Home » Archived » BIRT » how to make more than column?
how to make more than column? [message #66396] Wed, 10 August 2005 06:23 Go to next message
Originally posted by: fremen.k9.pl
I need to make payment report, but for saving sheet of paper and space
i'd like that BRIT automatically split table to 2 colums, for ex.:
Till now i have 2 pages:
+---------------+ <- page size
|John 10|
|Mary 10|
|Lucy 10|
|Alf 10|
|Brit 10|
|Zen 10|
But i want to have it like this:
+John 10 Brit 10|
+Mary 10 Zen 10|
+Lucy 10 |
+Alf 10 |
It's one and the same table. Num of rows
is various.
Fremen
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: how to make more than column? [message #66561 is a reply to message #66396] Wed, 10 August 2005 11:33 Go to previous messageGo to next message
Originally posted by: statineni.issintl.com
Hey,
I got a question similar to this.
How can we get the 2 chart reports on the same page.
Sudha
> |John 10|
> |Mary 10|
> |Lucy 10|
> |Alf 10|
> |Brit 10|
> |Zen 10|
> +John 10 Brit 10|
> +Mary 10 Zen 10|
> +Lucy 10 |
> +Alf 10 |
> is various.
> Fremen
Re: how to make more than column? [message #66706 is a reply to message #66396] Wed, 10 August 2005 23:50 Go to previous messageGo to next message
Hi Fremen,
At present, BRIT does not supprt to split table to 2 or more colums
automatically.
However, you could achieve the similar preview result by a method as follows
(a little bit tricky ^-^):
1. Insert a Grid with 2 columns / 1 row
2. Insert a table to the first cell of grid, and then copy the table and
paste it to the 2nd cell of the grid.
shows how to set the map rule and the preview results corresponding to the
settings). In the Set Map rule dialog, leave the "Then display following
value:" field as blank.
Please see the attached Test.rptdesign file for more information.
Hope it could help.
Cheers.
Nina
<fremen@k9.pl> wrote in message
news:op.svae50kco751bb@localhost.localdomain...
> |John 10|
> |Mary 10|
> |Lucy 10|
> |Alf 10|
> |Brit 10|
> |Zen 10|
> +John 10 Brit 10|
> +Mary 10 Zen 10|
> +Lucy 10 |
> +Alf 10 |
> is various.
> Fremen
  • Attachment: Test.rptdesign
    (Size: 13.47KB, Downloaded 281 times)
  • Attachment: snap.gif
    (Size: 12.52KB, Downloaded 133 times)
Re: how to make more than column? [message #66728 is a reply to message #66706] Thu, 11 August 2005 02:37 Go to previous message
On Thu, 11 Aug 2005 05:50:30 +0200, Nina Li <nli@actuate.com> wrote:
> 3. Set the Map rule of the table in Property editor (The attached =
> shows how to set the map rule and the preview results corresponding to=
> the
> settings). In the Set Map rule dialog, leave the "Then display followi=
ng
Thanx, i was thinking about sth like "Example 2", but is there any
function/property to get number of rows returned by Set ??
it would be cause then I can write: "row[0]+1 Larger than =
(peopleSetNumOfRows/2)"
Fremen
Previous Topic:The FOP file
Next Topic:Scripts in onRow handler of table
Current Time: Wed Jul 23 01:17:39 EDT 2025
Powered by FUDForum. Page generated in 0.03582 seconds
