Home » Eclipse Projects » Mylyn » Ganymede & Mylyn
Ganymede & Mylyn [message #66855] Wed, 18 March 2009 23:15 Go to next message
I'm trying to pull Mylyn 3.4 (all the way down to 3.1....) without any
success...
this is the most recent site I've tried...
http://download.eclipse.org/tools/mylyn/update/weekly/e3.4
running Eclipse :
Eclipse Platform
Version: 3.4.2
Build id: M20090211-1700
I receive the error:
Cannot complete the request. See the details.
Mylyn Focused UI (Recommended) is already installed, so an update
will be performed instead.
Mylyn Task List (Required) is already installed, so an update will be
performed instead.
Mylyn Bridge: Eclipse IDE is already installed, so an update will be
performed instead.
Mylyn Bridge: Team Support is already installed, so an update will be
performed instead.
Cannot find a solution satisfying the following requirements
org.eclipse.jdt.feature.jar [3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq].
I've tried to uninstall DTP with a glorious crash and burn, thinking that
maybe that would be the problem (I'm at 1.6.2, with no idea how to
downgrade it to 1.6.1 or anything else for that matter)
In fact if I uninstall anything in this configuration, Ganymede simply
does not start anymore.
This package is causing all kinds of problems with Ganymede, it seems
Everything wants to be bound to it, but I obviously do not have it...
Heres my config: (below the config is my error log...)
[[[ I had to clip the message, it was refused when I attempted to initial
post]]]
Re: Ganymede & Mylyn [message #66873 is a reply to message #66855] Wed, 18 March 2009 23:17 Go to previous messageGo to next message
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20090211-1700
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Documents and
Settings\Dennis\Desktop\Ganymede\\plugins\org.eclipse.platfo rm_3.3.101.v200902111700\splash.bmp
-launcher
C:\Documents and Settings\Dennis\Desktop\Ganymede\eclipse.exe
-name
Eclipse
--launcher.library
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher.win32.win32.x86_1.0.101.R34x_v20080731\eclipse_111 5.dll
-startup
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher_1.0.101.R34x_v20081125.jar
-vm
C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/Documents and
Settings/Dennis/Desktop/Ganymede/
eclipse.launcher=C:\Documents and
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1237429353221
eclipse.vm=C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.vmargs=-Xms40m
-Xmx256m
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Documents and
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_04\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_04\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_04
java.io.tmpdir=C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\
java.library.path=C:\Documents and
Settings\Dennis\Desktop\Ganymede;.;C:\WINDOWS\Sun\Java\bin;C :\WINDOWS\system32;C:\WINDOWS;C:/Program
Files/Java/jre1.6.0_04/bin/client;C:/Program
Files/Java/jre1.6.0_04/bin;C:\Program Files\Support
Tools\;C:\ColdFusion8\verity\k2\_nti40\bin;C:\WINDOWS\system 32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Microsoft Windows Small Business
Server\Networking\;C:\Subversion\bin;C:\Program Files\Microsoft SQL
Server\80\Tools\Binn\;C:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Microsoft
Visual Studio 8\Common7\IDE\PrivateAssemblies\;C:\Program
Files\QuickTime\QTSystem\;C:\PROGRA~1\ATT\Graphviz\bin;C:\Pr ogram
Files\GNU\GnuPG\pub;C:\Program Files\TortoiseSVN\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_04-b12
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_04
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b19
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=C:\Documents and
org.eclipse.mylyn.context.core.context.active=true
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2003
org.osgi.framework.os.version=5.2.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.eve nts,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w 3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 2003
os.version=5.2
osgi.arch=x86
osgi.bundles=reference:file:/C:/Documents and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox.common_3.4.0.v20080421-2006.jar@2:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.update.configurator_3.2.201.R34x_v20080819.jar@3:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.run time_3.4.0.v20080512.jar@:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.releng.t ools_3.4.0.v20080414/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. cm_1.0.1.R34x_v20090107-1200.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. device_1.0.1.v20080303.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ds_1.0.0.v20080427-0830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. event_1.1.0.v20080225.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http_1.0.200.v20080421-2006.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http.servletbridge_1.0.0.v20080427-0830.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. io_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ip_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. log_1.1.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. metatype_1.0.0.v20070827.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin_1.0.0.v20080522-1735.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin.rcp_1.0.0.v20080604.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. servletbridge_1.0.101.R34x_v20090114-1346.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.hook_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.xslt_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. useradmin_1.1.1.R34x_v20090107-1200.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. util_1.0.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. wireadmin_1.0.0.v20080407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management_1.2 .0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management.rem ote_1.0.0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.servlet_2.5.0. v200806031605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.2.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.h ttpclient_3.1.0.v20080605-1935.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.common s.util_1.0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.jaxme_ 0.5.1.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xmlrpc_3. 0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples_3.1.100.v20060606/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples.xml_3.3.0.I20080604/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.res ources.jmx_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.core_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.ui_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.rmi_1.0.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.xmlrpc_1.0.0.v20070515.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.common_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server_1.0.0.v20071015.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.rmi_1.0.0.v20070510.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.xmlrpc_1.0.0.v20070608.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.vm_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. preferences.jmx_1.0.0.v20070510.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. registry.jmx_1.0.0.v20080610-1530.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jdt.ui.e xamples.projects_3.1.102.v20080617/,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jface.ex amples.databinding_1.0.100.I20080430-0100.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.osgi.jmx _1.0.0.v20080610-1530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.sdk.exam ples_3.1.200.v20080612/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples_3.4.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser.demos_3.1.200.v3448f/,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.controls_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.launcher_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.layouts_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.ole.win32_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.paint_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.jmx_ 1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.team.exa mples.filesystem_3.4.0.I20080604/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.agentcontroller_4.2.202.v200902101418/,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.iac.administrator_4.4.201.v200901100100.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.contributions_3.3.0.I20080606-0100/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.fieldassist_1.1.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.javaeditor_3.1.100.v20080603-2000/,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.multipageeditor_3.2.100.I20070605-0010/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.propertysheet_3.2.0.I20070319-0010/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.readmetool_3.3.0.I20070606-0010/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.undo_3.2.100.I20080204-0800a.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.views.properties.tabbed.article_3.2.0.I20060605-1400.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/com.lowagie.itext_1. 5.4.v20080228/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.activation_1.1 .0.v200806101325.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.mail_1.4.0.v20 0804091730.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.4.0.v20 0806030407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.5.1.v20 0806030408.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml_1.3.4.v200 806030440.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.rpc_1.1.0. v200806030420/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.soap_1.2.0 .v200806030421/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/net.sourceforge.lpg. lpgjavaruntime_1.1.0.v200803061910.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.axis_1.4. 0.v200807230600/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.bri dge_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.css _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom .svg_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext .awt_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext ension_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.par ser_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.pdf _1.6.0.v200806031500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.svg gen_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.swi ng_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.tra nscoder_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l.gui_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.xml _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.3.0.v20080530-1600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.d iscovery_0.2.0.v200806030120/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.derby.cor e_10.3.1.4/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.log4j_1.2 .13.v200806030600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.wsil4j_1. 0.0.v200806040330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xerces_2. 9.0.v200805270400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.resol ver_1.2.0.v200806030312.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.seria lizer_2.7.1.v200806030322.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt_2.3 .2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt_2.3.2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.cshelp_2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.pdf_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.svg_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.swt_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine_2.3.2.r232_20090211.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.examples_2.3.2.r232_20090211.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.integration.wtp.ui_2.3.2.r232_20081009/,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem.ui_2.3.2.r232_20090122.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui_2.3.2.r232_20081218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui.extension_2.3.2.r232_20081218.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e_2.3.2.r232_20090204a.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.script.function_2.3.2.r232_v20090211.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.ui_2.3.2.r232_20081009.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.csh elp_2.3.2.r232_v20081113/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a_2.3.2.r232_v20090211.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a.aggregation_2.3.2.r232_v20090211.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.doc _2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.exa mple_2.3.2.r232_v20081107.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.int egration.wtp.ui_2.3.2.r232_20090122/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.adapter_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc_2.3.2.r232_v20090212/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile_2.3.2.r232_v20090211.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.sampledb_2.3.2.r232_v20090211.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.ui_2.3.2.r232_v20090211.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.ui_2.3.2.r232_v20090211.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb_2.3.2.r232_v20090211/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb.ui_2.3.2.r232_v20090211.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml.ui_2.3.2.r232_v20090211.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.core_2.3.2.r232_20090202.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.ui_2.3.2.r232_20090202.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer_2.3.2.r232_v20081010.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.core_2.3.2.r232_20090202.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.samplereports_2.3.2.r232_20090202.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui_2.3.2.r232_20090202/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.cubebuilder_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.script_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.xml.wtp_2.3.2.r232_20090202.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors.schematic_2.3.2.r232_20090202.jar,re ference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.ide_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib.explorer_2.3.2.r232_20090202.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.preview.web_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samples.ide_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samplesview_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.views_2.3.2.r232_20090202.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine_2.3.2.r232_20090217.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction_2.3.2.r232_20090122.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction.csv_2.3.2.r232_20090122.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.html_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.pdf_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.postscript_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.ppt_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.prototype.excel_2.3.2.r232_20090202.jar,r eference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.wpml_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.fonts_2.3.2.r232_20090202/,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.core_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.ui_2.3.2.r232_20090202.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model_2.3.2.r232_20090115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model.adapter.oda_2.3.2.r232_20090108.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.viewer_2.3.2.r232_20090212/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.res ources_2.3.2.r232_20081030/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity_1.1.2.v200901090028.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby_1.0.3.v200902070611.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.dbdefinition_1.0.2.v200901090940 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.ui_1.0.1.v200807010433.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.console.profile_1.0.0.v200805231345.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic_1.0.1.v200810140922.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic.ui_1.0.1.v200805152355.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.dbdefinition.genericJDBC_1.0.1.v200810300511. jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda_3.1.3.v200808270255.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.consumer_3.1.3.v200808270255.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design_3.0.7.v200807231215.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design.ui_3.0.8.v200901061015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile_3.0.8.v200812171046.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile.ui_3.0.8.v200812171046.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.profile_3.0.7.v200812050755.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.template.ui_3.0.6.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core_1.0.7.v200902180551.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core.ui_1.1.3.v200902070558.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.server.ui_1.1.3.v200902120834.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui_1.1.3.v200901150027.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui.dse_1.1.3.v200810140349.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.doc.user_1.6.1.v20080828133713.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.finfo_1.5.1.v200805152355.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.dbdefinition_1.0.0.v200805152355.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.ui_1.0.0.v200807220100.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.dbdefinition_1.0.2.v20090109085 3.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw_1.0.1.v200811210224.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.dbdefinition_1.0.3.v200901090853.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.ui_1.0.1.v200806260315.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.dbdefinition_1.0.3.v20090106093 8.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.dbdefinition_1.0.3.v200811040352.j ar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.ui_1.0.1.v200806260315.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.ui_1.0.0.v200806271414.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.jdt.classpath_1.0.1.v200901170137.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver_1.0.1.v200807181158.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.dbdefinition_1.0.0.v200805152355 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.ui_1.0.1.v200808222228.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql_1.0.2.v200810160130.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.dbdefinition_1.0.4.v200901090853.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.ui_1.0.0.v200805152355.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws_1.1.2.v200812171046.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws.ui_1.1.2.v200901191112.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml_1.1.2.v200902111040.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml.ui_1.1.2.v200812171046.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.dbdefinition_1.0.2.v200902030725.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.ui_1.0.1.v200806260315.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql_1.0.1.v200805152355.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.dbdefinition_1.0.1.v200901090853.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.ui_1.0.0.v200806060334.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb_1.0.0.v200805152355.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.dbdefinition_1.0.0.v200805152355.jar, reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.ui_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase_1.0.1.v200805310538.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa_1.0.1.v200901150020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.models_1.0.0.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.ui_1.0.1.v200805310538.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase_1.0.1.v200901170012.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.models_1.0.1.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.ui_1.0.1.v200806260315.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.models_1.0.0.v200805152355.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ui_1.0.0.v20081212.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.help_1.5.0.v200805152355.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.dbdefinition_1.0.1.v200901090853.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.derby_1.0.0.v200805152355.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql_1.0.1.v200812031125.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.edit_1.0.0.v200805152355.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query_1.0.1.v200901241145.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query.edit_1.0.0.v200806070329.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.xml.query_1.0.0.v200807080500.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.oda.cshelp_1.1.0.v200810240330.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.common.ui_1.0.0.v200812121740.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.core_1.0.1.v200902140515.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.ui_1.1.1.v200901140830.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.derby_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.generic_1.0.0.v200902031600.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.ddlgen.ui_1.0.0.v200808140615.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.debugger.core_1.0.0.v200808140615.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.editor.core_1.0.0.v200902031600.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql_1.0.1.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.lexer_1.0.1.v200811081015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.query_1.0.1.v200810291500.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.xml.query_1.0.0.v200808140615.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.plan_1.0.0.v200812121520.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.result_1.0.0.v200902120900.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.routineeditor_1.0.0.v200807211830.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sql_1.0.0.v200902031600.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlbuilder_1.0.0.v200901280650.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqleditor_1.0.0.v200901220945.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlscrapbook_1.0.0.v200901151810.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tabledataeditor_1.0.0.v200901280500.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tablewizard_1.0.0.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.draw2d_3 .4.2.v20090114-1330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf_2.4. 0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ant_ 2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore_2.4.2.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore.ui_2.4.1.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.conv erter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding_1.0.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding.edit_1.0.0.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change.edit_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.edit_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.editor_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.xmi_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit _2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit .ui_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.expo rter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.java_2.4.1.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.rose_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore.editor_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore_2.4.0.v200902171115.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore.editor_2.4.0.v200902171115.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml.ui_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.gef_3.4. 1.v20080806.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem_2.0. 202.v200810282000.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info_2.0.200.v200811261206.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm_2.0.200.v200811260651.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm.common_2.0.200.v200811260651.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.prox y_2.0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.ui_2 .0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.util _2.0.100.v200805140020.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.work bench_2.0.102.v200810230530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.controller_1.1.100.v200805140020.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.core_1.1.100.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.ui_1.1.102.v200806010600.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.frameworks_1.1.201.v200810161330.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.core_1.3.1.v200807031821.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.ui_1.3.1.v200807031821.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. doc.user_1.1.100.v200810092245.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui_1.1.203.v200810010400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui.infopop_1.0.100.v200805222207/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee _1.1.206.v200902052030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .core_1.1.203.v200901221030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .doc.user_1.1.1.v200808070608.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb_1.1.203.v200811060500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotation.model_1.1.102.v200805140020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.emitter_1.1.102.v200805140135.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.ui_1.1.102.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.xdoclet_1.2.0.v200805140020.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .infopop_1.0.300.v200805140415.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca_1.1.203.v200811060900.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca.ui_1.1.200.v200805140020.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .navigator.ui_1.1.203.v200901290400.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ui_1.1.206.v200901280857.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .web_1.1.203.v200901290400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice_1.1.201.v200807240600.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice.ui_1.1.201.v200811062130.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .xdoclet.runtime_1.1.102.v200805140135.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee_ 1.0.103.v200901220530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ejb_1.0.102.v200810230722.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ui_1.0.104.v200902040818.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. web_1.0.101.v200810230738.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common_1.1.4.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.runtime_1.0.101.v20090128.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.ui_1.1.0.v20080605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. core_1.1.103.v200902042324.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. doc.user_1.1.100.v20080811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig_1.1.1.v20090129.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig.ui_1.1.3.v20090128.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. standard.tagsupport_1.1.102.v20090128.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. ui_1.1.102.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. core_1.2.121.v200901290830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui_1.1.312.v200901290909.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui.infopop_1.0.100.v200805301545.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv er.core_1.1.3.v20090115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui_1.1.203.v200810222000.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui.infopop_1.0.300.v200805140415.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.stan dard.schemas_1.0.101.v200807220523.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws_1 .0.307.v200901142050.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.core_1.0.306.v200810082309.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.ui_1.0.305.v200809301934.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.creation.ui_1.0.306.v200811200248.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.infopop_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.ui.doc.user_1.1.0.v200806092139.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption_1.0.307.v200811220753/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.infopop_1.0.300.v200805140230.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui_1.1.4.v200901212148.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui.doc.user_1.0.550.v200901232040.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ejb.ui_1.0.200.v200805140230.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ui_1.0.308.v200901212148.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.d oc.user_1.0.500.v200809092107.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.i nfopop_1.0.300.v200805140230.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u ddiregistry_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u i_1.0.304.v200901271844.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.wst.comm and.env_1.0.308.v200811200248/,reference:file:/C:/Documents
and
Re: Ganymede & Mylyn [message #66886 is a reply to message #66855] Wed, 18 March 2009 23:17 Go to previous messageGo to next message
*** Features:
AnyEditTools (2.1.3.200901071535) "AnyEdit Tools"
com.lowagie.itext (1.5.4.v20080225-1437w31191339) "Lowagie Itext"
com.sun.jna (3.0.9) "JNA Library Plug-in"
EclipseSkins (1.5.1) "Extended VS Presentation Plug-in"
FileSync (1.3.3) "FileSync Plug-in"
JDepend4Eclipse (1.2.1) "JDepend4Eclipse"
org.apache.commons.codec (1.3.0.v20070920-12-7w3119164102711) "Apache
Commons Codec Plug-in"
org.apache.derby.core (10.3.1.4) "Apache Derby Core Plug-in for Eclipse"
org.cfeclipse.cfml.feature (1.3.2.200901041029) "CFML Plug-in"
org.eclipse.birt (2.3.2.r232_v20081010-7N7Y7MAIe2QJZSgfOaAphGBR4t7b)
"Business Intelligence and Reporting Tools"
org.eclipse.birt.chart (2.3.2.r232_v20081010-7_7D79_doT2uMPVNwOGoz0HKuyI8)
"BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.3.2.r232_v20081010-2217s343Aw31192216)
"BIRT Chart Context-sensitive Help"
org.eclipse.birt.chart.integration.wtp
(2.3.2.r232_v20081010-2217s343A3119211_) "BIRT Chart WTP Integration
Plug-in"
Plug-in"
org.eclipse.birt.chart.runtime
(2.3.2.r232_v20081010-7X8n7EELtcA6FxGJtxH7_f) "BIRT Chart Runtime"
org.eclipse.birt.cshelp (2.3.2.r232_v20081010-2217s343Aw31192224) "BIRT
org.eclipse.birt.doc (2.3.2.r232_v20081010-2217s343Aw31192216) "BIRT
Documentation"
Documentation"
org.eclipse.birt.example (2.3.2.r232_v20081010-7D7J7CC7QXRK0ICmcLILD)
"BIRT Example"
"BIRT Example"
org.eclipse.birt.integration.wtp (2.3.2.r232_v20081204-2217s343A311_1233)
"BIRT WTP Integration Plug-in"
org.eclipse.birt.report.designer
(2.3.2.r232_v20081010-7X7n7WEBPrSQ6K-eN3CvLiGaMQ4d) "BIRT Report Designer"
org.eclipse.birt.report.designer.editor.xml.wtp
(2.3.2.r232_v20090212-2217s343A311_1313) "BIRT Advanced XML Editor Plug-in"
org.eclipse.birt.report.runtime
(2.3.2.r232_v20081010-7k8E7fELFluav5n_2NEXh3W6B9_) "BIRT Report Runtime"
org.eclipse.buckminster.core.feature (1.1.0.r09948) "Buckminster UI
Plug-in"
Plug-in"
org.eclipse.buckminster.cvs.feature (1.0.0.r09930) "Buckminster CVS
Plug-in"
Plug-in"
org.eclipse.buckminster.maven.feature (1.1.0.r09904) "Buckminster Maven
Plug-in"
Plug-in"
org.eclipse.buckminster.p4.feature (1.0.0.r09908) "Buckminster Perforce UI
Plug-in"
Plug-in"
org.eclipse.buckminster.pde.feature (1.1.340.r09942) "Buckminster PDE
Plug-in"
Plug-in"
org.eclipse.cdt.mylyn (5.0.2.200902130801) "Mylyn Plug-in"
org.eclipse.cvs (1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7) "Eclipse CVS
Client"
Client"
org.eclipse.cvs.source (1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7)
"Eclipse CVS Client SDK"
org.eclipse.datatools.common.doc.user
(1.6.2.v200810071455-1507w31191939244824) "Data Tools Platform Tutorial
Documentation"
Documentation"
org.eclipse.datatools.connectivity.doc.user
(1.6.2.v200810071455-27A18s733I3I7I599G59) "Data Tools Platform
Connectivity Documentation"
org.eclipse.datatools.connectivity.feature
(1.6.2.v200810071455-7_7K7NDn-QYKjkBKlmD4edYsAX) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.6.2.v200901211403-7C67XCYQCD7ESIqIQco) "DTP ODA Designer UI Framework
Plug-in"
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.6.2.v200810071455-7F27SBcMAAxCcHmCNWi) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.6.2.v200810071455-37A09oA55S6H_L8DFG24)
"Data Tools Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.6.2.v200810071455-6577AlJCKcLZI2Ljcc8MDD) "High-level Sybase Enablement
Plug-in"
Plug-in"
org.eclipse.datatools.enablement.feature
(1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.6.2.v200810071455-57_2_pFAIQJZIsLSXb8MDD) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.ibm.feature
(1.6.2.v200810071455-7D47FEB7sQSBV7hXWQ6R) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.6.2.v200810071455-3-29oA55S7__D7LCC) "High-level Sybase Enablement
Plug-in"
Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.6.2.v200810071455-442_kE77c7VBQDFNW) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.6.2.v200810071455-446_kE77d8H_VALOJ) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.6.2.v200810071455-2138s733J465I548A) "Eclipse Data Tools Platform XML
ODA Designer"
ODA Designer"
org.eclipse.datatools.enablement.oda.feature
(1.6.2.v200810071455-797P78CYQCD5DjGdEURT) "Eclipse Data Tools Platform
XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.6.2.v200810071455-443_kE77d7OAPAMJQ) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
(1.6.2.v200810071455-442_kE77d7N9VANON) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.6.2.v200810071455-440_kE77c7QAQEIQQ) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.6.2.v200810071455-7A-5E9IgKLjM1d1Oepu) "High-level Sybase Enablement
Plug-in"
Plug-in"
org.eclipse.datatools.intro (1.6.2.v200810071455-1507w311918132411)
"Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature
(1.6.2.v200810071455-6-2BcMAAyBWDkEVSb) "Eclipse Data Tools Platform
SQLModel Plug-in"
SQLModel Plug-in"
org.eclipse.datatools.sdk.feature
(1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx) "DTP Connectivity
Templates Plug-in"
Templates Plug-in"
org.eclipse.datatools.sdk.feature.source (1.6.2.v200810071455) "Eclipse
Datatools Source"
Datatools Source"
org.eclipse.datatools.sqldevtools.feature
(1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqltools.doc.user
(1.6.2.v200810071455-1507w31191939244824) "Data Tools Platform SQL Dev
Tools Documentation"
org.eclipse.dd.ipxact (0.9.0.v20080609) "Bundle-Name.0"
org.eclipse.dltk.core (0.95.1.v20080626-2043-0EEJ6E9IgKLhLZW8AKz0uq5)
"Eclipse Dynamic Languages Toolkit (Incubation)"
org.eclipse.dltk.itcl (0.95.1.v20080903-1434-0AR09oA55S5N9J28GBE) "iTcl
Extension Support for TCL language (Incubation)"
org.eclipse.dltk.mylyn (0.95.1.v20080626-2043-08T07w31191_1402545)
"Dynamic Languages Toolkit IncrTcl Core"
org.eclipse.dltk.ruby (0.95.1.v20080626-2043-0ECq6E8McIJXJUOr9upp-2) "Ruby
Development Tools (Incubation)"
org.eclipse.dltk.tcl (0.95.1.v20080626-2043-0EEJ77E9IgKLhLeUz0ALs1x5) "Tcl
