Home » Eclipse Projects » Equinox » which HTTP registry to use?
which HTTP registry to use? [message #66282] Fri, 05 May 2006 00:48 Go to next message
Hi, it seems there are two registries in the equinox
incubator(org.....http.registry and org....servlet.ext), both exposing the servlet, context
and resource Extension points, but with a slightly different syntax.
Which one should be used for development, it seems the code is almost the
same?
/peter
Re: which HTTP registry to use? [message #66315 is a reply to message #66282] Fri, 05 May 2006 02:41 Go to previous messageGo to next message
Originally posted by: savagearts.gmail.com
I'm confused by this too.
Re: which HTTP registry to use? [message #66333 is a reply to message #66282] Fri, 05 May 2006 08:10 Go to previous messageGo to next message
Originally posted by: giacomin.vettatech.com
Hi Peter,See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=128059This
is part of a recent refactoring:[org.eclipse.equinox.servlet.ext] will
become[org.eclipse.equinox.http.registry]Regards,Regards, Ricardo Giacomin
"Peter Neubauer" <peter@neubauer.se> escreveu na mensagem
news:e3eler$oo7$1@utils.eclipse.org...
> servlet, context
> same?
> /peter
Re: which HTTP registry to use? [message #66357 is a reply to message #66315] Fri, 05 May 2006 09:14 Go to previous message
Originally posted by: skaegi.sympatico.ca
Sorry for the confusion,
org.eclipse.equinox.servlet.ext is no longer maintained. I left it there
primarily as a courtesy to anyone who integrated against but eventually
(this summer perhaps) will remove it.
I guess the readme.txt doesn't cut it. ;)
-Simon
"eisenhower" <savagearts@gmail.com> wrote in message
news:31229846.1146811322245.JavaMail.root@cp1.javalobby.org...
Previous Topic:The RSP bundle must be singleton?
Next Topic:multiple instances, osgi kernel stability issues
Current Time: Tue Jul 22 01:46:30 EDT 2025
Powered by FUDForum. Page generated in 0.08867 seconds
