Home » Newcomers » Newcomers » jetty continuations help!(unable to compile servlet which uses jetty continuations.)
icon8.gif  jetty continuations help! [message #665809] Sat, 16 April 2011 05:13 Go to next message
hi!
i have recently started using jetty (version 7.3.0.v20110203).
i'm unable to compile the following servlet which uses jetty continuations.
Please HELP.
thanks,
ravi.
import java.lang.*;
import java.io.*;
import java.util.*;
import javax.servlet.*;
import javax.servlet.http.*;
import org.eclipse.jetty.continuation.Continuation;
import org.eclipse.jetty.continuation.ContinuationSupport;
public class ContinuationServlet extends HttpServlet {
  public void service(HttpServletRequest req, HttpServletResponse res)
                                              throws java.io.IOException {
    String reqId = req.getParameter("id");
   Continuation cc = ContinuationSupport.getContinuation(req);
    res.setContentType("text/plain");
    res.getWriter().println("Request: "+reqId+"\tstart:\t"+new Date());
    res.getWriter().flush();
    cc.suspend(2000);
    res.getWriter().println("Request: "+reqId+"\tend:\t"+new Date());
i'm able to compile HelloWorld.java but not this servlet.
i'm using windows and C:\jetty7 is my jetty installation directory.
for compiling:
javac -cp C:\jetty7\lib\servlet-api-2.5.jar;C:\jetty7\lib\jetty-all-$J ETTY_VERSION.jar ContinuationServlet.java
i'm getting the following error:
package org.eclipse.jetty.continuation does not exist
[Updated on: Sat, 16 April 2011 05:16] by Moderator
Re: jetty continuation help! [message #665824 is a reply to message #665809] Sat, 16 April 2011 10:55 Go to previous messageGo to next message
On Sat, 2011-04-16 at 05:13 -0400, ravi wrote:
> hi!
> Please HELP.
> thanks,
> ravi.
> import java.lang.*;
> import java.io.*;
> import java.util.*;
> cc.suspend(2000);
> for compiling:
You need to include the jetty-continuation-{version}.jar file in your
classpath.
Re: jetty continuation help! [message #665853 is a reply to message #665824] Sun, 17 April 2011 02:45 Go to previous messageGo to next message
hi David!
First off all thanks for your reply.I'm still unable to compile the servlet which uses jetty continuations.I'm still getting
package org.eclipse.jetty does not exist even after including the continuation file in classpath !.I have used the following code for compiling. Embarrassed Please check for any error.
javac -cp C:\jetty7\lib\servlet-api-2.5.jar;C:\jetty7\lib\jetty-contin uation-7.3.0.v20110203.jar ContinuationServlet.java
thanks in advance,
ravi.
Re: jetty continuation help! [message #665896 is a reply to message #665853] Mon, 18 April 2011 00:29 Go to previous message
On Sun, 2011-04-17 at 02:45 -0400, ravi wrote:
> hi David!
> package org.eclipse.jetty does not exist even after including the continuation file in classpath !.I have used the following code for compiling. :blush: Please check for any error.
> thanks in advance,
> ravi.
You need to include ALL the required jars in your class path. You
removed one that you probably need and replaced it with one you
definitely need. Check the documentation for Jetty to find out what
jars are needed to compile/run servlets that use the continuation api.
Previous Topic:Configure JTA Datasouce in Persistence.xml
Next Topic:Content assist and classes
Current Time: Wed Jul 02 15:24:34 EDT 2025
Powered by FUDForum. Page generated in 0.11779 seconds
