(no subject) [message #669228 is a reply to message #668858] |
Mon, 09 May 2011 14:08 |
On 09-May-11 06:48, ja11946 wrote:
> Hello All,
> When I try and run a Servlet "Run on Server" the web
> browsing window opens up but then it asks if I want to save
> the file. The only way I can see the Servlet in a browser is
> by opening the saved file in a browser.
> I am using the latest Eclipse and TomCat 7.
> Thanks in advance for the help.
> John
I'm not certain I understand what you're describing. Is the result of
your servlet XML output or something?
As a stab in the dark, I have a suggestion: right-click on the Tomcat
server in the Server view (usually down at the bottom of your workbench)
and start/restart it. (This is instead of right-cliking some file in
your project and choosing Run on Server.) Then, open a Chrome browser
and type the servlet URI into the address line (and press Enter). (If
you use Firefox, you'll probably get the same behavior you're condemning
in Eclipse.)
This *might* show what you're after.
Good luck.
FUDForum. Page generated in 0.08618 seconds
