| multiple instances, osgi kernel stability issues [message #66503] |
Fri, 12 May 2006 03:54  |
While testing our new RCP application package we are plagued by
intermittend and hard to reproduce exceptions in classloading,
statereader, statewriter, ... ranging from Nullpointers to
ClassNotFoundExceptions. Now it did not occur to me before but I think we
only get these errors when we have multiple instances running. For
instance our application contains a ui IPlatformRunnable and a server
IPlatformRunnable running in different jvms. So they share the same
configuration area with the same bundledata etc.
Could this present problems ? Especially with plugins that are lazy
started ? How come eclipse itself uses this setup and it keeps on working
then ?
The reason I ask is that some of these errors are quite severe and if this
should work properly then I need to start reporting bugs.
FUDForum. Page generated in 0.04890 seconds
