Home » Language IDEs » C / C++ IDE (CDT) » Missing Symbol Table ( newbie question )
Missing Symbol Table ( newbie question ) [message #66702] |
Fri, 11 April 2003 11:45  |
Originally posted by: sandro_de_santis.it.ibm.com
I am having great fun with Eclipse, CDT and CGYWIN on Win2K.
I downloaded the latest stable versions about 15 days ago.
Even though my experience is really limited I could compile and run a
simple project.
I wrote the following .mak
Prj1 : Prog1.o
gcc -O Prj1 Prog1.o
Prog1.o : Prog1.c
gcc -ggdb -O Prog1.c
all :
make -f prog1.mak
..PHONY : clean
clean :
-del Prj1.exe -del *.o
the project is compiled and runs correctly in native mode.
When I try to debug it I can stop the execution at the main()
but when I look at the gdb console I get the following:
info threads
No stack.
No symbol table is loaded. Use the "file" command.
info threads
2 thread 1412.0x9d4 * 1 thread 1412.0x588
I'd appreciate any help.
Thank in advance
Sandro
Re: Missing Symbol Table ( newbie question ) [message #66875 is a reply to message #66868] |
Sat, 12 April 2003 07:35   |
Mikhail, please forgive me as I sent some misleading info.
First this is my current makefile:
Prj1 : Prog1.o
gcc -o Prj1 Prog1.o
Prog1.o : Prog1.c
gcc -ggdb -o Prog1.c
all :
make -f prog1.mak
..PHONY : clean
clean :
When I started this thread I used the -O and I could get a clean build
but I was missing debugging info.
Then you suggested to use -o I did it and I tried again, but I didn't
build correctly the project again, so in fact the second time I used the
very first build.
Whne I deleted .o and .exe and rebuilt with -o I didn't get a clean
build and the messages I get are as follows:
***(all) Error 2
***(Prog1.o) Error 1
Maybe the installation of CGYWIN is not correct but I don't know how to
go further.
Thank you again,
Ciao
Sandro
Mikhail Khodjaiants wrote:
> Sorry, disregard the previous message.
> It seems like your executable doesn't contain debug information. Can you
> send your makefile?
> "Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
> news:b77ach$lrk$1@rogue.oti.com...
>>Check if the full path of your executable contains space characters. This
> is
>>a bug in this version of CDT but it has been fixed in the head branch.
>>"Sandro De Santis" <sandro_de_santis@it.ibm.com> wrote in message
>>news:3E971AC5.4070600@it.ibm.com...
>>>Thank you Mikhail for the quick response!!
>>>I did as suggested but unfortunately there are no changes.
>>>Now the gdb console shows the following:
>>>info threads
>>>No stack.
>>>info threads
>>> 2 thread 2472.0x9bc * 1 thread 2472.0x8b4 No symbol table is
>>>Single stepping until exit from function main,
>>>which has no line number information.
>>>while the program is still running in suspended mode.
>>>Thank you for your patience!!
>>>Ciao
>>>Sandro
>>>>Use '-o' instead of '-O' in your make file.
>>>>news:3E96E646.3000008@it.ibm.com...
>>>>>I forgot to say that in these conditions Breakpoints do not work, nor
>>>>>the program runs step by step. It simply keeps running in the gdb
> window
>>>>>up to the completion.
>>>>>Thank you,
>>>>>Ciao
>>>>>Sandro
>>>>>Sandro De Santis wrote:
>>>>>>Hello,
>>>>>>simple project.
>>>>>>Prj1 : Prog1.o
>>>>>> gcc -O Prj1 Prog1.o
>>>>>>Prog1.o : Prog1.c
>>>>>>all :
>>>>>> make -f prog1.mak
>>>>>>.PHONY : clean
>>>>>>clean :
>>>>>>info threads
>>>>>>No stack.
>>>>>>info threads
>>>>>>Thank in advance
>>>>>>Sandro
Re: Missing Symbol Table ( newbie question ) [message #66880 is a reply to message #66702] |
Sat, 12 April 2003 22:33   |
Your Makefile is awefully filled with mistakes!
