Home » Newcomers » Newcomers » running esclipse
running esclipse [message #66887] Thu, 19 May 2005 18:43 Go to next message
Originally posted by: henry.le.u210565.wamu.net
Anybody know why Eclipse could not find the compiler even I installed both
java SDK and JRE? I also set the path corectly. If I try to build it from
the DOS prompt, it comipiled successfully.
The following is error messages:
Buildfile: D:\projects\Autoboard\build.xml
clean:
[echo] D:/Projects/autoboard/classes
compile:
[javac] Compiling 87 source files to D:\Projects\autoboard\classes
BUILD FAILED: D:\projects\Autoboard\build.xml:32: Unable to find a javac
compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Thank you,
HL
Re: running esclipse [message #66903 is a reply to message #66887] Thu, 19 May 2005 18:48 Go to previous messageGo to next message
What you need to ensure is that you have either set JAVA_HOME to the jdk
install OR start Eclipse using the JDK OR explicitly add the tools.jar from
the JDK install to your Ant runtime classpath.
HTH
Darins
"Henry Le" <henry.le.u210565@wamu.net> wrote in message
news:88eaf567345a0aff82354b6b014a4e53$1@www.eclipse.org...
> clean:
> compile:
> compiler;
> Thank you,
> HL
Re: running esclipse [message #66984 is a reply to message #66903] Fri, 20 May 2005 06:59 Go to previous messageGo to next message
Originally posted by: sandip.abc.com
I have the same problem running JSP on Eclipse.
But I can not understand the solution given by as I am new to Eclipse.
Please say in details.
Thanks in advance
Sandip
Re: running esclipse [message #67100 is a reply to message #66984] Fri, 20 May 2005 11:21 Go to previous message
Please read the tutorials and the Help.
Eric
Previous Topic:installed log4j plugin, but...
Next Topic:Subversion Support
Current Time: Sat Jul 26 19:42:29 EDT 2025
Powered by FUDForum. Page generated in 0.07887 seconds
