Selection in GEF [message #66321] |
Mon, 24 February 2003 12:41  |
I would like to change the appearance of a figure and update my model when
user select a figure (e.g. when I select a label in the logic editor
example, there are 4 small black squares in the corners) . Do I need to
implmenet my edit policy with the SELECTION_FEEDBACK_ROLE = "Selection
Feedback"?
But in the logic editor example, only container add SELECTION_FEEDBACK_ROLE,
not the label itself. Where in the example which in install the edit policy
for the selection feedback of the label?
Thanks for any help.
installEditPolicy(
EditPolicy.SELECTION_FEEDBACK_ROLE,
new ContainerHighlightEditPolicy());
Re: Selection in GEF [message #66425 is a reply to message #66405] |
Mon, 24 February 2003 22:16  |
The easiest way is to subclass SelectionEditPolicy, or copy the code from
it.
"Hal" <otaconss2@hotmail.com> wrote in message
news:b3e8cg$f8s$1@rogue.oti.com...
> Thanks. Could you please tell me how can a editpolicy know if the figure
has
> been selected by the user?
> Thank you again.
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:b3e5pt$dm9$1@rogue.oti.com...
> > news:b3djrf$tn7$1@rogue.oti.com...
> > > Hi,
> when
> > Model? How would you change the model on selection?
> > policy
> > Any EditPolicy can decide to change the figure's appearance when the
> > EditPart is selected. The role is not too important unless you are
> > dynamically switch edit policies, or subclasses wish to remove a role
> added
> > in the superclass.
FUDForum. Page generated in 0.04482 seconds
