EMF installation problem in eclipse [message #660562] |
Sat, 19 March 2011 13:41 |
zoheb Messages: 7 Registered: March 2011 |
Junior Member |
i have downloaded eclipse 3.6.2 Helios ... i have to use this
for java swing application development in drag and drop controls ..... for that i downloaded zip file GEF 3.6.2 it installed
with no problem ..... then i i downloaded
EMF emf -runtime-2.6.1.zip and xsd-runtime-2.6.1.zip
and when i installed them through HELP>INSTALL NEW SOFTWARE >ADD
i got error message
no software site found at this location
i have downloaded EMF from eclipse site i have confusion
regarding EMF version not supporting in eclipse 3.6.2 Helios
please tell me what is the actual problem
[Updated on: Sat, 19 March 2011 13:55] Report message to a moderator
Re: EMF installation problem in eclipse [message #660571 is a reply to message #660562] |
Sat, 19 March 2011 14:47 |
Ed Merks Messages: 33218 Registered: July 2009 |
I'm not sure which version of VE is compatible with Eclipse 3.6, but
that version of VE will determine which version of EMF it needs. Any
version of EMF < 2.7 should work on Helios. The 2.6.1 was build and
tested with Helios. Maybe you want to look into the Google's designer,
which is now open source and migrating to become an Eclipse project.
zoheb wrote:
> i have downloaded eclipse 3.6.2 Helios ... i need to install
> EMF and visual Editor for java swing application so that i can use it
> for drag and drop controls but i am not able to install
> EMF so please help me in this that which version of EMF
> should be eclipse 3.6.2 Helios and if possible
> provide me some link also
Ed Merks
FUDForum. Page generated in 0.10148 seconds