org.eclipse.dltk.xotcl (0.95.1.v20080903-1434-0Bw2_kE77c7a9N3BFKL) "XOTcl
org.eclipse.draw2d (3.4.2.v20090218-1145-3317w311_122502441) "Graphical
Editing Framework Draw2d"
org.eclipse.draw2d.sdk (3.4.2.v20090218-1145-67738084A6665K366B84__58x422)
"Graphical Editing Framework Draw2d Developer Resources"
org.eclipse.draw2d.source (3.4.2.v20090218-1145-3317w311_122502441)
org.eclipse.ecf.core (2.1.0.v20081224-1728) "Eclipse Communication
Framework (ECF)"
Framework (ECF)"
org.eclipse.ecf.examples (2.1.0.v20081224-1728) "ECF Collaboration
Examples"
Examples"
org.eclipse.emf (2.4.2.v200902171115) "EMF - Eclipse Modeling Framework"
org.eclipse.emf.codegen (2.4.0.v200902171115) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.4.2.v200902171115) "EMF Ecore Code
Generator"
Generator"
org.eclipse.emf.codegen.ecore.ui (2.4.1.v200902171115) "EMF Ecore Code
Generator UI"
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200902171115) "EMF Code Generation UI"
org.eclipse.emf.common (2.4.0.v200902171115) "EMF Common"
org.eclipse.emf.common.ui (2.4.0.v200902171115) "EMF Common UI"
org.eclipse.emf.converter (2.4.1.v200902171115) "EMF Model Converter"
org.eclipse.emf.databinding (1.0.0.v200902171115) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.0.0.v200902171115) "EMF Edit Data
Binding"
Binding"
org.eclipse.emf.ecore (2.4.2.v200902171115) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.4.1.v200902171115) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.4.0.v200902171115) "EMF Sample Ecore
Editor"
Editor"
org.eclipse.emf.edit (2.4.2.v200902171115) "EMF Edit"
org.eclipse.emf.edit.ui (2.4.2.v200902171115) "EMF Edit UI"
org.eclipse.emf.mapping (2.4.0.v200902171115) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.4.0.v200902171115) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.4.0.v200902171115) "EMF Ecore
Mapping Editor"
Mapping Editor"
org.eclipse.emf.mapping.ui (2.4.0.v200902171115) "EMF Mapping UI"
org.eclipse.emf.mint.doc (0.7.1.v200809162149) "Mint Developer Guide
(Incubation)"
(Incubation)"
org.eclipse.emf.mint.source (0.7.1.v200809162149) "Mint Source
(Incubation)"
(Incubation)"
org.eclipse.emf.ocl (1.1.101.v200808291106-108Z7w3119193_2217) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.query (1.2.0.v200805130238-11-7w311916241349) "EMF Model
Query"
Query"
org.eclipse.emf.query.ocl (1.2.0.v200805130238-11-7w311916241349) "EMF
Model Query OCL Integration"
org.eclipse.emf.search.ecore (0.7.0.v200806130939) "Ecore Model Search
(Incubation)"
(Incubation)"
org.eclipse.emf.search.ecore.ocl (0.7.0.v200806130939) "Ecore OCL Model
Search (Incubation)"
org.eclipse.emf.search.ocl (0.7.0.v200806130939) "Ecore Model Search OCL
(Incubation)"
(Incubation)"
org.eclipse.emf.transaction (1.2.1.v200807161719-2308s733I3E5B4B7J) "EMF
Model Transaction Core"
org.eclipse.emf.validation (1.2.0.v200805130238-35-9oA55S5L8G6FCT) "EMF
Validation Framework Core"
org.eclipse.emf.validation.ocl (1.2.0.v200805130238-11-7w311916241349)
"EMF Validation Framework OCL Integration"
org.eclipse.emf.workspace (1.2.3.v200810041753-2328s733J3_56398B) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.gef (3.4.2.v20090218-1145-67728084A56B4I233613552) "Graphical
Editing Framework GEF"
org.eclipse.gef.sdk (3.4.2.v20090218-1145-7B7E597OKBd7QHgEHNHn9JKTFJJR)
"Graphical Editing Framework GEF Developer Resources"
org.eclipse.gef.source (3.4.2.v20090218-1145-67728084A56B4I233613552)
org.eclipse.gmf (1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ)
"Graphical Modeling Framework"
org.eclipse.gmf.examples.pde (1.1.0.v20080716-1600-2-Ag8s733I3A7C15KCK)
"Graphical Modeling Framework Examples"
org.eclipse.gmf.runtime.notation (1.1.2.v20080916-2008-2108s733I3E4F15B59)
"GMF Notation Model Support"
org.eclipse.gmf.runtime.notation.source
(1.1.2.v20080916-2008-2108s733I3E4F15B59) "Graphical Modeling Framework
Notation Developer Resources"
org.eclipse.gmf.source (1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ)
"Graphical Modeling Framework Runtime Developer Resources"
org.eclipse.gmf.tooling (2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE)
"Graphical Modeling Framework Tooling"
org.eclipse.gmf.tooling.source
(2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE) "Graphical Modeling
Framework Tooling Developer Resources"
org.eclipse.help (1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK) "Help
System Base"
System Base"
org.eclipse.help.source
(1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK) "Help System Core
Source"
Source"
org.eclipse.jdt (3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI)
"Eclipse Java Development Tools"
org.eclipse.jdt.source (3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI)
"Eclipse Java Development Tools SDK"
org.eclipse.mylyn_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.pde_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.nab.mwt (0.9.9.200806181757) "NAB/MWT Plug-in"
org.eclipse.nab.mwt.native.win32 (0.9.9.200806181757) "Win32 handler for
NAB/MWT Plug-in"
NAB/MWT Plug-in"
org.eclipse.ocl (1.2.3.v200810101725-3439oA55T5F8H8PAB) "Object Constraint
Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.uml (1.2.3.v200811021759-1127w311_12182518) "OCL 2.0
Binding for UML"
Binding for UML"
org.eclipse.ocl.uml.source (1.2.3.v200811021759-1127w311_12182518) "OCL
2.0 Binding for UML Source"
org.eclipse.pde (3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS) "PDE"
org.eclipse.pde.source (3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS)
"Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform
(3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL) "Eclipse
Platform"
Platform"
org.eclipse.platform.source
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63)
"Eclipse RCP"
"Eclipse RCP"
org.eclipse.rcp.source
(3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63) "Eclipse RCP Plug-in
org.eclipse.releng.tools (3.2.200.v20080603-33-7w31191525) "RelEng Plug-in"
org.eclipse.rse (3.0.3.v200902042310-7H37E8qfisI6diJKMbrhR-TV-a3) "Remote
System Explorer End-User Runtime"
org.eclipse.rse.core (3.0.3.v200902042310-7Z37HEB7sQSCRiULOVOE) "Remote
System Explorer Core"
org.eclipse.rse.dstore (3.0.3.v200902042310-7J378DUUEFGEpIz-AW8E) "RSE
DStore Services"
DStore Services"
org.eclipse.rse.ftp (3.0.1.v200809171630-78479_kE77c7Q8b8T_F) "RSE FTP
Service"
Service"
org.eclipse.rse.local (2.1.1.v20080710-7_40AgI99m9d_O) "RSE Local Services"
org.eclipse.rse.remotecdt (2.1.1.v200809041200-4118s733I3J4F5C48) "Remote
System Explorer C/C++ Remote Debug Launcher"
org.eclipse.rse.ssh (2.1.1.v20080714-7830_kE77c7V8M) "RSE SSH Services"
org.eclipse.rse.telnet (2.1.1.v200809181500-6678AgI99m9W9X5J79) "RSE
Telnet Service"
Telnet Service"
org.eclipse.rse.terminals (0.1.3.v200902181600-2269sB9EP_M_W5B5B3822) "RSE
Terminals UI (Incubation)"
org.eclipse.rse.useractions (1.1.2.v200812041720-2138s733I573A5G73) "RSE
User Actions"
User Actions"
org.eclipse.sdk
(3.4.2.R342_v20090122-7O7S7GApJ3_vCyk7ETmsfcmjhz0eHnqw7MIjk9 Vdhe4Ic)
"Eclipse Project SDK"
org.eclipse.sdk
org.eclipse.sdk.examples (3.2.0.v20080611-837bEN1ECCP57BAaYN7HSHEb)
"Eclipse SDK Examples"
org.eclipse.sdk.examples.source (3.2.0.v20080611) "Eclipse Platform
org.eclipse.tm.discovery (3.0.0.v20080530-7N-E8ME8McIJXIwdh) "Target
Management Service Discovery Engine"
org.eclipse.tm.terminal (2.0.3.v200902181600-2-27w311_13292711) "Target
Management Terminal Widget"
org.eclipse.tm.terminal.serial (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal Serial Connector"
org.eclipse.tm.terminal.ssh (2.0.2.v200811110900-2-17w311922221_11)
"Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal View"
org.eclipse.tptp.lta.gla.ui.epi (4.5.0.v200805132041-44-7w311916271211)
"Generic Adapter UI"
org.eclipse.tptp.lta.log.epi (4.5.0.v200805132041-44-7w311916243152) "TPTP
LTA Log Extension Instances"
org.eclipse.tptp.lta.sdb.epi (4.5.0.v200805132041-44-7w311916243152) "TPTP
LTA Log SDB Extension Instances"
org.eclipse.tptp.lta.symptom.epi (4.5.0.v200805132041-44-7w311916243152)
"TPTP LTA Log Symptom Catalog Extension Instances"
org.eclipse.tptp.monitoring.instrumentation
(4.3.101.v200901090956-7B79Aj9oA55V585V5VJM) "TPTP Instrumentation
Monitoring "
Monitoring "
org.eclipse.tptp.monitoring.la.core
(4.4.100.v200901090956-7B78CE9oA55S8A8M5855) "Monitoring Log Analyzer Core
backward compatibility"
org.eclipse.tptp.monitoring.managedagent
(4.4.101.v200901090956-7F7DDr_kE77g7A7g7gQU) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.200.v200901090956-43_77w311_121_1_67) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.100.v200901090956-3-37w311_12211211) "MX4J"
org.eclipse.tptp.platform.la.core
(4.3.200.v200812160100-42_77w311923271211) "Log Analysis Core backward
compatibility"
compatibility"
org.eclipse.uml2 (2.2.2.v200902101430) "UML2"
org.eclipse.uml2.diagram (0.8.1.v200809231457) "UML2 Diagramming Plug-in
(Incubation)"
(Incubation)"
org.eclipse.uml2.diagram.source (0.8.1.v200809231457) "UML2 Diagramming
Source"
Source"
org.eclipse.uml2.doc (2.2.0.v200805201350) "UML2 Documentation"
org.eclipse.uml2.examples (2.2.0.v200805131030) "UML2 Examples"
org.eclipse.uml2.examples.source (2.2.0.v200805131030) "UML2 Examples
Source"
Source"
org.eclipse.uml2.search.ocl (0.7.0.v200806130939) "Ecore OCL Model Search
(Incubation)"
(Incubation)"
org.eclipse.uml2.source (2.2.2.v200902101430) "UML2 Source"
org.eclipse.wst (3.0.4.v200811190840-7A-8l8Qqcz0HyVgjXUE-iuOYZ9ai) "Web
Standard Tools (WST)"
org.eclipse.xsd (2.4.2.v200902171115) "XSD - XML Schema Definition Model"
org.eclipse.xsd.edit (2.4.0.v200902171115) "XSD Edit"
org.eclipse.zest (1.0.0.v20080115-5318xB6CE899P233613552) "Graphical
Editing Framework Zest Core"
org.eclipse.zest.sdk (1.0.0.v20080115-5318_GCGFGJMZHOMaa6PMUULSPXD)
"Graphical Editing Framework Zest Developer Resources"
org.eclipse.zest.source (1.0.0.v20080115-5318xB6CE899P233613552)
org.mozilla.rhino (1.6.7.v20071217-1567w31191325) "Mozilla Rhino"
org.tigris.subversion.clientadapter.feature (1.5.3) "Subversion Client
Adapter"
Adapter"
org.tigris.subversion.clientadapter.javahl.feature (1.5.6) "Subversion
JavaHL"
JavaHL"
org.tigris.subversion.clientadapter.svnkit.feature (1.5.6) "SVNKit Client
Adapter"
Adapter"
org.tigris.subversion.subclipse (1.4.8) "SVN Team Provider Core"
org.tigris.subversion.subclipse.graph.feature (1.0.5) "Subversion Revision
Graph"
Graph"
org.tigris.subversion.subclipse.mylyn (3.0.0) "Subclipse Integration for
Mylyn 3.x"
Mylyn 3.x"
org.tmatesoft.svnkit (1.2.3.5521) "SVNKit Library Plug-in"
org.w3c.sac (1.3.0.v20080102-46-_kE77b7U_N56BA) "W3C Sac"
Re: Ganymede & Mylyn [message #67021 is a reply to message #66855] Wed, 18 March 2009 23:18 Go to previous messageGo to next message
*** Plug-in Registry:
ch.ethz.iks.r_osgi.remote (1.0.0.RC2_v20081224-1728) "R_OSGi Remote
Service" [Active]
ch.ethz.iks.slp (1.1.0.v20081224-1728) "jslp-osgi" [Active]
com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.base (3.8.1.v20080530) "International Components for Unicode
for Java (ICU4J) Replacement plug-in" [Starting]
com.ibm.icu.base.source (3.8.1.v20080530) "International Components for
Unicode for Java (ICU4J) Replacement plug-in Source" [Resolved]
com.ibm.icu.source (3.8.1.v20080530) "International Components for Unicode
for Java (ICU4J) Source" [Resolved]
com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
com.lowagie.itext (1.5.4.v20080228) "Lowagie Itext" [Resolved]
com.sun.jna (3.0.9) "JNA Library Plug-in" [Starting]
de.loskutov.anyedit.AnyEditTools (2.1.3.200901071535) "AnyEdit Tools"
[Active]
de.loskutov.BytecodeOutline (2.2.8) "Bytecode Outline Plug-in" [Starting]
de.loskutov.eclipse.jdepend (1.2.1) "JDepend4Eclipse" [Starting]
de.loskutov.eclipseskins.extvs (1.5.1) "Extended VS Presentation Plug-in"
[Starting]
de.loskutov.FileSync (1.3.3) "FileSync Plug-in" [Starting]
javax.activation (1.1.0.v200806101325) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.mail (1.4.0.v200804091730) "Javax Mail Plug-in" [Resolved]
javax.management (1.2.0.v200803061811) "Java Management Extensions API"
[Resolved]
javax.management.remote (1.0.0.v200803061811) "Java Management Remote
Extensions API" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.source (2.0.0.v200806031607) "Java Server Pages API
Source Bundle" [Resolved]
javax.servlet.source (2.4.0.v200806031604) "Servlet API Source Bundle"
[Resolved]
javax.wsdl (1.4.0.v200806030407) "WSDL4J" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200806030440) "JAXP XML" [Resolved]
javax.xml.rpc (1.1.0.v200806030420) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200806030421) "SAAJ" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG"
[Resolved]
org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200803061910) "Apache Ant Source" [Resolved]
org.apache.axis (1.4.0.v200807230600) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200805290154) "Apache Batik Extension"
[Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200805290154) "Apache Batik Swing"
[Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.commons.codec (1.2.0.v20080530-1550) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200806030120) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter Source" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v20080605-1930) "Apache Commons
Logging Plug-in Source" [Resolved]
org.apache.commons.net (1.4.1.v200803071935) "Apache Commons Net"
[Resolved]
[Starting]
org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.source (5.5.17.v200806031609) "Apache Jasper 2 Source
Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200806030600) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
[Resolved]
org.apache.lucene.analysis.source (1.9.1.v20080530-1600) "Apache Lucene
Analysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v20080530-1600) "Apache Lucene Source"
[Resolved]
org.apache.oro (2.0.8.v200803061811) "Apache Jakarta ORO" [Resolved]
org.apache.ws.commons.util (1.0.0.v20080530-1550) "WS Commons Util
Plug-in" [Resolved]
org.apache.ws.jaxme (0.5.1.v20080530-1550) "Apache JAX-ME Plug-in"
[Resolved]
org.apache.wsil4j (1.0.0.v200806040330) "WSIL4J" [Resolved]
org.apache.xerces (2.9.0.v200805270400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200806030312) "Apache XmlResolver"
[Resolved]
org.apache.xml.serializer (2.7.1.v200806030322) "Apache XML Commons
Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20080530-1550) "Apache XML-RPC Plug-in"
[Resolved]
org.cfeclipse.cfml (1.3.2.200901041029) "CFML Plug-in" [Active]
org.cfeclipse.cfml.cfunit (1.3.2.200901041029) "CFUnit Fragment" [Resolved]
org.cfeclipse.cfml.frameworks (1.0.3) "CF Frameworks Plugin" [Starting]
org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
org.eclipse.ant.core.source (3.2.0.v20080529) "Ant Build Tool Core Source"
[Resolved]
org.eclipse.ant.ui (3.3.1.v20090120_r342) "Ant UI" [Active]
org.eclipse.ant.ui.source (3.3.1.v20090120_r342) "Ant UI Source" [Resolved]
org.eclipse.birt (2.3.2.r232_v20081010) "Business Intelligence and
Reporting Tools" [Resolved]
org.eclipse.birt.chart (2.3.2.r232_v20081010) "BIRT Chart Framework"
[Resolved]
org.eclipse.birt.chart.cshelp (2.3.2.r232_v20081105) "BIRT Chart
Context-sensitive Help" [Starting]
org.eclipse.birt.chart.device.extension (2.3.2.r232_20090115) "BIRT Chart
Device Extension(s)" [Starting]
org.eclipse.birt.chart.device.pdf (2.3.2.r232_20090115) "BIRT Chart Device
PDF Extension" [Starting]
org.eclipse.birt.chart.device.svg (2.3.2.r232_20090115) "BIRT Chart Device
SVG Extension" [Starting]
org.eclipse.birt.chart.device.swt (2.3.2.r232_20090115) "BIRT Chart Device
SWT Extension" [Starting]
org.eclipse.birt.chart.engine (2.3.2.r232_20090211) "BIRT Chart Engine"
[Starting]
org.eclipse.birt.chart.engine.extension (2.3.2.r232_20090115) "BIRT Chart
Engine Extension" [Starting]
org.eclipse.birt.chart.examples (2.3.2.r232_20090211) "BIRT Chart Examples
Plug-in" [Starting]
org.eclipse.birt.chart.integration.wtp.ui (2.3.2.r232_20081009) "BIRT
Chart WTP Integration Plug-in" [Starting]
org.eclipse.birt.chart.reportitem (2.3.2.r232_20090115) "BIRT Chart-Report
Integration" [Starting]
org.eclipse.birt.chart.reportitem.ui (2.3.2.r232_20090122) "BIRT
Chart-Report UI Integration Plug-in" [Starting]
org.eclipse.birt.chart.runtime (2.3.2.r232_v20081010) "BIRT Chart Runtime"
[Resolved]
org.eclipse.birt.chart.ui (2.3.2.r232_20081218) "BIRT Chart Library UI
Plug-in" [Starting]
org.eclipse.birt.chart.ui.extension (2.3.2.r232_20081218) "BIRT Chart UI
org.eclipse.birt.core (2.3.2.r232_20090204a) "BIRT Core Package" [Starting]
org.eclipse.birt.core.script.function (2.3.2.r232_v20090211) "Function
Plug-in" [Starting]
org.eclipse.birt.core.ui (2.3.2.r232_20081009) "BIRT Core UI" [Starting]
org.eclipse.birt.cshelp (2.3.2.r232_v20081113) "BIRT Context-sensitive
Help" [Starting]
org.eclipse.birt.data (2.3.2.r232_v20090211) "BIRT Data Engine" [Starting]
org.eclipse.birt.data.aggregation (2.3.2.r232_v20090211) "Build-in
Aggregation Plug-in" [Starting]
org.eclipse.birt.doc (2.3.2.r232_v20081105) "BIRT Documentation" [Starting]
org.eclipse.birt.example (2.3.2.r232_v20081107) "BIRT Example" [Resolved]
org.eclipse.birt.integration.wtp.ui (2.3.2.r232_20090122) "BIRT WTP
org.eclipse.birt.report.data.adapter (2.3.2.r232_v20090211) "BIRT Data
Adapter" [Starting]
org.eclipse.birt.report.data.oda.jdbc (2.3.2.r232_v20090212) "BIRT
ODA-JDBC Bridge Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile (2.3.2.r232_v20090211)
"JDBC Databases Profile Data Source ODA Runtime Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb
(2.3.2.r232_v20090211) "BIRT Sample Database Connection Profile Plug-in"
[Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.ui (2.3.2.r232_v20090211)
"JDBC Databases Profile Data Source ODA Designer" [Starting]
org.eclipse.birt.report.data.oda.jdbc.ui (2.3.2.r232_v20090211) "BIRT JDBC
UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.sampledb (2.3.2.r232_v20090211) "BIRT
Sample Database" [Starting]
org.eclipse.birt.report.data.oda.sampledb.ui (2.3.2.r232_v20090211) "BIRT
Sample Database UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.xml (2.3.2.r232_v20090211) "BIRT ODA-XML
Driver" [Starting]
org.eclipse.birt.report.data.oda.xml.ui (2.3.2.r232_v20090211) "BIRT ODA
XML Designer" [Starting]
org.eclipse.birt.report.debug.core (2.3.2.r232_20090202) "BIRT Debug Core
Plug-in" [Resolved]
org.eclipse.birt.report.debug.ui (2.3.2.r232_20090202) "BIRT Debug UI
Plug-in" [Starting]
org.eclipse.birt.report.designer (2.3.2.r232_v20081010) "BIRT Report
Designer" [Resolved]
org.eclipse.birt.report.designer.core (2.3.2.r232_20090202) "BIRT Designer
Core" [Starting]
org.eclipse.birt.report.designer.samplereports (2.3.2.r232_20090202) "BIRT
Samplereports Plug-in" [Starting]
org.eclipse.birt.report.designer.ui (2.3.2.r232_20090202) "BIRT Designer
UI" [Starting]
org.eclipse.birt.report.designer.ui.cubebuilder (2.3.2.r232_20090202)
"BIRT Cube Builder Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editor.script (2.3.2.r232_20090202)
"BIRT Enhanced Script Editor Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editor.xml.wtp (2.3.2.r232_20090202)
"BIRT Advanced XML Editor Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors (2.3.2.r232_20090202) "BIRT
MultipageEditor Extension Point Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors.schematic
(2.3.2.r232_20090202) "BIRT Editors Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.ide (2.3.2.r232_20090202) "BIRT
Designer UI for IDE" [Starting]
org.eclipse.birt.report.designer.ui.lib (2.3.2.r232_20090202) "BIRT
Designer UI for Library" [Starting]
org.eclipse.birt.report.designer.ui.lib.explorer (2.3.2.r232_20090202)
"BIRT Library Explorer Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.preview.web (2.3.2.r232_20090202)
"BIRT Preview Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samples.ide (2.3.2.r232_20090202)
"Report Samples IDE Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samplesview (2.3.2.r232_20090202)
"BIRT Report Samples View Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.views (2.3.2.r232_20090202) "BIRT UI
Views Plug-in" [Starting]
org.eclipse.birt.report.engine (2.3.2.r232_20090217) "BIRT Engine"
[Starting]
org.eclipse.birt.report.engine.dataextraction (2.3.2.r232_20090122)
"Dataextraction Plug-in" [Starting]
org.eclipse.birt.report.engine.dataextraction.csv (2.3.2.r232_20090122)
"CSV Data Extraction Plug-in" [Starting]
org.eclipse.birt.report.engine.emitter.html (2.3.2.r232_20090202) "BIRT
HTML Emitter" [Starting]
org.eclipse.birt.report.engine.emitter.pdf (2.3.2.r232_20090202) "BIRT PDF
emitter" [Starting]
org.eclipse.birt.report.engine.emitter.postscript (2.3.2.r232_20090202)
"BIRT POSTSCRIPT emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.ppt (2.3.2.r232_20090202) "BIRT PPT
emitter" [Starting]
org.eclipse.birt.report.engine.emitter.prototype.excel
(2.3.2.r232_20090202) "BIRT Excel emitter" [Starting]
org.eclipse.birt.report.engine.emitter.wpml (2.3.2.r232_20090202) "BIRT
Word emitter" [Starting]
org.eclipse.birt.report.engine.fonts (2.3.2.r232_20090202) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.item.crosstab.core (2.3.2.r232_20090202) "BIRT
Crosstab Plug-in" [Starting]
org.eclipse.birt.report.item.crosstab.ui (2.3.2.r232_20090202) "BIRT
Crosstab UI Plug-in" [Starting]
org.eclipse.birt.report.model (2.3.2.r232_20090115) "BIRT Model" [Starting]
org.eclipse.birt.report.model.adapter.oda (2.3.2.r232_20090108) "BIRT
Model ODA Adapter" [Starting]
org.eclipse.birt.report.runtime (2.3.2.r232_v20081010) "BIRT Report
Runtime" [Resolved]
org.eclipse.birt.report.viewer (2.3.2.r232_20090212) "BIRT Web Viewer"
[Starting]
org.eclipse.birt.resources (2.3.2.r232_20081030) "BIRT Resources Plug-in"
[Resolved]
org.eclipse.buckminster.ant (1.1.0.r09861) "Buckminster Ant Plug-in"
[Starting]
org.eclipse.buckminster.cmdline (1.0.0.r09941) "Buckminster Headless
Launcher" [Starting]
org.eclipse.buckminster.core (1.1.340.r09948) "Buckminster Core" [Starting]
org.eclipse.buckminster.cvs (1.0.0.r09930) "Buckminster CVS Plug-in"
[Starting]
org.eclipse.buckminster.download (1.1.0.r09802) "Buckminster download
cache" [Starting]
org.eclipse.buckminster.executor (1.0.0.r09842) "Buckminster Executor
Plug-in" [Starting]
org.eclipse.buckminster.fetcher (1.0.0.r09849) "Buckminster Fetcher
Plug-in" [Starting]
org.eclipse.buckminster.generic (1.0.0.r09794) "Buckminster Generic
Plug-in" [Resolved]
org.eclipse.buckminster.generic.ui (1.0.0.r09795) "Buckminster Generic Ui
Plug-in" [Resolved]
org.eclipse.buckminster.installer (1.0.0.r09796) "Installer Plug-in"
[Resolved]
org.eclipse.buckminster.jdt (1.0.0.r09842) "Buckminster JDT Plug-in"
[Starting]
org.eclipse.buckminster.maven (1.1.0.r09904) "Buckminster Maven Plug-in"
[Starting]
org.eclipse.buckminster.opml (1.0.0.r09811) "Buckminster OPML support"
[Resolved]
org.eclipse.buckminster.osgi.filter (1.0.0) "OSGi Filter Bundle" [Resolved]
org.eclipse.buckminster.p4 (1.0.0.r09908) "Buckminster Perforce Plug-in"
[Starting]
org.eclipse.buckminster.p4.ui (1.0.0.r09842) "Buckminster Perforce UI
Plug-in" [Starting]
org.eclipse.buckminster.pde (1.1.340.r09942) "Buckminster PDE Plug-in"
[Starting]
org.eclipse.buckminster.pde.ui (1.0.0.r09842) "Buckminster Ui Plug-in for
the PDE extension" [Resolved]
org.eclipse.buckminster.remote (1.0.0.r09842) "Buckminster Remote"
[Resolved]
org.eclipse.buckminster.remote.cloudsmith (1.0.0.r09666) "Cloudsmith
Remote Resolution Service Connector" [Resolved]
org.eclipse.buckminster.runtime (1.1.0.r09908) "Buckminster Runtime
Plug-in" [Starting]
org.eclipse.buckminster.sax (1.0.0.r09855) "Buckminster SAX Parser
utilities" [Resolved]
org.eclipse.buckminster.slf4j (1.0.0) "Slf4j implementation using the
Buckminster logger" [Resolved]
org.eclipse.buckminster.ui (1.0.0.r09937) "Buckminster UI Plug-in"
[Starting]
org.eclipse.cdt.core (5.0.2.200902130801) "C/C++ Development Tools Core"
[Active]
org.eclipse.cdt.debug.core (5.0.2.200902130801) "C/C++ Development Tools
Debug Model" [Starting]
org.eclipse.cdt.debug.mi.core (5.0.1.200902130801) "C/C++ Development
Tools GDB/MI CDI Debugger Core" [Starting]
org.eclipse.cdt.debug.mi.ui (5.0.1.200902130801) "C/C++ Development Tools
GDB/MI CDI Debugger UI" [Starting]
org.eclipse.cdt.debug.ui (5.0.1.200902130801) "C/C++ Development Tools
org.eclipse.cdt.launch (5.0.2.200902130801) "C/C++ Development Tools
Launching Support" [Starting]
org.eclipse.cdt.make.core (5.0.2.200902130801) "C/C++ Standard make Build
Core" [Starting]
org.eclipse.cdt.mylyn (1.0.0.200902130801) "Mylyn Plug-in" [Resolved]
org.eclipse.cdt.mylyn.ui (5.0.1.200902130801) "Mylyn CDT Integrator"
[Active]
org.eclipse.cdt.ui (5.0.2.200902130801) "C/C++ Development Tools UI"
[Active]
org.eclipse.compare (3.4.1.r34x_20090121) "Compare Support" [Active]
org.eclipse.compare.examples (3.1.100.v20060606) "Compare Example"
[Starting]
org.eclipse.compare.examples.source (3.1.100.v20060606) "Compare Example
Source" [Resolved]
org.eclipse.compare.examples.xml (3.3.0.I20080604) "XML Compare Support"
[Starting]
org.eclipse.compare.examples.xml.source (3.3.0.I20080604) "XML Compare
Support Source" [Resolved]
org.eclipse.compare.source (3.4.1.r34x_20090121) "Compare Support Source"
[Resolved]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
org.eclipse.core.commands.source (3.4.0.I20080509-2000) "Commands Source"
[Resolved]
org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.contenttype.source (3.3.0.v20080604-1400) "Eclipse
Content Mechanism Source" [Resolved]
org.eclipse.core.databinding (1.1.1.M20080827-0800b) "JFace Data Binding"
[Active]
org.eclipse.core.databinding.beans (1.1.1.M20080827-0800a) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.beans.source (1.1.1.M20080827-0800a) "JFace
Data Binding for JavaBeans Source" [Resolved]
org.eclipse.core.databinding.source (1.1.1.M20080827-0800b) "JFace Data
Binding Source" [Resolved]
org.eclipse.core.expressions (3.4.1.r342_v20081203-0800) "Expression
Language" [Active]
org.eclipse.core.expressions.source (3.4.1.r342_v20081203-0800)
"Expression Language Source" [Resolved]
org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
org.eclipse.core.filebuffers.source (3.4.0.v20080603-2000) "File Buffers
Source" [Resolved]
org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems"
[Active]
org.eclipse.core.filesystem.source (1.2.0.v20080604-1400) "Core File
Systems Source" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.1.R34x_v20081128) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.jobs.source (3.4.1.R34x_v20081128) "Eclipse Jobs
org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management"
[Active]
org.eclipse.core.net.source (1.1.0.I20080604) "Internet Connection
Management Source" [Resolved]
org.eclipse.core.net.win32.x86 (1.0.0.I20080521) "Proxy for Windows"
[Resolved]
org.eclipse.core.resources (3.4.2.R34x_v20090126) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.compatibility.source (3.4.0.v20080604-1400)
"Core Resource Management Compatibility Fragment Source" [Resolved]
org.eclipse.core.resources.jmx (1.0.0.v20070510) "Resource Monitoring Core
Resources Extensions (Incubation)" [Starting]
org.eclipse.core.resources.source (3.4.2.R34x_v20090126) "Core Resource
org.eclipse.core.resources.win32.x86 (3.4.0.v20071204) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.auth.source (3.2.100.v20070502)
"Authorization Compatibility Plug-in Source" [Resolved]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.runtime.compatibility.registry.source (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment Source" [Resolved]
org.eclipse.core.runtime.compatibility.source (3.2.0.v20071008) "Core
Runtime Plug-in Compatibility Source" [Resolved]
org.eclipse.core.runtime.source (3.4.0.v20080512) "Core Runtime Source"
[Resolved]
org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables"
[Starting]
org.eclipse.core.variables.source (3.2.100.v20080529-1300) "Core Variables
Source" [Resolved]
org.eclipse.cvs (1.0.200.R342_v20090206) "Eclipse CVS Client" [Starting]
org.eclipse.cvs.source (1.0.200.R342_v20090206) "Eclipse CVS Client SDK"
[Resolved]
org.eclipse.datatools.common.doc.user (1.6.1.v20080828133713) "Data Tools
Platform Tutorial Documentation" [Resolved]
org.eclipse.datatools.connectivity (1.1.2.v200901090028) "Data Tools
Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.3.v200902070611)
"Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition
(1.0.2.v200901090940) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200807010433)
"Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200805231345)
"DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200810140922)
"Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200805152355)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.1.v200810300511) "Eclipse Data Tools Platform DBDefinition Generic
JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.6.1.v20080828133713) "Data
Tools Platform Connectivity Documentation" [Resolved]
org.eclipse.datatools.connectivity.doc.user.contexts
(1.6.1.v20080828133713) "Data Tools Platform Connectivity Documentation
for context-sensitive help" [Resolved]
org.eclipse.datatools.connectivity.oda (3.1.3.v200808270255) "DTP Open
Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.3.v200808270255) "DTP
ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.7.v200807231215) "DTP
ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.8.v200901061015)
"DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.8.v200812171046)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.8.v200812171046)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.7.v200812050755) "DTP
ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.v200805152355)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.7.v200902180551) "Eclipse
Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.3.v200902070558)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.3.v200902120834)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.3.v200901150027) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.3.v200810140349) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.templates (1.0.0.v200805152355) "DTP
Connectivity Templates Plug-in" [Starting]
org.eclipse.datatools.doc.isv (1.6.0.200806091108) "Data Tools
Documentation Plug-in" [Resolved]
org.eclipse.datatools.doc.user (1.6.1.v20080828133713) "Data Tools
Platform User Documentation" [Resolved]
org.eclipse.datatools.enablement.finfo (1.5.1.v200805152355) "Eclipse Data
Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200805152355) "Eclipse
Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200805152355)
"Eclipse Data Tools Platform HSQLDB Database Definition Enablement
Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200807220100) "Eclipse
Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.1.v200811210224)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.2.v200901090853) "DB2 UDB iSeries Database Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.1.v200811210224)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.3.v200901090853) "Eclipse Data Tools Platform DB2 UDB Database
Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.1.v200811210224)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.3.v200901060938) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200805152355)
"Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.3.v200811040352) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200806271414) "Eclipse
Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200901170137) "Data
Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200807181158)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200808222228)
"Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v200810160130) "Eclipse Data
Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200901090853)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.1.2.v200812171046) "Eclipse
Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.1.2.v200901191112) "Eclipse
Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.1.2.v200902111040) "Eclipse
Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.1.2.v200812171046) "Eclipse
Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200805152355) "Eclipse
Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.2.v200902030725)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200806260315) "Eclipse
Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200805152355)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.1.v200901090853) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200806060334)
"PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200805152355) "Eclipse
Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Definition
Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200805152355)
"Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200805310538) "High-level
Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200901150020) "Sybase
ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASA Database
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200805152355)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200805310538)
"Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200901170012)
"JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASE Database
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200805152355)
"Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200806260315) "ASE
Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200805152355)
"Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v20081212) "Sybase UI
Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200805152355) "Data Tools Platform Help
org.eclipse.datatools.intro (1.6.1.v200807021300) "Eclipse Data Tools
Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.1.v200901090853)
"Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200805152355) "Derby
Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.1.v200812031125) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200901241145) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200806070329) "SQL
Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200807080500)
"Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.0.v200810240330) "DTP ODA
Datatools Source" [Resolved]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200812121740) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.1.v200902140515) "Data Core
Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.1.v200901140830) "Data UI
Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200805152355) "Eclipse
Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200902031600) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200808140615) "Eclipse
Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.6.1.v20080828133713) "Data
Tools Platform SQL Dev Tools Documentation" [Resolved]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200902031600) "Eclipse
Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200808140615) "Eclipse
Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200811081015)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200810291500)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200812121520) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200902120900) "Eclipse Data
Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200807211830)
"Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200902031600) "Eclipse Data
Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200901280650) "SQL
Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200901220945) "Eclipse
Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200901151810) "Eclipse
Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200901280500)
"Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.v200808140615) "Eclipse
Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.v20080609)
"Traditional Memory Rendering" [Starting]
org.eclipse.dd.debug.ui.memory.transport (1.0.0.v20080609) "Memory
Transport Plug-in" [Starting]
org.eclipse.dd.dsf (1.0.0.v20080609) "Debug Services Framework Core"
[Starting]
org.eclipse.dd.dsf.debug (1.0.0.v20080609) "Debug Services Framework
Debug" [Starting]
org.eclipse.dd.dsf.debug.ui (1.0.0.v20080609) "Debug Services Framework
Debug UI" [Starting]
org.eclipse.dd.dsf.ui (1.0.0.v20080609) "Debug Services Framework UI"
[Starting]
org.eclipse.dd.gdb (1.0.0.v20080609) "GDB DSF Debugger Integration Core"
[Starting]
org.eclipse.dd.gdb.launch (1.0.0.v20080609) "Debug Services Framework GDB
Launch Plug-in" [Starting]
org.eclipse.dd.gdb.ui (1.0.0.v20080609) "Debug Services Framework GDB UI
