classes hidden in trasformation [message #66839] |
Wed, 28 November 2007 10:46  |
Originally posted by: luciananegri81.yahoo.it
Hi all,
I've written a basic transformation in ATL.
When I run atl file, classes of model are hidden.
I've the following result
****** BEGIN Stack Trace
message: cannot find metamodel element PAstep in model UMLbase
A.main() : ??#22 null
local variables = {self=Uc2Ft : ASMModule}
local stack = []
A.__initallClassesUC() : ??#6 5:52-5:66
local stack = [Uc2Ft : ASMModule, Sequence {}]
****** END Stack Trace
Have anyone an idea for this problem?
Luciana
Re: [ATL] classes hidden in trasformation [message #67943 is a reply to message #67607] |
Sat, 01 December 2007 09:08  |
I've installed ATL 2.0.0 (with UML2, EMF), but when I run
the file .atl, I've same error.
In Error Log view I've:
Launching UML2FT Reason: java.lang.NullPointerException
and in console:
GRAVE: null
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.getSourceMode ls(AtlRegularVM.java:137)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
GRAVE: ****** BEGIN Stack Trace
GRAVE: message: cannot find model UML
GRAVE: A.main() : ??#22 null
GRAVE: local variables = {self=UML2FT : ASMModule}
GRAVE: local stack = []
GRAVE: A.__initallClassesUC() : ??#6 5:48-5:58
GRAVE: local stack = [UML2FT : ASMModule, Sequence {}]
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
GRAVE: cannot find model UML
java.lang.RuntimeException: cannot find model UML
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:81)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:279)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:155)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:351)
How can I resolve this problem?
Thank you.
Luciana
FUDForum. Page generated in 0.06054 seconds
