Home » Archived » BIRT » Cannot adjust the X-axis Attributes
Cannot adjust the X-axis Attributes [message #66179] Tue, 09 August 2005 13:32 Go to next message
Originally posted by: statineni.issintl.com
Hello ,
Iam created a Chart and got the values inserted from the DataSet.
All the values are mixed up on Xaxis they are comming up as one line.Can
some one tell me how i can provide space between these values on Xaxis.I
checked entire "Chart Dialog" and i cannot find anything realated to it.
Appreciate quick response.
Sudha
Re: Cannot adjust the X-axis Attributes [message #66221 is a reply to message #66179] Tue, 09 August 2005 16:14 Go to previous messageGo to next message
Hi Sudha,
A screenshot would help, but I understand you have too many labels and they
overlap. The best solution for now is to rotate them vertically. If you
would be interested in a new feature like label staggering or automatic drop
of some labels, please file a bugzilla enhancement for it.
To rotate the labels, follow those instructions (from another thread):
"You could go to Chart builder -> Attributes -> X Axis -> Labels, then
you'll
find a button beside the Label grid -> Font. Click the button to invoke Font
Descriptor, there is an attribute named Rotation. By changing the value of
rotation, You could set the X-Axis label to be vertically or arbitrary angle
you like."
David
"Sudha Tatineni" <statineni@issintl.com> wrote in message
news:24a7e9d50cae0aebc6968b25bdd1c921$1@www.eclipse.org...
> Hello ,
> Sudha
Re: Cannot adjust the X-axis Attributes [message #66499 is a reply to message #66221] Wed, 10 August 2005 10:09 Go to previous messageGo to next message
Hello David,
I am able to rotate the X.axis attirbutes. Thanks !!
I got one more doubt.
I have 'Month_year' column whose datatype is 'datetime' in SQL server
table and the values i entered in that column are in the formatll be like
'12/1/2004'. But when i used this "Month_Year" column in BIRT iam getting
the time stamp too.
Example :
Iam getting the format as "12/1/2004 00:00:00"
I want it in the format "Dec 2005 " but it will show in the column as
'12/1/2005'and no time stamp beside it.
I dont have facility in the SQL Server2000 other than
'datetime','smalldatetime' and 'timestamp' datatypes.
So can i use expression builder to get the format i want ?.If so HOw can i
use it.Could you send me the sample.Could you please send me your email to
send the screen shots.
Sudha
David Michonneau wrote:
> Hi Sudha,
> you'll
> Descriptor, there is an attribute named Rotation. By changing the value off
> you like."
> David
>> Hello ,
>> Thanks,
>> Sudha
Hello David,
Here is the screen shot
Re: Cannot adjust the X-axis Attributes [message #66520 is a reply to message #66499] Wed, 10 August 2005 10:35 Go to previous messageGo to next message
Sudha,
There are several formatting options for datetime values. Where are you
using it? If it's an chart you can invoke the format specifier by clicking
on the 0.0# button next to the Data Definition. If it's in a data element,
you can go to the property editor view and select Format DateTime in the
properties tab.
Hope this helps,
David
news:9c60f2be496c583b7a885fa6ab14c37b$1@www.eclipse.org...
> Hello David,
> the time stamp too.
> Example :
> Thanks
> Sudha
>> Hi Sudha,
>> they overlap. The best solution for now is to rotate them vertically. If
>> you would be interested in a new feature like label staggering or
>> automatic drop of some labels, please file a bugzilla enhancement for it.
>> you'll
>> Font
>> off
>> angle
>> you like."
>> Thanks,
>> David
>>> Hello ,
>>> Thanks,
>>> Sudha
> Hello David,
Re: Cannot adjust the X-axis Attributes [message #66540 is a reply to message #66520] Wed, 10 August 2005 11:17 Go to previous messageGo to next message
David,
There will be several Dates like "05/1/2005 00:00:00" , "04/1/2005
00:00:00" on X-axis and cost values on Y axis.
