Home » Modeling » OCL » execute ocl query that is not boolean expression
execute ocl query that is not boolean expression [message #66787] Sat, 07 February 2009 16:41 Go to next message
Hi group!
I need to execute an ocl query from java code, so I create this method
execute pasted below but this method just execute query if the constraint
be boolean.
If I run this query "self.name = 'className'" the method return correctly.
But i want to execute a query like that:
"self.allOwnedElements() -> select(e | e.oclIsKindOf(Package))
->collect(e | e.oclAsType(Package))->select(e | e.name = 'domain')"
when i run this query I obtain this message:
java.lang.IllegalArgumentException: Query must be a boolean-valued
constraint.
someone can help me?
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.query.conditions.Condition;
import org.eclipse.emf.query.conditions.DataTypeCondition;
import org.eclipse.emf.query.conditions.eobjects.EObjectCondition;
import org.eclipse.emf.query.ocl.conditions.BooleanOCLCondition;
import org.eclipse.emf.query.statements.FROM;
import org.eclipse.emf.query.statements.IQueryResult;
import org.eclipse.emf.query.statements.SELECT;
import org.eclipse.emf.query.statements.WHERE;
import org.eclipse.ocl.ParserException;
import org.eclipse.ocl.ecore.OCL;
import org.eclipse.uml2.uml.resource.UMLResource;
public class QueryExecutor {
* The method thats execute ocl queries
* @param query the ocl query that must be executed
public static IQueryResult execute( UMLResource uml2Resource, String query
OCL ocl = org.eclipse.ocl.ecore.OCL.newInstance();
Condition condition;
DataTypeCondition<org.eclipse.uml2.uml.Class> dtCondition;
IQueryResult results = null;
try {
condition = new BooleanOCLCondition<EClassifier, EClass, EObject>(
ocl.getEnvironment(),query,null);
SELECT statement = new SELECT(SELECT.UNBOUNDED, false,
new FROM(uml2Resource.getContents()), new WHERE((EObjectCondition)
condition) );
results = statement.execute();
} catch (ParserException e) {
e.printStackTrace();
return results;
BEST REGARDS!
Re: execute ocl query that is not boolean expression [message #67358 is a reply to message #66787] Mon, 09 February 2009 11:12 Go to previous message
Originally posted by: cdamus.zeligsoft.com
Hi, Victor,
The Query framework's Conditions all check boolean predicates, because
they use them to determine whether an object is in the result set or
not. The OCL condition objects are no different.
If you want to execute a non-boolean OCL query expression, you can just
use the evaluate(...) API of the OCL object, or use
OCL::createQuery(...) to create a Query object that can be evaluated
repeatedly on different model elements.
HTH,
Christian
Victor Hugo wrote:
> Hi group!
> constraint be boolean.
> constraint.
> query ){
> try {
> EObject>(
> WHERE((EObjectCondition) condition) );
> return results;
> BEST REGARDS!
Previous Topic:Re: Redefinition
Next Topic:syntax of this ocl expression
Current Time: Sun Aug 31 20:03:47 EDT 2025
Powered by FUDForum. Page generated in 0.02883 seconds
