Home » Modeling » GMF (Graphical Modeling Framework) » Internal Error while generating gmfgen Model
Internal Error while generating gmfgen Model [message #66655] Fri, 20 October 2006 16:34 Go to next message
it often happens that trying to generate the gmfgen model from inside
the mapping definition gives a nice and informative popup window "An
internal Error occured during "Create generator model..."
Is there a way to find out more about what kind of Internal Error
occured, or a major modeling mistake that causes this Message to occur?
Felix
Re: Internal Error while generating gmfgen Model [message #66700 is a reply to message #66655] Fri, 20 October 2006 17:05 Go to previous messageGo to next message
Hi Felix,
Please check 'Error Log' view for further details.
This might be caused by invalid gmfmap model and should be reported as
validation diagnostics.
/Radek
"Felix Dorner" <felix_do@web.de> wrote in message
news:ehbbtc$vdp$1@utils.eclipse.org...
> it often happens that trying to generate the gmfgen model from inside the
> mapping definition gives a nice and informative popup window "An internal
> Is there a way to find out more about what kind of Internal Error occured,
> Felix
Re: Internal Error while generating gmfgen Model [message #66739 is a reply to message #66700] Sat, 21 October 2006 06:59 Go to previous messageGo to next message
Radek Dvorak schrieb:
> Hi Felix,
Thanks for the tip with the log, i could have found out this myself..
The error I get is something like:
java.lang.IllegalStateException: Can't find genFeature for feature
'blabla' in class Field. I think the error occurs when doing the
following workflow:
- change the domain model.
- open the gmfmap model and adapt changes in the domain model. It looks
like i do not have to reload any resources or so, since domain model
changes are directly available in the gmfmap editor. The Error however
makes me think it might be necessary to somehow refresh the gmfmap model?
Thanks, felix
Re: Internal Error while generating gmfgen Model [message #67524 is a reply to message #66739] Mon, 23 October 2006 05:04 Go to previous message
Hi Felix,
Looks like your .genmodel is not in sync with your .ecore.
Please, try to run 'Reload' action on .genmodel.
BTW: Also try searching this newsgroup for 'Can't find GenFeature' ;-)
/Radek
news:ehcujn$cgd$1@utils.eclipse.org...
>> Hi Felix,
> Thanks for the tip with the log, i could have found out this myself.. The
> 'blabla' in class Field. I think the error occurs when doing the following
> workflow:
> Thanks, felix
Previous Topic:Element in Metrics View
Next Topic:SWT property editor(2)
Current Time: Tue Jul 08 21:36:21 EDT 2025
Powered by FUDForum. Page generated in 0.08414 seconds