Plug-in" [Starting]
org.eclipse.dd.ipxact (0.9.0.v20080609) "Bundle-Name.0" [Resolved]
org.eclipse.dd.ipxact.checker.core (0.9.0.v20080609) "IP-XACT Document
Checker" [Starting]
org.eclipse.dd.ipxact.checker.ui (0.9.0.v20080609) "IP-XACT Checker Ui
Plug-in" [Starting]
org.eclipse.dd.ipxact.docs (0.9.0.v20080609) "IP-XACT Editor Docs Plug-in"
[Resolved]
org.eclipse.dd.ipxact.editor.core (0.9.0.v20080609) "IP-XACT Editor Core"
[Starting]
org.eclipse.dd.ipxact.editor.ui (0.9.0.v20080609) "IP-XACT Editor UI"
[Starting]
org.eclipse.dd.ipxact.validator.ui (0.9.0.v20080609) "IP-XACT validator"
[Starting]
org.eclipse.dd.mi (1.0.0.v20080609) "GDB/MI Protocol-based DSF Debugger
Integration Core" [Starting]
org.eclipse.debug.core (3.4.1.v20090106_r342) "Debug Core" [Active]
org.eclipse.debug.core.source (3.4.1.v20090106_r342) "Debug Core Source"
[Resolved]
org.eclipse.debug.examples.core (1.0.0) "Example Debug Core Plug-in"
[Starting]
org.eclipse.debug.examples.core.source (1.0.0) "Example Debug Core Plug-in
Source" [Resolved]
org.eclipse.debug.examples.ui (1.0.0) "Example Debug UI Plug-in" [Starting]
org.eclipse.debug.examples.ui.source (1.0.0) "Example Debug UI Plug-in
Source" [Resolved]
org.eclipse.debug.ui (3.4.2.v20090110_r342) "Debug UI" [Active]
org.eclipse.debug.ui.source (3.4.2.v20090110_r342) "Debug UI Source"
[Resolved]
org.eclipse.dltk (0.95.0.v20080526-1423) "Eclipse Dynamic Languages
Toolkit (Incubation)" [Resolved]
org.eclipse.dltk.console (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Console Core (Incubation)" [Starting]
org.eclipse.dltk.console.ui (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Console UI (Incubation)" [Active]
org.eclipse.dltk.core (0.95.1.v20080920-R0951) "Dynamic Languages Toolkit
Core (Incubation)" [Active]
org.eclipse.dltk.debug (0.95.1.v20080903-1434) "Dynamic Languages Toolkit
Debug Core (Incubation)" [Starting]
org.eclipse.dltk.debug.ui (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Debug UI (Incubation)" [Starting]
org.eclipse.dltk.itcl (0.95.0.v20080526-1423) "iTcl Extension Support for
TCL language (Incubation)" [Resolved]
org.eclipse.dltk.itcl.core (0.95.1.v20080903-1434) "pluginName" [Starting]
org.eclipse.dltk.itcl.ui (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit IncrTcl UI" [Starting]
org.eclipse.dltk.launching (0.95.1.v20080915-1703) "Dynamic Languages
Toolkit Launching Core (Incubation)" [Active]
org.eclipse.dltk.mylyn (0.95.1.v20080903-1434) "Dynamic Languages Toolkit
IncrTcl Core" [Active]
org.eclipse.dltk.rse.core (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit RSE Integration Core (Incubation)" [Active]
org.eclipse.dltk.rse.ui (0.95.0.v20080609-1540) "Dynamic Languages Toolkit
RSE Integration UI (Incubation)" [Starting]
org.eclipse.dltk.ruby (0.95.0.v20080526-1423) "Ruby Development Tools
org.eclipse.dltk.ruby.abstractdebugger (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit Ruby Debuggers Support (Incubation)" [Starting]
org.eclipse.dltk.ruby.activestatedebugger (0.95.0.v20080604-1628) "Dynamic
Languages Toolkit Ruby ActiveState Debugger Support (Incubation)"
[Starting]
org.eclipse.dltk.ruby.basicdebugger (0.95.1.v20080626-2043) "Dynamic
Languages Toolkit Ruby Built-In Debugger Support (Incubation)" [Starting]
org.eclipse.dltk.ruby.core (0.95.1.v20080920-R0951) "Dynamic Languages
Toolkit Ruby Core (Incubation)" [Active]
org.eclipse.dltk.ruby.debug (0.95.0.v20080604-1306) "Dynamic Languages
Toolkit Ruby Debug (Incubation)" [Starting]
org.eclipse.dltk.ruby.debug.ui (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Ruby Debug UI (Incubation)" [Starting]
org.eclipse.dltk.ruby.fastdebugger (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit Ruby Fast Debugger Support (Incubation)" [Starting]
org.eclipse.dltk.ruby.launching (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Ruby Launching (Incubation)" [Starting]
org.eclipse.dltk.ruby.ui (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Ruby UI (Incubation)" [Active]
org.eclipse.dltk.tcl (0.95.0.v20080526-1423) "Tcl Development Tools
org.eclipse.dltk.tcl.activestatedebugger (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit Tcl Active State Debugger Support (Incubation)"
[Starting]
org.eclipse.dltk.tcl.core (0.95.1.v20080920-R0951) "Dynamic Languages
Toolkit Tcl Core (Incubation)" [Active]
org.eclipse.dltk.tcl.debug (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Tcl Debug Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.debug.ui (0.95.1.v20080626-2043) "Dynamic Languages
Toolkit Tcl Debug UI (Incubation)" [Starting]
org.eclipse.dltk.tcl.doc.user (0.95.0.v20080609-1540) "Tcl Development
User Guide (Incubation)" [Starting]
org.eclipse.dltk.tcl.launching (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Tcl Launching Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.tclchecker (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit TclChecker Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.testing (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Tcl Testing Frameworks Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.testing.tcltest (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit TclTest Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.ui (0.95.1.v20080920-R0951) "Dynamic Languages
Toolkit Tcl UI (Incubation)" [Active]
org.eclipse.dltk.testing (0.95.0.v20080609-1540) "Dynamic Languages
Toolkit Testing Frameworks Support (Incubation)" [Starting]
org.eclipse.dltk.ui (0.95.1.v20080920-R0951) "Dynamic Languages Toolkit
Core UI (Incubation)" [Active]
org.eclipse.dltk.validators.core (0.95.1.v20080707-1511) "Dynamic
Languages Toolkit Validators Core (Incubation)" [Starting]
org.eclipse.dltk.validators.ui (0.95.1.v20080707-1511) "Dynamic Languages
Toolkit Validators UI (Incubation)" [Starting]
org.eclipse.dltk.xotcl (0.95.0.v20080605-1144) "XOTcl Extension Support
for TCL language (Incubation)" [Resolved]
org.eclipse.dltk.xotcl.core (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit XOTcl Core" [Starting]
org.eclipse.dltk.xotcl.testing.xounit (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit XOUnit Framework Support (Incubation)" [Starting]
org.eclipse.dltk.xotcl.ui (0.95.1.v20080626-2043) "Dynamic Languages
Toolkit XOTcl UI" [Starting]
org.eclipse.draw2d (3.4.2.v20090114-1330) "Graphical Editing Framework
Draw2d" [Starting]
org.eclipse.draw2d.doc.isv (3.4.1.v20080806) "Graphical Editing Framework
Draw2d Documentation" [Starting]
"Graphical Editing Framework Draw2d Developer Resources" [Resolved]
org.eclipse.dstore.core (3.0.3.v200902101918) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.0.v20080406) "RSE DStore Platform Support"
[Starting]
org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Active]
org.eclipse.ecf.core.source (2.1.0.v20081224-1728) "ECF Core Source"
[Resolved]
org.eclipse.ecf.datashare (1.3.0.v20081224-1728) "ECF DataShare API"
[Resolved]
org.eclipse.ecf.discovery (2.1.0.v20081224-1728) "ECF Discovery API"
[Active]
org.eclipse.ecf.discovery.ui (2.0.0.v20081224-1728) "ECF Discovery UI"
[Starting]
org.eclipse.ecf.doc (1.3.0.v20081224-1728) "ECF Documentation" [Starting]
org.eclipse.ecf.docshare (2.0.0.v20081224-1728) "ECF DocShare Plugin"
[Active]
org.eclipse.ecf.example.clients (1.3.0.v20081224-1728) "ECF Clients
Example" [Resolved]
org.eclipse.ecf.example.collab (1.3.0.v20081224-1728) "ECF Collaboration
Examples" [Starting]
org.eclipse.ecf.example.collab.editor (1.0.200.v20081224-1728) "ECF Shared
Editor Example" [Starting]
org.eclipse.ecf.examples.remoteservices.client (1.0.100.v20081224-1728)
"ECF RemoteService Example Client" [Starting]
org.eclipse.ecf.examples.remoteservices.common (1.0.100.v20081224-1728)
"ECF RemoteService Example Common" [Starting]
org.eclipse.ecf.examples.remoteservices.server (1.0.100.v20081224-1728)
"ECF RemoteService Example Server" [Starting]
org.eclipse.ecf.examples.source (2.1.0.v20081224-1728) "ECF Examples
Source" [Resolved]
org.eclipse.ecf.examples.updatesite.client (1.0.100.v20081224-1728) "ECF
Updatesite Example Client" [Starting]
org.eclipse.ecf.examples.updatesite.server (1.0.100.v20081224-1728) "ECF
Updatesite Example Server" [Starting]
org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer API"
[Active]
org.eclipse.ecf.filetransfer.ui (1.4.0.v20081224-1728) "ECF File Transfer
UI" [Starting]
org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API" [Active]
org.eclipse.ecf.presence (1.4.0.v20081224-1728) "ECF Presence API"
[Starting]
org.eclipse.ecf.presence.bot (1.2.0.v20081224-1728) "ECF Presence Bot API"
[Starting]
org.eclipse.ecf.presence.collab.ui (1.2.0.v20081224-1728) "ECF Presence
Collaboration UI" [Active]
org.eclipse.ecf.presence.ui (1.2.0.v20081224-1728) "ECF Presence UI"
[Starting]
org.eclipse.ecf.protocol.bittorrent (0.3.0) "ECF BitTorrent Protocol
Implementation" [Resolved]
org.eclipse.ecf.protocol.msn (1.2.0.v20081224-1728) "ECF MSN Protocol
org.eclipse.ecf.provider (1.3.0.v20081224-1728) "ECF Provider API" [Active]
org.eclipse.ecf.provider.bittorrent (0.3.100.v20081224-1728) "ECF
Bittorrent Provider" [Active]
org.eclipse.ecf.provider.bittorrent.ui (0.2.0.v20081224-1728) "ECF
Bitorrent Provider UI" [Starting]
org.eclipse.ecf.provider.datashare (1.3.0.v20081224-1728) "ECF Datashare
Provider" [Starting]
org.eclipse.ecf.provider.discovery (2.1.100.v20081224-1728) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.efs (1.5.0.v20081224-1728) "ECF EFS
Provider" [Active]
org.eclipse.ecf.provider.filetransfer.scp (2.0.0.v20081224-1728) "ECF SCP
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.irc (1.3.0.v20081224-1728) "ECF IRC Provider"
[Active]
org.eclipse.ecf.provider.irc.ui (1.3.0.v20081224-1728) "ECF IRC UI"
[Starting]
org.eclipse.ecf.provider.jmdns (2.1.0.v20081224-1728) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.jslp (2.1.0.v20081224-1728) "ECF SLP Discovery
Provider" [Active]
org.eclipse.ecf.provider.msn (1.2.0.v20081224-1728) "ECF MSN Provider"
[Active]
org.eclipse.ecf.provider.msn.ui (1.3.0.v20081224-1728) "ECF MSN Provider
UI" [Starting]
org.eclipse.ecf.provider.r_osgi (2.0.100.v20081224-1728) "ECF R-OSGi
Remoteservice Provider" [Active]
org.eclipse.ecf.provider.remoteservice (1.3.100.v20081224-1728) "ECF
RemoteService Provider" [Starting]
org.eclipse.ecf.provider.ui (1.3.0.v20081224-1728) "ECF Provider UI"
[Starting]
org.eclipse.ecf.provider.xmpp (2.0.100.v20081224-1728) "ECF XMPP Provider"
[Active]
org.eclipse.ecf.provider.xmpp.ui (2.1.0.v20081224-1728) "ECF XMPP Provider
UI" [Starting]
org.eclipse.ecf.remoteservice (2.0.0.v20081224-1728) "ECF RemoteService
API" [Starting]
org.eclipse.ecf.remoteservice.ui (2.0.0.v20081224-1728) "ECF Remote
Services UI" [Starting]
org.eclipse.ecf.server (1.3.0.v20081224-1728) "ECF Server API" [Starting]
org.eclipse.ecf.server.generic (1.2.1.v20081224-1728) "ECF Generic Server"
[Starting]
org.eclipse.ecf.sharedobject (1.3.100.v20081224-1728) "ECF Sharedobject
API" [Active]
org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication
Framework (ECF)" [Resolved]
org.eclipse.ecf.storage (1.0.0.v20081224-1728) "ECF Storage Plug-in"
[Active]
org.eclipse.ecf.sync (1.0.0.v20081224-1728) "ECF Synchronization API"
[Starting]
org.eclipse.ecf.telephony.call (1.3.0.v20081224-1728) "ECF Telephony Call
API" [Starting]
org.eclipse.ecf.telephony.call.ui (1.2.0.v20081224-1728) "ECF Call UI"
[Starting]
org.eclipse.ecf.ui (2.0.0.v20081224-1728) "ECF UI" [Starting]
org.eclipse.emf (2.4.0.v200902171115) "EMF - Eclipse Modeling Framework"
[Starting]
org.eclipse.emf.ant (2.4.0.v200902171115) "EMF Ant Tasks" [Starting]
[Starting]
Generator" [Starting]
Generator UI" [Starting]
[Starting]
org.eclipse.emf.common (2.4.0.v200902171115) "EMF Common" [Starting]
org.eclipse.emf.common.ui (2.4.0.v200902171115) "EMF Common UI" [Starting]
org.eclipse.emf.converter (2.4.0.v200902171115) "EMF Model Converter"
[Starting]
[Starting]
Binding" [Starting]
org.eclipse.emf.ecore (2.4.2.v200902171115) "EMF Ecore" [Starting]
org.eclipse.emf.ecore.change (2.4.0.v200902171115) "EMF Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.4.0.v200902171115) "EMF Change Edit"
[Starting]
[Starting]
Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.4.1.v200902171115) "EMF XML/XMI Persistence"
[Starting]
org.eclipse.emf.edit (2.4.2.v200902171115) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.4.2.v200902171115) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.4.0.v200902171115) "EMF Model Exporter"
[Starting]
org.eclipse.emf.importer (2.4.1.v200902171115) "EMF Model Importer"
[Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200902171115) "EMF Ecore Importer"
[Starting]
org.eclipse.emf.importer.java (2.4.1.v200902171115) "EMF Annotated Java
Importer" [Starting]
org.eclipse.emf.importer.rose (2.4.0.v200902171115) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.4.0.v200902171115) "EMF Mapping" [Starting]
[Starting]
Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.4.0.v200902171115) "EMF Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200902171115) "EMF
Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.4.0.v200902171115) "EMF Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.4.0.v200902171115) "EMF Ecore to
XML Mapping Editor" [Starting]
[Starting]
org.eclipse.emf.mint.ui.source (0.7.1.v200809162149) "Mint UI (Incubation)
Source" [Resolved]
org.eclipse.emf.ocl (1.1.101.v200808291106) "Object Constraint Language
(OCL) 2.0 Compatibility API" [Starting]
org.eclipse.emf.query (1.2.0.v200805130238) "EMF Model Query" [Starting]
org.eclipse.emf.query.ocl (1.2.0.v200805130238) "EMF Model Query OCL
org.eclipse.emf.search (0.7.0.v200806130939) "Model Search Core
org.eclipse.emf.search.common (0.7.0.v200806130939) "Model Search Common
org.eclipse.emf.search.common.ui (0.7.0.v200806130939) "Model Search
Common Ui (Incubation)" [Starting]
Search (Incubation)" [Starting]
org.eclipse.emf.search.ecore.ocl.ui (0.7.0.v200806130939) "OCL Model
Search Ui (Incubation)" [Starting]
org.eclipse.emf.search.ecore.ui (0.7.0.v200806130939) "Ecore Model Search
org.eclipse.emf.search.ocl.ui (0.7.0.v200806130939) "Ecore Model Search
OCL Ui (Incubation)" [Starting]
org.eclipse.emf.search.ui (0.7.0.v200806130939) "Model Search Ui
org.eclipse.emf.transaction (1.2.1.v200807161719) "EMF Model Transaction
Core" [Starting]
org.eclipse.emf.transaction.ui (1.2.0.v200805130238) "EMF Model
Transaction UI" [Starting]
org.eclipse.emf.validation (1.2.0.v200807161729) "EMF Validation Framework
Core" [Starting]
org.eclipse.emf.validation.ocl (1.2.0.v200805130238) "EMF Validation
Framework OCL Integration" [Resolved]
org.eclipse.emf.validation.ui (1.2.0.v200805130238) "EMF Validation
Framework UI" [Starting]
org.eclipse.emf.validation.ui.ide (1.2.0.v200805130238) "EMF Validation
Framework UI IDE" [Starting]
org.eclipse.emf.workspace (1.2.3.v200902100421) "EMF Model Transaction
Workbench Integration Core" [Starting]
org.eclipse.emf.workspace.ui (1.2.0.v200805130238) "EMF Model Transaction
Workbench Integration UI" [Starting]
org.eclipse.epp.usagedata.gathering (1.0.1.R200809220400) "Usage Data
Gathering Plug-in" [Starting]
org.eclipse.epp.usagedata.recording (1.0.1.R200809220400) "Usage Data
Recording Plug-in" [Starting]
org.eclipse.epp.usagedata.ui (1.0.1.R200809220400) "Usage Data UI Plug-in"
[Starting]
org.eclipse.equinox.app (1.1.0.v20080421-2006) "Equinox Application
Container" [Active]
org.eclipse.equinox.app.source (1.1.0.v20080421-2006) "Equinox Application
Container Source" [Resolved]
org.eclipse.equinox.cm (1.0.1.R34x_v20090107-1200) "Configuration Admin"
[Resolved]
org.eclipse.equinox.cm.source (1.0.1.R34x_v20090107-1200) "Configuration
Admin Source" [Resolved]
org.eclipse.equinox.common (3.4.0.v20080421-2006) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.common.source (3.4.0.v20080421-2006) "Common Eclipse
Runtime Source" [Resolved]
org.eclipse.e
Re: Ganymede & Mylyn [message #67039 is a reply to message #66855] Wed, 18 March 2009 23:18 Go to previous messageGo to next message
*** User Preferences:
#Wed Mar 18 20:19:23 PDT 2009
/instance/org.eclipse.core.resources/description.filestatelo ngevity=1209600000
/project/trunk/org.eclipse.wst.html.core/attrInvalidName=2
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/file\:_C\:_Documents\
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/version=1.0.0
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/url=file\:/C\:/Docu ments
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/69/data/listener_1925729951/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/enabled =true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/file\:_C\:_Documents\
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/type=org.eclipse.equinox.internal.p2.metada ta.repository.LocalMetadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/name=artifact
listener file\:/C\:/Documents and
Settings/Dennis/Desktop/eclipse/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="tag"
name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info >\r\n<info
extension\="adapter" name\="*">\r\n<editor
id\=" org.eclipse.hyades.logging.adapter.ui.internal.presentation. AdaptorEditorID "/>\r\n</info>\r\n<info
extension\="shtml" name\="*">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info
extension\="cfm" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n</info>\r\n <info
extension\="umldeployment_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgraph" name\="*">\r\n<editor
id\="org.eclipse.gmf.gmfgraph.presentation.GMFGraphEditorID "/>\r\n</info>\r\n<info
extension\="cspec" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n </info>\r\n<info
extension\="tagf" name\="*">\r\n<editor
extension\="umlusc" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlclass" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlstm" name\="*">\r\n<editor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n<defaultEditor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n</info>\r\n<info
extension\="itcl" name\="*">\r\n<editor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n</info >\r\n<info
extension\="js" name\="*">\r\n<editor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n <defaultEditor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n </info>\r\n<info
extension\="gmfmap" name\="*">\r\n<editor
id\="org.eclipse.gmf.mappings.presentation.GMFMapEditorID"/ >\r\n</info>\r\n<info
extension\="sqlpage" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<defaultEditor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n</info>\r\n<info
extension\="jsp" name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n </info>\r\n<info
extension\="cspex" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n </info>\r\n<info
extension\="override" name\="*">\r\n<editor
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info >\r\n<info
extension\="tagx" name\="*">\r\n<editor
extension\="umlprofile_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgen" name\="*">\r\n<editor
id\="org.eclipse.gmf.codegen.gmfgen.presentation.GMFGenEditorID "/>\r\n</info>\r\n<info
extension\="jspx" name\="*">\r\n<editor
extension\="properties" name\="sample">\r\n<editor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info
extension\="class" name\="*">\r\n<editor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n <defaultEditor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n </info>\r\n<info
extension\="jspf" name\="*">\r\n<editor
extension\="umlcsd" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n</info>\r\n<info
extension\="gmftool" name\="*">\r\n<editor
id\="org.eclipse.gmf.tooldef.presentation.GMFToolEditorID"/ >\r\n</info>\r\n<info
extension\="trcpxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCProcessEdito r "/>\r\n</info>\r\n<info
extension\="cfc" name\="*">\r\n<editor
extension\="tcl" name\="*">\r\n<editor
extension\="usr" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.propertysheet.UserEditor"/>\r\n </info>\r\n<info
extension\="umlusecase_diagram" name\="*">\r\n<editor
extension\="xpt" name\="*">\r\n<editor
id\="org.eclipse.gmf.xpand.XpandEditor"/>\r\n</info>\r\n <info
extension\="umlactivity_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="readme" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.readmetool.ReadmeEditor"/>\r\n </info>\r\n<info
extension\="cfml" name\="*">\r\n<editor
extension\="umlclass_diagram" name\="*">\r\n<editor
extension\="test" name\="*">\r\n<editor
extension\="trcnxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCNodeEditor "/>\r\n</info>\r\n<info
extension\="sql" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<editor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<defaultEditor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n</info >\r\n<info
extension\="exp" name\="*">\r\n<editor
extension\="umldepl" name\="*">\r\n<editor
extension\="jpage" name\="*">\r\n<editor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info
extension\="umlstatemachine_diagram" name\="*">\r\n<editor
extension\="ddl" name\="*">\r\n<editor
extension\="html" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n <editor
extension\="htm" name\="*">\r\n<editor
extension\="mpe" name\="*">\r\n<editor
id\=" org.eclipse.ui.examples.multipageeditor.MultiPageEditorExamp le "/>\r\n</info>\r\n<info
extension\="jsf" name\="*">\r\n<editor
extension\="umlcomponent_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="xml" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n<editor
id\=" org.eclipse.ui.examples.templateeditor.editors.TemplateEdito r "/>\r\n</info>\r\n<info
extension\="rb" name\="*">\r\n<editor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n</info >\r\n<info
extension\="spirit" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n</info>\r\n<info
extension\="symptom" name\="*">\r\n<editor
id\=" org.eclipse.tptp.symptom.internal.presentation.SymptomEditor "/>\r\n</info>\r\n<info
extension\="umlcompositestructures_diagram" name\="*">\r\n<editor
extension\="ecore_diagram" name\="*">\r\n<editor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n <defaultEditor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n </info>\r\n<info
extension\="trcaxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCAgentEditor "/>\r\n</info>\r\n<info
extension\="xhtml" name\="*">\r\n<editor
extension\="probe" name\="*">\r\n<editor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n<defaultEditor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n</info>\r\n<info
extension\="rmap" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n </info>\r\n<info
extension\="jav" name\="*">\r\n<editor
id\="org.eclipse.ui.JavaEditor"/>\r\n</info>\r\n<info extension\="xotcl"
extension\="umlcomp" name\="*">\r\n<editor
extension\="cquery" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n </info>\r\n<info
extension\="umlact" name\="*">\r\n<editor
extension\="pda" name\="*">\r\n<editor id\="pda.editor"/>\r\n<editor
id\="pda.editor"/>\r\n<defaultEditor
id\="pda.editor"/>\r\n</info>\r\n<info extension\="jardesc"
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info
extension\="trcmxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCMonitorEdito r "/>\r\n</info>\r\n<info
extension\="server" name\="*">\r\n<editor
id\="org.eclipse.wst.server.ui.editor"/>\r\n</info>\r\n <info
extension\="trcdbxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.sdb.internal.editors.SymptomDBEditor "/>\r\n</info>\r\n</editors>
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.wst.sse.core/task-tags/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=The
Eclipse Project Updates
/instance/org.eclipse.wst.jsdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes_/isSystem=false
@org.eclipse.dltk.mylyn=0.95.1.v20080903-1434
/instance/org.eclipse.core.resources/description.maxfilestat es=100
@org.eclipse.wst.sse.core=1.1.303.v200901290024
/instance/org.eclipse.ui.editors/changeIndicationInOverviewR uler=true
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby.genericDriverTemplate=true
/instance/org.eclipse.mylyn.context.core/mylyn.attention.mig rated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags =TODO
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskPriorities=NORMAL,HIGH,NORMAL
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.fo rmatterprofiles.version=11
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.metadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/enabled=true
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/name=artifact
listener dropins
@org.eclipse.jdt.core=3.4.4.v_894_R34x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/enabled=false
/instance/org.cfeclipse.cfml/SQLTextColor=91,249,174
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/type=org.eclip se.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/63/data/listener_-205926309/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/url=http\://download.eclipse.org/technology/epp/updates/1.0/
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.ord er.connections=sagan.Local
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/name=download
cache
/project/trunk/org.eclipse.wst.html.core/piInvalidContent=2
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/url=file\:/C\:/Documents
and Settings/Dennis/Desktop/eclipse/p2/org.eclipse.equinox.p2.co re/cache/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/url= http\://download.eclipse.org/tools/gef/update-site/releases/ site.xml
@org.eclipse.wst.jsdt.core=1.0.104.v200901281939
/instance/org.cfeclipse.cfml/cfnumberColor=226,194,148
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/enabled=false
/project/trunk/org.eclipse.wst.html.core/elemEndInvalidCase= 1
/instance/org.eclipse.wst.sse.ui/matchingBracketsColor=255,0 ,128
/instance/org.cfeclipse.cfml/cfstringColor=191,205,240
and\
Settings_Dennis_Desktop_eclipse_.eclipseextension/url=file\: /C\:/Documents
and Settings/Dennis/Desktop/eclipse/.eclipseextension
/instance/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=alway s
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/version =1
/instance/org.eclipse.dltk.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.dltk.ruby.ui/useAnnotationsPrefPage=tr ue
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/url=file\ :/C\:/Documents
and Settings/Dennis/Desktop/Ganymede/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/url=http\://www.eclipse.org/mylyn/downloads/
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.org_tptp_updates_/enabled=false
/instance/org.eclipse.compare/StructureViewerAliases=CLASSPA TH.XML
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
and\ Settings_Dennis_Desktop_eclipse/description=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskCaseSensitive=enabled
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/enabled=false
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .url=local
/project/trunk/org.eclipse.wst.html.core/cdataInvalidContent =2
@org.eclipse.jst.j2ee.webservice.ui=1.1.201.v200811062130
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.equinox.p2.ui.sdk/enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.eclipse.core.resources/version=1
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/url=http\://download.eclipse.org/tools/buckminster/updates
@org.eclipse.wst.jsdt.ui=1.0.104.v200901290004
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/version=1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /isSystem=false
/project/trunk/org.eclipse.wst.html.core/elemInvalidDirectiv e=1
/instance/org.eclipse.dltk.core/editor_folding_enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/de scription=
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.ge ttersetter.use.is=true
/instance/org.eclipse.jdt.ui/content_assist_favorite_static_ members=
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/name=metadata
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/isS ystem=false
@org.eclipse.rse.ui=3.0.3.v200902042310
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/na me=Ganymede
Update Site
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndAddLi ne=false
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby102.genericDriverTemplate=true
/project/trunk/org.eclipse.wst.html.core/attrNameMismatch=2
/instance/org.eclipse.jdt.ui/fontPropagated=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/name=Mylyn
for Eclipse 3.4
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/description=
/instance/org.eclipse.core.runtime/content-types/org.eclipse .wst.html.core.htmlsource/file-extensions=cfm,cfc,cfml
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/enabled=false
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jst.j2ee.navigator.ui.java.resource.decorator\:true,or g.eclipse.jst.jee.navigator.ui.java.resource.decorator\:true ,org.eclipse.team.pessimistic.ui.decorator\:true,org.eclipse .wst.server.ui.decorator\:false,org.cfeclipse.cfml.ui.decora tors.cfcdecorator\:true,org.cfeclipse.cfml.ui.decorators.cfe readonlydecorator\:true,org.eclipse.cdt.ui.indexedFiles\:fal se,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.DependencyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.ColumnDecoration\:tr ue,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.ForeignKeyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.IndexTriggerDecorati on\:true,org.eclipse.datatools.connectivity.internal.core.ui .bookmarkDecoration\:true,org.eclipse.datatools.connectivity .internal.core.ui.FilterNodeDecoration\:true,org.eclipse.dat atools.connectivity.ui.decorator.contentextension\:false,org .eclipse.datatools.enablement.sybase.asa.proxytabledecorator \:true,org.eclipse.datatools.enablement.sybase.ase.webservic etabledecorator\:true,org.eclipse.datatools.enablement.sybas e.systemtabledecorator\:true,org.eclipse.dd.ipxact.editor.ui .decorators.DuplicateDecorator\:true,org.eclipse.dltk.ruby.p rojectdecorator\:true,org.eclipse.dltk.tcl.decorators.projec tdecorator\:true,org.eclipse.jdt.ui.override.decorator\:true ,org.eclipse.jdt.ui.interface.decorator\:false,org.eclipse.j st.j2ee.internal.ui.util.AnnotationIconDecorator_ejb\:true,o rg.eclipse.jst.j2ee.navigator.internal.J2EEProjectDecorator\ :true,org.eclipse.jst.jee.ui.internal.navigator.ejb.BeanDeco rator\:true,org.eclipse.jst.jee.navigator.internal.JEEProjec tDecorator\:true,org.eclipse.jst.j2ee.internal.ui.util.Annot ationIconDecorator_servlet\:true,org.eclipse.mylyn.context.u i.decorator.interest\:true,org.eclipse.mylyn.tasks.ui.decora tors.task\:true,org.eclipse.mylyn.team.ui.changeset.decorato r\:true,org.eclipse.nab.mwt.ab.core.MwtManageSourceDecorator \:true,org.eclipse.pde.ui.binaryProjectDecorator\:false,org. eclipse.rse.core.virtualobject.decorator\:true,org.eclipse.r se.core.binary.executable.decorator\:true,org.eclipse.rse.co re.script.executable.decorator\:true,org.eclipse.rse.core.ja va.executable.decorator\:true,org.eclipse.rse.core.library.d ecorator\:true,org.eclipse.rse.core.link.decorator\:true,org .eclipse.rse.subsystems.error.decorator\:true,org.eclipse.te am.cvs.ui.decorator\:true,org.eclipse.tptp.monitoring.manage dagent.views.browser.decorator\:true,org.eclipse.ui.LinkedRe sourceDecorator\:true,org.eclipse.ui.ContentTypeDecorator\:t rue,org.eclipse.wst.jsdt.ui.override.decorator\:true,org.ecl ipse.wst.jsdt.ui.interface.decorator\:false,
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/isSystem=false
/instance/org.eclipse.dltk.ui/editor_folding_enabled=true
@org.eclipse.ui=3.4.2.M20090204-0800
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/version=1.0.0
/instance/org.eclipse.wst.jsdt.ui/content_assist_category_or der=org.eclipse.wst.jsdt.ui.templateProposalCategory\:0\u000 0org.eclipse.wst.jsdt.ui.javaNoTypeProposalCategory\:1\u0000 org.eclipse.wst.jsdt.ui.textProposalCategory\:2\u0000
/project/trunk/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_nab_updates/isS ystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/version=1
/instance/org.cfeclipse.cfml/CFUnitFacadeLocation=localhost\ :82/net/sourceforge/cfunit/framework
/instance/org.eclipse.wst.ws.service.policy/org.eclipse.wst. ws.service.policy.ui.servicepols.wsiprofilecomp.wsissbp.defa ultProtocol=http\://schemas.xmlsoap.org/wsdl/soap/
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndTrim= true
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.timeoutForParameterNameFromAttachedJavadoc=50
/instance/org.cfeclipse.cfml/htmFormTagColor=255,255,128
and\ Settings_Dennis_Desktop_eclipse/suffix=artifacts.xml
/project/trunk/org.eclipse.wst.html.core/docInvalidContent=2
@org.eclipse.dltk.core=0.95.1.v20080920-R0951
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/name=C\:\\ Documents
and Settings\\Dennis\\Desktop\\eclipse\\.eclipseextension
@org.eclipse.birt.report.data.oda.jdbc.ui=2.3.2.r232_v200902 11
/instance/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=file\:/builds/M/org.eclipse.releng.eclipsebuilder/../sr c/repo
- artifacts
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /url=http\://download.eclipse.org/birt/update-site/2.3
/instance/org.cfeclipse.cfml/cfscriptfunctionColor=255,255,0
/instance/org.eclipse.wst.jsdt.ui/useAnnotationsPrefPage=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/isSystem=false
/instance/org.eclipse.birt.report.designer.ui/Palette\ Size=125
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/url=file\:/C\:/Docum ents
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/63/data/listener_-177846376/
/project/trunk/de.loskutov.anyedit.AnyEditTools/removeTraili ngSpaces=true
/instance/org.eclipse.ui/defaultPerspectiveId=org.cfeclipse. cfml.perspective.CFML
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/descripti on=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_webtools_updates/typ e=org.eclipse.equinox.internal.p2.metadata.repository.LocalM etadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/url=http\://andrei.gmxhome.de/eclipse/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_dd_updates/url=http\://download.eclipse.org/dsdp/dd/updates
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/url=http\://download.eclipse.org/modeling/emft/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/isSystem=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.bracketMatchin gStyle=0
/project/PROD/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.cfeclipse.org_update/url=http\://www.cfeclipse.org/update
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/isSystem=true
/project/PROD/de.loskutov.FileSync/defaultVariables=
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/isSystem= true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/url= http\://download.forge.objectweb.org/eclipse-update/site.xml
/project/trunk/org.eclipse.wst.html.core/elemUnclosedEndTag= 1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951/provider=
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/isSystem=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/69/data/listener_1925729951/
/instance/org.eclipse.dltk.mylyn/org.eclipse.dltk.mylyn.ui.f irst.run=false
@org.eclipse.mylyn.resources.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/project/trunk/org.eclipse.wst.html.core/cdataUnclosed=1
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.inter nal.ui.navigator.layout=1
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/version=1.0.0
/instance/org.cfeclipse.cfml/cfscriptStringColor=116,237,204
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates _/isSystem=false
/instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=never
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emf_updates _/isSystem=false
and\ Settings_Dennis_Desktop_eclipse/provider=
/instance/org.cfeclipse.cfml/cfeclipse.editor.showToolbar=tr ue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s_/isSystem=false
/configuration/org.eclipse.core.net/org.eclipse.core.net.has Migrated=true
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .kind=local
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates _/isSystem=false
/instance/org.tigris.subversion.subclipse.ui/pref_merge_use_ external=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/isSystem=t rue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/url=http\://andrei.gmxhome.de/eclipse/
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/Search\
for\ Contacts.\ Code/comment=Incomplete - taskSearch for Contacts. Code \n
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigra ted=true
and\ Settings_Dennis_Desktop_Ganymede/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/name=http\://andrei.gmxhome.de/eclipse/
