Re: [EMF compare] [message #664948 is a reply to message #664586] |
Tue, 12 April 2011 15:01 |
The error message is pretty clear on this : one of the object in the target model (after the merge, as it seem to happen when we try and save the merged model) is not "contained" within any of your models, yet it is "referenced" by another.
The offending object here is "Formulaire_add" of type "Form". You reference it from somewhere in the model, yet it isn't in the model tree itself (that is, "formulaire_add.eResource() == null"). EMF Cannot save such models.
You need to find where this object is referenced from, and why it isn't located in one of your models. Should it have been merged along with the other differences? Or did you create if ("FormFactory.eINSTANCE.createForm()" or something of the sort) without adding it into a proper container?
Laurent Goubet
Obeo
FUDForum. Page generated in 0.03416 seconds
