Home » Eclipse Projects » Equinox » Why would a plugin end up as [Installed] and not [Resolved] or [Active]?
Why would a plugin end up as [Installed] and not [Resolved] or [Active]? [message #66419] Fri, 12 May 2006 00:27 Go to next message
I have an issue in bugzilla and a post on the platform newsgroup about
this (links at the end). I'm seeing the plugins in my feature end up in
different "states" according to Help->About->Configuration Details.
One plugin ends up as state [Installed] when installed via online update
and the same plugin shows up as state [Active] when I do the same from an
achived update site.
As I said there is an issue in bugzilla.
My question for this newsgroup is what is the significance of [Installed]
vs [Resolved] vs [Active] (I think I can guess) and how are these states
achieved, or changed?
TIA
Geoff
Plaform newsgroup:
http://www.eclipse.org/newsportal/article.php?id=54287&g roup=eclipse.platform#54287
Bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139967
Re: Why would a plugin end up as [Installed] and not [Resolved] or [Active]? [message #66482 is a reply to message #66419] Fri, 12 May 2006 03:38 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
Installed - the plugins code is available in the platform.
Resolved - The plugin and all its plugins are available and the plugin
is ready to be activated.
Active - The plugin has been activated through a user action. E.g. code
from the plugin has been run. (See also Eclipse-LazyStart or
Eclipse-AutoStart in manifest.mf in the help)
Hope that clears some stuff up
Stefan
> an achived update site.
> [Installed] vs [Resolved] vs [Active] (I think I can guess) and how are
> these states achieved, or changed?
> TIA
> Geoff
> Plaform newsgroup:
> Bugzilla:
Re: Why would a plugin end up as [Installed] and not [Resolved] or [Active]? [message #66562 is a reply to message #66482] Fri, 12 May 2006 04:35 Go to previous messageGo to next message
Originally posted by: neil.integility.com
Just to add a little to what Stefan said: under Equinox, if a bundle is
stuck in INSTALLED state it generally means that its dependencies could
not be resolved. By adding the -console switch when you launch, you can
use the OSGi console to diagnose the missing dependencies using the "diag"
command. For example:
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.0.v20060328
1 ACTIVE org.eclipse.equinox.common_3.2.0.v20060329
2 INSTALLED org.eclipse.equinox.http_1.0.0.v20060317
osgi> diag 2
initial@reference:file:plugins/org.eclipse.equinox.http_1.0.0.v20060317.jar/
[2]
Missing imported package javax.servlet_0.0.0.
Missing imported package javax.servlet.http_0.0.0.
Missing imported package org.osgi.service.cm_1.0.0.
Missing imported package org.osgi.service.http_1.1.0.
Missing imported package org.osgi.service.log_1.0.0.
Neil
Re: Why would a plugin end up as [Installed] and not [Resolved] or [Active]? [message #67403 is a reply to message #66562] Mon, 15 May 2006 09:20 Go to previous message
Hey that's useful!
Thanks!
Geoff
> osgi> ss
> id State Bundle
> osgi> diag 2
> [2]
> Neil
Previous Topic:Best practices for class loading issues
Next Topic:shutdown framework -> relaunch framework
Current Time: Tue Jul 08 07:51:34 EDT 2025
Powered by FUDForum. Page generated in 0.07703 seconds
