Home » Eclipse Projects » Mylyn » Trac 0.11 + Mylyn: Weird Query results
Trac 0.11 + Mylyn: Weird Query results [message #66324] Tue, 10 March 2009 07:48 Go to next message
I'm transferring a Trac 0.10 environment to a new server. As part of that
process, I'm upgrading to Trac 0.11 following the instructions at
http://trac.edgewall.org/wiki/TracUpgrade.
I'm seeing some odd results with Mylyn queries based on the Ticket Owner:
Tickets that got carried over from 0.10 environment successfully show up in
the query results.
New Tickets that I create in Trac 0.11 environment do *not* show up, though.
Tickets that *should* match my query appear in the repository's "Unmatched"
container if I
* create a task with Mylyn
* create a task with the email2trac plugin
If I use a browser to create a Ticket that should match my query, it doesn't
show up at all. I can search the repository, and find it that way. If I
add some context (by adding a comment), then it shows up in
the "Uncategorized" container.
Anyone seen anything like this, before?
Some background:
I'm seeing these results on Linux/Eclipse 3.3.2 with Mylyn 3.0.3, and
Windows XP/Eclipse 3.3.2 with Mylyn 3.0.3 (Trac Connector 3.0.5).
I see from http://wiki.eclipse.org/index.php/Mylyn_FAQ#Trac_Connector that I
should be able to get Trac 0.11 talking to Mylyn:
* I don't use a custom work-flow, so the missing functionality shouldn't
affect me.
*Also, I'm logged in as an administrative user, so, at this point, I don't
think I need to worry about the XmlRpcPlugin patch.
I also read this article:
http://nil.checksite.co.uk/post.cfm/trac-0-11-and-mylyn
.... and so I'm using XmlRpcPlugin from trunk.
Re: Trac 0.11 + Mylyn: Weird Query results [message #66440 is a reply to message #66324] Thu, 12 March 2009 07:38 Go to previous messageGo to next message
> "Unmatched" container if I
> doesn't
Hmm. I tried upgrading to Mylyn 3.1 on my XP box. Now, no matter which
route I used to create a Ticket, those created since upgrading to Trac 0.11
don't appear at all in Mylyn, unless I manually "Search repository for key
or summary...".
When I open a Ticket that I've searched for, Mylyn tells me that it's "Not
in Task List. Click to add." When I do this, the Ticket appears in
Re: Trac 0.11 + Mylyn: Weird Query results [message #66461 is a reply to message #66324] Thu, 12 March 2009 12:25 Go to previous messageGo to next message
After writing my own script to query Trac via XML-RPC, it looks like my
installation of XmlRpcPlugin's ticket.query() method is returning a maximum
of 100 results.
If I exclude closed tickets from my Mylyn query (thereby bring the total
number of results to <100), then I get the results I'd expect.
Strangely, the XmlRpcPlugin on my Trac 0.10 install is *not* limited to 100
results - I don't know why I'm seeing different behaviour, here.
However, the fault doesn't appear to be anything to do with Mylyn. I
thought I'd post that outcome here in the hope of saving someone some
frustration.
G.
Re: Trac 0.11 + Mylyn: Weird Query results [message #66480 is a reply to message #66461] Thu, 12 March 2009 16:07 Go to previous messageGo to next message
Geraint, thanks for posting the solution to this problem. Here are some
links to related discussion:
http://trac-hacks.org/ticket/3509
http://dev.eclipse.org/newslists/news.eclipse.tools.mylyn/ms g01614.html
I have opened a bug:
268427: query only returns first 100 matches
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268427
Steffen
> maximum of 100 results.
> 100 results - I don't know why I'm seeing different behaviour, here.
> frustration.
> G.
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Trac 0.11 + Mylyn: Weird Query results [message #66522 is a reply to message #66480] Fri, 13 March 2009 05:20 Go to previous message
Steffen:
Actually, the items_per_page config solution mentioned in the links you
provided is probably better:
> Here are some
I think it would be a good idea to have (at least one of) these links on the
wiki at http://wiki.eclipse.org/Mylyn_FAQ#Does_Mylyn_support_Trac_0. 11.3F
Many thanks for your help.
G.
Re: Trac 0.11 + Mylyn: Weird Query results [message #596679 is a reply to message #66324] Thu, 12 March 2009 07:38 Go to previous message
> doesn't
or summary...".
Re: Trac 0.11 + Mylyn: Weird Query results [message #596684 is a reply to message #66324] Thu, 12 March 2009 12:25 Go to previous message
of 100 results.
frustration.
G.
Re: Trac 0.11 + Mylyn: Weird Query results [message #596691 is a reply to message #66461] Thu, 12 March 2009 16:07 Go to previous message
Steffen
> frustration.
> G.
Steffen Pingel
Re: Trac 0.11 + Mylyn: Weird Query results [message #596707 is a reply to message #66480] Fri, 13 March 2009 05:20 Go to previous message
Steffen:
> Here are some
G.
Previous Topic:How to use MarkupTaskEditorExtension
Next Topic:Access to Connector instance from query page
Current Time: Sun Jul 27 06:10:21 EDT 2025
Powered by FUDForum. Page generated in 0.05288 seconds
