Home » Language IDEs » PHP Development Tools (PDT) » Code Assist (suggests)
Code Assist (suggests) [message #66220] Tue, 19 February 2008 13:23 Go to next message
Is there a way to tell eclipse that variable of class is actually an
object of other class so code completion assistant can suggest methods?
I guess the best way to explain what I'm referring to is an example:
class Foo {
* @var object
public $subClass;
public function __construct() {
$subClass = new subFoo();
class subFoo {
public function foo() {
$foo = new Foo();
$foo->subClass->foo();
Now when I use $foo->subClass eclipse code completion assistant is not
suggesting anything to me. Is there a way to tell Eclipse that the
$foo->subClass is object of class subFoo?
Petr
Re: Code Assist (suggests) [message #66244 is a reply to message #66220] Tue, 19 February 2008 15:11 Go to previous messageGo to next message
Yes, (in your example) just use this:
class Foo {
* @var subFoo
public $subClass;
HTH,
Mark
Re: Code Assist (suggests) [message #66266 is a reply to message #66244] Wed, 20 February 2008 04:49 Go to previous message
Mark Kirchner napsal(a):
> class Foo {
> * @var subFoo
> public $subClass;
> HTH,
> Mark
Thank you very much. It's OK :)
Previous Topic:Small code formatting question
Next Topic:PDT and Eclipse 3.4
Current Time: Sat Jul 12 11:26:47 EDT 2025
Powered by FUDForum. Page generated in 0.03601 seconds
