Home » Language IDEs » ServerTools (WTP) » Installation problems
Installation problems [message #5939] Sat, 12 July 2003 18:42 Go to next message
Originally posted by: ulf.nordlund.frobozz.se
I keep getting this error message when trying to install eclipse 2.1 on
Windows XP:
JVM terminated.Exit code = 1.
C:\WINDOWS\system32\javaw.exe
-showsplash C:\eclipse\eclipse.exe -showsplash 600
I have noticed that also others have had this problem, but I cannot find a
solution that works... (I have tried starting it with:
">C:\eclipse\eclipse.exe -vm c:\j2sdk1.4.2\bin\javaw.exe", but that
doesn't work either.)
Can anyone give me a simple description on what to do?(I am no OS
expert.) I would appreciate it very much.
BTW: Anyone knows where can I find documentation on eclipse installation?
(Installation documentation seems to be the only area where other
IDEs/platforms do better...)
Many thanks,
/ulf
Re: Installation problems [message #5957 is a reply to message #5939] Sat, 12 July 2003 19:52 Go to previous messageGo to next message
Originally posted by: oshteynbuk.nyc.rr.com
Have a look at
http://home.nyc.rr.com/olegs/eclipse/antscript/readme.htm
there you will find assembled docs on eclipse install/update and Ant
script to automated the process.
If you upgrade eclipse quite often and have installed extra plug-ins you
might find Ant Script very useful.
There is also discussion on different upgrade strategies.
oleg
> Windows XP:
> Many thanks,
> /ulf
Re: Installation problems [message #5975 is a reply to message #5939] Mon, 14 July 2003 23:53 Go to previous messageGo to next message
Originally posted by: skaldl.systex.com.tw
I think you could remove .metadata/.plugins/org.eclipse.* of workspace.
And try it again.
Good luck.
"Ulf Nordlund" <ulf.nordlund@frobozz.se> ??? news:beq2sq$kh7$1@eclipse.org
> Windows XP:
> Many thanks,
> /ulf
Re: Installation problems [message #5993 is a reply to message #5975] Tue, 15 July 2003 03:20 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
>And try it again.
>Good luck.
A better idea would be to try the workspace restorer plug-in (use search
facility @ eclipse.org).
HTH
Dani
Re: Installation problems [message #6409 is a reply to message #5993] Fri, 25 July 2003 04:37 Go to previous messageGo to next message
Originally posted by: robert.varga.fathomtechnology.com
That's not Eclipse's or any plugin's responsibility.
That's how the system is installed. A JVM does not put anything in the path,
so that
it does not disturb other things already in place. You MAY have a java
program or
you may be viewing pages with Microsoft Java extensions, which probably
would not
work with a non-Microsoft JVM. Proper JDK/JRE packages play nice. Microsoft
was
not playing nice with how it approached Java, and that is causing the
problem.
What you can do is:
1. Create a JAVA_HOME environment variable, that points to your actually
preferred JDK.
This way you can easily choose between JDKs installed.
2. Put %JAVA_HOME%\bin in the path, anywhere preceeding
<windowsroot>\system32, which also
contains java, javaw & co binaries. This way the java* in the JDK bin
directory is invoked whenever
it is invoked from the path.
You can also configure the Java plugin in the Control Panel, that is for
changing what JVM is invoked
for running java code in a browser for which versions.This usually points to
the JRE in Program Files ...
The Eclipse Workbench itself uses Java from the path I think.
For Java things launched from inside Eclipse in a separate process, the JDK
in JAVA_HOME is
used if it was setup (the environment variable) there when first running
Eclipse.
So if you installed it after setting up the JAVA_HOME in the path, it
automatically finds the JDK in
JAVA_HOME.
If it was not done in this order, then you can configure a new JVM to be
used inside Eclipse
(whenever external java process is invoked).
Robert Varga
"Trevor Williams" <twilliams66@netscape.net> wrote in message
news:bfid8b$agc$1@eclipse.org...
