Home » Eclipse Projects » Plugin Development Environment (PDE) » [PDE UI Product export] Executabe bit is not set with generate metadata repository
[PDE UI Product export] Executabe bit is not set with generate metadata repository [message #66223] Tue, 30 June 2009 02:44 Go to next message
Executable bit is not set on exported launcher executable.
Environment: Eclipse 3.5 with delta pack
Host OS: Windows Vista and Mac OS X 10.5.7 (same results)
Export RCP product based on features with:
+Destination is: Archive file - (important)
+Generate metadata repository - (important)
+Export for multiple platforms
Same export without 'Generate metadata repository' and/or ZIP Archive
options, provide valid executable bit set on exported launcher.
Should i create a bug report?
Andrew Nesheret
InfiNet Wireless Ltd.
Re: [PDE UI Product export] Executabe bit is not set with generate metadata repository [message #66455 is a reply to message #66223] Thu, 02 July 2009 04:11 Go to previous message
Andrew Nesheret пишет:
Bug 282260 submitted.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282260
Andrew Nesheret
Re: [PDE UI Product export] Executabe bit is not set with generate metadata repository [message #598894 is a reply to message #66223] Thu, 02 July 2009 04:11 Go to previous message
Andrew Nesheret
Previous Topic:Questions about Update Manager
Next Topic:Launch config of JUnit Plug-in Test
Current Time: Sat Jul 12 15:16:54 EDT 2025
Powered by FUDForum. Page generated in 0.04231 seconds
