Home » Language IDEs » Java Development Tools (JDT) » Running java projects using jview
Running java projects using jview [message #66609] Wed, 25 June 2003 02:15 Go to next message
Originally posted by: jonny_day.nospamplease.hotmail.com
I noticed a post on comp.lang.java.programmer from someone who had managed
to get Eclipse running with jview as the JRE. However there were no details
provided. Is anyone aware of how to achieve this? I'm running Eclipse 2.1
on WinXP Pro.
Jonathan
Re: Running java projects using jview [message #66822 is a reply to message #66609] Wed, 25 June 2003 07:00 Go to previous messageGo to next message
details
2.1
> on WinXP Pro.
My solution:
I used a batch file like this:
"C:\Program Files\Java\JDK\Microsoft\Bin\jview.exe" /cp %2 %3
I saved it as run_ms.bat in C:\j2sdk1.4.2\bin
I set up a new JVM config called "MS".
I pointed the JDK at C:\j2sdk1.4.2
The java executable (in Eclipse run settings) was set to run_ms.bat.
That's all!
__________
|im |yler http://timtyler.org/ tim@tt1.org
Re: Running java projects using jview [message #68618 is a reply to message #66822] Fri, 27 June 2003 07:51 Go to previous message
Just remember that Microsoft's JVM is at 1.1.x level only ...
Genady
> details
> 2.1
>>on WinXP Pro.
> My solution:
> That's all!
> __________
Previous Topic:JAXP upgrade problem with V3 M1
Next Topic:How to use plug ins
Current Time: Tue Jul 22 07:25:52 EDT 2025
Powered by FUDForum. Page generated in 0.24776 seconds