* -O is for optimizations --> -o <file> is for "output into <file>"
* your target Prj is missing an extension! in you clean rule you wrote
it right
* The first target in you Makefile is 'Prj1', and your 'all' rules is
way below and looks really useless, since Eclipse calls the build
process this way:
make clean
make
Here is a more proper Makefile:
# Makefile for compiling simple projects
# depends on GNU Make and other GNU Tools
# Henning Riedel
# set your programs here and add neccesary object-files here
TargetArch = Windows
ifeq ($(TargetArch),"Windows")
EXE_EXTENSION = .exe
LIB_EXTENSION = .lib
elsis ($(TargetArch),"Unix")
EXE_EXTENSION =
LIB_EXTENSION = .a
endif
PROG1 = myprog$(EXE_EXTENSION)
PROG1_OBJ = myprog.o extramodule.o
PROG2 = anotherprog$(EXE_EXTENSION)
PROG2_OBJ = anotherprog.o othermodule.o
LIB1 = mylibrary$(LIB_EXTENSION)
LIB1_OBJ = module.o module2.o module3.o
CLEANFILES = $(PROG1) $(PROG1_OBJ)
CLEANFILES += $(PROG2) $(PROG2_OBJ)
CLEANFILES += $(LIB1) $(LIB1_OBJ)
# setup some needed tools and their flags and some include/library-paths
CC = gcc
AR = ar
RM = -rm -f
# for windows you could use
#RM = -del
# actually gdb is most likely the default debugger
# though -g would be good too
C_DEBUG = -ggdb
CFLAGS = $(C_DEBUG) -I<extraincludedirs>
LDFLAGS = -L<extralibs_dirpath> -lc
# these targets are no real files!
..PHONY: all debug clean
# the default target, if make is being called _without_ target
..DEFAULT: all
# if target 'all' is set, clear C_DEBUG
all:
$(MAKE) "C_DEBUG=" $(PROG1) $(PROG2) $(LIB1)
debug:
$(MAKE) $(PROG1) $(PROG2) $(LIB1)
$(PROG1): $(PROG1_OBJ)
$(CC) -o $@ $< $(LDFLAGS)
# rule for building PROG2
$(PROG2): $(PROG2_OBJ)
# rule for building a static library
# actually build all LIB1_OBJ-files before by calling the %o:-rule
# and then more or less copy them into the .a file
$(LIB1): $(LIB_OBJ)
$(AR) cr $@ $<
# general rule for compiling C-Files to objects
%.o: %.c
$(CC) $(CFLAGS) -o $@ -c $^
# general rule for compiling C++-Files to objects
%.o: %.cpp
$(CXX) $(CXXFLAGS) -o $@ -c $^
clean:
$(RM) $(CLEANFILES)
#### add dependencies below and if one of these file in the deps
#### is changed, compile the files again
myprog.o: myprog.c myprog.h extramodule.h
anotherprog.o: anothermodule.c anothermodule.h othermodule.h
extramodule.o: extramodule.c extramodule.h
othermodule.o: othermodule.c othermodule.h
module1.o: module1.c module1.h
module2.o: module2.c module2h
module3.o: module3.c module3.h
################### Makefile End #######################################
I have pasted a Makefile here before which also checks MAKECMDGLOBALS if
make is called with 'debug' to either set C_DEBUG or not.
kesselhaus
Sandro De Santis schrieb:
> Hello,
> simple project.
> Prj1 : Prog1.o
> gcc -O Prj1 Prog1.o
> Prog1.o : Prog1.c
> all :
> make -f prog1.mak
> .PHONY : clean
> clean :
> info threads
> No stack.
> info threads
> Thank in advance
> Sandro
Re: Missing Symbol Table ( newbie question ) [message #66915 is a reply to message #66880] |
Mon, 14 April 2003 11:22   |
Thank you!!!
I modified your makefile and could consistently build my test program.
Unfortunately I still cannot run the program step by step nor
stop at breakpoints.
