Home » Language IDEs » PHP Development Tools (PDT) » PDT and Eclipse 3.4
PDT and Eclipse 3.4 [message #66453] Thu, 21 February 2008 16:26 Go to next message
Hi all,
How do I run PDT on Eclipse 3.4?
I tried installing these recommended versions:
http://dev.eclipse.org/mhonarc/lists/pdt-dev/msg00427.html
from pdt-dev list, but is not working with the last nightly build -
Eclipse opens but there is no PDT vestiges there.
Any idea if is possible to run PDT on Eclipse 3.4 and how to do it?
thanks
Re: PDT and Eclipse 3.4 [message #66475 is a reply to message #66453] Fri, 22 February 2008 03:58 Go to previous messageGo to next message
It could be the nightly build is not taken from cvs HEAD branch but from the 1.0.2 branch, in which
case it is unlikely to work as the 1.0.2 branch is targetted at the 3.3 version and associated pre-reqs.
Dave Kelsey
Erico wrote:
> Hi all,
> thanks
Re: PDT and Eclipse 3.4 [message #66517 is a reply to message #66475] Fri, 22 February 2008 06:26 Go to previous message
> the 1.0.2 branch, in which case it is unlikely to work as the 1.0.2
It is taken from HEAD but misses one important pre-req on the download
page which is DLTK project. After installing it PDT should work. At
least it worked few days ago.
Piotr Szczepanik
Previous Topic:Code Assist (suggests)
Next Topic:Convert spaces to tabs
Current Time: Tue Jul 22 01:46:08 EDT 2025
Powered by FUDForum. Page generated in 0.44199 seconds
