Home » Language IDEs » PHP Development Tools (PDT) » short tags
short tags [message #66883] Wed, 27 February 2008 08:06 Go to next message
Dear All:
I don't use short tags. That is to say, I always use <?php ... ?>, and
never <? ... ?>. My php.ini is configured to enforce this.
That being the case, how do I prevent this code:
<?xml version="1.0" encoding="iso-8859-1"?>
.... showing up as an error? I always see this:
Multiple annotations found at this line:
- Syntax Error
- Syntax Error: unexpected 'encoding'
- Syntax Error: unexpected 'version'
- Syntax Error
.... which is kind of annoying. Eclipse thinks that that <? is an opening
tag for some PHP, when it isn't.
Any advice would be appreciated.
G.
Re: short tags [message #67559 is a reply to message #66883] Thu, 27 March 2008 05:33 Go to previous messageGo to next message
The following question was posed a while ago on this newsgroup however
nobody (was able to?) answer(ed) it. I however have the same problem and
if there's anyone who has a solution to it please let let us know :p.
Kind regards,
Marijn.
Geraint Howell wrote:
> Dear All:
> - Syntax Error
> - Syntax Error
> Regards
> G.
Re: short tags [message #67586 is a reply to message #67559] Thu, 27 March 2008 20:48 Go to previous messageGo to next message
Originally posted by: euthanasia_waltz.yahoo.co.jp.jp
Bug 177933 -- Enable/disable short tags
https://bugs.eclipse.org/bugs/show_bug.cgi?id=177933
Bug 200395 -- Short Tags interfere with XML in a php file
https://bugs.eclipse.org/bugs/show_bug.cgi?id=200395
Bug 166764 -- XML Declaration Syntax Error
https://bugs.eclipse.org/bugs/show_bug.cgi?id=166764
Bug 195162 -- XML start tags flagging errors
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195162
These are not solutions though.
Re: short tags [message #68679 is a reply to message #67586] Sat, 12 April 2008 05:40 Go to previous message
Totally agree. This does need to be addressed. It can cause problems
unfortunately :(
Toshihiro wrote, On 3/28/2008 6:18 AM:
Previous Topic:Implementing a formatter
Next Topic:Automatic code assist does not work
Current Time: Mon Sep 01 00:28:56 EDT 2025
Powered by FUDForum. Page generated in 0.02985 seconds
