getInstance();
var id = widgetManager.findIdByWidget(text);
req.addEvent( "org.eclipse.swt.events.modifyText", id );
// register listener that is notified when a request is sent
qx.client.Timer.once( org.eclipse.swt.TextUtil._delayedModifyText,
text,
500 );
* This function gets assigned to the 'blur' event of a text widget if there
* was a server-side ModifyListener registered.
modifyTextOnBlur : function( evt ) {
&& org.eclipse.swt.TextUtil._isModified( evt.getTarget() ) )
var id = widgetManager.findIdByWidget( evt.getTarget() );
req.send();
_onSend : function( evt ) {
// NOTE: 'this' references the text widget
var id = widgetManager.findIdByWidget( this );
req.addParameter( id + ".text", this.getComputedValue() );
// remove the _onSend listener and change the text widget state to 'unmodified'
req.removeEventListener( "send", org.eclipse.swt.TextUtil._onSend, this );
org.eclipse.swt.TextUtil._setModified( this, false );
// Update the value property (which is qooxdoo-wise only updated on
// focus-lost) to be in sync with server-side
if( this.getFocused() ) {
this.setValue( this.getComputedValue() );
_delayedModifyText : function( evt ) {
// NOTE: this references the text widget (see qx.client.Timer.once above)
if( org.eclipse.swt.TextUtil._isModified( this ) ) {
req.send();
_isModified : function( widget ) {
return widget.getUserData("modified") == true;
_setModified : function( widget, modified ) {
return widget.setUserData("modified", modified);
* Determines whether the given keyIdentifier potentially modifies the
* content of a text widget.
_isModifyingKey : function( keyIdentifier ) {
var result = false;
switch( keyIdentifier ) {
// Modifier keys
case "Shift":
case "Control":
case "Alt":
case "Meta":
case "Win":
// Navigation keys
case "Up":
case "Down":
case "Left":
case "Right":
case "Home":
case "End":
case "PageUp":
case "PageDown":
case "Tab":
// Context menu key
case "Apps":
case "Escape":
case "Insert":
case "Enter":
case "CapsLock":
case "NumLock":
case "Scroll":
case "PrintScreen":
// Function keys 1 - 12
case "F1":
case "F2":
case "F3":
case "F4":
case "F5":
case "F6":
case "F7":
case "F8":
case "F9":
case "F10":
case "F11":
case "F12":
break;
default:
result = true;
return result;
// Functions to maintain the selection-start and -length properties
onMouseUp : function( evt ) {
if( !org_eclipse_rap_rwt_EventUtil_suspend ) {
updateSelection : function( text, enclosingWidget ) {
// TODO [rh] executing the code below for a TextArea leads to Illegal
// Argument
if( text.classname != "qx.ui.form.TextArea" ) {
var widget = enclosingWidget != null ? enclosingWidget : text;
var start = text.getSelectionStart();
var length = text.getSelectionLength();
if( text.getUserData( "selectionStart" ) != start ) {
text.setUserData( "selectionStart", start );
org.eclipse.swt.TextUtil._setPropertyParam( widget,
"selectionStart",
start );
if( text.getUserData( "selectionLength" ) != length ) {
text.setUserData( "selectionLength", length );
"selectionCount",
length );
// TODO [rst] not text specific, move this function to Request
_setPropertyParam : function( widget, name, value ) {
var id = widgetManager.findIdByWidget( widget );
req.addParameter( id + "." + name, value );
setSelection : function( text, start, length ) {
if( text.isCreated() && !text.getUserData( "pooled" ) ) {
org.eclipse.swt.TextUtil._doSetSelection( text, start, length );
else {
text.setUserData( "onAppear.selectionStart", start );
text.setUserData( "onAppear.selectionLength", length );
text.addEventListener( "appear",
org.eclipse.swt.TextUtil._onAppearSetSelection );
_onAppearSetSelection : function( evt ) {
var start = text.getUserData( "onAppear.selectionStart" );
var length = text.getUserData( "onAppear.selectionLength" );
text.removeEventListener( "appear",
_doSetSelection : function( text, start, length ) {
text.setSelectionStart( start );
text.setSelectionLength( length );
// TODO [rst] Workaround for pooling problems with wrap property in IE.
// These methods can probably be dropped once qx bug 300 is fixed.
setWrap : function( text, wrap ) {
text.setWrap( wrap );
} else {
text.setUserData( "onAppear.wrap", wrap );
org.eclipse.swt.TextUtil._onAppearSetWrap );
_onAppearSetWrap : function( evt ) {
var wrap = text.getUserData( "onAppear.wrap" );
text.setUserData( "onAppear.wrap", undefined );
// SelectionListener support
* This function is registered server-side if a SelectionListener should
* be notified about the widgetDefaultSelection event that occurs when
* Enter was pressed.
widgetDefaultSelected : function( evt ) {
if( evt.getKeyIdentifier() == "Enter"
&& !evt.isShiftPressed()
&& !evt.isAltPressed()
&& !evt.isCtrlPressed()
&& !evt.isMetaPressed() )
evt.setPropagationStopped( true );
req.addEvent( "org.eclipse.swt.events.widgetDefaultSelected", id );
req.send();
--------------070003010901000303000001--
Previous Topic:Resource management
Next Topic:Is RAP Production Ready?
Current Time: Fri Jul 18 04:09:16 EDT 2025
Powered by FUDForum. Page generated in 0.11655 seconds