/project/PROD/de.loskutov.FileSync/useCurrentDateForDestinat ionFiles=false
/project/trunk/org.eclipse.wst.html.core/elemMissingStart=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.artifactRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/url=http\://download.eclipse.org/tools/mylyn/update/e3.4
and\ Settings_Dennis_Desktop_Ganymede/suffix=artifacts.xml
/instance/org.eclipse.jst.jsp.core/org.eclipse.jst.jsp.core. taglib.TaglibIndex=CLEAN
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates /isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /enabled=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/provider=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_stp_updates_/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.te xt.custom_templates= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/isSystem=false
/instance/org.cfeclipse.cfml/unknowTagColors=151,255,177
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_gmf_updates _releases_/url=http\://download.eclipse.org/modeling/gmf/updates/releases/
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/isSystem=true
/project/trunk/org.eclipse.wst.html.core/elemInvalidContent= 2
/project/trunk/org.eclipse.wst.html.core/docDoctypeUnclosed= 1
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/name=download
cache
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.codeComplete.visibilityCheck=enabled
/project/trunk/de.loskutov.anyedit.AnyEditTools/replaceAllSp aces=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/type=org.eclipse.eq uinox.internal.p2.metadata.repository.LocalMetadataRepositor y
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/descrip tion=
/instance/org.cfeclipse.cfml/stringColor=188,224,152
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_mylyn_downloads_/url=http\://www.eclipse.org/mylyn/downloads/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/description=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/enabled=true
/instance/org.cfeclipse.cfml/SQLKeywordColor=159,205,232
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/url=file\:/C\:/Documents
and
Settings/Dennis/Desktop/Ganymede/p2/org.eclipse.equinox.p2.d irector/rollback
/project/trunk/org.eclipse.wst.html.core/elemCoexistence=2
/instance/org.eclipse.rse.core/org.eclipse.rse.systemtype.lo cal.systemType.defaultUserId=Dennis
/instance/org.cfeclipse.cfml/cfscriptKeywordColor=131,189,22 4
and\
Settings_Dennis_Desktop_Ganymede/type=org.eclipse.equinox.p2 .artifact.repository.simpleRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/enabled=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/isSystem=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/url=http\://download.eclipse.org/technology/dltk/updates/
/instance/org.eclipse.wst.sse.ui/hoverModifiers=combinationH over|true|0;problemHover|false|0;documentationHover|false|0; annotationHover|true|Shift;
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/url=http\://download.eclipse.org/technology/emft/updates/
/instance/org.tigris.subversion.subclipse.ui/pref_merge_prog ram_location=C\:\\Program
Files\\Compare It\!\\wincmp3.exe
/instance/org.eclipse.jdt.ui/content_assist_proposals_foregr ound=0,0,0
@org.eclipse.ui.editors=3.4.0.v20080603-2000
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ url=http\://download.eclipse.org/eclipse/updates/3.4
/instance/org.eclipse.jst.j2ee.webservice.ui/areThereWebServ ices=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/url=http\://download.eclipse.org/tools/cdt/releases/ganymede
/project/trunk/de.loskutov.FileSync/useCurrentDateForDestina tionFiles=false
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.ui. perspectives.task.none=org.cfeclipse.cfml.perspective.CFML
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/descriptio n=
@org.eclipse.cdt.ui=5.0.2.200902130801
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/is System=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.warnReadOnlyFi les=false
/instance/org.eclipse.wst.jsdt.ui/proposalOrderMigrated=true
@org.eclipse.mylyn.java.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/defaultSet=Search
for Contacts. Code
/instance/org.eclipse.ui.ide/platformState=1236880094838
and\
Settings_Dennis_Desktop_eclipse/type=org.eclipse.equinox.p2. artifact.repository.simpleRepository
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.6
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/type=org.eclipse.equinox.internal.p2.metadata.rep ository.LocalMetadataRepository
@org.eclipse.team.cvs.ui=3.3.100.r34x_20090121
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.svnkit.com_1.2.x_/type=org.eclips e.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/provider=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/project/trunk/org.eclipse.wst.html.core/attrInvalidValue=2
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/project/trunk/org.eclipse.wst.html.core/elemMissingEnd=2
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =3
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/version=1
/project/trunk/org.eclipse.wst.html.core/elemUnnecessaryEnd= 2
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/isSystem=false
/project/trunk/org.eclipse.wst.html.core/piUnclosed=1
/instance/org.cfeclipse.cfml/cftagColor=131,173,252
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/instance/org.eclipse.team.core/changeSets/CVS\
Workspace/defaultSet=Search for Contacts. Code
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/description=
@org.eclipse.cdt.mylyn.ui=5.0.1.200902130801
/instance/org.cfeclipse.cfml/cfscriptTextColor=255,128,128
/project/trunk/org.eclipse.wst.html.core/attrValueMismatch=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates/ena bled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/type=org.eclipse.equ inox.p2.artifact.repository.simpleRepository
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPrio rities=normal
and\ Settings_Dennis_Desktop_Ganymede/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/provide r=
/project/trunk/org.eclipse.wst.html.core/elemInvalidName=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/url=http\://download.eclipse.org/tools/mylyn/update/extras
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/type=org.eclipse.equinox.internal.p2.metadata.reposito ry.LocalMetadataRepository
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
standalone\="no"?>\r\n<launchPerspectives/>\r\n
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/name=C\:\ \Documents and
Settings\\Dennis\\Desktop\\Ganymede\\.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ty pe=org.eclipse.equinox.p2.artifact.repository.simpleReposito ry
@org.eclipse.jst.jsp.core=1.2.121.v200901290830
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/enabled=true
/instance/org.eclipse.epp.usagedata.recording/org.eclipse.ep p.usagedata.recording.last-upload=1236892187523
@org.eclipse.team.core=3.4.2.r34x_20080115
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/url =http\://download.eclipse.org/webtools/updates
and\ Settings_Dennis_Desktop_eclipse/version=1.0.0
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.cfeclipse.cfml/currentLineColor=95,95,95
/instance/org.eclipse.mylyn.monitor.ui/org.eclipse.mylyn.mon itor.user.activity.enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/enabled=t rue
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_dsdp_tm_updates_3.0/ isSystem=false
and\
/project/trunk/org.eclipse.wst.html.core/elemUnclosedStartTa g=1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/isSystem=true
/project/trunk/org.eclipse.wst.html.core/commentUnclosed=1
/instance/org.eclipse.jdt.ui/spelling_locale_initialized=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/name=http\://eclipse.svnkit.com/1.2.x/
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1236894838136 ">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1236894838136" javadocURL\="http\://java.sun.com/javase/6/docs/api/"
name\="jre1.6.0_04" path\="C\:\\Program
Files\\Java\\jre1.6.0_04"/>\r\n</vmType>\r\n</vmSettings >\r\n
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/enabled=false
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/name=file\:/User s/markdrew/Documents/Eclipse_Workspaces/cfeclipse2/org.cfecl ipse.cfml.update/
- artifacts
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/provider=
/instance/org.eclipse.mylyn.java.ui/org.eclipse.mylyn.ui.fir st.run.0_4_9=false
/instance/org.eclipse.equinox.p2.ui.sdk/download=true
/project/trunk/de.loskutov.FileSync/defaultVariables=
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.con text.ui.close.action.manage.warning=false
and\
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/ur l=http\://www.eclipse.org/modeling/emft/updates/
/instance/org.eclipse.wst.sse.ui/foldingEnabled=true
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/enabled=true
and\ Settings_Dennis_Desktop_Ganymede/url=file\:/C\:/Documents and
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/provider=
Re: Ganymede & Mylyn [message #67054 is a reply to message #66855] Wed, 18 March 2009 23:19 Go to previous messageGo to next message
*** Current Install Configuration:
Install configuration:
Last changed on Mar 18, 2009
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.u pdate/platform.xml
Configured sites:
platform:/base/
file:/C:/Documents and Settings/Dennis/Desktop/Ganymede/
Configured features:
ID: org.eclipse.dd.dsf.gdb_launch, Version: 1.0.0.v20080609
2.3.2.r232_v20081010-7_7D79_doT2uMPVNwOGoz0HKuyI8
ID: org.eclipse.buckminster.cvs, Version: 1.0.0.r09930
2.3.2.r232_v20081010-4538k797M733K3737
ID: org.eclipse.nab.mwt.native, Version: 0.9.9.200806181757
1.2.0.v200805130238-11-7w311916241349
3.4.1.R342_v20090126-7w7TENgETuNblxYRhBOLydU3ADDC
1.6.2.v200810071455-3019oA55U6_7H6KAC
ID: org.eclipse.ecf.example.collab, Version: 2.1.0.v20081224-1728
ID: com.lowagie.itext, Version: 1.5.4.v20080225-1437w31191339
3.4.2.R342_v20090122-7O7S7GApJ3_vCyk7ETmsfcmjhz0eHnqw7MIjk9V dhe4Ic
ID: org.eclipse.emf.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.uml2tools.examples, Version: 0.8.0.v200809231457
ID: org.mx4j.jmx, Version: 4.4.100.v200901090956-3-37w311_12211211
1.0.0.v20080115-5318xB6CE899P233613552
1.6.2.v200810071455-443_kE77d7OAPAMJQ
1.0.2.r34x_v20090120-7d-7tEQcCaaYSBeNOClOn02267
1.6.2.v200810071455-1507w31191939244824
2.0.3.v200902181600-7J-7EB-NLwTYlTNN4PlbFLKRNHYG
2.3.2.r232_v20081010-7k8E7fELFluav5n_2NEXh3W6B9_
0.95.1.v20080626-2043-08T07w31191_1402545
2.3.2.r232_v20090212-2217s343A311_1313
ID: org.tigris.subversion.clientadapter, Version: 1.5.3
3.0.0.v20080530-7N-E8ME8McIJXIwdh
2.3.2.r232_v20081010-2217s343Aw31192216
1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE
1.6.2.v200810071455-1-07w311_12281248
1.2.0.v200805130238-35-9oA55S5L8G6FCT
3.0.4.v200812040936-7A7NEH2E7QYGHOIsNrGpVX
3.0.4.v200811261813-7H7QECiED69XqLgwowgm-47C5J
1.5.2.v200809302010-1407w311917141519
2.1.1.v200809041200-4118s733I3J4F5C48
ID: org.eclipse.emf.common, Version: 2.4.0.v200902171115
1.6.2.v200810071455-25184B23NbbGK_OXQXHz-QP
ID: org.eclipse.uml2.search.runtime, Version: 0.7.0.v200806130939
4.4.200.v200901090956-43_77w311_121_1_67
3.0.3.v200810010400-42E_4_kE77c_FAP7X99
3.0.4.v200811211541-7F2ENnCwum8W79A1UYNgSjOcFVJg
1.1.0.v20080731-1518-7K8V4EFp_acwc90fc4fP
ID: org.apache.commons.codec, Version: 1.3.0.v20070920-12-7w3119164102711
0.95.1.v20080626-2043-0EEJ77E9IgKLhLeUz0ALs1x5
2.3.2.r232_v20081010-7N7Y7MAIe2QJZSgfOaAphGBR4t7b
ID: org.eclipse.emf.ecore.editor, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.mint.doc, Version: 0.7.1.v200809162149
ID: org.tigris.subversion.subclipse.graph, Version: 1.0.5
3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL
1.6.2.v200810071455-7D47FEB7sQSBV7hXWQ6R
1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK
ID: org.tigris.subversion.subclipse.core, Version: 1.4.8
ID: org.eclipse.emf.codegen.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.emf.databinding, Version: 1.0.0.v200902171115
3.0.4.v20090115-791DC9vETDnvTGSaCQNM76BD
2.0.2.v200811110900-2-17w311922221_11
ID: org.eclipse.uml2.source, Version: 2.2.2.v200902101430
1.1.2.v20080916-2008-2108s733I3E4F15B59
1.6.2.v200810071455-6--BcMAB-BKFVEmLF
4.3.200.v200812160100-42_77w311923271211
3.4.2.v20090218-1145-67738084A6665K366B84__58x422
1.1.0.v20080716-1600-2-Ag8s733I3A7C15KCK
1.0.1.r34x_v20080721-7Y-7hEMrtGZhTrQ--t43w02267
1.6.2.v200810071455-502AgI99mASCdBYCN
0.95.1.v20080626-2043-0ECq6E8McIJXJUOr9upp-2
4.5.0.v200805132041-44-7w311916271211
2.1.0.v20090128-3219oA55U5D7N2532
3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI
1.6.2.v200810071455-7A-5E9IgKLjM1d1Oepu
2.3.2.r232_v20081204-2217s343A311_1233
3.0.4.v200811240900-7R0EP7E8Ks9v7urtuDJtBcaRV6Ri
1.0.1.r34x_v20080721-7T-7cEJ6Wz-YqXOBdehgpS
1.0.0.v20070608-3--8s733G3C5C
ID: org.eclipse.emf.mapping, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.codegen.ecore.ui, Version: 2.4.1.v200902171115
2.1.1.v20080710-7_40AgI99m9d_O
2.1.1.v200809181500-6678AgI99m9W9X5J79
3.3.101.R34x_v20081125-7H-ELfE8hXnkE15Wh9Tnyu
ID: org.apache.derby.core, Version: 10.3.1.4
ID: org.eclipse.uml2.search.common, Version: 0.7.0.v200806130939
ID: org.eclipse.gmf.doc, Version: 1.2.2.v20080916-2008-2218s733H3H4_1673A
3.0.1.v200808091845-108Y7w31191922
1.6.2.v200810071455-3019oA55V599K5M9_
ID: org.eclipse.uml2.search.ocl, Version: 0.7.0.v200806130939
3.0.150.v200901232034-109K7w311_12343145
ID: org.eclipse.emf.edit, Version: 2.4.2.v200902171115
ID: org.eclipse.epp.usagedata.feature, Version: 1.0.1.R200809220400
3.0.3.v200810090336-40EJs_kE77c8P_TALGS
0.95.1.v20080903-1434-0Bw2_kE77c7a9N3BFKL
ID: org.eclipse.emf.converter, Version: 2.4.1.v200902171115
3.0.100.v200901232040-34EEP9oA55T5J7N9BBK
ID: org.eclipse.ocl.uml, Version: 1.2.3.v200811021759-1127w311_12182518
1.6.2.v200810071455-1507w311918132411
1.6.2.v200810071455-57_2_pFAIQJZIsLSXb8MDD
1.6.2.v200810071455-446_kE77d8H_VALOJ
ID: org.eclipse.uml2.examples, Version: 2.2.0.v200805131030
ID: org.eclipse.dd.ipxact, Version: 0.9.0.v20080609
2.3.2.r232_v20081010-67859cADAamA55V5A89
4.5.0.v200805132041-7879-8192A5695E699A2322
2.3.2.r232_v20081010-7D7J7CC7QXRK0ICmcLILD
ID: org.eclipse.emf.common.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.query, Version: 1.2.0.v200805130238-11-7w311916241349
ID: org.eclipse.emf.mapping.ecore.editor, Version: 2.4.0.v200902171115
ID: de.loskutov.eclipse.jdepend, Version: 1.2.1
3.0.3.v200902042310-7J378DUUEFGEpIz-AW8E
ID: org.tmatesoft.svnkit, Version: 1.2.3.5521
3.0.2.v200809102124-2518s733I3G395I75
1.6.2.v200810071455-442_kE77d7N9VANON
1.6.2.v200810071455-440_kE77c7QAQEIQQ
4.4.100.v200901090956-7B78CE9oA55S8A8M5855
3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63
ID: org.eclipse.releng.tools, Version: 3.2.200.v20080603-33-7w31191525
1.6.2.v200810071455-797P78CYQCD5DjGdEURT
1.6.2.v200810071455-6-2BcMAAyBWDkEVSb
3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS
ID: org.eclipse.uml2.doc, Version: 2.2.0.v200805201350
ID: org.eclipse.cvs, Version: 1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
3.4.2.v20090218-1145-67728084A56B4I233613552
3.0.4.v200811251652-7E4EAvDgz-Y1htmiH5158SnFBSiT
3.0.1.v200809171630-78479_kE77c7Q8b8T_F
ID: org.eclipse.mylyn, Version: 3.0.5.v20090218-1800-e3x
ID: org.eclipse.uml2.diagram, Version: 0.8.1.v200809231457
ID: org.eclipse.dd.debug.memory.renderings, Version: 1.0.0.v20080609
1.6.2.v200810071455-7_7K7NDn-QYKjkBKlmD4edYsAX
3.0.4.v200811260650-7Q7AEf1EHhHehNmEARhS7t
1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z
1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx
3.0.4.v200811200248-7C78ELhE8VrRVqtHp4iT8PuSwZ5W
ID: org.eclipse.cdt.mylyn, Version: 5.0.2.200902130801
ID: org.eclipse.emf.mapping.ecore, Version: 2.4.0.v200902171115
ID: org.cfeclipse.cfml, Version: 1.3.2.200901041029
3.0.3.v200902042310-7H37E8qfisI6diJKMbrhR-TV-a3
4.5.0.v200805132041-7J7N-_-M7OKEQDfDTIK95C7
1.0.4.v200812112112-6-E75BcMAAyDJGhFpNN
4.5.0.v200805132041-7879-8s733I3D6B5878
ID: org.eclipse.emf.mapping.ui, Version: 2.4.0.v200902171115
4.5.0.v200805230100-7p80-E9UsMfZXChNc0so95C7
ID: org.eclipse.ecf, Version: 2.1.0.v20081224-1728
1.4.1.v200809302010-13-7w311917141518
ID: de.loskutov.FileSync, Version: 1.3.3
1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj
1.6.2.v200810071455-37A09oA55S6H_L8DFG24
1.2.3.v200810041753-2328s733J3_56398B
ID: org.eclipse.emf.codegen.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.jst, Version: 1.0.3.v200901220134-77-E_FCYQCD5EeNgKUUY
ID: org.tigris.subversion.clientadapter.javahl, Version: 1.5.6
1.2.1.v200807161719-2308s733I3E5B4B7J
ID: org.eclipse.rse.services.ssh, Version: 2.1.1.v20080714-7830_kE77c7V8M
1.1.101.v200808291106-108Z7w3119193_2217
ID: org.eclipse.uml2.diagram.source, Version: 0.8.1.v200809231457
ID: com.sun.jna, Version: 3.0.9
ID: org.eclipse.draw2d, Version: 3.4.2.v20090218-1145-3317w311_122502441
0.95.1.v20080626-2043-0EEJ6E9IgKLhLZW8AKz0uq5
1.6.2.v200810071455-2138s733J465I548A
4.3.101.v200901090956-7B79Aj9oA55V585V5VJM
3.0.4.v20090115-20Am8s733J3_4F1256
ID: org.eclipse.emf.databinding.edit, Version: 1.0.0.v200902171115
ID: org.eclipse.dd.dsf.sdk, Version: 1.0.0.v20080609
3.0.4.v200901240221-52EFzAgI99n_WAjGIJb
ID: org.eclipse.emf.ecore.edit, Version: 2.4.1.v200902171115
ID: org.eclipse.nab.mwt, Version: 0.9.9.200806181757
ID: de.loskutov.eclipseskins.extvs, Version: 1.5.1
4.4.101.v200901090956-7F7DDr_kE77g7A7g7gQU
1.6.2.v200810071455-27A18s733I3I7I599G59
2.3.2.r232_v20081010-7X7n7WEBPrSQ6K-eN3CvLiGaMQ4d
1.0.1.r34x_v20080721-7T-7ZEIdY2TtPOAWojptd
1.6.2.v200810071455-3-29oA55S7__D7LCC
1.6.2.v200810071455-442_kE77c7VBQDFNW
3.0.3.v200902042310-7Z37HEB7sQSCRiULOVOE
2.0.1.v20080715-2-07w31191826
3.0.4.v200811240900-7G2EAzAM215iJKQCZssIGG6lQwlL
ID: org.eclipse.emf.edit.ui, Version: 2.4.2.v200902171115
ID: org.tigris.subversion.subclipse.mylyn, Version: 3.0.0
ID: de.loskutov.anyedit.AnyEditTools, Version: 2.1.3.200901071535
3.0.1.v20080730-4-CF_kE77c7SCI58GJ
0.1.3.v200902181600-2269sB9EP_M_W5B5B3822
1.6.2.v200810071455
2.3.2.r232_v20081010-2217s343A3119211_
0.95.1.v20080903-1434-09y08s733I3H3E15B_7
ID: org.eclipse.uml2, Version: 2.2.2.v200902101430
1.6.2.v200810071455-77-0CYQCD7FTIWGyPO
3.0.0.v200805040310-21CE8s733I3D4C56AA
3.0.4.v200811190840-7A-8l8Qqcz0HyVgjXUE-iuOYZ9ai
0.95.1.v20080903-1434-0AR09oA55S5N9J28GBE
ID: org.eclipse.emf.search.ecore, Version: 0.7.0.v200806130939
3.4.2.v20090218-1145-7B7E597OKBd7QHgEHNHn9JKTFJJR
ID: org.w3c.sac, Version: 1.3.0.v20080102-46-_kE77b7U_N56BA
ID: org.eclipse.tm.terminal.view, Version: 2.0.1.v20080715-2-07w31191826
ID: org.eclipse.buckminster.ui, Version: 1.1.0.r09948
4.5.0.v200805132041-44-7w311916243152
1.6.2.v200810071455-7F27SBcMAAxCcHmCNWi
ID: org.eclipse.emf, Version: 2.4.2.v200902171115
ID: org.eclipse.xsd, Version: 2.4.2.v200902171115
2.3.2.r232_v20081010-2217s343Aw31192224
2.3.2.r232_v20081010-7X8n7EELtcA6FxGJtxH7_f
1.6.2.v200810071455-6577AlJCKcLZI2Ljcc8MDD
ID: org.eclipse.emf.mint.source, Version: 0.7.1.v200809162149
1.0.0.v20080115-5318_GCGFGJMZHOMaa6PMUULSPXD
3.0.4.v200811190820-7Y7BFT1EPOwQQfPq5sVdQ6P_QtVn
ID: org.tigris.subversion.clientadapter.svnkit, Version: 1.5.6
1.6.2.v200901211403-7C67XCYQCD7ESIqIQco
1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ
1.0.0.v20070507-7B794E7QYGHMGxTcAasgF
ID: org.eclipse.buckminster.maven, Version: 1.1.0.r09904
ID: org.eclipse.sdk.examples.source, Version: 3.2.0.v20080611
ID: org.eclipse.buckminster.remote.feature, Version: 1.0.0.r09842
ID: org.eclipse.emf.search.runtime, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7E2EH6C-2fA3PMioFSbnhI_YkSTU
ID: de.loskutov.BytecodeOutline.feature, Version: 2.2.8
1.0.0.v20070510-7F57CE9IgKLaMASi7KHI3
2.0.3.v200902181600-2-27w311_13292711
1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.ocl, Version: 1.2.3.v200810101725-3439oA55T5F8H8PAB
ID: org.eclipse.buckminster.p4.ui, Version: 1.0.0.r09908
Version: 2.3.2.r232_v20081010-787A779lxNRkRRSNH-o3EoA3OFYi
3.2.0.v20080611-837bEN1ECCP57BAaYN7HSHEb
ID: org.mozilla.rhino, Version: 1.6.7.v20071217-1567w31191325
ID: org.eclipse.pde.p2, Version: 1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.xsd.edit, Version: 2.4.0.v200902171115
ID: org.eclipse.dd.dsf.gdb, Version: 1.0.0.v20080609
ID: org.eclipse.emf.search.ecore.ocl, Version: 0.7.0.v200806130939
ID: org.eclipse.buckminster.pde, Version: 1.1.340.r09942
1.1.2.v200812041720-2138s733I573A5G73
ID: org.eclipse.emf.search.ocl, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7C7_EVNE_EkMNtRvY4V6o0
ID: org.eclipse.emf.codegen, Version: 2.4.0.v200902171115
ID: org.eclipse.uml2.examples.source, Version: 2.2.0.v200805131030
ID: org.eclipse.sdk, Version: null
ID: org.eclipse.equinox.p2.user.ui, Version: null
ID: org.eclipse.cvs.source, Version: null
ID: org.eclipse.platform, Version: null
ID: org.eclipse.help.base, Version: null
ID: org.eclipse.jdt, Version: null
ID: org.eclipse.help.source, Version: null
ID: org.eclipse.rcp.source, Version: null
ID: org.eclipse.pde.source, Version: null
ID: org.eclipse.cvs, Version: null
ID: org.eclipse.rcp, Version: null
ID: org.eclipse.platform.source, Version: null
ID: org.eclipse.jdt.source, Version: null
ID: org.eclipse.equinox.p2.user.ui.source, Version: null
1.6.2.v200810071455
ID: org.eclipse.pde, Version: null
ID: org.eclipse.pde.p2.source, Version: null
ID: org.eclipse.pde.p2, Version: null
Re: Ganymede & Mylyn [message #67075 is a reply to message #66855] Wed, 18 March 2009 23:21 Go to previous messageGo to next message
!SESSION 2009-03-18 19:22:33.221
eclipse.buildId=M20090211-1700
java.version=1.6.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Code\DENDev\.metadata\.bak_0.log
Created Time: 2009-03-18 19:23:41.316
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2009-03-18 19:23:41.316
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector'
extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the
'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
will be ignored because it contains invalid attributes.
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE Conflict for
'AUTOGEN:::org.cfeclipse.cfml.frameworks.contribution1/org.c feclipse.cfml.frameworks.newAction':
HandlerActivation(commandId=AUTOGEN:::org.cfeclipse.cfml.fra meworks.contribution1/org.cfeclipse.cfml.frameworks.newActio n,
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetFrameworkFile),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1e0f790),sourcePriority=16384)
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetAsConfigFolder),
!ENTRY org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE A conflict occurred for CTRL+SHIFT+P:
Binding(CTRL+SHIFT+P,
ParameterizedCommand(Command(org.eclipse.ecf.presence.ui.com mands.browse,Open
Contact,
Category(org.eclipse.ecf.ui.commands.category,Communications ,null,true),
org.eclipse.ecf.internal.presence.ui.handlers.BrowseHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.emf.search.ecore.co mmon.ui.OpenFilteredEPackageMetaElementsSelectionDialogComma nd,Open
Filtered Ecore Package Meta-Elements Dialog,
Open Filtered Ecore Package Meta-Elements Dialog,
Category(org.eclipse.modeling.editors,Modeling Editors,Modeling Editors
Commands,true),
org.eclipse.emf.search.ecore.common.ui.handlers.OpenFiltered EPackageMetaElementSelectionDialogHandler,
,,true),null),
!ENTRY org.eclipse.mylyn.core 4 0 2009-03-18 19:23:47.910
!MESSAGE Context listener failed:
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager
!STACK 0
java.lang.IllegalArgumentException: Class file name must end with .class
org.eclipse.jdt.internal.core.PackageFragment.getClassFile(P ackageFragment.java:182)
org.eclipse.jdt.internal.core.PackageFragment.getHandleFromM emento(PackageFragment.java:270)
org.eclipse.jdt.internal.core.JavaElement.getHandleFromMemen to(JavaElement.java:272)
org.eclipse.jdt.internal.core.PackageFragmentRoot.getHandleF romMemento(PackageFragmentRoot.java:445)
org.eclipse.jdt.internal.core.JavaProject.getHandleFromMemen to(JavaProject.java:1506)
org.eclipse.jdt.internal.core.JavaModel.getHandleFromMemento (JavaModel.java:167)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2353)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2330)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.update TypeHistory(TypeHistoryManager.java:48)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.contex tActivated(TypeHistoryManager.java:40)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.internalActivateContext(InteractionContextManager.java :589)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.activateContext(InteractionContextManager.java:159)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$1.taskActi vated(TasksUiPlugin.java:264)
org.eclipse.mylyn.internal.tasks.core.TaskActivityManager.ac tivateTask(TaskActivityManager.java:413)
org.eclipse.mylyn.internal.tasks.ui.TaskListManager.activate Task(TaskListManager.java:126)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiIni tializationJob.runInUIThread(TasksUiPlugin.java:417)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
!ENTRY org.eclipse.osgi 4 0 2009-03-18 19:23:49.972
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.nab.mwt.jni (17354).
!STACK 0
org.osgi.framework.BundleException: The activator
org.widestudio.mwt.MwtPlugin for bundle org.eclipse.nab.mwt.jni is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:443)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.nab.mwt.ab.core.CorePlugin.start(CorePlugin.java :70)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:52)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:124)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:120)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:251)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 72)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:356)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:338)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:374)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:334)
Caused by: java.lang.UnsatisfiedLinkError: no mwt_java in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.widestudio.mwt.MwtPlugin.<clinit>(MwtPlugin.java:30)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 54 more
Root exception:
Source)
org.eclipse.nab.mwt (17356).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.nab.mwt.ab.core.CorePlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
Caused by: java.lang.NoClassDefFoundError:
org/widestudio/mwt/MwtInitializer
... 35 more
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 39 more
Caused by: org.osgi.framework.BundleException: The activator
... 49 more
Source)
... 54 more
Root exception:
java.lang.NoClassDefFoundError: org/widestudio/mwt/MwtInitializer
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.registry 4 1 2009-03-18 19:23:49.972
!MESSAGE Plug-in org.eclipse.nab.mwt was unable to load class
org.eclipse.nab.mwt.ab.core.MwtSourceDecorator.
!STACK 0
Caused by: org.osgi.framework.BundleException: Exception in
... 30 more
... 35 more
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-03-18
19:31:59.556
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:31:59.556
!MESSAGE Error at line 10, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 99: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 102: Illegal value for attribute "url"
of element "repository": null
!MESSAGE Error at line 12, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 99: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 14, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 14, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 15, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 15, column 102: Illegal value for attribute "url"
!ENTRY org.eclipse.equinox.p2.metadata.generator 4 0 2009-03-18
19:32:37.244
!MESSAGE Error reading site digest
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\digest23076.zip.
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at java.util.jar.JarFile.<init>(Unknown Source)
org.eclipse.equinox.internal.p2.metadata.generator.features. DigestParser.parse(DigestParser.java:75)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe aturesFromDigest(UpdateSite.java:402)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe atures(UpdateSite.java:375)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository.generateMetadata(UpdateSiteMetadataRepo sitory.java:108)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository. <init>(UpdateSiteMetadataRepository.java:73)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepositoryFactory.load(UpdateSiteMetadataRepositor yFactory.java:48)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:485)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:452)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:435)
org.eclipse.equinox.internal.p2.director.SimplePlanner.gathe rAvailableInstallableUnits(SimplePlanner.java:196)
org.eclipse.equinox.internal.p2.director.SimplePlanner.getPr ovisioningPlan(SimplePlanner.java:235)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.getProvisioningPlan(ProvisioningUtil.java:210 )
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.computeProvisioningPlan(InstallAction.java:80)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.getProvisioningPlan(InstallAction.java:130)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Profi leModificationAction$1.run(ProfileModificationAction.java:61 )
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE No solution found because the problem in
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\p2Encoding23092.opb is unsatisfiable.
!ENTRY org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!MESSAGE Cannot complete the request. See the details.
!SUBENTRY 1 org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!SUBENTRY 1 org.eclipse.equinox.p2.ui 1 10002 2009-03-18 19:32:52.135
!MESSAGE Mylyn Focused UI (Recommended) is already installed, so an update
will be performed instead.
!MESSAGE Mylyn Task List (Required) is already installed, so an update
!MESSAGE Mylyn Bridge: Eclipse IDE is already installed, so an update will
!MESSAGE Mylyn Bridge: Team Support is already installed, so an update
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2009-03-18 19:32:52.135
!MESSAGE Cannot find a solution satisfying the following requirements
org.eclipse.jdt.feature.jar [3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq].
19:39:20.452
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:20.452
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
19:39:31.015
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:31.015
"repository": url
!MESSAGE Error at line 11, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 99: Illegal value for attribute "url" of
20:01:56.767
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:01:56.767
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
20:02:24.892
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:24.892
"repository": url
"repository": url
20:02:26.533
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:26.533
"repository": url
"repository": url
"repository": url
"repository": url
!ENTRY org.eclipse.equinox.p2.metadata.generator 2 0 2009-03-18
20:02:27.189
!MESSAGE An error occurred while loading the bundle manifest C:\Documents
and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.gmf.doc _1.2.2.v20080916-2008.jar
!STACK 0
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.loadManifest(BundleDescriptionFa ctory.java:124)
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.getBundleDescription(BundleDescr iptionFactory.java:96)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.processBundle(RepositoryListener.java:23 6)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.process(RepositoryListener.java:226)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.added(RepositoryListener.java:201)
org.eclipse.equinox.internal.p2.extensionlocation.BundlePool FilteredListener.added(BundlePoolFilteredListener.java:39)
org.eclipse.equinox.internal.p2.extensionlocation.SiteListen er.added(SiteListener.java:284)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.processFile(DirectoryWatcher.java:200)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.scanDirectories(DirectoryWatcher.java:161)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.poll(DirectoryWatcher.java:108)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.ensureInitialized(ExtensionLocatio nMetadataRepository.java:72)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.getProperties(ExtensionLocationMet adataRepository.java:159)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.addRepository(MetadataRepositoryManager.ja va:110)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:454)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 20:02:30.689
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-18 20:02:30.689
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web
1.1.105.v200802192030 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4
Re: Ganymede & Mylyn [message #67087 is a reply to message #66855] Wed, 18 March 2009 23:40 Go to previous messageGo to next message
Dennis. please file a new bug report and attach your configuration details
to the bug: http://www.eclipse.org/mylyn/support/.
Steffen
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Ganymede & Mylyn [message #67096 is a reply to message #66855] Thu, 19 March 2009 07:12 Go to previous messageGo to next message
Hi Dennis,
I just tried the install based on a clean Ganymede J2EE package (3.4.1).
Here's what I did:
1. Downloaded Ganymede 3.4.1 to a clean directory
2. Started my workspace. Mylyn 3.0.4 was included.
3. I had issues here with the Java workspace settings not being loadable,
because the workspace was from 3.3.2, and I had to correct Mylyn user ids.
I
also had to restart to have my problem markers show up.
4. Launched the Ganymede Software Updates window. The Installed Software
tab
Update function didn't work, so I used the Available Software tab. There,
I
modified my Mylyn for Eclipse site to point to
http://download.eclipse.org/tools/mylyn/update/e3.4, which is different
from
the one you reported.
5. I hit the Install... button and Mylyn 3.1.0 was downloaded for me and
installed.
6. The workbench was restarted and Mylyn 3.1.0 came up cleanly with one
Information marker:
"Reset Bugzilla repository configuration cache due to format change"
I did notice that an SQL update appeared to be needed to process the Mylyn
3.1.0 update, and I allowed that through. It may have been a result of my
J2EE configuration. I hope this helps.
Randall
Dennis wrote:
> I'm trying to pull Mylyn 3.4 (all the way down to 3.1....) without any
> success...
> this is the most recent site I've tried...
> http://download.eclipse.org/tools/mylyn/update/weekly/e3.4
> running Eclipse :
> Eclipse Platform
> Version: 3.4.2
> Build id: M20090211-1700
> I receive the error:
> Mylyn Task List (Required) is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Eclipse IDE is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Team Support is already installed, so an update will be
> performed instead.
> I've tried to uninstall DTP with a glorious crash and burn, thinking that
> maybe that would be the problem (I'm at 1.6.2, with no idea how to
> downgrade it to 1.6.1 or anything else for that matter)
> In fact if I uninstall anything in this configuration, Ganymede simply
> does not start anymore.
> This package is causing all kinds of problems with Ganymede, it seems
> Everything wants to be bound to it, but I obviously do not have it...
> Heres my config: (below the config is my error log...)
> [[[ I had to clip the message, it was refused when I attempted to initial
> post]]]
Re: Ganymede & Mylyn [message #67127 is a reply to message #66855] Fri, 20 March 2009 04:57 Go to previous messageGo to next message
Originally posted by: philippe.couton.sercel.com
When I try to update Mylyn to version 3.1, I have this error:
org.eclipse.ui.workbench [3.4.2.M20090127-1700]
My Eclipse version is 3.4.2 from the Eclipse update site
(eclipse.buildId=M20090211-1700).
Is there something to do on my side to be able to update Mylyn?
Philippe
Re: Ganymede & Mylyn [message #67172 is a reply to message #67127] Sat, 21 March 2009 19:46 Go to previous messageGo to next message
Please try updating all installed features first. Then disable all update
site except for the Mylyn sites and try installing/updating Mylyn.
If that does not help, please file a bug. Please attach the list of
installed features and plug-ins to the bug and provide steps to reproduce
the problem.
