Internal Error while generating gmfgen Model [message #66655] |
Fri, 20 October 2006 16:34  |
it often happens that trying to generate the gmfgen model from inside
the mapping definition gives a nice and informative popup window "An
internal Error occured during "Create generator model..."
Is there a way to find out more about what kind of Internal Error
occured, or a major modeling mistake that causes this Message to occur?
Felix
Re: Internal Error while generating gmfgen Model [message #67524 is a reply to message #66739] |
Mon, 23 October 2006 05:04  |
Hi Felix,
Looks like your .genmodel is not in sync with your .ecore.
Please, try to run 'Reload' action on .genmodel.
BTW: Also try searching this newsgroup for 'Can't find GenFeature' ;-)
/Radek
"Felix Dorner" <felix_do@web.de> wrote in message
news:ehcujn$cgd$1@utils.eclipse.org...
> Radek Dvorak schrieb:
>> Hi Felix,
>> Please check 'Error Log' view for further details.
>> This might be caused by invalid gmfmap model and should be reported as
>> validation diagnostics.
> Thanks for the tip with the log, i could have found out this myself.. The
> error I get is something like:
> java.lang.IllegalStateException: Can't find genFeature for feature
> 'blabla' in class Field. I think the error occurs when doing the following
> workflow:
> - change the domain model.
> - open the gmfmap model and adapt changes in the domain model. It looks
> like i do not have to reload any resources or so, since domain model
> changes are directly available in the gmfmap editor. The Error however
> makes me think it might be necessary to somehow refresh the gmfmap model?
> Thanks, felix
FUDForum. Page generated in 0.03856 seconds
