Home » Modeling » GMF (Graphical Modeling Framework) » composing commands vs executing commands inside doExecuteWithResult
composing commands vs executing commands inside doExecuteWithResult [message #66569] Fri, 20 October 2006 14:39 Go to next message
Originally posted by: vcciubot.uwaterloo.ca
I find myself creating AbstractTransactionalCommands that execute other
semantic commands in doExecuteWithResult.
Is this the right approach? Should I be composing commands instead?
thank you
vlad
Re: composing commands vs executing commands inside doExecuteWithResult [message #67860 is a reply to message #66569] Mon, 23 October 2006 10:15 Go to previous message
Hello Vlad,
It is preferable if you use a composite rather than delegating to the
other command. By using a composite command the affected files and
undo/redo behaviour of its children will automatically be considered
when the composite is executed. If you delegate to the second command,
you need to ensure that your wrapper command correctly reflects the
affected files and undo/redo behaviour of its delegate.
Linda
> thank you
> vlad
Previous Topic:Link mapping problem
Next Topic:Toggle arrange all action
Current Time: Tue Jul 15 06:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.25907 seconds