I did also the following:
- copied the files ( .c and .mak ) into the native cygwin environment
- built the program again
- compared the size of the .exes : they are the same.
- then I rebuilt ( in cygwin ) the program WITHOUT the -g or -ggdb
options and THE SIZE REMAINS THE SAME!!!
No Debugging info are added in either cases.
So, it looks like a problem in cygwin.
I subscribed to the cygwin@cygwin.com but I have problems because my
e-mails are rejected.
I'll try anyway to reach that mailing list.
Thanks to all for the helpful info.
ciao
Sandro
> it right
> process this way:
> make clean
> make
> # Henning Riedel
> EXE_EXTENSION =
> LIB_EXTENSION = .a
> endif
> CC = gcc
> AR = ar
> RM = -rm -f
> #RM = -del
> C_DEBUG = -ggdb
> .DEFAULT: all
> all:
> debug:
> $(LIB1): $(LIB_OBJ)
> $(AR) cr $@ $<
> %.o: %.c
> %.o: %.cpp
> clean:
> $(RM) $(CLEANFILES)
> kesselhaus
>> Hello,
>> simple project.
>> Prj1 : Prog1.o
>> gcc -O Prj1 Prog1.o
>> Prog1.o : Prog1.c
>> all :
>> make -f prog1.mak
>> .PHONY : clean
>> clean :
>> info threads
>> No stack.
>> info threads
>> Thank in advance
>> Sandro
Re: Missing Symbol Table ( newbie question ) [message #66942 is a reply to message #66915] |
Tue, 15 April 2003 12:37   |
The first is by myself :(
In the top ifeq... the elsis must be written as:
else
ifeq ($(TargetArch),"Unix")
endif
endif
since make does not recognize nested conditional statements.
The second mistake is yours.
In the debug: -rule, their is no "C_DEBUG=", since this would clear out
this variable!
Thats why I added it just in the 'all'-rule, where you dont want debug
infos usually.
The make command in the debug-rule should be:
<tab>$(MAKE) $(PROG1)
Also, if you set .DEFAULT: debug, you dont need to move the debug rule
above the all-rule.
kesselhaus
> Thank you!!!
> ciao
> Sandro
>> it right
>> process this way:
>> make clean
>> make
>> # Henning Riedel
>> EXE_EXTENSION =
>> LIB_EXTENSION = .a
>> endif
>> CC = gcc
>> AR = ar
>> RM = -rm -f
>> #RM = -del
>> C_DEBUG = -ggdb
>> .DEFAULT: all
>> all:
>> debug:
>> $(LIB1): $(LIB_OBJ)
>> $(AR) cr $@ $<
>> %.o: %.c
>> %.o: %.cpp
>> clean:
>> $(RM) $(CLEANFILES)
>> kesselhaus
>>> Hello,
>>> simple project.
>>> Prj1 : Prog1.o
>>> gcc -O Prj1 Prog1.o
>>> Prog1.o : Prog1.c
>>> all :
>>> make -f prog1.mak
>>> .PHONY : clean
>>> clean :
>>> info threads
>>> No stack.
>>> info threads
>>> Thank in advance
>>> Sandro
Re: Missing Symbol Table ( newbie question ) [message #67012 is a reply to message #66702] |
Thu, 17 April 2003 11:13  |
Originally posted by: brianr1026.netscape.net
Regardless of the details of your makefile, if you can build and run from
the Cygwin shell, but get
> info threads
when you try to debug within CDT, it is because there are spaces in the
path to your project. Move the project to a path without spaces, or move
the entier Eclipse install to a path without spaces and it should work. I
was tearing my hair out over the same problem.
Brian
> Hello,
> simple project.
> Prj1 : Prog1.o
> gcc -O Prj1 Prog1.o
> Prog1.o : Prog1.c
> all :
> make -f prog1.mak
> ..PHONY : clean
> clean :
> info threads
> No stack.
> info threads
> Thank in advance
> Sandro
Current Time: Mon Sep 01 00:25:41 EDT 2025
Powered by FUDForum. Page generated in 0.03715 seconds
