Home » Language IDEs » ServerTools (WTP) » Default folders in Dynamic Web Projects
Default folders in Dynamic Web Projects [message #66879] Thu, 20 January 2005 23:13 Go to next message
Originally posted by: ""danoxster \". gmail . com"
Hi all,
I'm attempting to collaborate with a comapany that uses IBM websphere
studio (which I am aware is built on websphere), and use their CVS
server. My problem occurs trying to create a Dynamic Web Project, the
webshpere studio default appears to be to create two required folders
"Java Source" and "Web Content", whereas, eclipse with WTS requires the
folders to be named "JavaSource" and "WebContent". If I don't have these
folders, then eclipse reports errors on my project, so I am wondering if
it possible for me to change some configuration property somewhere that
allows me to specify the folder "Java Source" instead of "JavaSource",
so that I might be able to collaborate with this company effectively.
Thank you in advance for anyone who can help me.
Dan.
Re: Default folders in Dynamic Web Projects [message #66900 is a reply to message #66879] Fri, 21 January 2005 03:53 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
Dan Simmonds > wrote:
> Hi all,
> the folders to be named "JavaSource" and "WebContent". If I don't have
> these folders, then eclipse reports errors on my project, so I am
> wondering if it possible for me to change some configuration property
> somewhere that allows me to specify the folder "Java Source" instead
> of "JavaSource", so that I might be able to collaborate with this
> Dan.
Right button over the project -> Properties -> J2EE -> Web content
folder name
Chemi.
Re: Default folders in Dynamic Web Projects [message #66975 is a reply to message #66900] Fri, 21 January 2005 16:58 Go to previous messageGo to next message
Thanks for this, is there also a way to change the JavaSouce folder name?
>> Hi all,
>> Dan.
> folder name
> Chemi.
Re: Default folders in Dynamic Web Projects [message #67527 is a reply to message #66975] Tue, 25 January 2005 10:50 Go to previous messageGo to next message
Sure there is, you can edit it with a right click on your project ->
properties -> java build path -> source -> delete the old
one and replace it with the kind of folder you want to. You are able to
specify them with "Add Folder"
Hope that helps!
Bye
"Dan Simmonds" <""danoxster \"@ gmail . com"> wrote in message
news:csrtsh$ft5$1@www.eclipse.org...
>>> Hi all,
>>> Dan.
>> Right button over the project -> Properties -> J2EE -> Web content folder
>> name
>> Regards,
>> Chemi.
Re: Default folders in Dynamic Web Projects [message #67969 is a reply to message #66900] Wed, 26 January 2005 09:17 Go to previous messageGo to next message
> folder name
BTW, WTP tries to rename the current web content folder to the new one
specified. What if I'm creating a project from existing sources, and thus
I just need to point the content folder to an existing directory?
Currently, WTP complains that it can't rename the content folder because
the new one already exists. My only solution to this problem was to close
the project, manually edit the ".j2ee" file to change the <webcontent>
element and then open the project again. This works, but it's quite
cumbersome.
-- Marcus Brito
Re: Default folders in Dynamic Web Projects [message #68736 is a reply to message #67527] Wed, 26 January 2005 17:48 Go to previous message
Thank you!
> Hope that helps!
> Bye
>>>>Hi all,
>>>>Dan.
>>>name
>>>Regards,
>>> Chemi.
Previous Topic:Generic Server: java.lang.NoClassDefFoundError
Next Topic:Importing EJB jars into EAR Project
Current Time: Sun Aug 31 22:07:56 EDT 2025
Powered by FUDForum. Page generated in 0.06564 seconds
