Home » Language IDEs » PHP Development Tools (PDT) » Updates of PDT
Updates of PDT [message #66948] Wed, 05 March 2008 02:00 Go to next message
When I run Update Manager to search for updates of the currently
installed features, there are 29 new updates (0 of 29 selected) but
there are invisible until I have unchecked "Show the latest version of a
future only". But when I unchacked that button and checked PDT Updates,
Next and Finish button is still inactive. This PDT version is from Zend
with Zend Debugger and I have 1.0.2 non SDK and SDK version of PDT. This
problem I have with previous versions too. Any solution?
Re: Updates of PDT [message #67136 is a reply to message #66948] Tue, 11 March 2008 14:12 Go to previous messageGo to next message
Originally posted by: etheise.cisco.com
Hi Petr,
I have no answer for you. I came here to ask the same thing.
I am alerted that updates are available.
The updates box shows nothing listed in "Select the features to install:",
and below that I have "0 of 18 selected" with "Show the latest version of
a feature only" checked.
If I uncheck "Show the latest version...", the window shows an unchecked
"PDT Updates" as the site for features to install; an expansion arrow
appears to its left.
I can check PDT Updates, but when I click on the arrow to expand, it
simply vanishes. "Select Required" and all combination of boxes and
buttons produces no updates.
This happens every time I fire up eclipse.
If anyone knows how to clear this state and get around this obstacle, I
would sure like to learn it.
Thanks, Eric
Re: Updates of PDT [message #68868 is a reply to message #67136] Wed, 16 April 2008 20:12 Go to previous messageGo to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
This problem still exists in the latest version I downloaded yesterday
(the all in one package).
Does no one from PDT project have an answer? Should I file a bug report?
Eric Theise wrote:
> Hi Petr,
> install:", and below that I have "0 of 18 selected" with "Show the
> latest version of a feature only" checked.
> Thanks, Eric
Re: Updates of PDT [message #70402 is a reply to message #68868] Tue, 13 May 2008 05:26 Go to previous messageGo to next message
Can someone tell us an answer? Some solution? This problem "disabled"
all automatic updates.
Re: Updates of PDT [message #70422 is a reply to message #70402] Tue, 13 May 2008 11:17 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
Because Eclipse 3.4 has achieved M7 status, and is about to move into
its Release Candidate (beta) cycle, I'd recommend trying PDT with
Eclipse 3.4M7. The new p2 Install Manager is much better than the old
Update Manager at resolving and correcting dependency disconnects.
You can get Eclipse 3.4M7 here:
http://download.eclipse.org/eclipse/downloads/drops/S-3.4M7- 200805020100/index.php
Or, try an EPP package that includes Web Tools (WTP) 3.0, and you'll
have all the PDT 1.1 requirements pre-installed for you:
http://www.eclipse.org/epp/download.php
Then, grab a PDT 1.1 nightly:
http://download.eclipse.org/tools/pdt/downloads/
As far as PDT 1.0.x goes, it might work on Eclipse 3.4, but you might
have to manually install WTP 2.0.x instead of 3.0, depending on how
tightly PDT sets its plugin dependency ranges.
Good luck!
Nick
Installing PDT 1.1 (was Re: Updates of PDT) [message #70439 is a reply to message #70422] Tue, 13 May 2008 12:01 Go to previous messageGo to next message
In fact, I just tried it, and it works. Here's how:
http://wiki.eclipse.org/PDT/Installation#Eclipse_3.4_.2F_Gan ymede_.2F_PDT_1.1
Nick
Re: Installing PDT 1.1 (was Re: Updates of PDT) [message #70994 is a reply to message #70439] Thu, 15 May 2008 13:51 Go to previous messageGo to next message
Originally posted by: jacob.datajoe.com
FYI, using the Latest integraded build
(1.1.0.v20080406-7978-E7QYGHNGqH6) resulted in the following error:
Can't deal with three or more different versions of the same IU
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.ltk.core.refactoring/[ 3.3.1.r332_20080128,3.3.1.r332_20080128].
See bug 200380
But, when I used the latest nightly it was successful.
Jacob Fogg
> Nick
Re: Installing PDT 1.1 (was Re: Updates of PDT) [message #71010 is a reply to message #70994] Thu, 15 May 2008 14:42 Go to previous messageGo to next message
That build
( http://download.eclipse.org/tools/pdt/downloads/release.php? release=I20080407)
requires M5, not M7. Ganymede update site only has the latest milestone.
Of course PDT should probably not be so stringent in its version
requirements, so that it can work across milestones....
Does anyone know when the next PDT 1.1 I build will be available?
Anyone? Beuller? :)
Nick
> requiredCapability:
> See bug 200380
> Jacob Fogg
>> Nick
Re: Installing PDT 1.1 (was Re: Updates of PDT) [message #76384 is a reply to message #71010] Fri, 18 July 2008 07:40 Go to previous messageGo to next message
Is there any chance for an 1.1/2.0 update site?
Thanks!
Nick Boldt wrote:
> That build
> Anyone? Beuller? :)
> Nick
>> requiredCapability:
>> See bug 200380
>> Jacob Fogg
>>> Nick
Re: Installing PDT 1.1 (was Re: Updates of PDT) [message #76400 is a reply to message #76384] Fri, 18 July 2008 08:14 Go to previous message
Originally posted by: stoyan.amexy.com
You may want to add yourself to CC for
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=233744>
> Thanks!
> Nick Boldt wrote:
>> That build
>> Anyone? Beuller? :)
>> Nick
>>> requiredCapability:
>>> See bug 200380
>>> Jacob Fogg
>>>> into
>>>> old
>>>> Nick
Previous Topic:Code Assist Fail
Next Topic:Re: Error when I assoc *.phtml files with the WTP Web Page Editor, the editor cr
Current Time: Wed Jul 16 08:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.47369 seconds
