debugging in QNX [message #66377] |
Wed, 09 April 2003 09:51  |
I run eclipse 2.1 and CDT 1.0.1 in QNX. I managed to build "Hello World",
but I cannot start debugger. This is an excerpt from log file:
!ENTRY org.eclipse.debug.ui 4 120 Apr 09, 2003 09:43:11.984
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.core.runtime.CoreException: No such debugger
Stack trace:
java/lang/Throwable.<init>()V
java/lang/Throwable.<init>(Ljava/lang/String;)V
org/eclipse/core/runtime/CoreException.<init>(Lorg/eclipse/core/runtime/IStatus;)V
org/eclipse/cdt/debug/core/CDebugCorePlugin.getDebugConfigur ation(Ljava/lang/String;)Lorg/eclipse/cdt/debug/core/ICDebug Configuration;
org/eclipse/cdt/launch/AbstractCLaunchDelegate.getDebugConfi g(Lorg/eclipse/debug/core/ILaunchConfiguration;)Lorg/eclipse /cdt/debug/core/ICDebugConfiguration;
org/eclipse/cdt/launch/internal/LocalCLaunchConfigurationDel egate.launch(Lorg/eclipse/debug/core/ILaunchConfiguration;Lj ava/lang/String;Lorg/eclipse/debug/core/ILaunch;Lorg/eclipse /core/runtime/IProgressMonitor;)V
org/eclipse/debug/internal/core/LaunchConfiguration.launch(L java/lang/String;Lorg/eclipse/core/runtime/IProgressMonitor; )Lorg/eclipse/debug/core/ILaunch;
org/eclipse/debug/internal/ui/DebugUIPlugin.buildAndLaunch(L org/eclipse/debug/core/ILaunchConfiguration;Ljava/lang/Strin g;Lorg/eclipse/core/runtime/IProgressMonitor;)Lorg/eclipse/d ebug/core/ILaunch;
org/eclipse/debug/ui/DebugUITools.buildAndLaunch(Lorg/eclips e/debug/core/ILaunchConfiguration;Ljava/lang/String;Lorg/ecl ipse/core/runtime/IProgressMonitor;)Lorg/eclipse/debug/core/ ILaunch;
org/eclipse/debug/ui/DebugUITools$2.run(Lorg/eclipse/core/ru ntime/IProgressMonitor;)V
org/eclipse/jface/operation/ModalContext$ModalContextThread. run()V
!ENTRY org.eclipse.cdt.debug.core 4 100 Apr 09, 2003 09:43:11.989
!MESSAGE No such debugger
Can I fix it by simple altering something in configuration or I have to
wait for another release?
Serge
Re: debugging in QNX [message #66474 is a reply to message #66432] |
Wed, 09 April 2003 11:36   |
Thank you for the hint. I missed this place. Now I set it to gdb, but when
I press "Debug" button I get following:
!ENTRY org.eclipse.debug.ui 4 120 Apr 09, 2003 11:36:48.862
!STACK 1
org.eclipse.core.runtime.CoreException[150]:
org.eclipse.cdt.debug.core.cdi.CDIException: Error initializing:
{R,T}xThread terminated
Stack trace:
org/eclipse/cdt/debug/core/cdi/CDIException.<init>(Ljava/lang/String;)V
org/eclipse/cdt/debug/mi/core/GDBDebugger.createLaunchSessio n(Lorg/eclipse/debug/core/ILaunchConfiguration;Lorg/eclipse/ core/resources/IFile;)Lorg/eclipse/cdt/debug/core/cdi/ICDISe ssion;
!ENTRY org.eclipse.cdt.launch 4 150 Apr 09, 2003 11:36:48.878
!MESSAGE Failed Launching CDI Debugger : Error initializing: {R,T}xThread
terminated
!STACK 0
Stack trace:
> David Inglis wrote:
> Your launch configuration contains a debugger ID which does not exist in
your installation.
> To fix this go to the debugger tab in the launch configuration dialog and it
should change
> to the correct debugger.
> > !STACK 1
> > Stack trace:
> > Thanks,
> > Serge
Re: debugging in QNX [message #66537 is a reply to message #66474] |
Wed, 09 April 2003 15:09   |
Originally posted by: mikhailk.qnx.com
Check the version of your gdb. It should be 5.2.1 to work with CDT.
"Serge" <Serge_Yuschenko@kelk.com> wrote in message
news:b71elt$ubf$1@rogue.oti.com...
> !STACK 1
> Stack trace:
ebug/core/ILaunchConfiguration;Lorg/eclipse/core/resources/I File;)Lorg/eclip
se/cdt/debug/core/cdi/ICDISession;
g/eclipse/debug/core/ILaunchConfiguration;Ljava/lang/String; Lorg/eclipse/deb
ug/core/ILaunch;Lorg/eclipse/core/runtime/IProgressMonitor;) V
;Lorg/eclipse/core/runtime/IProgressMonitor;)Lorg/eclipse/de bug/core/ILaunch
g/core/ILaunchConfiguration;Ljava/lang/String;Lorg/eclipse/c ore/runtime/IPro
gressMonitor;)Lorg/eclipse/debug/core/ILaunch;
unchConfiguration;Ljava/lang/String;Lorg/eclipse/core/runtim e/IProgressMonit
onitor;)V
> terminated
> !STACK 0
> Stack trace:
onitor;)V
> your installation.
and it
> should change
World",
> > > !STACK 1
> > > Stack trace:
tus;)V
/String;)Lorg/eclipse/cdt/debug/core/ICDebugConfiguration;
ebug/core/ILaunchConfiguration;)Lorg/eclipse/cdt/debug/core/ ICDebugConfigura
tion;
onitor;)V
to
> > > Thanks,
> > > Serge
Re: debugging in QNX [message #66579 is a reply to message #66537] |
Wed, 09 April 2003 16:25   |
Thanks. I have 5.0. As far as I know 5.2.1 is comming with QNX 6.2.1. I'll
wait.
Serge
> > !STACK 1
> > Stack trace:
> onitor;)V
> > terminated
> > !STACK 0
> > Stack trace:
> onitor;)V
> > your installation.
> and it
> > should change
> World",
> > > > !STACK 1
> > > > Stack trace:
> tus;)V
> tion;
> onitor;)V
> to
> > > > Thanks,
> > > > Serge
Re: debugging in QNX [message #66601 is a reply to message #66579] |
Wed, 09 April 2003 16:39  |
That's correct. The QNX 6.2.1 includes gdb 5.2.1.
news:b71vk6$fd8$1@rogue.oti.com...
> wait.
> Serge
when
> > > !STACK 1
> > > Stack trace:
> > onitor;)V
{R,T}xThread
> > > terminated
> > > !STACK 0
> > > Stack trace:
> > onitor;)V
exist in
> > > your installation.
dialog
> > and it
> > > should change
> > World",
> > > > > !STACK 1
> > > > > Stack trace:
> > tus;)V
> > tion;
> > onitor;)V
have
> > to
> > > > > Thanks,
> > > > > Serge
FUDForum. Page generated in 0.03240 seconds
