Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Library Editor Example not working
[Teneo] Library Editor Example not working [message #66448] Thu, 04 January 2007 14:15 Go to next message
Originally posted by: nelson.silva.gmail.com
I just started looking at Teneo. I followed the EMF Library example and
got it working. Then, according to the Teneo tutorials I overloaded the
start(BundleContext context) method in LibraryEditorPlugin and set the
org.eclipse.emf.ecore.extension_parser extension point as said.
The plugin is connecting to the database and creating the necessary
tables but, when I try to create a Library Model nothing happens! I
click "Finnish" there are no errors in Eclipse's error log but the
library is not created and the Wizard's dialog does not close! Any ideas ?
Nelson Silva
Re: [Teneo] Library Editor Example not working [message #66510 is a reply to message #66448] Thu, 04 January 2007 16:19 Go to previous message
Hi Nelson,
To be sure, did you set the name of the library object as outlined here:
http://www.elver.org/hibernate/tutorialtwo/tutorial2_1.html# Create+valid+EMF+Objects
gr. Martin
Nelson Silva wrote:
> Nelson Silva
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Library Editor Example not working [message #600672 is a reply to message #66448] Thu, 04 January 2007 16:19 Go to previous message
Hi Nelson,
gr. Martin
Nelson Silva wrote:
> Nelson Silva
The Netherlands
Previous Topic:Teneo : where is the last release ?
Next Topic:Questions on JET transformation project
Current Time: Sat Jul 12 23:57:04 EDT 2025
Powered by FUDForum. Page generated in 0.04106 seconds