Steffen
Steffen Pingel
Re: Ganymede & Mylyn [message #67182 is a reply to message #67172] Mon, 23 March 2009 05:28 Go to previous message
It seems that my problems are due to the connector I use, which is not
yet compatible with Mylyn 3.1. I have to wait a little to use the new
stuff of Mylyn.
Anyway, thanks for your help!
Philippe
> the problem.
> Steffen
Re: Ganymede & Mylyn [message #596822 is a reply to message #66855] Wed, 18 March 2009 23:17 Go to previous message
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Documents and
Settings\Dennis\Desktop\Ganymede\\plugins\org.eclipse.platfo rm_3.3.101.v200902111700\splash.bmp
-launcher
C:\Documents and Settings\Dennis\Desktop\Ganymede\eclipse.exe
-name
Eclipse
--launcher.library
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher.win32.win32.x86_1.0.101.R34x_v20080731\eclipse_111 5.dll
-startup
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher_1.0.101.R34x_v20081125.jar
-vm
C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/Documents and
eclipse.launcher=C:\Documents and
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1237429353221
eclipse.vm=C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.vmargs=-Xms40m
-Xmx256m
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Documents and
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_04\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_04\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_04
java.io.tmpdir=C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\
java.library.path=C:\Documents and
Settings\Dennis\Desktop\Ganymede;.;C:\WINDOWS\Sun\Java\bin;C :\WINDOWS\system32;C:\WINDOWS;C:/Program
Files/Java/jre1.6.0_04/bin/client;C:/Program
Files/Java/jre1.6.0_04/bin;C:\Program Files\Support
Tools\;C:\ColdFusion8\verity\k2\_nti40\bin;C:\WINDOWS\system 32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Microsoft Windows Small Business
Server\Networking\;C:\Subversion\bin;C:\Program Files\Microsoft SQL
Server\80\Tools\Binn\;C:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Microsoft
Visual Studio 8\Common7\IDE\PrivateAssemblies\;C:\Program
Files\QuickTime\QTSystem\;C:\PROGRA~1\ATT\Graphviz\bin;C:\Pr ogram
Files\GNU\GnuPG\pub;C:\Program Files\TortoiseSVN\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_04-b12
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b19
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=C:\Documents and
org.eclipse.mylyn.context.core.context.active=true
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2003
org.osgi.framework.os.version=5.2.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.eve nts,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w 3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 2003
os.version=5.2
osgi.arch=x86
osgi.bundles=reference:file:/C:/Documents and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox.common_3.4.0.v20080421-2006.jar@2:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.update.configurator_3.2.201.R34x_v20080819.jar@3:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.run time_3.4.0.v20080512.jar@:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.releng.t ools_3.4.0.v20080414/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. cm_1.0.1.R34x_v20090107-1200.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. device_1.0.1.v20080303.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ds_1.0.0.v20080427-0830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. event_1.1.0.v20080225.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http_1.0.200.v20080421-2006.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http.servletbridge_1.0.0.v20080427-0830.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. io_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ip_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. log_1.1.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. metatype_1.0.0.v20070827.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin_1.0.0.v20080522-1735.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin.rcp_1.0.0.v20080604.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. servletbridge_1.0.101.R34x_v20090114-1346.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.hook_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.xslt_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. useradmin_1.1.1.R34x_v20090107-1200.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. util_1.0.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. wireadmin_1.0.0.v20080407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management_1.2 .0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management.rem ote_1.0.0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.servlet_2.5.0. v200806031605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.2.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.h ttpclient_3.1.0.v20080605-1935.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.common s.util_1.0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.jaxme_ 0.5.1.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xmlrpc_3. 0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples_3.1.100.v20060606/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples.xml_3.3.0.I20080604/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.res ources.jmx_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.core_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.ui_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.rmi_1.0.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.xmlrpc_1.0.0.v20070515.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.common_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server_1.0.0.v20071015.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.rmi_1.0.0.v20070510.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.xmlrpc_1.0.0.v20070608.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.vm_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. preferences.jmx_1.0.0.v20070510.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. registry.jmx_1.0.0.v20080610-1530.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jdt.ui.e xamples.projects_3.1.102.v20080617/,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jface.ex amples.databinding_1.0.100.I20080430-0100.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.osgi.jmx _1.0.0.v20080610-1530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.sdk.exam ples_3.1.200.v20080612/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples_3.4.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser.demos_3.1.200.v3448f/,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.controls_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.launcher_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.layouts_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.ole.win32_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.paint_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.jmx_ 1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.team.exa mples.filesystem_3.4.0.I20080604/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.agentcontroller_4.2.202.v200902101418/,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.iac.administrator_4.4.201.v200901100100.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.contributions_3.3.0.I20080606-0100/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.fieldassist_1.1.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.javaeditor_3.1.100.v20080603-2000/,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.multipageeditor_3.2.100.I20070605-0010/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.propertysheet_3.2.0.I20070319-0010/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.readmetool_3.3.0.I20070606-0010/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.undo_3.2.100.I20080204-0800a.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.views.properties.tabbed.article_3.2.0.I20060605-1400.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/com.lowagie.itext_1. 5.4.v20080228/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.activation_1.1 .0.v200806101325.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.mail_1.4.0.v20 0804091730.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.4.0.v20 0806030407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.5.1.v20 0806030408.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml_1.3.4.v200 806030440.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.rpc_1.1.0. v200806030420/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.soap_1.2.0 .v200806030421/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/net.sourceforge.lpg. lpgjavaruntime_1.1.0.v200803061910.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.axis_1.4. 0.v200807230600/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.bri dge_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.css _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom .svg_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext .awt_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext ension_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.par ser_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.pdf _1.6.0.v200806031500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.svg gen_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.swi ng_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.tra nscoder_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l.gui_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.xml _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.3.0.v20080530-1600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.d iscovery_0.2.0.v200806030120/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.derby.cor e_10.3.1.4/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.log4j_1.2 .13.v200806030600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.wsil4j_1. 0.0.v200806040330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xerces_2. 9.0.v200805270400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.resol ver_1.2.0.v200806030312.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.seria lizer_2.7.1.v200806030322.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt_2.3 .2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt_2.3.2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.cshelp_2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.pdf_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.svg_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.swt_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine_2.3.2.r232_20090211.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.examples_2.3.2.r232_20090211.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.integration.wtp.ui_2.3.2.r232_20081009/,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem.ui_2.3.2.r232_20090122.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui_2.3.2.r232_20081218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui.extension_2.3.2.r232_20081218.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e_2.3.2.r232_20090204a.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.script.function_2.3.2.r232_v20090211.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.ui_2.3.2.r232_20081009.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.csh elp_2.3.2.r232_v20081113/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a_2.3.2.r232_v20090211.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a.aggregation_2.3.2.r232_v20090211.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.doc _2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.exa mple_2.3.2.r232_v20081107.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.int egration.wtp.ui_2.3.2.r232_20090122/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.adapter_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc_2.3.2.r232_v20090212/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile_2.3.2.r232_v20090211.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.sampledb_2.3.2.r232_v20090211.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.ui_2.3.2.r232_v20090211.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.ui_2.3.2.r232_v20090211.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb_2.3.2.r232_v20090211/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb.ui_2.3.2.r232_v20090211.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml.ui_2.3.2.r232_v20090211.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.core_2.3.2.r232_20090202.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.ui_2.3.2.r232_20090202.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer_2.3.2.r232_v20081010.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.core_2.3.2.r232_20090202.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.samplereports_2.3.2.r232_20090202.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui_2.3.2.r232_20090202/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.cubebuilder_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.script_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.xml.wtp_2.3.2.r232_20090202.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors.schematic_2.3.2.r232_20090202.jar,re ference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.ide_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib.explorer_2.3.2.r232_20090202.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.preview.web_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samples.ide_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samplesview_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.views_2.3.2.r232_20090202.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine_2.3.2.r232_20090217.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction_2.3.2.r232_20090122.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction.csv_2.3.2.r232_20090122.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.html_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.pdf_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.postscript_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.ppt_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.prototype.excel_2.3.2.r232_20090202.jar,r eference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.wpml_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.fonts_2.3.2.r232_20090202/,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.core_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.ui_2.3.2.r232_20090202.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model_2.3.2.r232_20090115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model.adapter.oda_2.3.2.r232_20090108.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.viewer_2.3.2.r232_20090212/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.res ources_2.3.2.r232_20081030/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity_1.1.2.v200901090028.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby_1.0.3.v200902070611.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.dbdefinition_1.0.2.v200901090940 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.ui_1.0.1.v200807010433.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.console.profile_1.0.0.v200805231345.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic_1.0.1.v200810140922.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic.ui_1.0.1.v200805152355.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.dbdefinition.genericJDBC_1.0.1.v200810300511. jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda_3.1.3.v200808270255.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.consumer_3.1.3.v200808270255.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design_3.0.7.v200807231215.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design.ui_3.0.8.v200901061015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile_3.0.8.v200812171046.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile.ui_3.0.8.v200812171046.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.profile_3.0.7.v200812050755.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.template.ui_3.0.6.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core_1.0.7.v200902180551.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core.ui_1.1.3.v200902070558.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.server.ui_1.1.3.v200902120834.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui_1.1.3.v200901150027.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui.dse_1.1.3.v200810140349.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.doc.user_1.6.1.v20080828133713.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.finfo_1.5.1.v200805152355.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.dbdefinition_1.0.0.v200805152355.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.ui_1.0.0.v200807220100.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.dbdefinition_1.0.2.v20090109085 3.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw_1.0.1.v200811210224.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.dbdefinition_1.0.3.v200901090853.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.ui_1.0.1.v200806260315.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.dbdefinition_1.0.3.v20090106093 8.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.dbdefinition_1.0.3.v200811040352.j ar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.ui_1.0.1.v200806260315.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.ui_1.0.0.v200806271414.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.jdt.classpath_1.0.1.v200901170137.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver_1.0.1.v200807181158.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.dbdefinition_1.0.0.v200805152355 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.ui_1.0.1.v200808222228.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql_1.0.2.v200810160130.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.dbdefinition_1.0.4.v200901090853.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.ui_1.0.0.v200805152355.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws_1.1.2.v200812171046.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws.ui_1.1.2.v200901191112.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml_1.1.2.v200902111040.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml.ui_1.1.2.v200812171046.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.dbdefinition_1.0.2.v200902030725.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.ui_1.0.1.v200806260315.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql_1.0.1.v200805152355.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.dbdefinition_1.0.1.v200901090853.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.ui_1.0.0.v200806060334.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb_1.0.0.v200805152355.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.dbdefinition_1.0.0.v200805152355.jar, reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.ui_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase_1.0.1.v200805310538.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa_1.0.1.v200901150020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.models_1.0.0.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.ui_1.0.1.v200805310538.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase_1.0.1.v200901170012.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.models_1.0.1.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.ui_1.0.1.v200806260315.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.models_1.0.0.v200805152355.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ui_1.0.0.v20081212.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.help_1.5.0.v200805152355.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.dbdefinition_1.0.1.v200901090853.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.derby_1.0.0.v200805152355.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql_1.0.1.v200812031125.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.edit_1.0.0.v200805152355.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query_1.0.1.v200901241145.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query.edit_1.0.0.v200806070329.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.xml.query_1.0.0.v200807080500.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.oda.cshelp_1.1.0.v200810240330.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.common.ui_1.0.0.v200812121740.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.core_1.0.1.v200902140515.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.ui_1.1.1.v200901140830.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.derby_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.generic_1.0.0.v200902031600.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.ddlgen.ui_1.0.0.v200808140615.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.debugger.core_1.0.0.v200808140615.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.editor.core_1.0.0.v200902031600.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql_1.0.1.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.lexer_1.0.1.v200811081015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.query_1.0.1.v200810291500.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.xml.query_1.0.0.v200808140615.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.plan_1.0.0.v200812121520.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.result_1.0.0.v200902120900.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.routineeditor_1.0.0.v200807211830.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sql_1.0.0.v200902031600.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlbuilder_1.0.0.v200901280650.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqleditor_1.0.0.v200901220945.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlscrapbook_1.0.0.v200901151810.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tabledataeditor_1.0.0.v200901280500.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tablewizard_1.0.0.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.draw2d_3 .4.2.v20090114-1330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf_2.4. 0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ant_ 2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore_2.4.2.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore.ui_2.4.1.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.conv erter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding_1.0.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding.edit_1.0.0.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change.edit_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.edit_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.editor_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.xmi_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit _2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit .ui_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.expo rter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.java_2.4.1.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.rose_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore.editor_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore_2.4.0.v200902171115.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore.editor_2.4.0.v200902171115.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml.ui_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.gef_3.4. 1.v20080806.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem_2.0. 202.v200810282000.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info_2.0.200.v200811261206.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm_2.0.200.v200811260651.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm.common_2.0.200.v200811260651.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.prox y_2.0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.ui_2 .0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.util _2.0.100.v200805140020.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.work bench_2.0.102.v200810230530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.controller_1.1.100.v200805140020.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.core_1.1.100.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.ui_1.1.102.v200806010600.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.frameworks_1.1.201.v200810161330.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.core_1.3.1.v200807031821.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.ui_1.3.1.v200807031821.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. doc.user_1.1.100.v200810092245.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui_1.1.203.v200810010400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui.infopop_1.0.100.v200805222207/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee _1.1.206.v200902052030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .core_1.1.203.v200901221030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .doc.user_1.1.1.v200808070608.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb_1.1.203.v200811060500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotation.model_1.1.102.v200805140020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.emitter_1.1.102.v200805140135.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.ui_1.1.102.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.xdoclet_1.2.0.v200805140020.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .infopop_1.0.300.v200805140415.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca_1.1.203.v200811060900.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca.ui_1.1.200.v200805140020.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .navigator.ui_1.1.203.v200901290400.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ui_1.1.206.v200901280857.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .web_1.1.203.v200901290400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice_1.1.201.v200807240600.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice.ui_1.1.201.v200811062130.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .xdoclet.runtime_1.1.102.v200805140135.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee_ 1.0.103.v200901220530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ejb_1.0.102.v200810230722.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ui_1.0.104.v200902040818.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. web_1.0.101.v200810230738.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common_1.1.4.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.runtime_1.0.101.v20090128.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.ui_1.1.0.v20080605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. core_1.1.103.v200902042324.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. doc.user_1.1.100.v20080811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig_1.1.1.v20090129.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig.ui_1.1.3.v20090128.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. standard.tagsupport_1.1.102.v20090128.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. ui_1.1.102.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. core_1.2.121.v200901290830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui_1.1.312.v200901290909.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui.infopop_1.0.100.v200805301545.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv er.core_1.1.3.v20090115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui_1.1.203.v200810222000.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui.infopop_1.0.300.v200805140415.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.stan dard.schemas_1.0.101.v200807220523.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws_1 .0.307.v200901142050.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.core_1.0.306.v200810082309.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.ui_1.0.305.v200809301934.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.creation.ui_1.0.306.v200811200248.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.infopop_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.ui.doc.user_1.1.0.v200806092139.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption_1.0.307.v200811220753/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.infopop_1.0.300.v200805140230.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui_1.1.4.v200901212148.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui.doc.user_1.0.550.v200901232040.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ejb.ui_1.0.200.v200805140230.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ui_1.0.308.v200901212148.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.d oc.user_1.0.500.v200809092107.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.i nfopop_1.0.300.v200805140230.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u ddiregistry_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u i_1.0.304.v200901271844.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.wst.comm and.env_1.0.308.v200811200248/,reference:file:/C:/Documents
and
Re: Ganymede & Mylyn [message #596832 is a reply to message #66855] Wed, 18 March 2009 23:17 Go to previous message
*** Features:
AnyEditTools (2.1.3.200901071535) "AnyEdit Tools"
com.lowagie.itext (1.5.4.v20080225-1437w31191339) "Lowagie Itext"
com.sun.jna (3.0.9) "JNA Library Plug-in"
EclipseSkins (1.5.1) "Extended VS Presentation Plug-in"
FileSync (1.3.3) "FileSync Plug-in"
JDepend4Eclipse (1.2.1) "JDepend4Eclipse"
org.apache.commons.codec (1.3.0.v20070920-12-7w3119164102711) "Apache
Commons Codec Plug-in"
org.apache.derby.core (10.3.1.4) "Apache Derby Core Plug-in for Eclipse"
org.cfeclipse.cfml.feature (1.3.2.200901041029) "CFML Plug-in"
org.eclipse.birt (2.3.2.r232_v20081010-7N7Y7MAIe2QJZSgfOaAphGBR4t7b)
"Business Intelligence and Reporting Tools"
org.eclipse.birt.chart (2.3.2.r232_v20081010-7_7D79_doT2uMPVNwOGoz0HKuyI8)
"BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.3.2.r232_v20081010-2217s343Aw31192216)
"BIRT Chart Context-sensitive Help"
org.eclipse.birt.chart.integration.wtp
(2.3.2.r232_v20081010-2217s343A3119211_) "BIRT Chart WTP Integration
Plug-in"
Plug-in"
org.eclipse.birt.chart.runtime
(2.3.2.r232_v20081010-7X8n7EELtcA6FxGJtxH7_f) "BIRT Chart Runtime"
org.eclipse.birt.cshelp (2.3.2.r232_v20081010-2217s343Aw31192224) "BIRT
org.eclipse.birt.doc (2.3.2.r232_v20081010-2217s343Aw31192216) "BIRT
Documentation"
Documentation"
org.eclipse.birt.example (2.3.2.r232_v20081010-7D7J7CC7QXRK0ICmcLILD)
"BIRT Example"
"BIRT Example"
org.eclipse.birt.integration.wtp (2.3.2.r232_v20081204-2217s343A311_1233)
"BIRT WTP Integration Plug-in"
org.eclipse.birt.report.designer
(2.3.2.r232_v20081010-7X7n7WEBPrSQ6K-eN3CvLiGaMQ4d) "BIRT Report Designer"
org.eclipse.birt.report.designer.editor.xml.wtp
(2.3.2.r232_v20090212-2217s343A311_1313) "BIRT Advanced XML Editor Plug-in"
org.eclipse.birt.report.runtime
(2.3.2.r232_v20081010-7k8E7fELFluav5n_2NEXh3W6B9_) "BIRT Report Runtime"
org.eclipse.buckminster.core.feature (1.1.0.r09948) "Buckminster UI
Plug-in"
Plug-in"
org.eclipse.buckminster.cvs.feature (1.0.0.r09930) "Buckminster CVS
Plug-in"
Plug-in"
org.eclipse.buckminster.maven.feature (1.1.0.r09904) "Buckminster Maven
Plug-in"
Plug-in"
org.eclipse.buckminster.p4.feature (1.0.0.r09908) "Buckminster Perforce UI
Plug-in"
Plug-in"
org.eclipse.buckminster.pde.feature (1.1.340.r09942) "Buckminster PDE
Plug-in"
Plug-in"
org.eclipse.cdt.mylyn (5.0.2.200902130801) "Mylyn Plug-in"
org.eclipse.cvs (1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7) "Eclipse CVS
Client"
Client"
org.eclipse.cvs.source (1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7)
"Eclipse CVS Client SDK"
org.eclipse.datatools.common.doc.user
(1.6.2.v200810071455-1507w31191939244824) "Data Tools Platform Tutorial
Documentation"
Documentation"
org.eclipse.datatools.connectivity.doc.user
(1.6.2.v200810071455-27A18s733I3I7I599G59) "Data Tools Platform
Connectivity Documentation"
org.eclipse.datatools.connectivity.feature
(1.6.2.v200810071455-7_7K7NDn-QYKjkBKlmD4edYsAX) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.6.2.v200901211403-7C67XCYQCD7ESIqIQco) "DTP ODA Designer UI Framework
Plug-in"
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.6.2.v200810071455-7F27SBcMAAxCcHmCNWi) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.6.2.v200810071455-37A09oA55S6H_L8DFG24)
"Data Tools Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.6.2.v200810071455-6577AlJCKcLZI2Ljcc8MDD) "High-level Sybase Enablement
Plug-in"
Plug-in"
org.eclipse.datatools.enablement.feature
(1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.6.2.v200810071455-57_2_pFAIQJZIsLSXb8MDD) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.ibm.feature
(1.6.2.v200810071455-7D47FEB7sQSBV7hXWQ6R) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.6.2.v200810071455-3-29oA55S7__D7LCC) "High-level Sybase Enablement
Plug-in"
Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.6.2.v200810071455-442_kE77c7VBQDFNW) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.6.2.v200810071455-446_kE77d8H_VALOJ) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.6.2.v200810071455-2138s733J465I548A) "Eclipse Data Tools Platform XML
ODA Designer"
ODA Designer"
org.eclipse.datatools.enablement.oda.feature
(1.6.2.v200810071455-797P78CYQCD5DjGdEURT) "Eclipse Data Tools Platform
XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.6.2.v200810071455-443_kE77d7OAPAMJQ) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
(1.6.2.v200810071455-442_kE77d7N9VANON) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.6.2.v200810071455-440_kE77c7QAQEIQQ) "Eclipse Data Tools Platform
Enablement"
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.6.2.v200810071455-7A-5E9IgKLjM1d1Oepu) "High-level Sybase Enablement
Plug-in"
Plug-in"
org.eclipse.datatools.intro (1.6.2.v200810071455-1507w311918132411)
"Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature
(1.6.2.v200810071455-6-2BcMAAyBWDkEVSb) "Eclipse Data Tools Platform
SQLModel Plug-in"
SQLModel Plug-in"
org.eclipse.datatools.sdk.feature
(1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx) "DTP Connectivity
Templates Plug-in"
Templates Plug-in"
org.eclipse.datatools.sdk.feature.source (1.6.2.v200810071455) "Eclipse
Datatools Source"
Datatools Source"
org.eclipse.datatools.sqldevtools.feature
(1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqltools.doc.user
(1.6.2.v200810071455-1507w31191939244824) "Data Tools Platform SQL Dev
Tools Documentation"
org.eclipse.dd.ipxact (0.9.0.v20080609) "Bundle-Name.0"
org.eclipse.dltk.core (0.95.1.v20080626-2043-0EEJ6E9IgKLhLZW8AKz0uq5)
"Eclipse Dynamic Languages Toolkit (Incubation)"
org.eclipse.dltk.itcl (0.95.1.v20080903-1434-0AR09oA55S5N9J28GBE) "iTcl
Extension Support for TCL language (Incubation)"
org.eclipse.dltk.mylyn (0.95.1.v20080626-2043-08T07w31191_1402545)
"Dynamic Languages Toolkit IncrTcl Core"
org.eclipse.dltk.ruby (0.95.1.v20080626-2043-0ECq6E8McIJXJUOr9upp-2) "Ruby
Development Tools (Incubation)"
org.eclipse.dltk.tcl (0.95.1.v20080626-2043-0EEJ77E9IgKLhLeUz0ALs1x5) "Tcl
org.eclipse.dltk.xotcl (0.95.1.v20080903-1434-0Bw2_kE77c7a9N3BFKL) "XOTcl
org.eclipse.draw2d (3.4.2.v20090218-1145-3317w311_122502441) "Graphical
Editing Framework Draw2d"
org.eclipse.draw2d.sdk (3.4.2.v20090218-1145-67738084A6665K366B84__58x422)
"Graphical Editing Framework Draw2d Developer Resources"
org.eclipse.draw2d.source (3.4.2.v20090218-1145-3317w311_122502441)
org.eclipse.ecf.core (2.1.0.v20081224-1728) "Eclipse Communication
Framework (ECF)"
Framework (ECF)"
org.eclipse.ecf.examples (2.1.0.v20081224-1728) "ECF Collaboration
Examples"
Examples"
org.eclipse.emf (2.4.2.v200902171115) "EMF - Eclipse Modeling Framework"
org.eclipse.emf.codegen (2.4.0.v200902171115) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.4.2.v200902171115) "EMF Ecore Code
Generator"
Generator"
org.eclipse.emf.codegen.ecore.ui (2.4.1.v200902171115) "EMF Ecore Code
Generator UI"
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200902171115) "EMF Code Generation UI"
org.eclipse.emf.common (2.4.0.v200902171115) "EMF Common"
org.eclipse.emf.common.ui (2.4.0.v200902171115) "EMF Common UI"