> Granted I'm new to Eclipse, but wouldn't it also make sense to get the
> Sun VM ahead of the MS VM in the path? javaw.exe should be found in
> (for instance) c:\j2sdk1.x.x\bin. Just my opinion.
> - Trevor Williams
> Daniel Megert wrote:
> >> And try it again.
> >> Good luck.
> > HTH
> > Dani
Re: Installation problems [message #6427 is a reply to message #6409] Fri, 25 July 2003 10:33 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
The easiest approach is to explicitly specify the VM from the eclipse
command line. That way, java doesn't need to be on any path, and no
environment variables are needed:
eclipse -vm c:\jre\bin\java
> so that
> program or
> would not
> was
> problem.
> What you can do is:
> preferred JDK.
> in JAVA_HOME is
> Eclipse.
> JAVA_HOME.
> used inside Eclipse
> Robert Varga
Re: Installation problems [message #6851 is a reply to message #6427] Thu, 14 August 2003 00:28 Go to previous messageGo to next message
Originally posted by: dmolony.bytezone.com
I am having a similar problem (JVM terminated. Exit code=1), even after
following all the suggestions here. However, an error log is created, which
starts with the following:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77D8C059
Function=[Unknown.]
Library=C:\WINDOWS\system32\USER32.dll
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.win32.OS.DrawTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.DrawText(OS.java:1242)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1265)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1216)
at org.eclipse.swt.custom.CLabel.onPaint(CLabel.java:380)
at org.eclipse.swt.custom.CLabel.access$0(CLabel.java:287)
at org.eclipse.swt.custom.CLabel$1.paintControl(CLabel.java:102 )
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:80)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:66 5)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2711 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:1992 )
at org.eclipse.swt.internal.win32.OS.UpdateWindow(Native Method)
at org.eclipse.swt.widgets.Decorations.setVisible(Decorations.j ava:1247)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:992)
at org.eclipse.swt.widgets.Shell.open(Shell.java:656)
at org.eclipse.jface.window.Window.open(Window.java:533)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:356)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:735)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:566)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1153)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
at org.eclipse.core.launcher.Main.basicRun(Main.java:248)
at org.eclipse.core.launcher.Main.run(Main.java:698)
at org.eclipse.core.launcher.Main.main(Main.java:534)
I am using windows xp pro, sdk1.4.2 and eclipse v2.0 (which I obtained from
a book cd). Does this shed any light on the problem??
Re: Installation problems [message #6875 is a reply to message #6851] Thu, 14 August 2003 02:39 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
You need to use Eclipse 2.1.1 with jdk1.4.2. If you cannot upgrade you need
to use jdk1.4.1 or earlier with Eclipse 2.0. Eclipse 2.0 does not work with
jdk1.4.2 due to jdk changes. For details see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=34940.
HTH,
Csaba
"Denis Molony" <dmolony@bytezone.com> wrote in message
news:bhf348$3sv$1@eclipse.org...
> Hi
which
> PC=0x77D8C059
> Function=[Unknown.]
> at
> at
> at
> a:775)
from
Re: Installation problems [message #11172 is a reply to message #5975] Wed, 26 November 2003 17:58 Go to previous message
Originally posted by: luiz.almeida.xtremecode.com.br
On my machine, I couldn't install eclipse M3. I got the same error message.
A friend advice me to try install using jdk1.3. I'ts run.
Good luck !!!
"Larry Lin" <skaldl@systex.com.tw> escreveu na mensagem
news:bevtro$ibo$1@eclipse.org...
> And try it again.
> Good luck.
> > Windows XP:
a
installation?
> > Many thanks,
> > /ulf
Previous Topic:ANN: New Visual Editor Project
Next Topic:FTP and WebDAV - only portion of directory transration
Current Time: Fri Jul 18 02:27:25 EDT 2025
Powered by FUDForum. Page generated in 0.08876 seconds
