Re: Eclipse programs won't unzip [message #666953 is a reply to message #666946] |
Mon, 25 April 2011 03:22 |
On 2011.04.24 18:27, VerucaSalt2011@gmail.com wrote:
> Hi All,
> I'm very green so please pardon any apparent ignorance. I've downloaded
> the Java IDE and C++ IDE but neither will unzip. When I reach the second
> stage of the unzip wizard the computer will freeze, the desktop loses
> all icons and the task bar - even cntrl+alt+del fails is impotent - the
> task manager will appear but nothing works.
> I am using an Acer TravelMate 6460 running XP professional SP 3. I've
> downloaed JDK1.6.0_24 from Oracle and can compile programs using the
> command prompt. I just can't get anything from the eclipse web site to
> unzip without crashing the computer.
> Any help would be greatly appreciated.
> Steve.
Steve,
You may be running into a problem using WinZip. Try 7-zip. WinZip has
known problems unzipping Eclipse distributions because of path lengths.
Re: Eclipse programs won't unzip [message #667000 is a reply to message #666954] |
Mon, 25 April 2011 12:35 |
On 2011.04.24 22:26, Steve Street wrote:
> Hi Russell,
> Thanks for the advice. I've downloaded 7-zip and attempted to open the
> folder with 7-zip and still have the same problem. I'm at a bit of a
> loss as to what the problem might be.
> Steve.
This happens when unzipping Eclipse. What about other distributions?
Have you downloaded anything else (JRE, etc.) and unzipped it
successfully? You're not out of diskspace or something like that?
Are you attempting to unzip Eclipse in the root of C:? On Windows XP,
that would be the best place for it.
It's been a few years since I installed or used Eclipse under Windows
XP, but I don't remember any other trouble except for the path length.
FUDForum. Page generated in 0.08388 seconds