Now my point is I want them as " May 05 " instead of "05/1/2005 00:00:00".
The value in SQLServer table is in the format '12/1/2004' under
"Month_Year" column with datatype "dateTime". So when iam trying to use
this column in chart x-axis the format is comming up like "05/1/2005
00:00:00" instead of " May 05 ". Is there any way to convert it ?
I tried 0.0 button and changed the value to datetime from number but no
luck. I dont understand how to set it in property editor view because it
is going to expression builder and when i dragged and dropped "getMonth()"
method from date functions i dont see any change. May be i need to code
properly apart from dragging and dropping "getMonth()" function onto
expression area.
Hope you got me.
Sudha.
> Sudha,
> properties tab.
> Hope this helps,
> David
>> Hello David,
>> the time stamp too.
>> Example :
>> Thanks
>> Sudha
>>> Hi Sudha,
>>> you'll
>>> Font
>>> off
>>> angle
>>> you like."
>>> Thanks,
>>> David
>>>> Hello ,
>>>> Thanks,
>>>> Sudha
>> Hello David,
Re: Cannot adjust the X-axis Attributes [message #66665 is a reply to message #66540] Wed, 10 August 2005 22:23 Go to previous messageGo to next message
Sudha,
Please try the following steps:
Invoke Chart Dialog -> Data -> X Axis; Set Type: DataTime, then invoke the
0.0# button next to the field.
In Format Specifier -Base Axis dialog, Set Data Type: Date/Time, then go to
Advanced, Set Pattern: MMM dd
Hope it is what you want.
Cheers.
Nina
news:cd6fe9bd467ddcaeee13e4beebe0591b$1@www.eclipse.org...
> David,
> expression area.
> Hope you got me.
> Sudha.
>> Sudha,
>> clicking on the 0.0# button next to the Data Definition. If it's in a
>> data element, you can go to the property editor view and select Format
>> DateTime in the properties tab.
>> Hope this helps,
>> David
>>> Hello David,
>>> like '12/1/2004'. But when i used this "Month_Year" column in BIRT iam
>>> getting the time stamp too.
>>> Example :
>>> i use it.Could you send me the sample.Could you please send me your
>>> email to send the screen shots.
>>> Thanks
>>> Sudha
>>>> Hi Sudha,
>>>> If you would be interested in a new feature like label staggering or
>>>> it.
>>>> you'll
>>>> Font
>>>> off
>>>> angle
>>>> you like."
>>>> Thanks,
>>>> David
>>>>> Hello ,
>>>>> line.Can some one tell me how i can provide space between these values
>>>>> on Xaxis.I checked entire "Chart Dialog" and i cannot find anything
>>>>> realated to it.
>>>>> Thanks,
>>>>> Sudha
>>> Hello David,
Solved - Re: Cannot adjust the X-axis Attributes [message #66814 is a reply to message #66665] Thu, 11 August 2005 11:02 Go to previous message
Nina,
Great Thanks a lot!!!!!.
I did a slight change in the advanced pattern instead of "MMM DD" i gave
it as "MMM yy".
Sudha.
Nina Li wrote:
> Sudha,
> Cheers.
> Nina
>> David,
>> expression area.
>> Hope you got me.
>> Sudha.
>>> Sudha,
>>> Hope this helps,
>>> David
>>>> Hello David,
>>>> Example :
>>>> Thanks
>>>> Sudha
>>>>> Hi Sudha,
>>>>> it.
>>>>> you'll
>>>>> Font
>>>>> off
>>>>> angle
>>>>> you like."
>>>>> Thanks,
>>>>> David
>>>>>> Hello ,
>>>>>> realated to it.
>>>>>> Thanks,
>>>>>> Sudha
>>>> Hello David,
Previous Topic:Scripts in onRow handler of table
Next Topic:User interaction with chart
Current Time: Sat Jul 12 09:33:08 EDT 2025
Powered by FUDForum. Page generated in 0.05080 seconds
