Home » Language IDEs » ServerTools (WTP) » Error opening XML editor
Error opening XML editor [message #66528] Thu, 20 January 2005 04:55 Go to next message
I get an error message when I try to open a XML editor. This XML file as
no schema.
I get a popup error: "An error has occurred when creating this editor"
I'm using eclipse 3.1M4.
Bests,
Bruno Basílio
Re: Error opening XML editor [message #66549 is a reply to message #66528] Thu, 20 January 2005 07:54 Go to previous message
This error comes 'cause the eclipse doesn't correctly identify the file
as an xml file... click right on the file -> open with -> TextEditor and
it should work... after the first time eclipse should correctly identify
the file...
On my engine this happened with application.xml prior to installing the
webtools... after the install application.xml got a schemata xsd file etc...
Previous Topic:Web Tools Platform (WTP) project track at EclipseCon
Next Topic:wtp website & downloads
Current Time: Thu Jul 17 20:55:31 EDT 2025
Powered by FUDForum. Page generated in 7.86963 seconds
