Home » Eclipse Projects » GEF » Problem using ScrollableThumbnail with ZoomManager
Problem using ScrollableThumbnail with ZoomManager [message #66629] Wed, 26 February 2003 12:42 Go to next message
I am trying to use the draw2d ScrollableThumbnail to show a thumbnail of a
figure that is zoomed using the ZoomManager. The issue appears to be that
the same scale used for the viewport depiction in the thumbnail is being
used for the figure drawing. What ends up happening is that the viewport is
drawn in the correct location relative to the figure, but the figure is not
drawn scaled correctly. Also since ScrollableThumbnail is declared final
it makes it difficult to work around the issue. Any thoughts on how to fix
or workaround without duplicating much of the ScrollableThumbnail code in a
new class.
Re: Problem using ScrollableThumbnail with ZoomManager [message #66651 is a reply to message #66629] Wed, 26 February 2003 15:05 Go to previous messageGo to next message
Please open a bugzilla explaining the problem. If you have code that
reproduces it, even better.
If you have a picture of the problem, maybe posting an image here is easier
than w/ bugzilla
"Chris Keller" <chris.keller@active-endpoints.com> wrote in message
news:b3ishn$tu4$1@rogue.oti.com...
Are you talking about a Viewport figure, or are you using the term viewport
to mean something else?
is
not
final
fix
a
> new class.
Re: Problem using ScrollableThumbnail with ZoomManager [message #66672 is a reply to message #66651] Wed, 26 February 2003 18:49 Go to previous message
It is a viewport associated with a ScalableRootEditPart, which is being
displayed in the thumbnail. I have zoomed the display using the ZoomManager
and when I do so the SrollableThumbnail displays the viewport image
appropriately, but draws the rest of the figure as if it were not zoomed. I
have attached a picture of a graph with a 2x zoom. One figure is on
visible, but there are two figures on the graph. Notice that the
thumbnail below the graph is showing the viewport as if both figures are
within view.
If the ScrollableThumbnail was not final or better yet accepted a
ZoomManager so it could account for the zoom level of the underlying figure
it would be great. I can open a bugzilla report if that would be the
easiest way to track the issue.
Thanks in advance.
BTW - The ScrollableThumbnail works great if the figure is not zoomed. Also
super work on GEF and draw2d. I have used commercial packages in the past
and the architecture of GEF and draw2d is very good. Nice job.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b3j4uq$55l$1@rogue.oti.com...
easier
> than w/ bugzilla
a
that
viewport
viewport
> is
> not
> final
> fix
in
> a
> > new class.
Previous Topic:why are some classes left out in later GEF integration builds?
Next Topic:load HelloGef1 into a StructuredViewer
Current Time: Sat Jul 26 18:41:06 EDT 2025
Powered by FUDForum. Page generated in 0.03327 seconds
