Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Table Update problem
RAP Table Update problem [message #5897] Tue, 13 March 2007 08:15 Go to next message
first I like to say that RAP is a realy a cool project!
I installed the M2 release in Eclipse to play around a little bit with RAP.
I modified the DemoTableViewPart to fetch data via a SOAP Request. That
works
fine but I can't refresh the table after the Request. I used the eclipse
debugger to inspect the contents of the underlaying table data model. The
data changed after the SOAP request but the view does not refresh. I tried
viewer.setInput(this);
viewer.refresh(this);
I must say that I am not that familar with RWT/SWT.
Any hint would be appreciated.
Best Regards,
Thomas
Re: RAP Table Update problem [message #5949 is a reply to message #5897] Tue, 13 March 2007 14:29 Go to previous messageGo to next message
Hi Thomas,
unfortunately, the current Table implementation is very limited. We are
in the process of re-implementing it.
In the meanwhile the only way to refresh a table is to recreate it. In
Your case that would mean to also recreate the TableViewer.
Cheers
Rüdiger
Thomas Kühne wrote:
> works
> Best Regards,
> Thomas
Re: RAP Table Update problem [message #5966 is a reply to message #5897] Tue, 13 March 2007 14:31 Go to previous message
Originally posted by: jkrause.innoopract.com
Hi Thomas,
This is a known bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=175651
We are currently working on a new table (client side and
LifeCycleAdapter) that will solve the problem, this is one of the main
working areas for M3.
As a (quite ugly) workaround: delete and recreate the table when the
data has been changed:
if( viewer != null ) {
IContentProvider oldProvider = viewer.getContentProvider();
if( oldProvider != null ) {
oldProvider.dispose();
viewer.getTable().dispose();
viewer = new TableViewer( parent );
viewer.setContentProvider( new ViewContentProvider( id ) );
viewer.setLabelProvider( new ViewLabelProvider() );
Best Regards,
Jochen
Thomas Kühne wrote:
> works
> Best Regards,
> Thomas
Previous Topic:Problem accessing RAP demo
Next Topic:Changing the RAP Startup Page
Current Time: Sat Jul 26 08:29:15 EDT 2025
Powered by FUDForum. Page generated in 0.03840 seconds