org.eclipse.emf.converter (2.4.1.v200902171115) "EMF Model Converter"
org.eclipse.emf.databinding (1.0.0.v200902171115) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.0.0.v200902171115) "EMF Edit Data
Binding"
Binding"
org.eclipse.emf.ecore (2.4.2.v200902171115) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.4.1.v200902171115) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.4.0.v200902171115) "EMF Sample Ecore
Editor"
Editor"
org.eclipse.emf.edit (2.4.2.v200902171115) "EMF Edit"
org.eclipse.emf.edit.ui (2.4.2.v200902171115) "EMF Edit UI"
org.eclipse.emf.mapping (2.4.0.v200902171115) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.4.0.v200902171115) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.4.0.v200902171115) "EMF Ecore
Mapping Editor"
Mapping Editor"
org.eclipse.emf.mapping.ui (2.4.0.v200902171115) "EMF Mapping UI"
org.eclipse.emf.mint.doc (0.7.1.v200809162149) "Mint Developer Guide
(Incubation)"
(Incubation)"
org.eclipse.emf.mint.source (0.7.1.v200809162149) "Mint Source
(Incubation)"
(Incubation)"
org.eclipse.emf.ocl (1.1.101.v200808291106-108Z7w3119193_2217) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.query (1.2.0.v200805130238-11-7w311916241349) "EMF Model
Query"
Query"
org.eclipse.emf.query.ocl (1.2.0.v200805130238-11-7w311916241349) "EMF
Model Query OCL Integration"
org.eclipse.emf.search.ecore (0.7.0.v200806130939) "Ecore Model Search
(Incubation)"
(Incubation)"
org.eclipse.emf.search.ecore.ocl (0.7.0.v200806130939) "Ecore OCL Model
Search (Incubation)"
org.eclipse.emf.search.ocl (0.7.0.v200806130939) "Ecore Model Search OCL
(Incubation)"
(Incubation)"
org.eclipse.emf.transaction (1.2.1.v200807161719-2308s733I3E5B4B7J) "EMF
Model Transaction Core"
org.eclipse.emf.validation (1.2.0.v200805130238-35-9oA55S5L8G6FCT) "EMF
Validation Framework Core"
org.eclipse.emf.validation.ocl (1.2.0.v200805130238-11-7w311916241349)
"EMF Validation Framework OCL Integration"
org.eclipse.emf.workspace (1.2.3.v200810041753-2328s733J3_56398B) "EMF
Model Transaction Workbench Integration Core"
org.eclipse.gef (3.4.2.v20090218-1145-67728084A56B4I233613552) "Graphical
Editing Framework GEF"
org.eclipse.gef.sdk (3.4.2.v20090218-1145-7B7E597OKBd7QHgEHNHn9JKTFJJR)
"Graphical Editing Framework GEF Developer Resources"
org.eclipse.gef.source (3.4.2.v20090218-1145-67728084A56B4I233613552)
org.eclipse.gmf (1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ)
"Graphical Modeling Framework"
org.eclipse.gmf.examples.pde (1.1.0.v20080716-1600-2-Ag8s733I3A7C15KCK)
"Graphical Modeling Framework Examples"
org.eclipse.gmf.runtime.notation (1.1.2.v20080916-2008-2108s733I3E4F15B59)
"GMF Notation Model Support"
org.eclipse.gmf.runtime.notation.source
(1.1.2.v20080916-2008-2108s733I3E4F15B59) "Graphical Modeling Framework
Notation Developer Resources"
org.eclipse.gmf.source (1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ)
"Graphical Modeling Framework Runtime Developer Resources"
org.eclipse.gmf.tooling (2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE)
"Graphical Modeling Framework Tooling"
org.eclipse.gmf.tooling.source
(2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE) "Graphical Modeling
Framework Tooling Developer Resources"
org.eclipse.help (1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK) "Help
System Base"
System Base"
org.eclipse.help.source
(1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK) "Help System Core
Source"
Source"
org.eclipse.jdt (3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI)
"Eclipse Java Development Tools"
org.eclipse.jdt.source (3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI)
"Eclipse Java Development Tools SDK"
org.eclipse.mylyn_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.pde_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.nab.mwt (0.9.9.200806181757) "NAB/MWT Plug-in"
org.eclipse.nab.mwt.native.win32 (0.9.9.200806181757) "Win32 handler for
NAB/MWT Plug-in"
NAB/MWT Plug-in"
org.eclipse.ocl (1.2.3.v200810101725-3439oA55T5F8H8PAB) "Object Constraint
Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.uml (1.2.3.v200811021759-1127w311_12182518) "OCL 2.0
Binding for UML"
Binding for UML"
org.eclipse.ocl.uml.source (1.2.3.v200811021759-1127w311_12182518) "OCL
2.0 Binding for UML Source"
org.eclipse.pde (3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS) "PDE"
org.eclipse.pde.source (3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS)
"Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform
(3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL) "Eclipse
Platform"
Platform"
org.eclipse.platform.source
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63)
"Eclipse RCP"
"Eclipse RCP"
org.eclipse.rcp.source
(3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63) "Eclipse RCP Plug-in
org.eclipse.releng.tools (3.2.200.v20080603-33-7w31191525) "RelEng Plug-in"
org.eclipse.rse (3.0.3.v200902042310-7H37E8qfisI6diJKMbrhR-TV-a3) "Remote
System Explorer End-User Runtime"
org.eclipse.rse.core (3.0.3.v200902042310-7Z37HEB7sQSCRiULOVOE) "Remote
System Explorer Core"
org.eclipse.rse.dstore (3.0.3.v200902042310-7J378DUUEFGEpIz-AW8E) "RSE
DStore Services"
DStore Services"
org.eclipse.rse.ftp (3.0.1.v200809171630-78479_kE77c7Q8b8T_F) "RSE FTP
Service"
Service"
org.eclipse.rse.local (2.1.1.v20080710-7_40AgI99m9d_O) "RSE Local Services"
org.eclipse.rse.remotecdt (2.1.1.v200809041200-4118s733I3J4F5C48) "Remote
System Explorer C/C++ Remote Debug Launcher"
org.eclipse.rse.ssh (2.1.1.v20080714-7830_kE77c7V8M) "RSE SSH Services"
org.eclipse.rse.telnet (2.1.1.v200809181500-6678AgI99m9W9X5J79) "RSE
Telnet Service"
Telnet Service"
org.eclipse.rse.terminals (0.1.3.v200902181600-2269sB9EP_M_W5B5B3822) "RSE
Terminals UI (Incubation)"
org.eclipse.rse.useractions (1.1.2.v200812041720-2138s733I573A5G73) "RSE
User Actions"
User Actions"
org.eclipse.sdk
(3.4.2.R342_v20090122-7O7S7GApJ3_vCyk7ETmsfcmjhz0eHnqw7MIjk9 Vdhe4Ic)
"Eclipse Project SDK"
org.eclipse.sdk
org.eclipse.sdk.examples (3.2.0.v20080611-837bEN1ECCP57BAaYN7HSHEb)
"Eclipse SDK Examples"
org.eclipse.sdk.examples.source (3.2.0.v20080611) "Eclipse Platform
org.eclipse.tm.discovery (3.0.0.v20080530-7N-E8ME8McIJXIwdh) "Target
Management Service Discovery Engine"
org.eclipse.tm.terminal (2.0.3.v200902181600-2-27w311_13292711) "Target
Management Terminal Widget"
org.eclipse.tm.terminal.serial (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal Serial Connector"
org.eclipse.tm.terminal.ssh (2.0.2.v200811110900-2-17w311922221_11)
"Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.0.1.v20080715-2-07w31191826) "Target
Management Terminal View"
org.eclipse.tptp.lta.gla.ui.epi (4.5.0.v200805132041-44-7w311916271211)
"Generic Adapter UI"
org.eclipse.tptp.lta.log.epi (4.5.0.v200805132041-44-7w311916243152) "TPTP
LTA Log Extension Instances"
org.eclipse.tptp.lta.sdb.epi (4.5.0.v200805132041-44-7w311916243152) "TPTP
LTA Log SDB Extension Instances"
org.eclipse.tptp.lta.symptom.epi (4.5.0.v200805132041-44-7w311916243152)
"TPTP LTA Log Symptom Catalog Extension Instances"
org.eclipse.tptp.monitoring.instrumentation
(4.3.101.v200901090956-7B79Aj9oA55V585V5VJM) "TPTP Instrumentation
Monitoring "
Monitoring "
org.eclipse.tptp.monitoring.la.core
(4.4.100.v200901090956-7B78CE9oA55S8A8M5855) "Monitoring Log Analyzer Core
backward compatibility"
org.eclipse.tptp.monitoring.managedagent
(4.4.101.v200901090956-7F7DDr_kE77g7A7g7gQU) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.200.v200901090956-43_77w311_121_1_67) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.100.v200901090956-3-37w311_12211211) "MX4J"
org.eclipse.tptp.platform.la.core
(4.3.200.v200812160100-42_77w311923271211) "Log Analysis Core backward
compatibility"
compatibility"
org.eclipse.uml2 (2.2.2.v200902101430) "UML2"
org.eclipse.uml2.diagram (0.8.1.v200809231457) "UML2 Diagramming Plug-in
(Incubation)"
(Incubation)"
org.eclipse.uml2.diagram.source (0.8.1.v200809231457) "UML2 Diagramming
Source"
Source"
org.eclipse.uml2.doc (2.2.0.v200805201350) "UML2 Documentation"
org.eclipse.uml2.examples (2.2.0.v200805131030) "UML2 Examples"
org.eclipse.uml2.examples.source (2.2.0.v200805131030) "UML2 Examples
Source"
Source"
org.eclipse.uml2.search.ocl (0.7.0.v200806130939) "Ecore OCL Model Search
(Incubation)"
(Incubation)"
org.eclipse.uml2.source (2.2.2.v200902101430) "UML2 Source"
org.eclipse.wst (3.0.4.v200811190840-7A-8l8Qqcz0HyVgjXUE-iuOYZ9ai) "Web
Standard Tools (WST)"
org.eclipse.xsd (2.4.2.v200902171115) "XSD - XML Schema Definition Model"
org.eclipse.xsd.edit (2.4.0.v200902171115) "XSD Edit"
org.eclipse.zest (1.0.0.v20080115-5318xB6CE899P233613552) "Graphical
Editing Framework Zest Core"
org.eclipse.zest.sdk (1.0.0.v20080115-5318_GCGFGJMZHOMaa6PMUULSPXD)
"Graphical Editing Framework Zest Developer Resources"
org.eclipse.zest.source (1.0.0.v20080115-5318xB6CE899P233613552)
org.mozilla.rhino (1.6.7.v20071217-1567w31191325) "Mozilla Rhino"
org.tigris.subversion.clientadapter.feature (1.5.3) "Subversion Client
Adapter"
Adapter"
org.tigris.subversion.clientadapter.javahl.feature (1.5.6) "Subversion
JavaHL"
JavaHL"
org.tigris.subversion.clientadapter.svnkit.feature (1.5.6) "SVNKit Client
Adapter"
Adapter"
org.tigris.subversion.subclipse (1.4.8) "SVN Team Provider Core"
org.tigris.subversion.subclipse.graph.feature (1.0.5) "Subversion Revision
Graph"
Graph"
org.tigris.subversion.subclipse.mylyn (3.0.0) "Subclipse Integration for
Mylyn 3.x"
Mylyn 3.x"
org.tmatesoft.svnkit (1.2.3.5521) "SVNKit Library Plug-in"
org.w3c.sac (1.3.0.v20080102-46-_kE77b7U_N56BA) "W3C Sac"
Re: Ganymede & Mylyn [message #596846 is a reply to message #66855] Wed, 18 March 2009 23:18 Go to previous message
*** Plug-in Registry:
ch.ethz.iks.r_osgi.remote (1.0.0.RC2_v20081224-1728) "R_OSGi Remote
Service" [Active]
ch.ethz.iks.slp (1.1.0.v20081224-1728) "jslp-osgi" [Active]
com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.base (3.8.1.v20080530) "International Components for Unicode
for Java (ICU4J) Replacement plug-in" [Starting]
com.ibm.icu.base.source (3.8.1.v20080530) "International Components for
Unicode for Java (ICU4J) Replacement plug-in Source" [Resolved]
com.ibm.icu.source (3.8.1.v20080530) "International Components for Unicode
for Java (ICU4J) Source" [Resolved]
com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
com.lowagie.itext (1.5.4.v20080228) "Lowagie Itext" [Resolved]
com.sun.jna (3.0.9) "JNA Library Plug-in" [Starting]
de.loskutov.anyedit.AnyEditTools (2.1.3.200901071535) "AnyEdit Tools"
[Active]
de.loskutov.BytecodeOutline (2.2.8) "Bytecode Outline Plug-in" [Starting]
de.loskutov.eclipse.jdepend (1.2.1) "JDepend4Eclipse" [Starting]
de.loskutov.eclipseskins.extvs (1.5.1) "Extended VS Presentation Plug-in"
[Starting]
de.loskutov.FileSync (1.3.3) "FileSync Plug-in" [Starting]
javax.activation (1.1.0.v200806101325) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.mail (1.4.0.v200804091730) "Javax Mail Plug-in" [Resolved]
javax.management (1.2.0.v200803061811) "Java Management Extensions API"
[Resolved]
javax.management.remote (1.0.0.v200803061811) "Java Management Remote
Extensions API" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.source (2.0.0.v200806031607) "Java Server Pages API
Source Bundle" [Resolved]
javax.servlet.source (2.4.0.v200806031604) "Servlet API Source Bundle"
[Resolved]
javax.wsdl (1.4.0.v200806030407) "WSDL4J" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200806030440) "JAXP XML" [Resolved]
javax.xml.rpc (1.1.0.v200806030420) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200806030421) "SAAJ" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG"
[Resolved]
org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200803061910) "Apache Ant Source" [Resolved]
org.apache.axis (1.4.0.v200807230600) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200805290154) "Apache Batik Extension"
[Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200805290154) "Apache Batik Swing"
[Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.commons.codec (1.2.0.v20080530-1550) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200806030120) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter Source" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v20080605-1930) "Apache Commons
Logging Plug-in Source" [Resolved]
org.apache.commons.net (1.4.1.v200803071935) "Apache Commons Net"
[Resolved]
[Starting]
org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.source (5.5.17.v200806031609) "Apache Jasper 2 Source
Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200806030600) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
[Resolved]
org.apache.lucene.analysis.source (1.9.1.v20080530-1600) "Apache Lucene
Analysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v20080530-1600) "Apache Lucene Source"
[Resolved]
org.apache.oro (2.0.8.v200803061811) "Apache Jakarta ORO" [Resolved]
org.apache.ws.commons.util (1.0.0.v20080530-1550) "WS Commons Util
Plug-in" [Resolved]
org.apache.ws.jaxme (0.5.1.v20080530-1550) "Apache JAX-ME Plug-in"
[Resolved]
org.apache.wsil4j (1.0.0.v200806040330) "WSIL4J" [Resolved]
org.apache.xerces (2.9.0.v200805270400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200806030312) "Apache XmlResolver"
[Resolved]
org.apache.xml.serializer (2.7.1.v200806030322) "Apache XML Commons
Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20080530-1550) "Apache XML-RPC Plug-in"
[Resolved]
org.cfeclipse.cfml (1.3.2.200901041029) "CFML Plug-in" [Active]
org.cfeclipse.cfml.cfunit (1.3.2.200901041029) "CFUnit Fragment" [Resolved]
org.cfeclipse.cfml.frameworks (1.0.3) "CF Frameworks Plugin" [Starting]
org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
org.eclipse.ant.core.source (3.2.0.v20080529) "Ant Build Tool Core Source"
[Resolved]
org.eclipse.ant.ui (3.3.1.v20090120_r342) "Ant UI" [Active]
org.eclipse.ant.ui.source (3.3.1.v20090120_r342) "Ant UI Source" [Resolved]
org.eclipse.birt (2.3.2.r232_v20081010) "Business Intelligence and
Reporting Tools" [Resolved]
org.eclipse.birt.chart (2.3.2.r232_v20081010) "BIRT Chart Framework"
[Resolved]
org.eclipse.birt.chart.cshelp (2.3.2.r232_v20081105) "BIRT Chart
Context-sensitive Help" [Starting]
org.eclipse.birt.chart.device.extension (2.3.2.r232_20090115) "BIRT Chart
Device Extension(s)" [Starting]
org.eclipse.birt.chart.device.pdf (2.3.2.r232_20090115) "BIRT Chart Device
PDF Extension" [Starting]
org.eclipse.birt.chart.device.svg (2.3.2.r232_20090115) "BIRT Chart Device
SVG Extension" [Starting]
org.eclipse.birt.chart.device.swt (2.3.2.r232_20090115) "BIRT Chart Device
SWT Extension" [Starting]
org.eclipse.birt.chart.engine (2.3.2.r232_20090211) "BIRT Chart Engine"
[Starting]
org.eclipse.birt.chart.engine.extension (2.3.2.r232_20090115) "BIRT Chart
Engine Extension" [Starting]
org.eclipse.birt.chart.examples (2.3.2.r232_20090211) "BIRT Chart Examples
Plug-in" [Starting]
org.eclipse.birt.chart.integration.wtp.ui (2.3.2.r232_20081009) "BIRT
Chart WTP Integration Plug-in" [Starting]
org.eclipse.birt.chart.reportitem (2.3.2.r232_20090115) "BIRT Chart-Report
Integration" [Starting]
org.eclipse.birt.chart.reportitem.ui (2.3.2.r232_20090122) "BIRT
Chart-Report UI Integration Plug-in" [Starting]
org.eclipse.birt.chart.runtime (2.3.2.r232_v20081010) "BIRT Chart Runtime"
[Resolved]
org.eclipse.birt.chart.ui (2.3.2.r232_20081218) "BIRT Chart Library UI
Plug-in" [Starting]
org.eclipse.birt.chart.ui.extension (2.3.2.r232_20081218) "BIRT Chart UI
org.eclipse.birt.core (2.3.2.r232_20090204a) "BIRT Core Package" [Starting]
org.eclipse.birt.core.script.function (2.3.2.r232_v20090211) "Function
Plug-in" [Starting]
org.eclipse.birt.core.ui (2.3.2.r232_20081009) "BIRT Core UI" [Starting]
org.eclipse.birt.cshelp (2.3.2.r232_v20081113) "BIRT Context-sensitive
Help" [Starting]
org.eclipse.birt.data (2.3.2.r232_v20090211) "BIRT Data Engine" [Starting]
org.eclipse.birt.data.aggregation (2.3.2.r232_v20090211) "Build-in
Aggregation Plug-in" [Starting]
org.eclipse.birt.doc (2.3.2.r232_v20081105) "BIRT Documentation" [Starting]
org.eclipse.birt.example (2.3.2.r232_v20081107) "BIRT Example" [Resolved]
org.eclipse.birt.integration.wtp.ui (2.3.2.r232_20090122) "BIRT WTP
org.eclipse.birt.report.data.adapter (2.3.2.r232_v20090211) "BIRT Data
Adapter" [Starting]
org.eclipse.birt.report.data.oda.jdbc (2.3.2.r232_v20090212) "BIRT
ODA-JDBC Bridge Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile (2.3.2.r232_v20090211)
"JDBC Databases Profile Data Source ODA Runtime Driver" [Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb
(2.3.2.r232_v20090211) "BIRT Sample Database Connection Profile Plug-in"
[Starting]
org.eclipse.birt.report.data.oda.jdbc.dbprofile.ui (2.3.2.r232_v20090211)
"JDBC Databases Profile Data Source ODA Designer" [Starting]
org.eclipse.birt.report.data.oda.jdbc.ui (2.3.2.r232_v20090211) "BIRT JDBC
UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.sampledb (2.3.2.r232_v20090211) "BIRT
Sample Database" [Starting]
org.eclipse.birt.report.data.oda.sampledb.ui (2.3.2.r232_v20090211) "BIRT
Sample Database UI Plug-in" [Starting]
org.eclipse.birt.report.data.oda.xml (2.3.2.r232_v20090211) "BIRT ODA-XML
Driver" [Starting]
org.eclipse.birt.report.data.oda.xml.ui (2.3.2.r232_v20090211) "BIRT ODA
XML Designer" [Starting]
org.eclipse.birt.report.debug.core (2.3.2.r232_20090202) "BIRT Debug Core
Plug-in" [Resolved]
org.eclipse.birt.report.debug.ui (2.3.2.r232_20090202) "BIRT Debug UI
Plug-in" [Starting]
org.eclipse.birt.report.designer (2.3.2.r232_v20081010) "BIRT Report
Designer" [Resolved]
org.eclipse.birt.report.designer.core (2.3.2.r232_20090202) "BIRT Designer
Core" [Starting]
org.eclipse.birt.report.designer.samplereports (2.3.2.r232_20090202) "BIRT
Samplereports Plug-in" [Starting]
org.eclipse.birt.report.designer.ui (2.3.2.r232_20090202) "BIRT Designer
UI" [Starting]
org.eclipse.birt.report.designer.ui.cubebuilder (2.3.2.r232_20090202)
"BIRT Cube Builder Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editor.script (2.3.2.r232_20090202)
"BIRT Enhanced Script Editor Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editor.xml.wtp (2.3.2.r232_20090202)
"BIRT Advanced XML Editor Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors (2.3.2.r232_20090202) "BIRT
MultipageEditor Extension Point Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.editors.schematic
(2.3.2.r232_20090202) "BIRT Editors Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.ide (2.3.2.r232_20090202) "BIRT
Designer UI for IDE" [Starting]
org.eclipse.birt.report.designer.ui.lib (2.3.2.r232_20090202) "BIRT
Designer UI for Library" [Starting]
org.eclipse.birt.report.designer.ui.lib.explorer (2.3.2.r232_20090202)
"BIRT Library Explorer Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.preview.web (2.3.2.r232_20090202)
"BIRT Preview Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samples.ide (2.3.2.r232_20090202)
"Report Samples IDE Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.samplesview (2.3.2.r232_20090202)
"BIRT Report Samples View Plug-in" [Starting]
org.eclipse.birt.report.designer.ui.views (2.3.2.r232_20090202) "BIRT UI
Views Plug-in" [Starting]
org.eclipse.birt.report.engine (2.3.2.r232_20090217) "BIRT Engine"
[Starting]
org.eclipse.birt.report.engine.dataextraction (2.3.2.r232_20090122)
"Dataextraction Plug-in" [Starting]
org.eclipse.birt.report.engine.dataextraction.csv (2.3.2.r232_20090122)
"CSV Data Extraction Plug-in" [Starting]
org.eclipse.birt.report.engine.emitter.html (2.3.2.r232_20090202) "BIRT
HTML Emitter" [Starting]
org.eclipse.birt.report.engine.emitter.pdf (2.3.2.r232_20090202) "BIRT PDF
emitter" [Starting]
org.eclipse.birt.report.engine.emitter.postscript (2.3.2.r232_20090202)
"BIRT POSTSCRIPT emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.ppt (2.3.2.r232_20090202) "BIRT PPT
emitter" [Starting]
org.eclipse.birt.report.engine.emitter.prototype.excel
(2.3.2.r232_20090202) "BIRT Excel emitter" [Starting]
org.eclipse.birt.report.engine.emitter.wpml (2.3.2.r232_20090202) "BIRT
Word emitter" [Starting]
org.eclipse.birt.report.engine.fonts (2.3.2.r232_20090202) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.item.crosstab.core (2.3.2.r232_20090202) "BIRT
Crosstab Plug-in" [Starting]
org.eclipse.birt.report.item.crosstab.ui (2.3.2.r232_20090202) "BIRT
Crosstab UI Plug-in" [Starting]
org.eclipse.birt.report.model (2.3.2.r232_20090115) "BIRT Model" [Starting]
org.eclipse.birt.report.model.adapter.oda (2.3.2.r232_20090108) "BIRT
Model ODA Adapter" [Starting]
org.eclipse.birt.report.runtime (2.3.2.r232_v20081010) "BIRT Report
Runtime" [Resolved]
org.eclipse.birt.report.viewer (2.3.2.r232_20090212) "BIRT Web Viewer"
[Starting]
org.eclipse.birt.resources (2.3.2.r232_20081030) "BIRT Resources Plug-in"
[Resolved]
org.eclipse.buckminster.ant (1.1.0.r09861) "Buckminster Ant Plug-in"
[Starting]
org.eclipse.buckminster.cmdline (1.0.0.r09941) "Buckminster Headless
Launcher" [Starting]
org.eclipse.buckminster.core (1.1.340.r09948) "Buckminster Core" [Starting]
org.eclipse.buckminster.cvs (1.0.0.r09930) "Buckminster CVS Plug-in"
[Starting]
org.eclipse.buckminster.download (1.1.0.r09802) "Buckminster download
cache" [Starting]
org.eclipse.buckminster.executor (1.0.0.r09842) "Buckminster Executor
Plug-in" [Starting]
org.eclipse.buckminster.fetcher (1.0.0.r09849) "Buckminster Fetcher
Plug-in" [Starting]
org.eclipse.buckminster.generic (1.0.0.r09794) "Buckminster Generic
Plug-in" [Resolved]
org.eclipse.buckminster.generic.ui (1.0.0.r09795) "Buckminster Generic Ui
Plug-in" [Resolved]
org.eclipse.buckminster.installer (1.0.0.r09796) "Installer Plug-in"
[Resolved]
org.eclipse.buckminster.jdt (1.0.0.r09842) "Buckminster JDT Plug-in"
[Starting]
org.eclipse.buckminster.maven (1.1.0.r09904) "Buckminster Maven Plug-in"
[Starting]
org.eclipse.buckminster.opml (1.0.0.r09811) "Buckminster OPML support"
[Resolved]
org.eclipse.buckminster.osgi.filter (1.0.0) "OSGi Filter Bundle" [Resolved]
org.eclipse.buckminster.p4 (1.0.0.r09908) "Buckminster Perforce Plug-in"
[Starting]
org.eclipse.buckminster.p4.ui (1.0.0.r09842) "Buckminster Perforce UI
Plug-in" [Starting]
org.eclipse.buckminster.pde (1.1.340.r09942) "Buckminster PDE Plug-in"
[Starting]
org.eclipse.buckminster.pde.ui (1.0.0.r09842) "Buckminster Ui Plug-in for
the PDE extension" [Resolved]
org.eclipse.buckminster.remote (1.0.0.r09842) "Buckminster Remote"
[Resolved]
org.eclipse.buckminster.remote.cloudsmith (1.0.0.r09666) "Cloudsmith
Remote Resolution Service Connector" [Resolved]
org.eclipse.buckminster.runtime (1.1.0.r09908) "Buckminster Runtime
Plug-in" [Starting]
org.eclipse.buckminster.sax (1.0.0.r09855) "Buckminster SAX Parser
utilities" [Resolved]
org.eclipse.buckminster.slf4j (1.0.0) "Slf4j implementation using the
Buckminster logger" [Resolved]
org.eclipse.buckminster.ui (1.0.0.r09937) "Buckminster UI Plug-in"
[Starting]
org.eclipse.cdt.core (5.0.2.200902130801) "C/C++ Development Tools Core"
[Active]
org.eclipse.cdt.debug.core (5.0.2.200902130801) "C/C++ Development Tools
Debug Model" [Starting]
org.eclipse.cdt.debug.mi.core (5.0.1.200902130801) "C/C++ Development
Tools GDB/MI CDI Debugger Core" [Starting]
org.eclipse.cdt.debug.mi.ui (5.0.1.200902130801) "C/C++ Development Tools
GDB/MI CDI Debugger UI" [Starting]
org.eclipse.cdt.debug.ui (5.0.1.200902130801) "C/C++ Development Tools
org.eclipse.cdt.launch (5.0.2.200902130801) "C/C++ Development Tools
Launching Support" [Starting]
org.eclipse.cdt.make.core (5.0.2.200902130801) "C/C++ Standard make Build
Core" [Starting]
org.eclipse.cdt.mylyn (1.0.0.200902130801) "Mylyn Plug-in" [Resolved]
org.eclipse.cdt.mylyn.ui (5.0.1.200902130801) "Mylyn CDT Integrator"
[Active]
org.eclipse.cdt.ui (5.0.2.200902130801) "C/C++ Development Tools UI"
[Active]
org.eclipse.compare (3.4.1.r34x_20090121) "Compare Support" [Active]
org.eclipse.compare.examples (3.1.100.v20060606) "Compare Example"
[Starting]
org.eclipse.compare.examples.source (3.1.100.v20060606) "Compare Example
Source" [Resolved]
org.eclipse.compare.examples.xml (3.3.0.I20080604) "XML Compare Support"
[Starting]
org.eclipse.compare.examples.xml.source (3.3.0.I20080604) "XML Compare
Support Source" [Resolved]
org.eclipse.compare.source (3.4.1.r34x_20090121) "Compare Support Source"
[Resolved]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
org.eclipse.core.commands.source (3.4.0.I20080509-2000) "Commands Source"
[Resolved]
org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.contenttype.source (3.3.0.v20080604-1400) "Eclipse
Content Mechanism Source" [Resolved]
org.eclipse.core.databinding (1.1.1.M20080827-0800b) "JFace Data Binding"
[Active]
org.eclipse.core.databinding.beans (1.1.1.M20080827-0800a) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.beans.source (1.1.1.M20080827-0800a) "JFace
Data Binding for JavaBeans Source" [Resolved]
org.eclipse.core.databinding.source (1.1.1.M20080827-0800b) "JFace Data
Binding Source" [Resolved]
org.eclipse.core.expressions (3.4.1.r342_v20081203-0800) "Expression
Language" [Active]
org.eclipse.core.expressions.source (3.4.1.r342_v20081203-0800)
"Expression Language Source" [Resolved]
org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
org.eclipse.core.filebuffers.source (3.4.0.v20080603-2000) "File Buffers
Source" [Resolved]
org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems"
[Active]
org.eclipse.core.filesystem.source (1.2.0.v20080604-1400) "Core File
Systems Source" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.1.R34x_v20081128) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.jobs.source (3.4.1.R34x_v20081128) "Eclipse Jobs
org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management"
[Active]
org.eclipse.core.net.source (1.1.0.I20080604) "Internet Connection
Management Source" [Resolved]
org.eclipse.core.net.win32.x86 (1.0.0.I20080521) "Proxy for Windows"
[Resolved]
org.eclipse.core.resources (3.4.2.R34x_v20090126) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.compatibility.source (3.4.0.v20080604-1400)
"Core Resource Management Compatibility Fragment Source" [Resolved]
org.eclipse.core.resources.jmx (1.0.0.v20070510) "Resource Monitoring Core
Resources Extensions (Incubation)" [Starting]
org.eclipse.core.resources.source (3.4.2.R34x_v20090126) "Core Resource
org.eclipse.core.resources.win32.x86 (3.4.0.v20071204) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.auth.source (3.2.100.v20070502)
"Authorization Compatibility Plug-in Source" [Resolved]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.runtime.compatibility.registry.source (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment Source" [Resolved]
org.eclipse.core.runtime.compatibility.source (3.2.0.v20071008) "Core
Runtime Plug-in Compatibility Source" [Resolved]
org.eclipse.core.runtime.source (3.4.0.v20080512) "Core Runtime Source"
[Resolved]
org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables"
[Starting]
org.eclipse.core.variables.source (3.2.100.v20080529-1300) "Core Variables
Source" [Resolved]
org.eclipse.cvs (1.0.200.R342_v20090206) "Eclipse CVS Client" [Starting]
org.eclipse.cvs.source (1.0.200.R342_v20090206) "Eclipse CVS Client SDK"
[Resolved]
org.eclipse.datatools.common.doc.user (1.6.1.v20080828133713) "Data Tools
Platform Tutorial Documentation" [Resolved]
org.eclipse.datatools.connectivity (1.1.2.v200901090028) "Data Tools
Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.3.v200902070611)
"Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition
(1.0.2.v200901090940) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200807010433)
"Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200805231345)
"DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200810140922)
"Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200805152355)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.1.v200810300511) "Eclipse Data Tools Platform DBDefinition Generic
JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.6.1.v20080828133713) "Data
Tools Platform Connectivity Documentation" [Resolved]
org.eclipse.datatools.connectivity.doc.user.contexts
(1.6.1.v20080828133713) "Data Tools Platform Connectivity Documentation
for context-sensitive help" [Resolved]
org.eclipse.datatools.connectivity.oda (3.1.3.v200808270255) "DTP Open
Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.3.v200808270255) "DTP
ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.7.v200807231215) "DTP
ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.8.v200901061015)
"DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.8.v200812171046)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.8.v200812171046)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.7.v200812050755) "DTP
ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.v200805152355)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.7.v200902180551) "Eclipse
Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.3.v200902070558)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.3.v200902120834)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.3.v200901150027) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.3.v200810140349) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.templates (1.0.0.v200805152355) "DTP
Connectivity Templates Plug-in" [Starting]
org.eclipse.datatools.doc.isv (1.6.0.200806091108) "Data Tools
Documentation Plug-in" [Resolved]
org.eclipse.datatools.doc.user (1.6.1.v20080828133713) "Data Tools
Platform User Documentation" [Resolved]
org.eclipse.datatools.enablement.finfo (1.5.1.v200805152355) "Eclipse Data
Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200805152355) "Eclipse
Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200805152355)
"Eclipse Data Tools Platform HSQLDB Database Definition Enablement
Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200807220100) "Eclipse
Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.1.v200811210224)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.2.v200901090853) "DB2 UDB iSeries Database Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.1.v200811210224)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.3.v200901090853) "Eclipse Data Tools Platform DB2 UDB Database
Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.1.v200811210224)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.3.v200901060938) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200805160737)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200805152355)
"Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.3.v200811040352) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200806271414) "Eclipse
Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200901170137) "Data
Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200807181158)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200808222228)
"Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v200810160130) "Eclipse Data
Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200901090853)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.1.2.v200812171046) "Eclipse
Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.1.2.v200901191112) "Eclipse
Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.1.2.v200902111040) "Eclipse
Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.1.2.v200812171046) "Eclipse
Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200805152355) "Eclipse
Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.2.v200902030725)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200806260315) "Eclipse
Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200805152355)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.1.v200901090853) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200806060334)
"PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200805152355) "Eclipse
Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Definition
Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200805152355)
"Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200805310538) "High-level
Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200901150020) "Sybase
ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASA Database
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200805152355)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200805310538)
"Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200901170012)
"JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASE Database
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200805152355)
"Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200806260315) "ASE
Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200805152355)
"Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v20081212) "Sybase UI
Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200805152355) "Data Tools Platform Help
org.eclipse.datatools.intro (1.6.1.v200807021300) "Eclipse Data Tools
Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.1.v200901090853)
"Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200805152355) "Derby
Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.1.v200812031125) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200901241145) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200806070329) "SQL
Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200807080500)
"Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.0.v200810240330) "DTP ODA
Datatools Source" [Resolved]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200812121740) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.1.v200902140515) "Data Core
Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.1.v200901140830) "Data UI
Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200805152355) "Eclipse
Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200902031600) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200808140615) "Eclipse
Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.6.1.v20080828133713) "Data
Tools Platform SQL Dev Tools Documentation" [Resolved]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200902031600) "Eclipse
Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200808140615) "Eclipse
Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200811081015)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200810291500)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200812121520) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200902120900) "Eclipse Data
Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200807211830)
"Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200902031600) "Eclipse Data
Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200901280650) "SQL
Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200901220945) "Eclipse
Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200901151810) "Eclipse
Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200901280500)
"Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.v200808140615) "Eclipse
Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.v20080609)
"Traditional Memory Rendering" [Starting]
org.eclipse.dd.debug.ui.memory.transport (1.0.0.v20080609) "Memory
Transport Plug-in" [Starting]
org.eclipse.dd.dsf (1.0.0.v20080609) "Debug Services Framework Core"
[Starting]
org.eclipse.dd.dsf.debug (1.0.0.v20080609) "Debug Services Framework
Debug" [Starting]
org.eclipse.dd.dsf.debug.ui (1.0.0.v20080609) "Debug Services Framework
Debug UI" [Starting]
org.eclipse.dd.dsf.ui (1.0.0.v20080609) "Debug Services Framework UI"
[Starting]
org.eclipse.dd.gdb (1.0.0.v20080609) "GDB DSF Debugger Integration Core"
[Starting]
org.eclipse.dd.gdb.launch (1.0.0.v20080609) "Debug Services Framework GDB
Launch Plug-in" [Starting]
org.eclipse.dd.gdb.ui (1.0.0.v20080609) "Debug Services Framework GDB UI
Plug-in" [Starting]
org.eclipse.dd.ipxact (0.9.0.v20080609) "Bundle-Name.0" [Resolved]
org.eclipse.dd.ipxact.checker.core (0.9.0.v20080609) "IP-XACT Document
Checker" [Starting]
org.eclipse.dd.ipxact.checker.ui (0.9.0.v20080609) "IP-XACT Checker Ui
Plug-in" [Starting]
org.eclipse.dd.ipxact.docs (0.9.0.v20080609) "IP-XACT Editor Docs Plug-in"
[Resolved]
org.eclipse.dd.ipxact.editor.core (0.9.0.v20080609) "IP-XACT Editor Core"
[Starting]
org.eclipse.dd.ipxact.editor.ui (0.9.0.v20080609) "IP-XACT Editor UI"
[Starting]
org.eclipse.dd.ipxact.validator.ui (0.9.0.v20080609) "IP-XACT validator"
[Starting]
org.eclipse.dd.mi (1.0.0.v20080609) "GDB/MI Protocol-based DSF Debugger
Integration Core" [Starting]
org.eclipse.debug.core (3.4.1.v20090106_r342) "Debug Core" [Active]
