Home » Eclipse Projects » EclipseLink » OptimisticLockException with delete
OptimisticLockException with delete [message #663129] Sun, 03 April 2011 21:25 Go to next message
attila Mising name is currently offline attila Mising nameFriend
Member
Upgrading from 2.1.2 to 2.2.0 (tried with 2.3.0-M6 also) i'm facing the following issue:
Trying to issue 2 delete statements:
 this.em.createQuery("delete from whatever_entity_with_empty_table") ... ;
  this.em.createQuery("delete from annother_entity_with_empty_table") ... ;
 <property name="eclipselink.jdbc.batch-writing" value="JDBC" />
  <property name="eclipselink.jdbc.native-sql" value="true" />
using MySQL 5 as database, throws an org.eclipse.persistence.exceptions.OptimisticLockException with
Exception Description: One or more objects cannot be updated because it has changed or been deleted since it was last read
Tracing the code until the second statement is processed , the execution reaches executeBatchedStatements method in
ParameterizedSQLBatchWritingMechanism and the condition in 'if' evaluates to true as
executionCount is 0 (coming from MySQLPlatform.executeBatch ) and statementCount =1
PreparedStatement statement = this.prepareBatchStatements(session);
  executionCount += this.databaseAccessor.executeJDK12BatchStatement(statement, this.lastCallAppended, session, true);
  this.databaseAccessor.writeStatementsCount++;
  if (this.previousCall.hasOptimisticLock() && (executionCount!=statementCount)){
     throw OptimisticLockException.batchStatementExecutionFailure();
I'm not really getting the point here, maybe there is something i'm missing in an upper level.
Any idea about this ?
Thank you
Re: OptimisticLockException with delete [message #663327 is a reply to message #663129] Mon, 04 April 2011 15:51 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
This is a bug,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324407
Please update this bug with your info and vote for it.
You may also wish to try the latest build, as I remember this being changed recently.
There is a workaround in the bug.
James : Wiki : Book : Blog : Twitter
Re: OptimisticLockException with delete [message #663334 is a reply to message #663327] Mon, 04 April 2011 16:29 Go to previous message
Member
Thank you James
Previous Topic:update query and stale cache
Next Topic:Cloning objects in EclipseLink
Current Time: Fri May 03 07:27:07 GMT 2024
Powered by FUDForum. Page generated in 0.03692 seconds
