Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Using JET on xsd compliant xml
Using JET on xsd compliant xml [message #66299] Wed, 03 January 2007 07:42 Go to next message
Originally posted by: rtv222.gmail.com
We have a .xsd to define relationships between entities we model.
(This .xsd gives us complexTypes and elements to define the entities
that we model, thier relationships and attributes)
We are trying to create an EMF model by importing this .xsd and
then generating an EMF/GMF editor to create xml compliant with
our modeling .xsd.
How can we use JET to browse EMF editor created xml via ecore EMF api
and generate java code ?
Rajesh
Re: Using JET on xsd compliant xml [message #68252 is a reply to message #66299] Tue, 16 January 2007 11:04 Go to previous message
Rajesh:
You asked:
do the following:
1) Create a new EMFT JET Project. EMFT JET project names should be valid
plug-in names - something like: dump.my.emf.model
2) Open plugin.xml, switch to the 'Extensions' tab, expand the tree and
select 'transform'. Set the 'modelLoader' attribute to
'org.eclipse.jet.emf'.
3) Save and exit the Plug-in Manifest Editor.
4) Find a instance of the document created by your EMF-created editor.
Select it.
5a) If the file has an XML extension, right click, and click Run As > Input
for JET Transformation
5b) If the file does not have an XML extesino, right click, and chick Run As
> Run... Then select JET Transformation, and click the 'New' icon.
6) In the ID drop-down, select the name of the project created in 1). Click
Run.
Although you have written no code, the above should execute, and produce a
file dump.xml in the root of the project containing th input selected in 4).
Note that dump.xml may not be an exact replica of the input - it is the
input document as seen by JET's XPath engine.
You can enhance this JET transformation to create other files/folders or
projects by including appropriate <ws:file>, <ws:folder> and <ws:project>
tags in templates/main.jet.
Each ws:file tag requires you to create a new JET template that provides the
file contents.
Lastly, you do not have to use JET Transformation launch configurations. It
is also possible to invoke JET Transformations via API. To run a JET
transformation from an already-loaded EMF model (say that your EMF/GMF
generated editor has open), you can use:
Resource emfResource = ... ; // the EMF Resource containing the already
loaded model
Map additionalVars = new HashMap();
// do things like additionalVars.add("targetProject", "foo.bar"); to define
input variables to the JET transformation
JET2Platform.runTransform("..transform id..", emfResource, additionalVars,
progressMonitor);
Re: Using JET on xsd compliant xml [message #601319 is a reply to message #66299] Tue, 16 January 2007 11:04 Go to previous message
Rajesh:
You asked:
do the following:
Select it.
Run.
file contents.
loaded model
progressMonitor);
Previous Topic:JET error
Next Topic:[Announce] EMFT EODM 0.8.0M4 is available
Current Time: Tue Jul 22 12:01:10 EDT 2025
Powered by FUDForum. Page generated in 0.03044 seconds