org.eclipse.debug.core.source (3.4.1.v20090106_r342) "Debug Core Source"
[Resolved]
org.eclipse.debug.examples.core (1.0.0) "Example Debug Core Plug-in"
[Starting]
org.eclipse.debug.examples.core.source (1.0.0) "Example Debug Core Plug-in
Source" [Resolved]
org.eclipse.debug.examples.ui (1.0.0) "Example Debug UI Plug-in" [Starting]
org.eclipse.debug.examples.ui.source (1.0.0) "Example Debug UI Plug-in
Source" [Resolved]
org.eclipse.debug.ui (3.4.2.v20090110_r342) "Debug UI" [Active]
org.eclipse.debug.ui.source (3.4.2.v20090110_r342) "Debug UI Source"
[Resolved]
org.eclipse.dltk (0.95.0.v20080526-1423) "Eclipse Dynamic Languages
Toolkit (Incubation)" [Resolved]
org.eclipse.dltk.console (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Console Core (Incubation)" [Starting]
org.eclipse.dltk.console.ui (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Console UI (Incubation)" [Active]
org.eclipse.dltk.core (0.95.1.v20080920-R0951) "Dynamic Languages Toolkit
Core (Incubation)" [Active]
org.eclipse.dltk.debug (0.95.1.v20080903-1434) "Dynamic Languages Toolkit
Debug Core (Incubation)" [Starting]
org.eclipse.dltk.debug.ui (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Debug UI (Incubation)" [Starting]
org.eclipse.dltk.itcl (0.95.0.v20080526-1423) "iTcl Extension Support for
TCL language (Incubation)" [Resolved]
org.eclipse.dltk.itcl.core (0.95.1.v20080903-1434) "pluginName" [Starting]
org.eclipse.dltk.itcl.ui (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit IncrTcl UI" [Starting]
org.eclipse.dltk.launching (0.95.1.v20080915-1703) "Dynamic Languages
Toolkit Launching Core (Incubation)" [Active]
org.eclipse.dltk.mylyn (0.95.1.v20080903-1434) "Dynamic Languages Toolkit
IncrTcl Core" [Active]
org.eclipse.dltk.rse.core (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit RSE Integration Core (Incubation)" [Active]
org.eclipse.dltk.rse.ui (0.95.0.v20080609-1540) "Dynamic Languages Toolkit
RSE Integration UI (Incubation)" [Starting]
org.eclipse.dltk.ruby (0.95.0.v20080526-1423) "Ruby Development Tools
org.eclipse.dltk.ruby.abstractdebugger (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit Ruby Debuggers Support (Incubation)" [Starting]
org.eclipse.dltk.ruby.activestatedebugger (0.95.0.v20080604-1628) "Dynamic
Languages Toolkit Ruby ActiveState Debugger Support (Incubation)"
[Starting]
org.eclipse.dltk.ruby.basicdebugger (0.95.1.v20080626-2043) "Dynamic
Languages Toolkit Ruby Built-In Debugger Support (Incubation)" [Starting]
org.eclipse.dltk.ruby.core (0.95.1.v20080920-R0951) "Dynamic Languages
Toolkit Ruby Core (Incubation)" [Active]
org.eclipse.dltk.ruby.debug (0.95.0.v20080604-1306) "Dynamic Languages
Toolkit Ruby Debug (Incubation)" [Starting]
org.eclipse.dltk.ruby.debug.ui (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Ruby Debug UI (Incubation)" [Starting]
org.eclipse.dltk.ruby.fastdebugger (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit Ruby Fast Debugger Support (Incubation)" [Starting]
org.eclipse.dltk.ruby.launching (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Ruby Launching (Incubation)" [Starting]
org.eclipse.dltk.ruby.ui (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Ruby UI (Incubation)" [Active]
org.eclipse.dltk.tcl (0.95.0.v20080526-1423) "Tcl Development Tools
org.eclipse.dltk.tcl.activestatedebugger (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit Tcl Active State Debugger Support (Incubation)"
[Starting]
org.eclipse.dltk.tcl.core (0.95.1.v20080920-R0951) "Dynamic Languages
Toolkit Tcl Core (Incubation)" [Active]
org.eclipse.dltk.tcl.debug (0.95.0.v20080526-1423) "Dynamic Languages
Toolkit Tcl Debug Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.debug.ui (0.95.1.v20080626-2043) "Dynamic Languages
Toolkit Tcl Debug UI (Incubation)" [Starting]
org.eclipse.dltk.tcl.doc.user (0.95.0.v20080609-1540) "Tcl Development
User Guide (Incubation)" [Starting]
org.eclipse.dltk.tcl.launching (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Tcl Launching Core (Incubation)" [Starting]
org.eclipse.dltk.tcl.tclchecker (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit TclChecker Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.testing (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit Tcl Testing Frameworks Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.testing.tcltest (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit TclTest Support (Incubation)" [Starting]
org.eclipse.dltk.tcl.ui (0.95.1.v20080920-R0951) "Dynamic Languages
Toolkit Tcl UI (Incubation)" [Active]
org.eclipse.dltk.testing (0.95.0.v20080609-1540) "Dynamic Languages
Toolkit Testing Frameworks Support (Incubation)" [Starting]
org.eclipse.dltk.ui (0.95.1.v20080920-R0951) "Dynamic Languages Toolkit
Core UI (Incubation)" [Active]
org.eclipse.dltk.validators.core (0.95.1.v20080707-1511) "Dynamic
Languages Toolkit Validators Core (Incubation)" [Starting]
org.eclipse.dltk.validators.ui (0.95.1.v20080707-1511) "Dynamic Languages
Toolkit Validators UI (Incubation)" [Starting]
org.eclipse.dltk.xotcl (0.95.0.v20080605-1144) "XOTcl Extension Support
for TCL language (Incubation)" [Resolved]
org.eclipse.dltk.xotcl.core (0.95.1.v20080903-1434) "Dynamic Languages
Toolkit XOTcl Core" [Starting]
org.eclipse.dltk.xotcl.testing.xounit (0.95.1.v20080903-1434) "Dynamic
Languages Toolkit XOUnit Framework Support (Incubation)" [Starting]
org.eclipse.dltk.xotcl.ui (0.95.1.v20080626-2043) "Dynamic Languages
Toolkit XOTcl UI" [Starting]
org.eclipse.draw2d (3.4.2.v20090114-1330) "Graphical Editing Framework
Draw2d" [Starting]
org.eclipse.draw2d.doc.isv (3.4.1.v20080806) "Graphical Editing Framework
Draw2d Documentation" [Starting]
"Graphical Editing Framework Draw2d Developer Resources" [Resolved]
org.eclipse.dstore.core (3.0.3.v200902101918) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.0.v20080406) "RSE DStore Platform Support"
[Starting]
org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Active]
org.eclipse.ecf.core.source (2.1.0.v20081224-1728) "ECF Core Source"
[Resolved]
org.eclipse.ecf.datashare (1.3.0.v20081224-1728) "ECF DataShare API"
[Resolved]
org.eclipse.ecf.discovery (2.1.0.v20081224-1728) "ECF Discovery API"
[Active]
org.eclipse.ecf.discovery.ui (2.0.0.v20081224-1728) "ECF Discovery UI"
[Starting]
org.eclipse.ecf.doc (1.3.0.v20081224-1728) "ECF Documentation" [Starting]
org.eclipse.ecf.docshare (2.0.0.v20081224-1728) "ECF DocShare Plugin"
[Active]
org.eclipse.ecf.example.clients (1.3.0.v20081224-1728) "ECF Clients
Example" [Resolved]
org.eclipse.ecf.example.collab (1.3.0.v20081224-1728) "ECF Collaboration
Examples" [Starting]
org.eclipse.ecf.example.collab.editor (1.0.200.v20081224-1728) "ECF Shared
Editor Example" [Starting]
org.eclipse.ecf.examples.remoteservices.client (1.0.100.v20081224-1728)
"ECF RemoteService Example Client" [Starting]
org.eclipse.ecf.examples.remoteservices.common (1.0.100.v20081224-1728)
"ECF RemoteService Example Common" [Starting]
org.eclipse.ecf.examples.remoteservices.server (1.0.100.v20081224-1728)
"ECF RemoteService Example Server" [Starting]
org.eclipse.ecf.examples.source (2.1.0.v20081224-1728) "ECF Examples
Source" [Resolved]
org.eclipse.ecf.examples.updatesite.client (1.0.100.v20081224-1728) "ECF
Updatesite Example Client" [Starting]
org.eclipse.ecf.examples.updatesite.server (1.0.100.v20081224-1728) "ECF
Updatesite Example Server" [Starting]
org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer API"
[Active]
org.eclipse.ecf.filetransfer.ui (1.4.0.v20081224-1728) "ECF File Transfer
UI" [Starting]
org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API" [Active]
org.eclipse.ecf.presence (1.4.0.v20081224-1728) "ECF Presence API"
[Starting]
org.eclipse.ecf.presence.bot (1.2.0.v20081224-1728) "ECF Presence Bot API"
[Starting]
org.eclipse.ecf.presence.collab.ui (1.2.0.v20081224-1728) "ECF Presence
Collaboration UI" [Active]
org.eclipse.ecf.presence.ui (1.2.0.v20081224-1728) "ECF Presence UI"
[Starting]
org.eclipse.ecf.protocol.bittorrent (0.3.0) "ECF BitTorrent Protocol
Implementation" [Resolved]
org.eclipse.ecf.protocol.msn (1.2.0.v20081224-1728) "ECF MSN Protocol
org.eclipse.ecf.provider (1.3.0.v20081224-1728) "ECF Provider API" [Active]
org.eclipse.ecf.provider.bittorrent (0.3.100.v20081224-1728) "ECF
Bittorrent Provider" [Active]
org.eclipse.ecf.provider.bittorrent.ui (0.2.0.v20081224-1728) "ECF
Bitorrent Provider UI" [Starting]
org.eclipse.ecf.provider.datashare (1.3.0.v20081224-1728) "ECF Datashare
Provider" [Starting]
org.eclipse.ecf.provider.discovery (2.1.100.v20081224-1728) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.efs (1.5.0.v20081224-1728) "ECF EFS
Provider" [Active]
org.eclipse.ecf.provider.filetransfer.scp (2.0.0.v20081224-1728) "ECF SCP
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.irc (1.3.0.v20081224-1728) "ECF IRC Provider"
[Active]
org.eclipse.ecf.provider.irc.ui (1.3.0.v20081224-1728) "ECF IRC UI"
[Starting]
org.eclipse.ecf.provider.jmdns (2.1.0.v20081224-1728) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.jslp (2.1.0.v20081224-1728) "ECF SLP Discovery
Provider" [Active]
org.eclipse.ecf.provider.msn (1.2.0.v20081224-1728) "ECF MSN Provider"
[Active]
org.eclipse.ecf.provider.msn.ui (1.3.0.v20081224-1728) "ECF MSN Provider
UI" [Starting]
org.eclipse.ecf.provider.r_osgi (2.0.100.v20081224-1728) "ECF R-OSGi
Remoteservice Provider" [Active]
org.eclipse.ecf.provider.remoteservice (1.3.100.v20081224-1728) "ECF
RemoteService Provider" [Starting]
org.eclipse.ecf.provider.ui (1.3.0.v20081224-1728) "ECF Provider UI"
[Starting]
org.eclipse.ecf.provider.xmpp (2.0.100.v20081224-1728) "ECF XMPP Provider"
[Active]
org.eclipse.ecf.provider.xmpp.ui (2.1.0.v20081224-1728) "ECF XMPP Provider
UI" [Starting]
org.eclipse.ecf.remoteservice (2.0.0.v20081224-1728) "ECF RemoteService
API" [Starting]
org.eclipse.ecf.remoteservice.ui (2.0.0.v20081224-1728) "ECF Remote
Services UI" [Starting]
org.eclipse.ecf.server (1.3.0.v20081224-1728) "ECF Server API" [Starting]
org.eclipse.ecf.server.generic (1.2.1.v20081224-1728) "ECF Generic Server"
[Starting]
org.eclipse.ecf.sharedobject (1.3.100.v20081224-1728) "ECF Sharedobject
API" [Active]
org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication
Framework (ECF)" [Resolved]
org.eclipse.ecf.storage (1.0.0.v20081224-1728) "ECF Storage Plug-in"
[Active]
org.eclipse.ecf.sync (1.0.0.v20081224-1728) "ECF Synchronization API"
[Starting]
org.eclipse.ecf.telephony.call (1.3.0.v20081224-1728) "ECF Telephony Call
API" [Starting]
org.eclipse.ecf.telephony.call.ui (1.2.0.v20081224-1728) "ECF Call UI"
[Starting]
org.eclipse.ecf.ui (2.0.0.v20081224-1728) "ECF UI" [Starting]
org.eclipse.emf (2.4.0.v200902171115) "EMF - Eclipse Modeling Framework"
[Starting]
org.eclipse.emf.ant (2.4.0.v200902171115) "EMF Ant Tasks" [Starting]
[Starting]
Generator" [Starting]
Generator UI" [Starting]
[Starting]
org.eclipse.emf.common (2.4.0.v200902171115) "EMF Common" [Starting]
org.eclipse.emf.common.ui (2.4.0.v200902171115) "EMF Common UI" [Starting]
org.eclipse.emf.converter (2.4.0.v200902171115) "EMF Model Converter"
[Starting]
[Starting]
Binding" [Starting]
org.eclipse.emf.ecore (2.4.2.v200902171115) "EMF Ecore" [Starting]
org.eclipse.emf.ecore.change (2.4.0.v200902171115) "EMF Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.4.0.v200902171115) "EMF Change Edit"
[Starting]
[Starting]
Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.4.1.v200902171115) "EMF XML/XMI Persistence"
[Starting]
org.eclipse.emf.edit (2.4.2.v200902171115) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.4.2.v200902171115) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.4.0.v200902171115) "EMF Model Exporter"
[Starting]
org.eclipse.emf.importer (2.4.1.v200902171115) "EMF Model Importer"
[Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200902171115) "EMF Ecore Importer"
[Starting]
org.eclipse.emf.importer.java (2.4.1.v200902171115) "EMF Annotated Java
Importer" [Starting]
org.eclipse.emf.importer.rose (2.4.0.v200902171115) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.4.0.v200902171115) "EMF Mapping" [Starting]
[Starting]
Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.4.0.v200902171115) "EMF Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200902171115) "EMF
Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.4.0.v200902171115) "EMF Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.4.0.v200902171115) "EMF Ecore to
XML Mapping Editor" [Starting]
[Starting]
org.eclipse.emf.mint.ui.source (0.7.1.v200809162149) "Mint UI (Incubation)
Source" [Resolved]
org.eclipse.emf.ocl (1.1.101.v200808291106) "Object Constraint Language
(OCL) 2.0 Compatibility API" [Starting]
org.eclipse.emf.query (1.2.0.v200805130238) "EMF Model Query" [Starting]
org.eclipse.emf.query.ocl (1.2.0.v200805130238) "EMF Model Query OCL
org.eclipse.emf.search (0.7.0.v200806130939) "Model Search Core
org.eclipse.emf.search.common (0.7.0.v200806130939) "Model Search Common
org.eclipse.emf.search.common.ui (0.7.0.v200806130939) "Model Search
Common Ui (Incubation)" [Starting]
Search (Incubation)" [Starting]
org.eclipse.emf.search.ecore.ocl.ui (0.7.0.v200806130939) "OCL Model
Search Ui (Incubation)" [Starting]
org.eclipse.emf.search.ecore.ui (0.7.0.v200806130939) "Ecore Model Search
org.eclipse.emf.search.ocl.ui (0.7.0.v200806130939) "Ecore Model Search
OCL Ui (Incubation)" [Starting]
org.eclipse.emf.search.ui (0.7.0.v200806130939) "Model Search Ui
org.eclipse.emf.transaction (1.2.1.v200807161719) "EMF Model Transaction
Core" [Starting]
org.eclipse.emf.transaction.ui (1.2.0.v200805130238) "EMF Model
Transaction UI" [Starting]
org.eclipse.emf.validation (1.2.0.v200807161729) "EMF Validation Framework
Core" [Starting]
org.eclipse.emf.validation.ocl (1.2.0.v200805130238) "EMF Validation
Framework OCL Integration" [Resolved]
org.eclipse.emf.validation.ui (1.2.0.v200805130238) "EMF Validation
Framework UI" [Starting]
org.eclipse.emf.validation.ui.ide (1.2.0.v200805130238) "EMF Validation
Framework UI IDE" [Starting]
org.eclipse.emf.workspace (1.2.3.v200902100421) "EMF Model Transaction
Workbench Integration Core" [Starting]
org.eclipse.emf.workspace.ui (1.2.0.v200805130238) "EMF Model Transaction
Workbench Integration UI" [Starting]
org.eclipse.epp.usagedata.gathering (1.0.1.R200809220400) "Usage Data
Gathering Plug-in" [Starting]
org.eclipse.epp.usagedata.recording (1.0.1.R200809220400) "Usage Data
Recording Plug-in" [Starting]
org.eclipse.epp.usagedata.ui (1.0.1.R200809220400) "Usage Data UI Plug-in"
[Starting]
org.eclipse.equinox.app (1.1.0.v20080421-2006) "Equinox Application
Container" [Active]
org.eclipse.equinox.app.source (1.1.0.v20080421-2006) "Equinox Application
Container Source" [Resolved]
org.eclipse.equinox.cm (1.0.1.R34x_v20090107-1200) "Configuration Admin"
[Resolved]
org.eclipse.equinox.cm.source (1.0.1.R34x_v20090107-1200) "Configuration
Admin Source" [Resolved]
org.eclipse.equinox.common (3.4.0.v20080421-2006) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.common.source (3.4.0.v20080421-2006) "Common Eclipse
Runtime Source" [Resolved]
org.eclipse.e
Re: Ganymede & Mylyn [message #596860 is a reply to message #66855] Wed, 18 March 2009 23:18 Go to previous message
*** User Preferences:
#Wed Mar 18 20:19:23 PDT 2009
/instance/org.eclipse.core.resources/description.filestatelo ngevity=1209600000
/project/trunk/org.eclipse.wst.html.core/attrInvalidName=2
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/file\:_C\:_Documents\
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/version=1.0.0
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/url=file\:/C\:/Docu ments
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/69/data/listener_1925729951/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/enabled =true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/file\:_C\:_Documents\
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/type=org.eclipse.equinox.internal.p2.metada ta.repository.LocalMetadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/name=artifact
listener file\:/C\:/Documents and
Settings/Dennis/Desktop/eclipse/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="tag"
name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info >\r\n<info
extension\="adapter" name\="*">\r\n<editor
id\=" org.eclipse.hyades.logging.adapter.ui.internal.presentation. AdaptorEditorID "/>\r\n</info>\r\n<info
extension\="shtml" name\="*">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info
extension\="cfm" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n</info>\r\n <info
extension\="umldeployment_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgraph" name\="*">\r\n<editor
id\="org.eclipse.gmf.gmfgraph.presentation.GMFGraphEditorID "/>\r\n</info>\r\n<info
extension\="cspec" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n </info>\r\n<info
extension\="tagf" name\="*">\r\n<editor
extension\="umlusc" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlclass" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlstm" name\="*">\r\n<editor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n<defaultEditor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n</info>\r\n<info
extension\="itcl" name\="*">\r\n<editor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n</info >\r\n<info
extension\="js" name\="*">\r\n<editor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n <defaultEditor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n </info>\r\n<info
extension\="gmfmap" name\="*">\r\n<editor
id\="org.eclipse.gmf.mappings.presentation.GMFMapEditorID"/ >\r\n</info>\r\n<info
extension\="sqlpage" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<defaultEditor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n</info>\r\n<info
extension\="jsp" name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n </info>\r\n<info
extension\="cspex" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n </info>\r\n<info
extension\="override" name\="*">\r\n<editor
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info >\r\n<info
extension\="tagx" name\="*">\r\n<editor
extension\="umlprofile_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgen" name\="*">\r\n<editor
id\="org.eclipse.gmf.codegen.gmfgen.presentation.GMFGenEditorID "/>\r\n</info>\r\n<info
extension\="jspx" name\="*">\r\n<editor
extension\="properties" name\="sample">\r\n<editor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info
extension\="class" name\="*">\r\n<editor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n <defaultEditor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n </info>\r\n<info
extension\="jspf" name\="*">\r\n<editor
extension\="umlcsd" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n</info>\r\n<info
extension\="gmftool" name\="*">\r\n<editor
id\="org.eclipse.gmf.tooldef.presentation.GMFToolEditorID"/ >\r\n</info>\r\n<info
extension\="trcpxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCProcessEdito r "/>\r\n</info>\r\n<info
extension\="cfc" name\="*">\r\n<editor
extension\="tcl" name\="*">\r\n<editor
extension\="usr" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.propertysheet.UserEditor"/>\r\n </info>\r\n<info
extension\="umlusecase_diagram" name\="*">\r\n<editor
extension\="xpt" name\="*">\r\n<editor
id\="org.eclipse.gmf.xpand.XpandEditor"/>\r\n</info>\r\n <info
extension\="umlactivity_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="readme" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.readmetool.ReadmeEditor"/>\r\n </info>\r\n<info
extension\="cfml" name\="*">\r\n<editor
extension\="umlclass_diagram" name\="*">\r\n<editor
extension\="test" name\="*">\r\n<editor
extension\="trcnxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCNodeEditor "/>\r\n</info>\r\n<info
extension\="sql" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<editor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<defaultEditor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n</info >\r\n<info
extension\="exp" name\="*">\r\n<editor
extension\="umldepl" name\="*">\r\n<editor
extension\="jpage" name\="*">\r\n<editor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info
extension\="umlstatemachine_diagram" name\="*">\r\n<editor
extension\="ddl" name\="*">\r\n<editor
extension\="html" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n <editor
extension\="htm" name\="*">\r\n<editor
extension\="mpe" name\="*">\r\n<editor
id\=" org.eclipse.ui.examples.multipageeditor.MultiPageEditorExamp le "/>\r\n</info>\r\n<info
extension\="jsf" name\="*">\r\n<editor
extension\="umlcomponent_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="xml" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n<editor
id\=" org.eclipse.ui.examples.templateeditor.editors.TemplateEdito r "/>\r\n</info>\r\n<info
extension\="rb" name\="*">\r\n<editor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n</info >\r\n<info
extension\="spirit" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n</info>\r\n<info
extension\="symptom" name\="*">\r\n<editor
id\=" org.eclipse.tptp.symptom.internal.presentation.SymptomEditor "/>\r\n</info>\r\n<info
extension\="umlcompositestructures_diagram" name\="*">\r\n<editor
extension\="ecore_diagram" name\="*">\r\n<editor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n <defaultEditor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n </info>\r\n<info
extension\="trcaxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCAgentEditor "/>\r\n</info>\r\n<info
extension\="xhtml" name\="*">\r\n<editor
extension\="probe" name\="*">\r\n<editor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n<defaultEditor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n</info>\r\n<info
extension\="rmap" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n </info>\r\n<info
extension\="jav" name\="*">\r\n<editor
id\="org.eclipse.ui.JavaEditor"/>\r\n</info>\r\n<info extension\="xotcl"
extension\="umlcomp" name\="*">\r\n<editor
extension\="cquery" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n </info>\r\n<info
extension\="umlact" name\="*">\r\n<editor
extension\="pda" name\="*">\r\n<editor id\="pda.editor"/>\r\n<editor
id\="pda.editor"/>\r\n<defaultEditor
id\="pda.editor"/>\r\n</info>\r\n<info extension\="jardesc"
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info
extension\="trcmxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCMonitorEdito r "/>\r\n</info>\r\n<info
extension\="server" name\="*">\r\n<editor
id\="org.eclipse.wst.server.ui.editor"/>\r\n</info>\r\n <info
extension\="trcdbxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.sdb.internal.editors.SymptomDBEditor "/>\r\n</info>\r\n</editors>
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.wst.sse.core/task-tags/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=The
Eclipse Project Updates
/instance/org.eclipse.wst.jsdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes_/isSystem=false
@org.eclipse.dltk.mylyn=0.95.1.v20080903-1434
/instance/org.eclipse.core.resources/description.maxfilestat es=100
@org.eclipse.wst.sse.core=1.1.303.v200901290024
/instance/org.eclipse.ui.editors/changeIndicationInOverviewR uler=true
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby.genericDriverTemplate=true
/instance/org.eclipse.mylyn.context.core/mylyn.attention.mig rated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags =TODO
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskPriorities=NORMAL,HIGH,NORMAL
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.fo rmatterprofiles.version=11
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.metadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/enabled=true
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/name=artifact
listener dropins
@org.eclipse.jdt.core=3.4.4.v_894_R34x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/enabled=false
/instance/org.cfeclipse.cfml/SQLTextColor=91,249,174
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/type=org.eclip se.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/63/data/listener_-205926309/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/url=http\://download.eclipse.org/technology/epp/updates/1.0/
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.ord er.connections=sagan.Local
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/name=download
cache
/project/trunk/org.eclipse.wst.html.core/piInvalidContent=2
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/url=file\:/C\:/Documents
and Settings/Dennis/Desktop/eclipse/p2/org.eclipse.equinox.p2.co re/cache/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/url= http\://download.eclipse.org/tools/gef/update-site/releases/ site.xml
@org.eclipse.wst.jsdt.core=1.0.104.v200901281939
/instance/org.cfeclipse.cfml/cfnumberColor=226,194,148
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/enabled=false
/project/trunk/org.eclipse.wst.html.core/elemEndInvalidCase= 1
/instance/org.eclipse.wst.sse.ui/matchingBracketsColor=255,0 ,128
/instance/org.cfeclipse.cfml/cfstringColor=191,205,240
and\
Settings_Dennis_Desktop_eclipse_.eclipseextension/url=file\: /C\:/Documents
and Settings/Dennis/Desktop/eclipse/.eclipseextension
/instance/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=alway s
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/version =1
/instance/org.eclipse.dltk.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.dltk.ruby.ui/useAnnotationsPrefPage=tr ue
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/url=file\ :/C\:/Documents
and Settings/Dennis/Desktop/Ganymede/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/url=http\://www.eclipse.org/mylyn/downloads/
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.org_tptp_updates_/enabled=false
/instance/org.eclipse.compare/StructureViewerAliases=CLASSPA TH.XML
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
and\ Settings_Dennis_Desktop_eclipse/description=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskCaseSensitive=enabled
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/enabled=false
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .url=local
/project/trunk/org.eclipse.wst.html.core/cdataInvalidContent =2
@org.eclipse.jst.j2ee.webservice.ui=1.1.201.v200811062130
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.equinox.p2.ui.sdk/enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.eclipse.core.resources/version=1
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/url=http\://download.eclipse.org/tools/buckminster/updates
@org.eclipse.wst.jsdt.ui=1.0.104.v200901290004
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/version=1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /isSystem=false
/project/trunk/org.eclipse.wst.html.core/elemInvalidDirectiv e=1
/instance/org.eclipse.dltk.core/editor_folding_enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/de scription=
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.ge ttersetter.use.is=true
/instance/org.eclipse.jdt.ui/content_assist_favorite_static_ members=
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/name=metadata
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/isS ystem=false
@org.eclipse.rse.ui=3.0.3.v200902042310
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/na me=Ganymede
Update Site
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndAddLi ne=false
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby102.genericDriverTemplate=true
/project/trunk/org.eclipse.wst.html.core/attrNameMismatch=2
/instance/org.eclipse.jdt.ui/fontPropagated=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/name=Mylyn
for Eclipse 3.4
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/description=
/instance/org.eclipse.core.runtime/content-types/org.eclipse .wst.html.core.htmlsource/file-extensions=cfm,cfc,cfml
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/enabled=false
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jst.j2ee.navigator.ui.java.resource.decorator\:true,or g.eclipse.jst.jee.navigator.ui.java.resource.decorator\:true ,org.eclipse.team.pessimistic.ui.decorator\:true,org.eclipse .wst.server.ui.decorator\:false,org.cfeclipse.cfml.ui.decora tors.cfcdecorator\:true,org.cfeclipse.cfml.ui.decorators.cfe readonlydecorator\:true,org.eclipse.cdt.ui.indexedFiles\:fal se,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.DependencyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.ColumnDecoration\:tr ue,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.ForeignKeyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.IndexTriggerDecorati on\:true,org.eclipse.datatools.connectivity.internal.core.ui .bookmarkDecoration\:true,org.eclipse.datatools.connectivity .internal.core.ui.FilterNodeDecoration\:true,org.eclipse.dat atools.connectivity.ui.decorator.contentextension\:false,org .eclipse.datatools.enablement.sybase.asa.proxytabledecorator \:true,org.eclipse.datatools.enablement.sybase.ase.webservic etabledecorator\:true,org.eclipse.datatools.enablement.sybas e.systemtabledecorator\:true,org.eclipse.dd.ipxact.editor.ui .decorators.DuplicateDecorator\:true,org.eclipse.dltk.ruby.p rojectdecorator\:true,org.eclipse.dltk.tcl.decorators.projec tdecorator\:true,org.eclipse.jdt.ui.override.decorator\:true ,org.eclipse.jdt.ui.interface.decorator\:false,org.eclipse.j st.j2ee.internal.ui.util.AnnotationIconDecorator_ejb\:true,o rg.eclipse.jst.j2ee.navigator.internal.J2EEProjectDecorator\ :true,org.eclipse.jst.jee.ui.internal.navigator.ejb.BeanDeco rator\:true,org.eclipse.jst.jee.navigator.internal.JEEProjec tDecorator\:true,org.eclipse.jst.j2ee.internal.ui.util.Annot ationIconDecorator_servlet\:true,org.eclipse.mylyn.context.u i.decorator.interest\:true,org.eclipse.mylyn.tasks.ui.decora tors.task\:true,org.eclipse.mylyn.team.ui.changeset.decorato r\:true,org.eclipse.nab.mwt.ab.core.MwtManageSourceDecorator \:true,org.eclipse.pde.ui.binaryProjectDecorator\:false,org. eclipse.rse.core.virtualobject.decorator\:true,org.eclipse.r se.core.binary.executable.decorator\:true,org.eclipse.rse.co re.script.executable.decorator\:true,org.eclipse.rse.core.ja va.executable.decorator\:true,org.eclipse.rse.core.library.d ecorator\:true,org.eclipse.rse.core.link.decorator\:true,org .eclipse.rse.subsystems.error.decorator\:true,org.eclipse.te am.cvs.ui.decorator\:true,org.eclipse.tptp.monitoring.manage dagent.views.browser.decorator\:true,org.eclipse.ui.LinkedRe sourceDecorator\:true,org.eclipse.ui.ContentTypeDecorator\:t rue,org.eclipse.wst.jsdt.ui.override.decorator\:true,org.ecl ipse.wst.jsdt.ui.interface.decorator\:false,
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/isSystem=false
/instance/org.eclipse.dltk.ui/editor_folding_enabled=true
@org.eclipse.ui=3.4.2.M20090204-0800
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/version=1.0.0
/instance/org.eclipse.wst.jsdt.ui/content_assist_category_or der=org.eclipse.wst.jsdt.ui.templateProposalCategory\:0\u000 0org.eclipse.wst.jsdt.ui.javaNoTypeProposalCategory\:1\u0000 org.eclipse.wst.jsdt.ui.textProposalCategory\:2\u0000
/project/trunk/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_nab_updates/isS ystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/version=1
/instance/org.cfeclipse.cfml/CFUnitFacadeLocation=localhost\ :82/net/sourceforge/cfunit/framework
/instance/org.eclipse.wst.ws.service.policy/org.eclipse.wst. ws.service.policy.ui.servicepols.wsiprofilecomp.wsissbp.defa ultProtocol=http\://schemas.xmlsoap.org/wsdl/soap/
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndTrim= true
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.timeoutForParameterNameFromAttachedJavadoc=50
/instance/org.cfeclipse.cfml/htmFormTagColor=255,255,128
and\ Settings_Dennis_Desktop_eclipse/suffix=artifacts.xml
/project/trunk/org.eclipse.wst.html.core/docInvalidContent=2
@org.eclipse.dltk.core=0.95.1.v20080920-R0951
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/name=C\:\\ Documents
and Settings\\Dennis\\Desktop\\eclipse\\.eclipseextension
@org.eclipse.birt.report.data.oda.jdbc.ui=2.3.2.r232_v200902 11
/instance/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=file\:/builds/M/org.eclipse.releng.eclipsebuilder/../sr c/repo
- artifacts
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /url=http\://download.eclipse.org/birt/update-site/2.3
/instance/org.cfeclipse.cfml/cfscriptfunctionColor=255,255,0
/instance/org.eclipse.wst.jsdt.ui/useAnnotationsPrefPage=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/isSystem=false
/instance/org.eclipse.birt.report.designer.ui/Palette\ Size=125
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/url=file\:/C\:/Docum ents
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/63/data/listener_-177846376/
/project/trunk/de.loskutov.anyedit.AnyEditTools/removeTraili ngSpaces=true
/instance/org.eclipse.ui/defaultPerspectiveId=org.cfeclipse. cfml.perspective.CFML
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/descripti on=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_webtools_updates/typ e=org.eclipse.equinox.internal.p2.metadata.repository.LocalM etadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/url=http\://andrei.gmxhome.de/eclipse/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_dd_updates/url=http\://download.eclipse.org/dsdp/dd/updates
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/url=http\://download.eclipse.org/modeling/emft/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/isSystem=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.bracketMatchin gStyle=0
/project/PROD/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.cfeclipse.org_update/url=http\://www.cfeclipse.org/update
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/isSystem=true
/project/PROD/de.loskutov.FileSync/defaultVariables=
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/isSystem= true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/url= http\://download.forge.objectweb.org/eclipse-update/site.xml
/project/trunk/org.eclipse.wst.html.core/elemUnclosedEndTag= 1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951/provider=
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/isSystem=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/69/data/listener_1925729951/
/instance/org.eclipse.dltk.mylyn/org.eclipse.dltk.mylyn.ui.f irst.run=false
@org.eclipse.mylyn.resources.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/project/trunk/org.eclipse.wst.html.core/cdataUnclosed=1
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.inter nal.ui.navigator.layout=1
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/version=1.0.0
/instance/org.cfeclipse.cfml/cfscriptStringColor=116,237,204
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates _/isSystem=false
/instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=never
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emf_updates _/isSystem=false
and\ Settings_Dennis_Desktop_eclipse/provider=
/instance/org.cfeclipse.cfml/cfeclipse.editor.showToolbar=tr ue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s_/isSystem=false
/configuration/org.eclipse.core.net/org.eclipse.core.net.has Migrated=true
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .kind=local
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates _/isSystem=false
/instance/org.tigris.subversion.subclipse.ui/pref_merge_use_ external=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/isSystem=t rue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/url=http\://andrei.gmxhome.de/eclipse/
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/Search\
for\ Contacts.\ Code/comment=Incomplete - taskSearch for Contacts. Code \n
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigra ted=true
and\ Settings_Dennis_Desktop_Ganymede/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/name=http\://andrei.gmxhome.de/eclipse/
/project/PROD/de.loskutov.FileSync/useCurrentDateForDestinat ionFiles=false
/project/trunk/org.eclipse.wst.html.core/elemMissingStart=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.artifactRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/url=http\://download.eclipse.org/tools/mylyn/update/e3.4
and\ Settings_Dennis_Desktop_Ganymede/suffix=artifacts.xml
/instance/org.eclipse.jst.jsp.core/org.eclipse.jst.jsp.core. taglib.TaglibIndex=CLEAN
