Home » Language IDEs » ServerTools (WTP) » Tomcat instalation & CATALINA_BASE
Tomcat instalation & CATALINA_BASE [message #66928] Fri, 21 January 2005 13:16 Go to next message
Tomcat provides option where a single binary installation can be shared by multiple runtime
instances. To take advantage of that, one needs to tell Tomcat where docroot is, by specifying the
CATALINA_BASE variable. In such setup, it is not required to have conf, webapps and work
directories, as they need to exist in the directory where CATALINA_BASE points to.
In wtp m2, tomcat without all directories is not recognized as valid, and there is no place to
specify what CATALINA_BASE should be.
Would it be possible to add support for this?
If more details are needed I'd be happy to provide them.
Many thanks,
Branko
Re: Tomcat instalation & CATALINA_BASE [message #66947 is a reply to message #66928] Fri, 21 January 2005 16:23 Go to previous messageGo to next message
it is possible to specify this even if its much work... or not so much
if you can get lomboz (not installed just the data)...
I wrote a server config for oc4j... you simply have to get lomboz unpack
it somewhere find the tomcatXYZ.server file and change it to the new
xml-form... examples are in the directory where you finally have to copy
your work to: %eclipse%/plugins/org.eclipse.jst.server.generic_core_1.0.0
Lomboz was using a plain text file the new WTP is all XML so you have to
do some work... but thats the way to get your "custom-catalina"
running... maybe they will fix bugs in the M3 or in one of the
Integration-builds but if you don't want to wait thats your chance... :P
Re: Tomcat instalation & CATALINA_BASE [message #67037 is a reply to message #66928] Sun, 23 January 2005 04:31 Go to previous message
Originally posted by: ekkehardREMOVE_NO_SPAM.gentz-software.de
Branko schrieb:
> by multiple runtime instances. To take advantage of that, one needs to
> tell Tomcat where docroot is, by specifying the CATALINA_BASE variable.
> points to.
> and there is no place to specify what CATALINA_BASE should be.
> Many thanks,
> Branko
would be really great to add this feature
regards
ekkehard
Previous Topic:WTP EclipseCon Project Sprint - call for ideas
Next Topic:Problems about sql editor and server explorer
Current Time: Tue Jul 22 01:48:52 EDT 2025
Powered by FUDForum. Page generated in 0.03960 seconds
