Home » Newcomers » Newcomers » How to install SDK 3.0.2 in Windows(2K)
How to install SDK 3.0.2 in Windows(2K) [message #66754] Thu, 19 May 2005 15:04 Go to next message
Originally posted by: prenum3.removethis-eathlink.net
I've downloaded Eclipse SDK 3.0.2 for Windows.
It is a huge zip file with no information inside (that I could find) on how
to install it.
Just unzip? Also unzip the zip files nested inside? Same directory? or where
to?
I did check Eclipse FAQ, but it has only info on UNinstall,
not a zip on how to install...
Re: How to install SDK 3.0.2 in Windows(2K) [message #66850 is a reply to message #66754] Thu, 19 May 2005 15:13 Go to previous messageGo to next message
Just unzip the downloaded file. You'll find eclipse.exe inside the new
"eclipse" directory which you can use to run eclipse.
To uninstall, just delete the directory.
Kevin
> to install it.
> to?
Re: How to install SDK 3.0.2 in Windows(2K) [message #67330 is a reply to message #66850] Sat, 21 May 2005 08:53 Go to previous message
Originally posted by: icelmen.hotmail.com
I am new to Eclipse. I use WinXP SP2. I have the same problem running
eclipse.exe .
Error message:
!SESSION Sat May 21 13:28:52 BST 2005
!ENTRY org.eclipse.core.launcher 4 0 May 21, 2005 13:28:52.843
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:395)
at org.eclipse.core.launcher.Main.basicRun(Main.java:174)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Please some help.
Thanks in advance.
Leo
Previous Topic:How to use Images in an Eclipse plugin?
Next Topic:For get sourcecode from cvs ,how to set proxy for eclipse??
Current Time: Sat Aug 30 14:37:12 EDT 2025
Powered by FUDForum. Page generated in 0.07626 seconds