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates /isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /enabled=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/provider=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_stp_updates_/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.te xt.custom_templates= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/isSystem=false
/instance/org.cfeclipse.cfml/unknowTagColors=151,255,177
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_gmf_updates _releases_/url=http\://download.eclipse.org/modeling/gmf/updates/releases/
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/isSystem=true
/project/trunk/org.eclipse.wst.html.core/elemInvalidContent= 2
/project/trunk/org.eclipse.wst.html.core/docDoctypeUnclosed= 1
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/name=download
cache
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.codeComplete.visibilityCheck=enabled
/project/trunk/de.loskutov.anyedit.AnyEditTools/replaceAllSp aces=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/type=org.eclipse.eq uinox.internal.p2.metadata.repository.LocalMetadataRepositor y
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/descrip tion=
/instance/org.cfeclipse.cfml/stringColor=188,224,152
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_mylyn_downloads_/url=http\://www.eclipse.org/mylyn/downloads/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/description=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/enabled=true
/instance/org.cfeclipse.cfml/SQLKeywordColor=159,205,232
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/url=file\:/C\:/Documents
and
Settings/Dennis/Desktop/Ganymede/p2/org.eclipse.equinox.p2.d irector/rollback
/project/trunk/org.eclipse.wst.html.core/elemCoexistence=2
/instance/org.eclipse.rse.core/org.eclipse.rse.systemtype.lo cal.systemType.defaultUserId=Dennis
/instance/org.cfeclipse.cfml/cfscriptKeywordColor=131,189,22 4
and\
Settings_Dennis_Desktop_Ganymede/type=org.eclipse.equinox.p2 .artifact.repository.simpleRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/enabled=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/isSystem=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/url=http\://download.eclipse.org/technology/dltk/updates/
/instance/org.eclipse.wst.sse.ui/hoverModifiers=combinationH over|true|0;problemHover|false|0;documentationHover|false|0; annotationHover|true|Shift;
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/url=http\://download.eclipse.org/technology/emft/updates/
/instance/org.tigris.subversion.subclipse.ui/pref_merge_prog ram_location=C\:\\Program
Files\\Compare It\!\\wincmp3.exe
/instance/org.eclipse.jdt.ui/content_assist_proposals_foregr ound=0,0,0
@org.eclipse.ui.editors=3.4.0.v20080603-2000
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ url=http\://download.eclipse.org/eclipse/updates/3.4
/instance/org.eclipse.jst.j2ee.webservice.ui/areThereWebServ ices=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/url=http\://download.eclipse.org/tools/cdt/releases/ganymede
/project/trunk/de.loskutov.FileSync/useCurrentDateForDestina tionFiles=false
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.ui. perspectives.task.none=org.cfeclipse.cfml.perspective.CFML
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/descriptio n=
@org.eclipse.cdt.ui=5.0.2.200902130801
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/is System=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.warnReadOnlyFi les=false
/instance/org.eclipse.wst.jsdt.ui/proposalOrderMigrated=true
@org.eclipse.mylyn.java.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/defaultSet=Search
for Contacts. Code
/instance/org.eclipse.ui.ide/platformState=1236880094838
and\
Settings_Dennis_Desktop_eclipse/type=org.eclipse.equinox.p2. artifact.repository.simpleRepository
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.6
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/type=org.eclipse.equinox.internal.p2.metadata.rep ository.LocalMetadataRepository
@org.eclipse.team.cvs.ui=3.3.100.r34x_20090121
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.svnkit.com_1.2.x_/type=org.eclips e.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/provider=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/project/trunk/org.eclipse.wst.html.core/attrInvalidValue=2
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/project/trunk/org.eclipse.wst.html.core/elemMissingEnd=2
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =3
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/version=1
/project/trunk/org.eclipse.wst.html.core/elemUnnecessaryEnd= 2
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/isSystem=false
/project/trunk/org.eclipse.wst.html.core/piUnclosed=1
/instance/org.cfeclipse.cfml/cftagColor=131,173,252
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/instance/org.eclipse.team.core/changeSets/CVS\
Workspace/defaultSet=Search for Contacts. Code
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/description=
@org.eclipse.cdt.mylyn.ui=5.0.1.200902130801
/instance/org.cfeclipse.cfml/cfscriptTextColor=255,128,128
/project/trunk/org.eclipse.wst.html.core/attrValueMismatch=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates/ena bled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/type=org.eclipse.equ inox.p2.artifact.repository.simpleRepository
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPrio rities=normal
and\ Settings_Dennis_Desktop_Ganymede/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/provide r=
/project/trunk/org.eclipse.wst.html.core/elemInvalidName=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/url=http\://download.eclipse.org/tools/mylyn/update/extras
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/type=org.eclipse.equinox.internal.p2.metadata.reposito ry.LocalMetadataRepository
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
standalone\="no"?>\r\n<launchPerspectives/>\r\n
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/name=C\:\ \Documents and
Settings\\Dennis\\Desktop\\Ganymede\\.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ty pe=org.eclipse.equinox.p2.artifact.repository.simpleReposito ry
@org.eclipse.jst.jsp.core=1.2.121.v200901290830
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/enabled=true
/instance/org.eclipse.epp.usagedata.recording/org.eclipse.ep p.usagedata.recording.last-upload=1236892187523
@org.eclipse.team.core=3.4.2.r34x_20080115
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/url =http\://download.eclipse.org/webtools/updates
and\ Settings_Dennis_Desktop_eclipse/version=1.0.0
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.cfeclipse.cfml/currentLineColor=95,95,95
/instance/org.eclipse.mylyn.monitor.ui/org.eclipse.mylyn.mon itor.user.activity.enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/enabled=t rue
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_dsdp_tm_updates_3.0/ isSystem=false
and\
/project/trunk/org.eclipse.wst.html.core/elemUnclosedStartTa g=1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/isSystem=true
/project/trunk/org.eclipse.wst.html.core/commentUnclosed=1
/instance/org.eclipse.jdt.ui/spelling_locale_initialized=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/name=http\://eclipse.svnkit.com/1.2.x/
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1236894838136 ">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1236894838136" javadocURL\="http\://java.sun.com/javase/6/docs/api/"
name\="jre1.6.0_04" path\="C\:\\Program
Files\\Java\\jre1.6.0_04"/>\r\n</vmType>\r\n</vmSettings >\r\n
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/enabled=false
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/name=file\:/User s/markdrew/Documents/Eclipse_Workspaces/cfeclipse2/org.cfecl ipse.cfml.update/
- artifacts
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/provider=
/instance/org.eclipse.mylyn.java.ui/org.eclipse.mylyn.ui.fir st.run.0_4_9=false
/instance/org.eclipse.equinox.p2.ui.sdk/download=true
/project/trunk/de.loskutov.FileSync/defaultVariables=
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.con text.ui.close.action.manage.warning=false
and\
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/ur l=http\://www.eclipse.org/modeling/emft/updates/
/instance/org.eclipse.wst.sse.ui/foldingEnabled=true
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/enabled=true
and\ Settings_Dennis_Desktop_Ganymede/url=file\:/C\:/Documents and
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/provider=
Re: Ganymede & Mylyn [message #596867 is a reply to message #66855] Wed, 18 March 2009 23:19 Go to previous message
*** Current Install Configuration:
Install configuration:
Last changed on Mar 18, 2009
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.u pdate/platform.xml
Configured sites:
platform:/base/
file:/C:/Documents and Settings/Dennis/Desktop/Ganymede/
Configured features:
ID: org.eclipse.dd.dsf.gdb_launch, Version: 1.0.0.v20080609
2.3.2.r232_v20081010-7_7D79_doT2uMPVNwOGoz0HKuyI8
ID: org.eclipse.buckminster.cvs, Version: 1.0.0.r09930
2.3.2.r232_v20081010-4538k797M733K3737
ID: org.eclipse.nab.mwt.native, Version: 0.9.9.200806181757
1.2.0.v200805130238-11-7w311916241349
3.4.1.R342_v20090126-7w7TENgETuNblxYRhBOLydU3ADDC
1.6.2.v200810071455-3019oA55U6_7H6KAC
ID: org.eclipse.ecf.example.collab, Version: 2.1.0.v20081224-1728
ID: com.lowagie.itext, Version: 1.5.4.v20080225-1437w31191339
3.4.2.R342_v20090122-7O7S7GApJ3_vCyk7ETmsfcmjhz0eHnqw7MIjk9V dhe4Ic
ID: org.eclipse.emf.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.uml2tools.examples, Version: 0.8.0.v200809231457
ID: org.mx4j.jmx, Version: 4.4.100.v200901090956-3-37w311_12211211
1.0.0.v20080115-5318xB6CE899P233613552
1.6.2.v200810071455-443_kE77d7OAPAMJQ
1.0.2.r34x_v20090120-7d-7tEQcCaaYSBeNOClOn02267
1.6.2.v200810071455-1507w31191939244824
2.0.3.v200902181600-7J-7EB-NLwTYlTNN4PlbFLKRNHYG
2.3.2.r232_v20081010-7k8E7fELFluav5n_2NEXh3W6B9_
0.95.1.v20080626-2043-08T07w31191_1402545
2.3.2.r232_v20090212-2217s343A311_1313
ID: org.tigris.subversion.clientadapter, Version: 1.5.3
3.0.0.v20080530-7N-E8ME8McIJXIwdh
2.3.2.r232_v20081010-2217s343Aw31192216
1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE
1.6.2.v200810071455-1-07w311_12281248
1.2.0.v200805130238-35-9oA55S5L8G6FCT
3.0.4.v200812040936-7A7NEH2E7QYGHOIsNrGpVX
3.0.4.v200811261813-7H7QECiED69XqLgwowgm-47C5J
1.5.2.v200809302010-1407w311917141519
2.1.1.v200809041200-4118s733I3J4F5C48
ID: org.eclipse.emf.common, Version: 2.4.0.v200902171115
1.6.2.v200810071455-25184B23NbbGK_OXQXHz-QP
ID: org.eclipse.uml2.search.runtime, Version: 0.7.0.v200806130939
4.4.200.v200901090956-43_77w311_121_1_67
3.0.3.v200810010400-42E_4_kE77c_FAP7X99
3.0.4.v200811211541-7F2ENnCwum8W79A1UYNgSjOcFVJg
1.1.0.v20080731-1518-7K8V4EFp_acwc90fc4fP
ID: org.apache.commons.codec, Version: 1.3.0.v20070920-12-7w3119164102711
0.95.1.v20080626-2043-0EEJ77E9IgKLhLeUz0ALs1x5
2.3.2.r232_v20081010-7N7Y7MAIe2QJZSgfOaAphGBR4t7b
ID: org.eclipse.emf.ecore.editor, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.mint.doc, Version: 0.7.1.v200809162149
ID: org.tigris.subversion.subclipse.graph, Version: 1.0.5
3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL
1.6.2.v200810071455-7D47FEB7sQSBV7hXWQ6R
1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK
ID: org.tigris.subversion.subclipse.core, Version: 1.4.8
ID: org.eclipse.emf.codegen.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.emf.databinding, Version: 1.0.0.v200902171115
3.0.4.v20090115-791DC9vETDnvTGSaCQNM76BD
2.0.2.v200811110900-2-17w311922221_11
ID: org.eclipse.uml2.source, Version: 2.2.2.v200902101430
1.1.2.v20080916-2008-2108s733I3E4F15B59
1.6.2.v200810071455-6--BcMAB-BKFVEmLF
4.3.200.v200812160100-42_77w311923271211
3.4.2.v20090218-1145-67738084A6665K366B84__58x422
1.1.0.v20080716-1600-2-Ag8s733I3A7C15KCK
1.0.1.r34x_v20080721-7Y-7hEMrtGZhTrQ--t43w02267
1.6.2.v200810071455-502AgI99mASCdBYCN
0.95.1.v20080626-2043-0ECq6E8McIJXJUOr9upp-2
4.5.0.v200805132041-44-7w311916271211
2.1.0.v20090128-3219oA55U5D7N2532
3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI
1.6.2.v200810071455-7A-5E9IgKLjM1d1Oepu
2.3.2.r232_v20081204-2217s343A311_1233
3.0.4.v200811240900-7R0EP7E8Ks9v7urtuDJtBcaRV6Ri
1.0.1.r34x_v20080721-7T-7cEJ6Wz-YqXOBdehgpS
1.0.0.v20070608-3--8s733G3C5C
ID: org.eclipse.emf.mapping, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.codegen.ecore.ui, Version: 2.4.1.v200902171115
2.1.1.v20080710-7_40AgI99m9d_O
2.1.1.v200809181500-6678AgI99m9W9X5J79
3.3.101.R34x_v20081125-7H-ELfE8hXnkE15Wh9Tnyu
ID: org.apache.derby.core, Version: 10.3.1.4
ID: org.eclipse.uml2.search.common, Version: 0.7.0.v200806130939
ID: org.eclipse.gmf.doc, Version: 1.2.2.v20080916-2008-2218s733H3H4_1673A
3.0.1.v200808091845-108Y7w31191922
1.6.2.v200810071455-3019oA55V599K5M9_
ID: org.eclipse.uml2.search.ocl, Version: 0.7.0.v200806130939
3.0.150.v200901232034-109K7w311_12343145
ID: org.eclipse.emf.edit, Version: 2.4.2.v200902171115
ID: org.eclipse.epp.usagedata.feature, Version: 1.0.1.R200809220400
3.0.3.v200810090336-40EJs_kE77c8P_TALGS
0.95.1.v20080903-1434-0Bw2_kE77c7a9N3BFKL
ID: org.eclipse.emf.converter, Version: 2.4.1.v200902171115
3.0.100.v200901232040-34EEP9oA55T5J7N9BBK
ID: org.eclipse.ocl.uml, Version: 1.2.3.v200811021759-1127w311_12182518
1.6.2.v200810071455-1507w311918132411
1.6.2.v200810071455-57_2_pFAIQJZIsLSXb8MDD
1.6.2.v200810071455-446_kE77d8H_VALOJ
ID: org.eclipse.uml2.examples, Version: 2.2.0.v200805131030
ID: org.eclipse.dd.ipxact, Version: 0.9.0.v20080609
2.3.2.r232_v20081010-67859cADAamA55V5A89
4.5.0.v200805132041-7879-8192A5695E699A2322
2.3.2.r232_v20081010-7D7J7CC7QXRK0ICmcLILD
ID: org.eclipse.emf.common.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.query, Version: 1.2.0.v200805130238-11-7w311916241349
ID: org.eclipse.emf.mapping.ecore.editor, Version: 2.4.0.v200902171115
ID: de.loskutov.eclipse.jdepend, Version: 1.2.1
3.0.3.v200902042310-7J378DUUEFGEpIz-AW8E
ID: org.tmatesoft.svnkit, Version: 1.2.3.5521
3.0.2.v200809102124-2518s733I3G395I75
1.6.2.v200810071455-442_kE77d7N9VANON
1.6.2.v200810071455-440_kE77c7QAQEIQQ
4.4.100.v200901090956-7B78CE9oA55S8A8M5855
3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63
ID: org.eclipse.releng.tools, Version: 3.2.200.v20080603-33-7w31191525
1.6.2.v200810071455-797P78CYQCD5DjGdEURT
1.6.2.v200810071455-6-2BcMAAyBWDkEVSb
3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS
ID: org.eclipse.uml2.doc, Version: 2.2.0.v200805201350
ID: org.eclipse.cvs, Version: 1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
3.4.2.v20090218-1145-67728084A56B4I233613552
3.0.4.v200811251652-7E4EAvDgz-Y1htmiH5158SnFBSiT
3.0.1.v200809171630-78479_kE77c7Q8b8T_F
ID: org.eclipse.mylyn, Version: 3.0.5.v20090218-1800-e3x
ID: org.eclipse.uml2.diagram, Version: 0.8.1.v200809231457
ID: org.eclipse.dd.debug.memory.renderings, Version: 1.0.0.v20080609
1.6.2.v200810071455-7_7K7NDn-QYKjkBKlmD4edYsAX
3.0.4.v200811260650-7Q7AEf1EHhHehNmEARhS7t
1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z
1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx
3.0.4.v200811200248-7C78ELhE8VrRVqtHp4iT8PuSwZ5W
ID: org.eclipse.cdt.mylyn, Version: 5.0.2.200902130801
ID: org.eclipse.emf.mapping.ecore, Version: 2.4.0.v200902171115
ID: org.cfeclipse.cfml, Version: 1.3.2.200901041029
3.0.3.v200902042310-7H37E8qfisI6diJKMbrhR-TV-a3
4.5.0.v200805132041-7J7N-_-M7OKEQDfDTIK95C7
1.0.4.v200812112112-6-E75BcMAAyDJGhFpNN
4.5.0.v200805132041-7879-8s733I3D6B5878
ID: org.eclipse.emf.mapping.ui, Version: 2.4.0.v200902171115
4.5.0.v200805230100-7p80-E9UsMfZXChNc0so95C7
ID: org.eclipse.ecf, Version: 2.1.0.v20081224-1728
1.4.1.v200809302010-13-7w311917141518
ID: de.loskutov.FileSync, Version: 1.3.3
1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj
1.6.2.v200810071455-37A09oA55S6H_L8DFG24
1.2.3.v200810041753-2328s733J3_56398B
ID: org.eclipse.emf.codegen.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.jst, Version: 1.0.3.v200901220134-77-E_FCYQCD5EeNgKUUY
ID: org.tigris.subversion.clientadapter.javahl, Version: 1.5.6
1.2.1.v200807161719-2308s733I3E5B4B7J
ID: org.eclipse.rse.services.ssh, Version: 2.1.1.v20080714-7830_kE77c7V8M
1.1.101.v200808291106-108Z7w3119193_2217
ID: org.eclipse.uml2.diagram.source, Version: 0.8.1.v200809231457
ID: com.sun.jna, Version: 3.0.9
ID: org.eclipse.draw2d, Version: 3.4.2.v20090218-1145-3317w311_122502441
0.95.1.v20080626-2043-0EEJ6E9IgKLhLZW8AKz0uq5
1.6.2.v200810071455-2138s733J465I548A
4.3.101.v200901090956-7B79Aj9oA55V585V5VJM
3.0.4.v20090115-20Am8s733J3_4F1256
ID: org.eclipse.emf.databinding.edit, Version: 1.0.0.v200902171115
ID: org.eclipse.dd.dsf.sdk, Version: 1.0.0.v20080609
3.0.4.v200901240221-52EFzAgI99n_WAjGIJb
ID: org.eclipse.emf.ecore.edit, Version: 2.4.1.v200902171115
ID: org.eclipse.nab.mwt, Version: 0.9.9.200806181757
ID: de.loskutov.eclipseskins.extvs, Version: 1.5.1
4.4.101.v200901090956-7F7DDr_kE77g7A7g7gQU
1.6.2.v200810071455-27A18s733I3I7I599G59
2.3.2.r232_v20081010-7X7n7WEBPrSQ6K-eN3CvLiGaMQ4d
1.0.1.r34x_v20080721-7T-7ZEIdY2TtPOAWojptd
1.6.2.v200810071455-3-29oA55S7__D7LCC
1.6.2.v200810071455-442_kE77c7VBQDFNW
3.0.3.v200902042310-7Z37HEB7sQSCRiULOVOE
2.0.1.v20080715-2-07w31191826
3.0.4.v200811240900-7G2EAzAM215iJKQCZssIGG6lQwlL
ID: org.eclipse.emf.edit.ui, Version: 2.4.2.v200902171115
ID: org.tigris.subversion.subclipse.mylyn, Version: 3.0.0
ID: de.loskutov.anyedit.AnyEditTools, Version: 2.1.3.200901071535
3.0.1.v20080730-4-CF_kE77c7SCI58GJ
0.1.3.v200902181600-2269sB9EP_M_W5B5B3822
1.6.2.v200810071455
2.3.2.r232_v20081010-2217s343A3119211_
0.95.1.v20080903-1434-09y08s733I3H3E15B_7
ID: org.eclipse.uml2, Version: 2.2.2.v200902101430
1.6.2.v200810071455-77-0CYQCD7FTIWGyPO
3.0.0.v200805040310-21CE8s733I3D4C56AA
3.0.4.v200811190840-7A-8l8Qqcz0HyVgjXUE-iuOYZ9ai
0.95.1.v20080903-1434-0AR09oA55S5N9J28GBE
ID: org.eclipse.emf.search.ecore, Version: 0.7.0.v200806130939
3.4.2.v20090218-1145-7B7E597OKBd7QHgEHNHn9JKTFJJR
ID: org.w3c.sac, Version: 1.3.0.v20080102-46-_kE77b7U_N56BA
ID: org.eclipse.tm.terminal.view, Version: 2.0.1.v20080715-2-07w31191826
ID: org.eclipse.buckminster.ui, Version: 1.1.0.r09948
4.5.0.v200805132041-44-7w311916243152
1.6.2.v200810071455-7F27SBcMAAxCcHmCNWi
ID: org.eclipse.emf, Version: 2.4.2.v200902171115
ID: org.eclipse.xsd, Version: 2.4.2.v200902171115
2.3.2.r232_v20081010-2217s343Aw31192224
2.3.2.r232_v20081010-7X8n7EELtcA6FxGJtxH7_f
1.6.2.v200810071455-6577AlJCKcLZI2Ljcc8MDD
ID: org.eclipse.emf.mint.source, Version: 0.7.1.v200809162149
1.0.0.v20080115-5318_GCGFGJMZHOMaa6PMUULSPXD
3.0.4.v200811190820-7Y7BFT1EPOwQQfPq5sVdQ6P_QtVn
ID: org.tigris.subversion.clientadapter.svnkit, Version: 1.5.6
1.6.2.v200901211403-7C67XCYQCD7ESIqIQco
1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ
1.0.0.v20070507-7B794E7QYGHMGxTcAasgF
ID: org.eclipse.buckminster.maven, Version: 1.1.0.r09904
ID: org.eclipse.sdk.examples.source, Version: 3.2.0.v20080611
ID: org.eclipse.buckminster.remote.feature, Version: 1.0.0.r09842
ID: org.eclipse.emf.search.runtime, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7E2EH6C-2fA3PMioFSbnhI_YkSTU
ID: de.loskutov.BytecodeOutline.feature, Version: 2.2.8
1.0.0.v20070510-7F57CE9IgKLaMASi7KHI3
2.0.3.v200902181600-2-27w311_13292711
1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.ocl, Version: 1.2.3.v200810101725-3439oA55T5F8H8PAB
ID: org.eclipse.buckminster.p4.ui, Version: 1.0.0.r09908
Version: 2.3.2.r232_v20081010-787A779lxNRkRRSNH-o3EoA3OFYi
3.2.0.v20080611-837bEN1ECCP57BAaYN7HSHEb
ID: org.mozilla.rhino, Version: 1.6.7.v20071217-1567w31191325
ID: org.eclipse.pde.p2, Version: 1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.xsd.edit, Version: 2.4.0.v200902171115
ID: org.eclipse.dd.dsf.gdb, Version: 1.0.0.v20080609
ID: org.eclipse.emf.search.ecore.ocl, Version: 0.7.0.v200806130939
ID: org.eclipse.buckminster.pde, Version: 1.1.340.r09942
1.1.2.v200812041720-2138s733I573A5G73
ID: org.eclipse.emf.search.ocl, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7C7_EVNE_EkMNtRvY4V6o0
ID: org.eclipse.emf.codegen, Version: 2.4.0.v200902171115
ID: org.eclipse.uml2.examples.source, Version: 2.2.0.v200805131030
ID: org.eclipse.sdk, Version: null
ID: org.eclipse.equinox.p2.user.ui, Version: null
ID: org.eclipse.cvs.source, Version: null
ID: org.eclipse.platform, Version: null
ID: org.eclipse.help.base, Version: null
ID: org.eclipse.jdt, Version: null
ID: org.eclipse.help.source, Version: null
ID: org.eclipse.rcp.source, Version: null
ID: org.eclipse.pde.source, Version: null
ID: org.eclipse.cvs, Version: null
ID: org.eclipse.rcp, Version: null
ID: org.eclipse.platform.source, Version: null
ID: org.eclipse.jdt.source, Version: null
ID: org.eclipse.equinox.p2.user.ui.source, Version: null
1.6.2.v200810071455
ID: org.eclipse.pde, Version: null
ID: org.eclipse.pde.p2.source, Version: null
ID: org.eclipse.pde.p2, Version: null
Re: Ganymede & Mylyn [message #596880 is a reply to message #66855] Wed, 18 March 2009 23:21 Go to previous message
!SESSION 2009-03-18 19:22:33.221
eclipse.buildId=M20090211-1700
java.version=1.6.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Code\DENDev\.metadata\.bak_0.log
Created Time: 2009-03-18 19:23:41.316
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2009-03-18 19:23:41.316
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector'
extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the
'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
will be ignored because it contains invalid attributes.
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE Conflict for
'AUTOGEN:::org.cfeclipse.cfml.frameworks.contribution1/org.c feclipse.cfml.frameworks.newAction':
HandlerActivation(commandId=AUTOGEN:::org.cfeclipse.cfml.fra meworks.contribution1/org.cfeclipse.cfml.frameworks.newActio n,
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetFrameworkFile),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1e0f790),sourcePriority=16384)
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetAsConfigFolder),
!ENTRY org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE A conflict occurred for CTRL+SHIFT+P:
Binding(CTRL+SHIFT+P,
ParameterizedCommand(Command(org.eclipse.ecf.presence.ui.com mands.browse,Open
Contact,
Category(org.eclipse.ecf.ui.commands.category,Communications ,null,true),
org.eclipse.ecf.internal.presence.ui.handlers.BrowseHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.emf.search.ecore.co mmon.ui.OpenFilteredEPackageMetaElementsSelectionDialogComma nd,Open
Filtered Ecore Package Meta-Elements Dialog,
Open Filtered Ecore Package Meta-Elements Dialog,
Category(org.eclipse.modeling.editors,Modeling Editors,Modeling Editors
Commands,true),
org.eclipse.emf.search.ecore.common.ui.handlers.OpenFiltered EPackageMetaElementSelectionDialogHandler,
,,true),null),
!ENTRY org.eclipse.mylyn.core 4 0 2009-03-18 19:23:47.910
!MESSAGE Context listener failed:
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager
!STACK 0
java.lang.IllegalArgumentException: Class file name must end with .class
org.eclipse.jdt.internal.core.PackageFragment.getClassFile(P ackageFragment.java:182)
org.eclipse.jdt.internal.core.PackageFragment.getHandleFromM emento(PackageFragment.java:270)
org.eclipse.jdt.internal.core.JavaElement.getHandleFromMemen to(JavaElement.java:272)
org.eclipse.jdt.internal.core.PackageFragmentRoot.getHandleF romMemento(PackageFragmentRoot.java:445)
org.eclipse.jdt.internal.core.JavaProject.getHandleFromMemen to(JavaProject.java:1506)
org.eclipse.jdt.internal.core.JavaModel.getHandleFromMemento (JavaModel.java:167)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2353)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2330)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.update TypeHistory(TypeHistoryManager.java:48)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.contex tActivated(TypeHistoryManager.java:40)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.internalActivateContext(InteractionContextManager.java :589)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.activateContext(InteractionContextManager.java:159)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$1.taskActi vated(TasksUiPlugin.java:264)
org.eclipse.mylyn.internal.tasks.core.TaskActivityManager.ac tivateTask(TaskActivityManager.java:413)
org.eclipse.mylyn.internal.tasks.ui.TaskListManager.activate Task(TaskListManager.java:126)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiIni tializationJob.runInUIThread(TasksUiPlugin.java:417)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
!ENTRY org.eclipse.osgi 4 0 2009-03-18 19:23:49.972
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.nab.mwt.jni (17354).
!STACK 0
org.osgi.framework.BundleException: The activator
org.widestudio.mwt.MwtPlugin for bundle org.eclipse.nab.mwt.jni is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:443)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.nab.mwt.ab.core.CorePlugin.start(CorePlugin.java :70)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:52)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:124)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:120)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:251)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 72)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:356)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:338)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:374)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:334)
Caused by: java.lang.UnsatisfiedLinkError: no mwt_java in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.widestudio.mwt.MwtPlugin.<clinit>(MwtPlugin.java:30)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 54 more
Root exception:
Source)
org.eclipse.nab.mwt (17356).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.nab.mwt.ab.core.CorePlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
Caused by: java.lang.NoClassDefFoundError:
org/widestudio/mwt/MwtInitializer
... 35 more
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 39 more
Caused by: org.osgi.framework.BundleException: The activator
... 49 more
Source)
... 54 more
Root exception:
java.lang.NoClassDefFoundError: org/widestudio/mwt/MwtInitializer
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.registry 4 1 2009-03-18 19:23:49.972
!MESSAGE Plug-in org.eclipse.nab.mwt was unable to load class
org.eclipse.nab.mwt.ab.core.MwtSourceDecorator.
!STACK 0
Caused by: org.osgi.framework.BundleException: Exception in
... 30 more
... 35 more
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-03-18
19:31:59.556
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:31:59.556
!MESSAGE Error at line 10, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 99: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 102: Illegal value for attribute "url"
of element "repository": null
!MESSAGE Error at line 12, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 99: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 14, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 14, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 15, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 15, column 102: Illegal value for attribute "url"
!ENTRY org.eclipse.equinox.p2.metadata.generator 4 0 2009-03-18
19:32:37.244
!MESSAGE Error reading site digest
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\digest23076.zip.
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at java.util.jar.JarFile.<init>(Unknown Source)
org.eclipse.equinox.internal.p2.metadata.generator.features. DigestParser.parse(DigestParser.java:75)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe aturesFromDigest(UpdateSite.java:402)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe atures(UpdateSite.java:375)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository.generateMetadata(UpdateSiteMetadataRepo sitory.java:108)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository. <init>(UpdateSiteMetadataRepository.java:73)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepositoryFactory.load(UpdateSiteMetadataRepositor yFactory.java:48)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:485)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:452)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:435)
org.eclipse.equinox.internal.p2.director.SimplePlanner.gathe rAvailableInstallableUnits(SimplePlanner.java:196)
org.eclipse.equinox.internal.p2.director.SimplePlanner.getPr ovisioningPlan(SimplePlanner.java:235)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.getProvisioningPlan(ProvisioningUtil.java:210 )
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.computeProvisioningPlan(InstallAction.java:80)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.getProvisioningPlan(InstallAction.java:130)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Profi leModificationAction$1.run(ProfileModificationAction.java:61 )
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE No solution found because the problem in
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\p2Encoding23092.opb is unsatisfiable.
!ENTRY org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!MESSAGE Cannot complete the request. See the details.
!SUBENTRY 1 org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!SUBENTRY 1 org.eclipse.equinox.p2.ui 1 10002 2009-03-18 19:32:52.135
!MESSAGE Mylyn Focused UI (Recommended) is already installed, so an update
will be performed instead.
!MESSAGE Mylyn Task List (Required) is already installed, so an update
!MESSAGE Mylyn Bridge: Eclipse IDE is already installed, so an update will
!MESSAGE Mylyn Bridge: Team Support is already installed, so an update
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2009-03-18 19:32:52.135
!MESSAGE Cannot find a solution satisfying the following requirements
org.eclipse.jdt.feature.jar [3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq].
19:39:20.452
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:20.452
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
19:39:31.015
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:31.015
"repository": url
!MESSAGE Error at line 11, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 99: Illegal value for attribute "url" of
20:01:56.767
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:01:56.767
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
20:02:24.892
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:24.892
"repository": url
"repository": url
20:02:26.533
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:26.533
"repository": url
"repository": url
"repository": url
"repository": url
!ENTRY org.eclipse.equinox.p2.metadata.generator 2 0 2009-03-18
20:02:27.189
!MESSAGE An error occurred while loading the bundle manifest C:\Documents
and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.gmf.doc _1.2.2.v20080916-2008.jar
!STACK 0
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.loadManifest(BundleDescriptionFa ctory.java:124)
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.getBundleDescription(BundleDescr iptionFactory.java:96)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.processBundle(RepositoryListener.java:23 6)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.process(RepositoryListener.java:226)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.added(RepositoryListener.java:201)
org.eclipse.equinox.internal.p2.extensionlocation.BundlePool FilteredListener.added(BundlePoolFilteredListener.java:39)
org.eclipse.equinox.internal.p2.extensionlocation.SiteListen er.added(SiteListener.java:284)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.processFile(DirectoryWatcher.java:200)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.scanDirectories(DirectoryWatcher.java:161)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.poll(DirectoryWatcher.java:108)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.ensureInitialized(ExtensionLocatio nMetadataRepository.java:72)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.getProperties(ExtensionLocationMet adataRepository.java:159)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.addRepository(MetadataRepositoryManager.ja va:110)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:454)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 20:02:30.689
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-18 20:02:30.689
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web
1.1.105.v200802192030 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4
Re: Ganymede & Mylyn [message #596889 is a reply to message #66855] Wed, 18 March 2009 23:40 Go to previous message
Dennis. please file a new bug report and attach your configuration details
to the bug: http://www.eclipse.org/mylyn/support/
Steffen
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Ganymede & Mylyn [message #596898 is a reply to message #66855] Thu, 19 March 2009 07:12 Go to previous message
Hi Dennis,
I just tried the install based on a clean Ganymede J2EE package (3.4.1).
Here's what I did:
1. Downloaded Ganymede 3.4.1 to a clean directory
2. Started my workspace. Mylyn 3.0.4 was included.
3. I had issues here with the Java workspace settings not being loadable,
because the workspace was from 3.3.2, and I had to correct Mylyn user ids.
I
also had to restart to have my problem markers show up.
4. Launched the Ganymede Software Updates window. The Installed Software
tab
Update function didn't work, so I used the Available Software tab. There,
I
modified my Mylyn for Eclipse site to point to
http://download.eclipse.org/tools/mylyn/update/e3.4, which is different
from
the one you reported.
5. I hit the Install... button and Mylyn 3.1.0 was downloaded for me and
installed.
6. The workbench was restarted and Mylyn 3.1.0 came up cleanly with one
Information marker:
"Reset Bugzilla repository configuration cache due to format change"
I did notice that an SQL update appeared to be needed to process the Mylyn
3.1.0 update, and I allowed that through. It may have been a result of my
J2EE configuration. I hope this helps.
Randall
Dennis wrote:
> I'm trying to pull Mylyn 3.4 (all the way down to 3.1....) without any
> success...
> this is the most recent site I've tried...
> http://download.eclipse.org/tools/mylyn/update/weekly/e3.4
> running Eclipse :
> Eclipse Platform
> Version: 3.4.2
> Build id: M20090211-1700
> I receive the error:
> Mylyn Task List (Required) is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Eclipse IDE is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Team Support is already installed, so an update will be
> performed instead.
> I've tried to uninstall DTP with a glorious crash and burn, thinking that
> maybe that would be the problem (I'm at 1.6.2, with no idea how to
> downgrade it to 1.6.1 or anything else for that matter)
> In fact if I uninstall anything in this configuration, Ganymede simply
> does not start anymore.
> This package is causing all kinds of problems with Ganymede, it seems
> Everything wants to be bound to it, but I obviously do not have it...
> Heres my config: (below the config is my error log...)
> [[[ I had to clip the message, it was refused when I attempted to initial
> post]]]
Re: Ganymede & Mylyn [message #596934 is a reply to message #66855] Fri, 20 March 2009 04:57 Go to previous message
When I try to update Mylyn to version 3.1, I have this error:
org.eclipse.ui.workbench [3.4.2.M20090127-1700]
My Eclipse version is 3.4.2 from the Eclipse update site
(eclipse.buildId=M20090211-1700).
Is there something to do on my side to be able to update Mylyn?
Philippe
Re: Ganymede & Mylyn [message #596991 is a reply to message #67127] Sat, 21 March 2009 19:46 Go to previous message
Please try updating all installed features first. Then disable all update
site except for the Mylyn sites and try installing/updating Mylyn.
If that does not help, please file a bug. Please attach the list of
installed features and plug-ins to the bug and provide steps to reproduce
the problem.
Steffen
Steffen Pingel
Re: Ganymede & Mylyn [message #597007 is a reply to message #67172] Mon, 23 March 2009 05:28 Go to previous message
It seems that my problems are due to the connector I use, which is not
yet compatible with Mylyn 3.1. I have to wait a little to use the new
stuff of Mylyn.
Anyway, thanks for your help!
Philippe
> the problem.
> Steffen
Previous Topic:Mylyn 3.1 is now available
Next Topic:CodeBeamer connector for Mylyn
Current Time: Mon Jul 14 11:50:27 EDT 2025
Powered by FUDForum. Page generated in 0.11765 seconds
